Thanks for the answer @mnicely. The complete code is here. The calculations are correct. I do validation after GPU calculations. I just cannot access some arrays in the device/global memory, like in line 37.
#include <stdio.h>
#include <algorithm>
#include <cassert>
#include <cstdlib>
#include <functional>
#include <iostream>
#include <vector>
using std::cout;
using std::generate;
using std::vector;
#define SIZE 64
#define THREADS 32
#define CUDA_CALL(x) do { if((x)!=cudaSuccess) { \
printf("Error at %s:%d\n",__FILE__,__LINE__);\
return EXIT_FAILURE;}} while(0)
#define CURAND_CALL(x) do { if((x)!=CURAND_STATUS_SUCCESS) { \
__global__ void MatrixMul(const int *Md, const int *Nd, int *Pd, int Width) {
// Calculate the row index of the Pd element and M
int row = (blockIdx.y * blockDim.y) + threadIdx.y;
// Calculate the column idenx of Pd and N
int col = (blockIdx.x * blockDim.x) + threadIdx.x;
if((row < Width) && (col < Width)) {
// each thread computes one element of the block sub-matrix
for (int k = 0; k < Width; ++k) {
// dot product or corresponding row and column.
Pd[(row * Width) + col] += Md[(row * Width) + k] * Nd[(k * Width) + col];
printf("%d = %d + %d", Pd[(row * Width) + col], Md[(row * Width) + k], Nd[(k * Width) + col]);
// Check result on the CPU (single threaded)
void verify_result(vector<int> &a, vector<int> &b, vector<int> &c, int N) {
// Loop over every row...
float time;
cudaEvent_t start, stop;
// start tracking the time
cudaEventCreate(&start) ;
cudaEventCreate(&stop) ;
cudaEventRecord(start, 0) ;
for (int i = 0; i < N; i++) {
// Loop every column...
for (int j = 0; j < N; j++) {
// For every element in the row-column pair
int tmp = 0;
for (int k = 0; k < N; k++) {
// Accumulate the partial results
tmp += a[i * N + k] * b[k * N + j];
// Check against the CPU result
assert(tmp == c[i * N + j]);
cudaEventRecord(stop, 0) ;
cudaEventSynchronize(stop) ;
cudaEventElapsedTime(&time, start, stop) ;
printf("Compute time on CPU: %3.6f ms \n", time);
int main(void){
// initialize event creation for time tracking
float time;
// Matrix size of 32 x 32;
int N = SIZE;
printf("Matrix Size: %d x %d\n", N, N);
// size (in bytes) of matrix
size_t size = N * N * sizeof(int);
vector<int> host_a(N * N);
vector<int> host_b(N * N);
vector<int> host_c(N * N);
// generate random indices between 0 and 1.
generate(host_a.begin(), host_a.end(), []() {return rand() % 2; });
generate(host_b.begin(), host_b.end(), []() {return rand() % 2; });
// device memory allocation
int *dev_a, *dev_b, *dev_c;
cudaMalloc(&dev_a, size);
cudaMalloc(&dev_b, size);
cudaMalloc(&dev_c, size);
//copy data from host to device
cudaMemcpy(dev_a, host_a.data(), size, cudaMemcpyHostToDevice);
cudaMemcpy(dev_b, host_b.data(), size, cudaMemcpyHostToDevice);
int BLOCKS = N/THREADS;
dim3 threads(THREADS, THREADS);
dim3 blocks(BLOCKS, BLOCKS);
// launch kernal
printf("No. of blocks: %d x %d\n", BLOCKS, BLOCKS);
printf("No. of therads: %d x %d\n", THREADS, THREADS);
MatrixMul<<<blocks, threads>>> (dev_a, dev_b, dev_c, N);
// stop tracking the time
cudaMemcpy(host_c.data(), dev_c, size, cudaMemcpyDeviceToHost);
printf("Compute time on GPU: %3.6f ms \n", time);
// verify result on CPU
verify_result(host_a, host_b, host_c, N);
//free device memory
cudaFree(dev_a);
cudaFree(dev_b);
cudaFree(dev_c);
return 0;
