Cannot allocate memory in static TLS block
Description
On my jetson xavier nx, I am trying to get an image from gstreamer and then use my tensorrt engine (detectron2) for object detection.
Problem is that under a few circumstances, it throws this error.
model
Basically, I will provide a rough code:
If I import this file on the top before cv2.videoCapture, it throws the above error.
from infer import TensorRTInfer
cap = cv2.VideoCapture(
                'thetauvcsrc ! h264parse ! nvv4l2decoder ! '
                'nvvidconv ! video/x-raw,format=BGRx ! queue ! videoconvert ! '
                'video/x-raw,format=BGR,width=1344,height=1344 ! '
                'queue ! videorate ! video/x-raw,framerate=10/3 ! '
                'queue ! appsink sync=false')
if not cap.isOpened():
            print('Could not capture')
            # sys.exit()
            return
But if I import it later, it works fine.
            # sys.exit()
            return
Now in my actual code, I cannot actually import it later since I need to call it in a class’s init.
I saw some solutions online especially the libgomp one but that isn’t the case here.
Any advices?
Environment
TensorRT Version: 8.5.2.2
Jetson & Jetpack: Nvidia Jetson Xavier Jetpack 5.1
CUDA Version: 11.4
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8.10
PyTorch Version (if applicable): 1.14.0
nvm, it’s solved.
