Hi, I am trying to run this example from keras.io in a Jupyter Lab
but got following when I run the code below,
import os
import re
import json
import string
import numpy as np
import tensorflow as tf
from tensorflow import keras
from tensorflow.keras import layers
from tokenizers import BertWordPieceTokenizer
from transformers import BertTokenizer, TFBertModel, BertConfig
max_len = 384
configuration = BertConfig() # default paramters and configuration for BERT
Error:
ImportError Traceback (most recent call last)
<ipython-input-1-1f9a8957001d> in <module>
6 import tensorflow as tf
7 from tokenizers import BertWordPieceTokenizer
----> 8 from transformers import BertTokenizer, TFBertModel, BertConfig
9 from tensorflow import keras
10 from tensorflow.keras import layers
~/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/__init__.py in <module>
97
98 # Pipelines
---> 99 from .pipelines import (
100 CsvPipelineDataFormat,
101 FeatureExtractionPipeline,
~/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/pipelines.py in <module>
34 from .file_utils import is_tf_available, is_torch_available
35 from .modelcard import ModelCard
---> 36 from .tokenization_auto import AutoTokenizer
37 from .tokenization_bert import BasicTokenizer
38 from .tokenization_utils import PreTrainedTokenizer
~/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/tokenization_auto.py in <module>
46 from .tokenization_bert import BertTokenizer, BertTokenizerFast
47 from .tokenization_bert_japanese import BertJapaneseTokenizer
---> 48 from .tokenization_camembert import CamembertTokenizer
49 from .tokenization_ctrl import CTRLTokenizer
50 from .tokenization_distilbert import DistilBertTokenizer, DistilBertTokenizerFast
~/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/tokenization_camembert.py in <module>
21 from typing import List, Optional
22
---> 23 import sentencepiece as spm
24
25 from .tokenization_utils import PreTrainedTokenizer
~/archiconda3/envs/beam/lib/python3.6/site-packages/sentencepiece.py in <module>
13 from . import _sentencepiece
14 else:
---> 15 import _sentencepiece
16
17 try:
ImportError: /usr/lib/aarch64-linux-gnu/libtcmalloc_minimal.so.4: cannot allocate memory in static TLS block
can some help with this error? I have tried another solution by this post, but it didn’t work…
I have also tried it in terminal and got the same error
(beam) root@jetson-nx:/# python
Python 3.6.10 | packaged by conda-forge | (default, Apr 24 2020, 16:15:58)
[GCC 7.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> import re
>>> import json
>>> import string
>>> import numpy as np
2020-06-13 04:14:40.151265: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
2020-06-13 04:14:42.824809: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer.so.7
2020-06-13 04:14:42.828041: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer_plugin.so.7
File "<stdin>", line 1, in <module>
File "/root/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/__init__.py", line 99, in <module>
File "/root/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/pipelines.py", line 36, in <module>
File "/root/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/tokenization_auto.py", line 48, in <module>
File "/root/archiconda3/envs/beam/lib/python3.6/site-packages/transformers/tokenization_camembert.py", line 23, in <module>
File "/root/archiconda3/envs/beam/lib/python3.6/site-packages/sentencepiece.py", line 15, in <module>
>>> import os
>>> import re
>>> import json
>>> import string
>>> import numpy as np
2020-06-13 04:21:06.752965: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
2020-06-13 04:21:09.365921: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer.so.7
2020-06-13 04:21:09.369567: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libnvinfer_plugin.so.7
Warning: please export TSAN_OPTIONS='ignore_noninstrumented_modules=1' to avoid false positive reports from the OpenMP runtime.!
ImportError: cannot import name 'TFBertModel'
This stack trace shows the problem when Python triggers a memory allocation request from C. Maybe one of the Bert components needs to be downloaded from git and compiled. If this functionality is wrapped inside a docker container on ngc then Python should be able to interface thru http post.
