Hi,i’m running tensorflow with python3.5 on tx2 but this seems unstable.It runs normally only first time i launched python script,but the else i got message like below and stuck.
2017-12-12 06:02:47.064075: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-12 06:02:47.064203: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
name: NVIDIA Tegra X2
major: 6 minor: 2 memoryClockRate (GHz) 1.3005
pciBusID 0000:00:00.0
Total memory: 7.67GiB
Free memory: 4.18GiB
2017-12-12 06:02:47.064255: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-12 06:02:47.064279: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-12 06:02:47.064310: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
2017-12-12 06:04:09.279612: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-12 06:04:09.279745: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
Free memory: 4.33GiB
2017-12-12 06:04:09.279795: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-12 06:04:09.279830: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-12 06:04:09.279868: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
I reboot tx2 just now and got error message like this:
2017-12-12 06:21:32.375742: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-12 06:21:32.375870: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
Free memory: 5.09GiB
2017-12-12 06:21:32.375923: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-12 06:21:32.376007: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-12 06:21:32.376039: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
2017-12-12 06:22:14.858684: E tensorflow/stream_executor/cuda/cuda_driver.cc:1068] failed to synchronize the stop event: CUDA_ERROR_LAUNCH_FAILED
2017-12-12 06:22:14.858769: E tensorflow/stream_executor/cuda/cuda_timer.cc:54] Internal: error destroying CUDA event in context 0xaedda10: CUDA_ERROR_LAUNCH_FAILED
2017-12-12 06:22:14.858799: E tensorflow/stream_executor/cuda/cuda_timer.cc:59] Internal: error destroying CUDA event in context 0xaedda10: CUDA_ERROR_LAUNCH_FAILED
2017-12-12 06:22:14.858956: F tensorflow/stream_executor/cuda/cuda_dnn.cc:2045] failed to enqueue convolution on stream: CUDNN_STATUS_EXECUTION_FAILED
2017-12-12 06:23:02.713872: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-12 06:23:02.713999: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
Free memory: 3.72GiB
2017-12-12 06:23:02.714054: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-12 06:23:02.714079: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-12 06:23:02.714105: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
python3
Python 3.5.2 (default,Nov 23 2017,16:37:01)
[GCC 5.4.0 20160609] on linux
Type "Help","copyright" for more information
>>> import tensorflow as tf
>>> print(tf.__version__)
1.3.0
Could you try Tensorflow 1.3.0 or the wheel shared in comment #4?
Based on this issue, the CUDA_ERROR_LAUNCH_FAILED error is gone after upgrading environment to TensorFlow 1.3.0 and cuDNN v6.
Yes,i do flashed my tx2 with JetPack3.1 and i just uninstall & install the tensorflow as you recommend ,but error remain the same.Thank you for your help.
nvidia@tegra-ubuntu:/media/nvidia/NVIDIA$ python3
Python 3.5.2 (default, Nov 23 2017, 16:37:01)
Type "help", "copyright", "credits" or "license" for more information.
>>> hello = tf.constant('Hello, TensorFlow!')
>>> sess = tf.Session()
2017-12-15 03:22:31.509179: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-15 03:22:31.509304: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
Free memory: 369.01MiB
2017-12-15 03:22:31.509358: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-15 03:22:31.509383: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-15 03:22:31.509406: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
>>> print(sess.run(hello))
b'Hello, TensorFlow!'
Here are our steps: 1. Flash TX2 with JetPack3.1 2. Upgrade cuDNNv7 via this package 3. Install TensorFlow
Updating cuda by tar file seems not work,the output of test is:
sudo dpkg -l | grep TensorRT
[sudo] password for nvidia:
ii libnvinfer-dev 3.0.2-1+cuda8.0 arm64 TensorRT development libraries and headers
ii libnvinfer3 3.0.2-1+cuda8.0 arm64 TensorRT runtime libraries
ii tensorrt-2.1.2 3.0.2-1+cuda8.0 arm64 Meta package of TensorRT
While by installing deb file can works better ?
ii libnvinfer-dev 4.0.0-1+cuda8.0 arm64 TensorRT development libraries and headers
ii libnvinfer-samples 4.0.0-1+cuda8.0 arm64 TensorRT samples and documentation
ii libnvinfer4 4.0.0-1+cuda8.0 arm64 TensorRT runtime libraries
ii tensorrt 3.0.0-1+cuda8.0 arm64 Meta package of TensorRT
Coping test files
/usr/local/cuda-8.0/bin/cuda-install-samples-8.0.sh .
Copying samples to ./NVIDIA_CUDA-8.0_Samples now...
Finished copying samples.
Running test code:
make && ./vectorAdd
/usr/local/cuda-8.0/bin/nvcc -ccbin g++ -I../../common/inc -m64 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_62,code=compute_62 -o vectorAdd.o -c vectorAdd.cu
/usr/local/cuda-8.0/bin/nvcc -ccbin g++ -m64 -gencode arch=compute_53,code=sm_53 -gencode arch=compute_60,code=sm_60 -gencode arch=compute_62,code=sm_62 -gencode arch=compute_62,code=compute_62 -o vectorAdd vectorAdd.o
mkdir -p ../../bin/aarch64/linux/release
cp vectorAdd ../../bin/aarch64/linux/release
[Vector addition of 50000 elements]
Copy input data from the host memory to the CUDA device
CUDA kernel launch with 196 blocks of 256 threads
Copy output data from the CUDA device to the host memory
Test PASSED
Done
The Tensorflow test script can run well, but you may notice some information like “Total memory: 7.67GiB
Free memory: 369.01MiB” .I ran my inference script and problem remain
2017-12-15 05:55:47.193361: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-15 05:55:47.193494: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
Free memory: 3.67GiB
2017-12-15 05:55:47.193548: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-15 05:55:47.193576: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-15 05:55:47.193603: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
2017-12-15 05:57:12.935098: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:857] ARM64 does not support NUMA - returning NUMA node zero
2017-12-15 05:57:12.935343: I tensorflow/core/common_runtime/gpu/gpu_device.cc:955] Found device 0 with properties:
Free memory: 3.82GiB
2017-12-15 05:57:12.935439: I tensorflow/core/common_runtime/gpu/gpu_device.cc:976] DMA: 0
2017-12-15 05:57:12.935483: I tensorflow/core/common_runtime/gpu/gpu_device.cc:986] 0: Y
2017-12-15 05:57:12.935531: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1045] Creating TensorFlow device (/gpu:0) -> (device: 0, name: NVIDIA Tegra X2, pci bus id: 0000:00:00.0)
I’m testing faster-rcnn(resnet v2) inference script, this script can be ran well by a small pc box(intel i5,4GB RAM,no GPU) in 44 secs per image (600x800).
Actually I met a situation where the tensorflow on TX1 stucks and it runs very slow with both python3.5 and python 2.7. My TX1 has R28.1.
Does anyone know how to update to cudnn v7?
