TensorFlow Error: cannot allocate memory in static TLS block
Need help resolving the error below:
  File "Mediapipe_det_recog.py", line 5, in <module>
    import mediapipe as mp
  File "/home/nikhil/.local/lib/python3.8/site-packages/mediapipe/__init__.py", line 17, in <module>
    import mediapipe.tasks.python as tasks
  File "/home/nikhil/.local/lib/python3.8/site-packages/mediapipe/tasks/python/__init__.py", line 17, in <module>
    from . import audio
  File "/home/nikhil/.local/lib/python3.8/site-packages/mediapipe/tasks/python/audio/__init__.py", line 18, in <module>
    import mediapipe.tasks.python.audio.audio_classifier
  File "/home/nikhil/.local/lib/python3.8/site-packages/mediapipe/tasks/python/audio/audio_classifier.py", line 26, in <module>
    from mediapipe.tasks.python.audio.core import base_audio_task_api
  File "/home/nikhil/.local/lib/python3.8/site-packages/mediapipe/tasks/python/audio/core/base_audio_task_api.py", line 25, in <module>
    from mediapipe.tasks.python.core.optional_dependencies import doc_controls
  File "/home/nikhil/.local/lib/python3.8/site-packages/mediapipe/tasks/python/core/optional_dependencies.py", line 20, in <module>
    from tensorflow.tools.docs import doc_controls
  File "/home/nikhil/.local/lib/python3.8/site-packages/tensorflow/__init__.py", line 38, in <module>
    from tensorflow.python.tools import module_util as _module_util
  File "/home/nikhil/.local/lib/python3.8/site-packages/tensorflow/python/__init__.py", line 36, in <module>
    from tensorflow.python import pywrap_tensorflow as _pywrap_tensorflow
  File "/home/nikhil/.local/lib/python3.8/site-packages/tensorflow/python/pywrap_tensorflow.py", line 26, in <module>
    self_check.preload_check()
  File "/home/nikhil/.local/lib/python3.8/site-packages/tensorflow/python/platform/self_check.py", line 63, in preload_check
    from tensorflow.python.platform import _pywrap_cpu_feature_guard
ImportError: /home/nikhil/.local/lib/python3.8/site-packages/tensorflow/python/platform/../../../tensorflow_cpu_aws.libs/libgomp-cc9055c7.so.1.0.0: cannot allocate memory in static TLS block
I get the error above while running an application that uses Mediapipe and DLib on my Jetpack 4.6.1.
I’m using Python 3.8.0
Do you build TensorFlow from the source?
We only provide the Python 3.6 package for the JetPack 4 users.
