I see an error during the import TensorFlow to my project. When I tried it I got:
**ubuntu@NVIDIA-01** : **~** $ python3
Python 3.6.9 (default, Jan 26 2021, 15:33:00)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import tensorflow as tf
>>> tf.random.normal((5,))
2021-10-04 12:56:47.553686: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-10-04 12:56:47.915038: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library 'libcutensor.so.1'; dlerror: libcutensor.so.1: cannot open shared object file: No such file or directory
2021-10-04 12:56:48.131866: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1835] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
Skipping registering GPU devices...
<tf.Tensor: shape=(5,), dtype=float32, numpy=
array([-0.02318512, -0.41199052, -0.8519837 , -0.7407376 , 1.5291699 ],
dtype=float32)>
After about 1 day of continual calculations, I got NaN values with my project, but with TF 2.5.0 all was working well. Is really now using GPU during calculation, because of Skipping registering GPU devices?
I think that now all calculations are done on CPU…
I would like to report a similar issue on Jetson Nano.
I’ve installed tensorflow 2.6.0 in accordance with the instructions on Nvidia website. Tensorflow was installed properly as no errors or warnings were detected when loading the library.
However, when I run a simple script just to validate the operation I get the following message:
I2021-10-10 15:48:02.405837: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-10-10 15:48:02.414289: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library ‘libcutensor.so.1’; dlerror: libcutensor.so.1: cannot open shared object file: No such file or directory
2021-10-10 15:48:02.423279: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1835] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at 使用 pip 安装 TensorFlow for how to download and setup the required libraries for your platform.
Skipping registering GPU devices…
I’m affraid my Jetson is running on CPU and not on GPU.
Would be very thankfull to get some help/feedback on this problem.
(mpai_venv) chunky@ckjetson:/mnt/sup2rtam/rtam_openai$ python3
>>> import tensorflow
>>> tf.test.is_gpu_available()
WARNING:tensorflow:From <stdin>:1: is_gpu_available (from tensorflow.python.framework.test_util) is deprecated and will be removed in a future version.
Instructions for updating:
Use `tf.config.list_physical_devices('GPU')` instead.
2021-10-18 22:47:55.618920: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-10-18 22:47:55.981493: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library 'libcutensor.so.1'; dlerror: libcutensor.so.1: cannot open shared object file: No such file or directory
2021-10-18 22:47:56.199765: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1835] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU. Follow the guide at https://www.tensorflow.org/install/gpu for how to download and setup the required libraries for your platform.
False
Facing exacly same issue at same situtation w/ @igal.kroyter . I didnt run tf yet. But in basic script calls such as list_physical_devices(‘GPU’) or device_lib.list_local_devices(); getting warnings about 1- ARM64 not support NUMA and 2- No such file libcutensor.so at LD_LIBRARY_PATH at cuda-10.2/lib64
I can confirm the same issue here with fresh install of Jetpack 4.6. Then following the Tensorflow installation instructions from Nvidia website:
2021-10-22 22:14:43.509309: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-10-22 22:14:43.636463: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library ‘libcutensor.so.1’; dlerror: libcutensor.so.1: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64:
2021-10-22 22:14:43.711188: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library ‘libcudnn.so.8’; dlerror: libcudnn.so.8: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /usr/local/cuda-10.2/lib64:
2021-10-22 22:14:43.711373: W tensorflow/core/common_runtime/gpu/gpu_device.cc:1835] Cannot dlopen some GPU libraries. Please make sure the missing libraries mentioned above are installed properly if you would like to use GPU.
GPU is NOT AVAILABLE
Unfortunately, all the aarch64 ones say they require CUDA 11, but CUDA 10.2 is all that’s in the devkit… I’m not sure how to proceed. For grins, I tried grabbing the latest and pointing to it using LD_LIBRARY_PATH, but then I just got an error on the next library it tried to load:
2021-10-24 20:01:28.568057: W tensorflow/stream_executor/platform/default/dso_loader.cc:65] Could not load dynamic library ‘libcutensor.so.1’; dlerror: libcublasLt.so.11: cannot open shared object file: No such file or directory; LD_LIBRARY_PATH: /home/chunky/Downloads/libcutensor-linux-sbsa-1.3.3.2-archive/lib/11:
It’s now more than two weeks since @AastaLLL said you were able to reproduce this in the lab; do you have any updates on when a patch will be available?
I have the same problem.
This is so annoying, after spending 2 weeks to get things done, I must tell the customer, cannot use Jetson, this is the LAST thing that need to be fixed. But I cannot do it here.
libcutensor.so.1 not being found, so GPU aceleration is ignored, and now Yolo runs on some demo’s 1 frame per 1,5 second. Also tensorflow 2.6 sucks in dnn.
I was able to make tensorflow 2 work with the GPU by forcing it to version 2.5.0. That’s really not an ideal solution, but at least I have GPU support, I guess?
I’ve also been incredibly frustrated by the thing where the SDK is still on Ubuntu 18.04, and leans so heavily on python3.6. I see the next version is expected in Q1 of 2022; @AastaLLL: does that mean we can expect it in two months, or would I be wiser to anticipate it six months from now?
Hi @chunkyks, we don’t currently have further details to share regarding the schedule for the JetPack 5.0 release other than is what’s included on these pages linked to below, so please stay tuned for further updates.
I just re-read your roadmap; apparently the Nano [which I have] isn’t getting JetPack 5. I guess that moots the whole question [and takes the nano off the table for this project]
Please test our latest v2.6.0+nv21.11 release.
The GPU mode now can run correctly.
$ python3
2021-11-22 02:48:26.034594: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:26.177009: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:26.177398: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:26.181837: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:26.182441: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:26.182685: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:27.771993: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:27.772281: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:27.772447: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:1017] ARM64 does not support NUMA - returning NUMA node zero
2021-11-22 02:48:27.772601: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1510] Created device /job:localhost/replica:0/task:0/device:GPU:0 with 9999 MB memory: -> device: 0, name: Xavier, pci bus id: 0000:00:00.0, compute capability: 7.2
array([ 0.3516134 , 0.85141206, 0.32087272, -0.38743106, 0.3919686 ],
dtype=float32)>
