CUDA Version: 11.8
Nsight compute version:Version 2023.3.1.0 (build 33474944) (public-release)
==PROF== Connected to process 29004 (E:\Workspace\learning\cuda\CudaRuntime\x64\Debug\CudaRuntime.exe)
==ERROR== Failed to prepare kernel for profiling
==ERROR== Unknown Error on device 0.
==ERROR== Failed to profile “addKernel” in process 29004
==PROF== Trying to shutdown target application
==ERROR== An error occurred while trying to profile.
==WARNING== No kernels were profiled.
I am facing the same issue; I tried profiling any CUDA samples but still have the same problem. This occurs with the “full” metrics sets, but other sets, such as “detailed” and “basic”, work fine.
[Matrix Multiply Using CUDA] - Starting…
MapSMtoCores for SM 8.9 is undefined. Default to use 128 Cores/SM
MapSMtoArchName for SM 8.9 is undefined. Default to use Hopper
GPU Device 0: “Hopper” with compute capability 8.9
MatrixA(320,320), MatrixB(640,320)
Computing result using CUDA Kernel…
done
Performance= 61.14 GFlop/s, Time= 2.144 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
Checking computed result for correctness: Result = PASS
NOTE: The CUDA Samples are not meant for performance measurements. Results may vary when GPU Boost is enabled.
With NCU:
==PROF== Connected to process 40340 (E:\Workspace\github\cuda-samples\bin\win64\Debug\matrixMul.exe)
==ERROR== Failed to profile “MatrixMulCUDA” in process 40340
Can you please get CUDA12.3 sample to check? Below output seems not correct as you are executing on Ada actually.
GPU Device 0: “Ada” with compute capability 8.9
done
Performance= 1044.62 GFlop/s, Time= 0.125 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
With NCU:
==PROF== Connected to process 7400 (E:\Workspace\github\cuda-samples-12.3\Samples\0_Introduction\matrixMul\matrixMul.exe)
==ERROR== Failed to profile “MatrixMulCUDA” in process 7400
So now you are using
12.3 sample + 2023.3.1.0 (build 33474944) + 546.33 Driver + NVIDIA GeForce RTX 4060 Laptop GPU, and any sample will cause “==ERROR== Unknown Error on device 0”.
Can you help us to do some isolation ?
Like using ncu --section ${section_name} or ncu --metrics ${metrics_name} to check if any section or metrics can work.
Also you can check in NCU-UI, use “Interactive Profile=>Run to Next Kernel=>Profile Kernel” to see if any other different error printed.
I will further check with our engineer team to see if anything else we can do. Thanks !
~ ncu --metrics l1tex__t_bytes_pipe_lsu_mem_global_op_ld.sum.per_second,l1tex__t_bytes_pipe_lsu_mem_global_op_st.sum.per_second E:\Workspace\github\cuda-samples-12.3\Samples\0_Introduction\matrixMul\matrixMul.exe
==PROF== Connected to process 33848 (E:\Workspace\github\cuda-samples-12.3\Samples\0_Introduction\matrixMul\matrixMul.exe)
==ERROR== Failed to profile “MatrixMulCUDA” in process 33848
When using ncu Version 2022.3.0.0 (build 31729285):
==PROF== Connected to process 43752 (E:\Workspace\github\cuda-samples-12.3\Samples\0_Introduction\matrixMul\matrixMul.exe)
==ERROR== Profiling is not supported on device 0. To find out supported GPUs refer --list-chips option.
done
Performance= 1028.99 GFlop/s, Time= 0.127 msec, Size= 131072000 Ops, WorkgroupSize= 1024 threads/block
==PROF== Disconnected from process 43752
==WARNING== Profiling kernels launched by child processes requires the --target-processes all option.
Thank you. Your assistance is greatly appreciated!
