CAN Communication using JETSON Orin
Please provide the following information
  • List item
(tick the boxes after creating this topic):
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
Hardware Platform
other
SDK Manager Version
1.9.2.10884
Host Machine Version
When we try to do CAN communication using the 4 GPIO pins as the 2 CAN controllers and using 2 SN65 transceivers from outside by following the CAN documentation.
The communication shows an acknowledgement error between the Jetson CAN controller and the CAN transceiver board, which was connected from outside.
The loopback for the Jetson is working properly but CAN communication between CAN1 and CAN0 is not working
We are using the Jetson Orin RTSO-1002. It is 60 pin(28+22+10) device but the CAN documentation for Jetson is given only for 40 pin device
https://docs.nvidia.com/jetson/archives/r34.1/DeveloperGuide/text/SO/JetsonAgxOrin.html
This is the link for the document we are using for CAN:
I will be highly grateful for any help.
Moved to right forum for attention
Hi madhavgupta6803,
Is this the devkit from NVIDIA?
It seems more like a custom carrier board.
How do you flash your board?
You should use custom BSP package with flash script for you board and configure the pinmux for CAN bus.
Can you please elaborate on the issue and is there any way we can test SPI communication also using Arduino on 1 end
Thank you for your response
Is there any way we can do CAN, SPI for our carrier board and other protocols using the documentation for the 40-pin header only.
CAN loopback is working using the pins but CAN communication between CAN1 and CAN0 is not working using CAN Transceivers(SN65)
What can be the possible reasons?
Where can we get the password for downloading the BSP file?
Jetson-IO is designed to configure pinmux for the devkit from NVIDIA. If your custom has the similar design as the devkit, you could try to use that too.
Or you should use pinmux spreadsheet to configure pinmux for those pins.
Do you have WaveShare SN65HVD230 CAN board CAN tranceiver as developer guide suggested to verify?
It should not need the password to download BSP package.
You are using the custom carrier board, you should use custom BSP package instead of default BSP package, which is for the devkit only.
