I’m experiencing an issue connecting my Jetson AGX Orin Dev Kit with a Hunter 2.0 robot using a USB to CAN adapter.
Setup:
- Flashed Jetson Orin with JetPack 6.0 and configured the kernel with
gs_usb
. - Followed the instructions on the Hunter ROS2 GitHub page to clone and build the necessary packages (ROS installed).
Commands Executed:
sudo modprobe gs_usb
sudo ip link set can0 up type can bitrate 500000
sudo apt install -y can-utils
Testing CAN Connection:
candump can0
However, no output is printed.
Additional Information:
- The CAN connection uses a USB to CAN adapter, which is plugged into the Jetson Orin’s USB port (not PCI).
- Output of
sudo ifconfig -a | grep can
can0: flags=193<UP,RUNNING,NOARP> mtu 16
can1: flags=128<NOARP> mtu 16
can2: flags=128<NOARP> mtu 16
- Detailed output of
sudo ifconfig -a
forcan0
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 212
- Output of
lsusb
shows the adapter:
Bus 002 Device 002: ID 0bda:0420 Realtek Semiconductor Corp. 4-Port USB 3.0 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0566:3107 Monterey International Corp. Keyboard
Bus 001 Device 005: ID 046d:c092 Logitech, Inc. G203 LIGHTSYNC Gaming Mouse
Bus 001 Device 009: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter
Bus 001 Device 003: ID 0bda:5420 Realtek Semiconductor Corp. 4-Port USB 2.0 Hub
Bus 001 Device 002: ID 13d3:3549 IMC Networks Bluetooth Radio
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
The adapter is identified as Bus 001 Device 009: ID 1d50:606f OpenMoko, Inc. Geschwister Schneider CAN adapter
Question: Is this issue due to the kernel configuration, or is there another step I need to take to get the CAN interface to communicate properly? Any help or suggestions would be greatly appreciated.
