While running a object detection+tracking project using the Ultralytics package on the Jetson Nano, I get the following error:
ImportError: /home/nikhil/detect/lib/python3.8/site-packages/torch/lib/…/…/torch.libs/libgomp-6e1a1d1b.so.1.0.0: cannot allocate memory in static TLS block
How do I resolve this?
I have tried getting exporting the path:
export LD_PRELOAD=/home/aurelien/.local/lib/python3.6/site-packages/sklearn/__check_build/../../scikit_learn.libs/libgomp-d22c30c5.so.1.0.0
and
export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
but this did not help fix the error.
Kind Regards.
This path is for Python 3.6. Since you are using Python 3.8, this is not correct.
This should work but have you checked if the library does exist in your environment?
I’ve tried the command above too, it does not resolve the error.
@AastaLLL Are you referring to the libgomp (GOMP) library above? If yes, how to I verify if it is installed correctly?
I tried running locate libgomp and got the error command not found.
How do I install libgomp? (on Ubuntu 18.04 ; JetPack 4.6.1 ; Python 3.8)
@AastaLLL I cannot find libgomp-6e1a1d1b.so.1.0.0 under the path ImportError: /home/nikhil/detect/detect/lib/python3.8/site-packages/torch/lib/…/…/torch.libs/libgomp-6e1a1d1b.so.1.0.0: cannot allocate memory in static TLS block
@AastaLLL Pls refer to the image below. I’m running a single line of code from ultralytics import YOLO and getting the error below:
@AastaLLL Request you to pls help me resolve this error.
Could you give it a try outside of the virtual environment?
Moreover, please check if the libgomp.so.1 exists in your environment by finding:
$ sudo find / -iname libgomp.so.1
@AastaLLL
Thank You it worked.
