Error: cannot allocate memory in static TLS blocjetsonk
While running a object detection+lane following on the Jetson Nano, I get the following error:
OSError: /usr/local/lib/python3.8/dist-packages/torch/lib/libgomp-d22c30c5.so.1: cannot allocate memory in static TLS block
How can I resolve this error?
I have tried getting exporting the path:
export LD_PRELOAD=/home/aurelien/.local/lib/python3.6/site-packages/sklearn/__check_build/../../scikit_learn.libs/libgomp-d22c30c5.so.1.0.0
and
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
but this did not help fix the error.
Kind Regards.
It looks like you meet the same issue as the below link:
Could you try the suggestion to see if it works?
I have tried this too. but unfortunately again having same error.
Based on the log:
Have you upgraded the default Python version from 3.6 to 3.8?
If yes, you might need to reinstall all the dependencies with Python 3.8 to make it work.
