Hi. I am trying to profile an application in Nsight Compute. The configuration is
After I click the launch button, the log shows that
and it’s just stuck there without response.
I also tried to use ncu directly in the terminal, and here is the situation:
What happend to my system? BTW, if I directly run the script it works fine.
It seems like there is a profiling BUG related to tensorrt.
I commented out all codes except the one line import torch_tensorrt, and I use ncu python test.py to profile it. Still, it does not work (==ERROR== Failed to connect to process 811792).
Version of my packages:
python: 3.11
torch_tensorrt: 2.2.0
pytorch: 2.2.1+cu121
veraj
April 5, 2024, 5:05am
3
Hi, @qwerty00
Sorry for the issue you met. Can you tell which NCU version is used ?
Also is it possible to share the script you used, so we can try to reproduce internally ?
Hi, with ncu --version, I got
NVIDIA (R) Nsight Compute Command Line Profiler
Copyright (c) 2018-2023 NVIDIA Corporation
Version 2023.3.1.0 (build 33474944) (public-release)
The python environment is
# Name Version Build Channel
_libgcc_mutex 0.1 main defaults
_openmp_mutex 5.1 1_gnu defaults
asttokens 2.0.5 pyhd3eb1b0_0 defaults
backcall 0.2.0 pyhd3eb1b0_0 defaults
blas 1.0 mkl defaults
brotli-python 1.0.9 py311h6a678d5_7 defaults
bzip2 1.0.8 h7b6447c_0 defaults
ca-certificates 2023.08.22 h06a4308_0 defaults
certifi 2023.11.17 py311h06a4308_0 defaults
cffi 1.16.0 py311h5eee18b_0 defaults
charset-normalizer 2.0.4 pyhd3eb1b0_0 defaults
coloredlogs 15.0.1 pypi_0 pypi
comm 0.1.2 py311h06a4308_0 defaults
cryptography 41.0.3 py311hdda0065_0 defaults
cuda-cudart 12.1.105 0 nvidia
cuda-cupti 12.1.105 0 nvidia
cuda-libraries 12.1.0 0 nvidia
cuda-nvrtc 12.1.105 0 nvidia
cuda-nvtx 12.1.105 0 nvidia
cuda-opencl 12.3.101 0 nvidia
cuda-runtime 12.1.0 0 nvidia
debugpy 1.6.7 py311h6a678d5_0 defaults
decorator 5.1.1 pyhd3eb1b0_0 defaults
executing 0.8.3 pyhd3eb1b0_0 defaults
ffmpeg 4.3 hf484d3e_0 http://mirror.nju.edu.cn/anaconda/cloud/pytorch
filelock 3.13.1 py311h06a4308_0 defaults
flatbuffers 23.5.26 pypi_0 pypi
freetype 2.12.1 h4a9f257_0 defaults
fsspec 2024.2.0 pypi_0 pypi
giflib 5.2.1 h5eee18b_3 defaults
gmp 6.2.1 h295c915_3 defaults
gmpy2 2.1.2 py311hc9b5ff0_0 defaults
gnutls 3.6.15 he1e5248_0 defaults
humanfriendly 10.0 pypi_0 pypi
idna 3.4 py311h06a4308_0 defaults
intel-openmp 2023.1.0 hdb19cb5_46306 defaults
ipykernel 6.25.0 py311h92b7b1e_0 defaults
ipython 8.15.0 py311h06a4308_0 defaults
jedi 0.18.1 py311h06a4308_1 defaults
jinja2 3.1.2 py311h06a4308_0 defaults
jpeg 9e h5eee18b_1 defaults
jupyter_client 8.6.0 py311h06a4308_0 defaults
jupyter_core 5.5.0 py311h06a4308_0 defaults
lame 3.100 h7b6447c_0 defaults
lcms2 2.12 h3be6417_0 defaults
ld_impl_linux-64 2.38 h1181459_1 defaults
lerc 3.0 h295c915_0 defaults
libcublas 12.1.0.26 0 nvidia
libcufft 11.0.2.4 0 nvidia
libcufile 1.8.1.2 0 nvidia
libcurand 10.3.4.101 0 nvidia
libcusolver 11.4.4.55 0 nvidia
libcusparse 12.0.2.55 0 nvidia
libdeflate 1.17 h5eee18b_1 defaults
libffi 3.4.4 h6a678d5_0 defaults
libgcc-ng 11.2.0 h1234567_1 defaults
libgomp 11.2.0 h1234567_1 defaults
libiconv 1.16 h7f8727e_2 defaults
libidn2 2.3.4 h5eee18b_0 defaults
libjpeg-turbo 2.0.0 h9bf148f_0 http://mirror.nju.edu.cn/anaconda/cloud/pytorch
libnpp 12.0.2.50 0 nvidia
libnvjitlink 12.1.105 0 nvidia
libnvjpeg 12.1.1.14 0 nvidia
libpng 1.6.39 h5eee18b_0 defaults
libsodium 1.0.18 h7b6447c_0 defaults
libstdcxx-ng 11.2.0 h1234567_1 defaults
libtasn1 4.19.0 h5eee18b_0 defaults
libtiff 4.5.1 h6a678d5_0 defaults
libunistring 0.9.10 h27cfd23_0 defaults
libuuid 1.41.5 h5eee18b_0 defaults
libwebp 1.3.2 h11a3e52_0 defaults
libwebp-base 1.3.2 h5eee18b_0 defaults
llvm-openmp 14.0.6 h9e868ea_0 defaults
lz4-c 1.9.4 h6a678d5_0 defaults
markupsafe 2.1.1 py311h5eee18b_0 defaults
matplotlib-inline 0.1.6 py311h06a4308_0 defaults
mkl 2023.1.0 h213fc3f_46344 defaults
mkl-service 2.4.0 py311h5eee18b_1 defaults
mkl_fft 1.3.8 py311h5eee18b_0 defaults
mkl_random 1.2.4 py311hdb19cb5_0 defaults
mpc 1.1.0 h10f8cd9_1 defaults
mpfr 4.0.2 hb69a4c5_1 defaults
mpmath 1.3.0 py311h06a4308_0 defaults
ncurses 6.4 h6a678d5_0 defaults
nest-asyncio 1.5.6 py311h06a4308_0 defaults
nettle 3.7.3 hbbd107a_1 defaults
networkx 3.1 py311h06a4308_0 defaults
numpy 1.26.2 py311h08b1b3b_0 defaults
numpy-base 1.26.2 py311hf175353_0 defaults
nvidia-cublas-cu12 12.3.4.1 pypi_0 pypi
nvidia-cuda-cupti-cu12 12.1.105 pypi_0 pypi
nvidia-cuda-nvrtc-cu12 12.1.105 pypi_0 pypi
nvidia-cuda-runtime-cu12 12.1.105 pypi_0 pypi
nvidia-cudnn-cu12 8.9.7.29 pypi_0 pypi
nvidia-cufft-cu12 11.0.2.54 pypi_0 pypi
nvidia-curand-cu12 10.3.2.106 pypi_0 pypi
nvidia-cusolver-cu12 11.4.5.107 pypi_0 pypi
nvidia-cusparse-cu12 12.1.0.106 pypi_0 pypi
nvidia-nccl-cu12 2.19.3 pypi_0 pypi
nvidia-nvjitlink-cu12 12.3.101 pypi_0 pypi
nvidia-nvtx-cu12 12.1.105 pypi_0 pypi
onnx 1.15.0 pypi_0 pypi
onnxruntime-gpu 1.17.1 pypi_0 pypi
openh264 2.1.1 h4ff587b_0 defaults
openjpeg 2.4.0 h3ad879b_0 defaults
openssl 3.0.12 h7f8727e_0 defaults
packaging 23.1 py311h06a4308_0 defaults
parso 0.8.3 pyhd3eb1b0_0 defaults
pexpect 4.8.0 pyhd3eb1b0_3 defaults
pickleshare 0.7.5 pyhd3eb1b0_1003 defaults
pillow 10.0.1 py311ha6cbd5a_0 defaults
pip 23.3.1 py311h06a4308_0 defaults
platformdirs 3.10.0 py311h06a4308_0 defaults
prompt-toolkit 3.0.36 py311h06a4308_0 defaults
protobuf 4.25.3 pypi_0 pypi
psutil 5.9.0 py311h5eee18b_0 defaults
ptyprocess 0.7.0 pyhd3eb1b0_2 defaults
pure_eval 0.2.2 pyhd3eb1b0_0 defaults
pycparser 2.21 pyhd3eb1b0_0 defaults
pygments 2.15.1 py311h06a4308_1 defaults
pyopenssl 23.2.0 py311h06a4308_0 defaults
pysocks 1.7.1 py311h06a4308_0 defaults
python 3.11.5 h955ad1f_0 defaults
python-dateutil 2.8.2 pyhd3eb1b0_0 defaults
pytorch-cuda 12.1 ha16c6d3_5 http://mirror.nju.edu.cn/anaconda/cloud/pytorch
pytorch-mutex 1.0 cuda http://mirror.nju.edu.cn/anaconda/cloud/pytorch
pyyaml 6.0.1 py311h5eee18b_0 defaults
pyzmq 25.1.0 py311h6a678d5_0 defaults
readline 8.2 h5eee18b_0 defaults
requests 2.31.0 py311h06a4308_0 defaults
setuptools 68.0.0 py311h06a4308_0 defaults
six 1.16.0 pyhd3eb1b0_1 defaults
sqlite 3.41.2 h5eee18b_0 defaults
stack_data 0.2.0 pyhd3eb1b0_0 defaults
sympy 1.11.1 py311h06a4308_0 defaults
tbb 2021.8.0 hdb19cb5_0 defaults
tensorrt 8.6.1.post1 pypi_0 pypi
tensorrt-bindings 8.6.1 pypi_0 pypi
tensorrt-libs 8.6.1 pypi_0 pypi
tk 8.6.12 h1ccaba5_0 defaults
torch 2.2.1 pypi_0 pypi
torch-tensorrt 2.2.0 pypi_0 pypi
torchaudio 2.1.1 py311_cu121 http://mirror.nju.edu.cn/anaconda/cloud/pytorch
torchvision 0.16.1 py311_cu121 http://mirror.nju.edu.cn/anaconda/cloud/pytorch
tornado 6.3.3 py311h5eee18b_0 defaults
traitlets 5.7.1 py311h06a4308_0 defaults
triton 2.2.0 pypi_0 pypi
typing-extensions 4.10.0 pypi_0 pypi
tzdata 2023c h04d1e81_0 defaults
urllib3 1.26.18 py311h06a4308_0 defaults
wcwidth 0.2.5 pyhd3eb1b0_0 defaults
wheel 0.41.2 py311h06a4308_0 defaults
xz 5.4.2 h5eee18b_0 defaults
yaml 0.2.5 h7b6447c_0 defaults
zeromq 4.3.4 h2531618_0 defaults
zlib 1.2.13 h5eee18b_0 defaults
zstd 1.5.5 hc292b87_0 defaults
The python script is
import numpy as np
import os
# PyTorch imports
import torch
import torchvision
input_shape = (1, 3, 1024, 1024)
model_name = "densenet121"
dev = torch.device('cuda')
libpath = "./data/" + model_name + "-in" + "-" + str(input_shape[0]) + "_" + str(input_shape[1]) + "_" + str(input_shape[2]) + "_" + str(input_shape[3]) + "-" + "trt-model.ts"
# https://pytorch.org/vision/0.8/models.html
model = getattr(torchvision.models, model_name)(pretrained=True)
model = model.to(dev)
model = model.eval()
# optimize
if not os.path.exists(libpath):
print("First use, need to compile.")
# Enabled precision for TensorRT optimization
enabled_precisions = {torch.float}
inputs = [torch.randn(input_shape, device = dev)]
trt_gm = torch_tensorrt.compile(model, "dynamo", inputs) # Output is a torch.fx.GraphModule
# Transform and create an exported program
# https://pytorch.org/TensorRT/user_guide/saving_models.html
trt_ts = torch_tensorrt.compile(model, "ts", inputs) # Output is a ScriptModule object
torch.jit.save(trt_ts, libpath)
# Later, you can load it and run inference
model = torch.jit.load(libpath)
input_data = torch.randn(input_shape, device = dev)
output_data = model(input_data)
print(output_data)
Run the file directly at the first time to optimize the model, and then use ncu to load the optimized model and do the inference, where you can reproduce the error.
veraj
April 29, 2024, 9:13am
5
Hi, @qwerty00
Thanks for reporting this issue ! We can repro internally and our dev will investigate this.
To workaround this error, please use “–target-processes application-only” instead of “–target-processes all”.
In GUI, you can change this option in "Common“ tab.
