Nsight compute exits with error code 3221226505
Hello everyone, I am having trouble using nsight compute.
I am using nsight integration for visual studio 2022.
OS: Windows 11
GPU: RTX 2060
Nvidia driver: 566.36
CUDA toolkit: 12.6
Nsight compute: 2024.3.2
The Interactive Profile works, but when I try to launch the profiler I get an error.
CONSOLE OUTPUT:
==PROF== Attempting to connect to ncu-ui at 127.0.0.1:50152...
==PROF== Connected to ncu-ui at 127.0.0.1:50152.
ERROR WINDOW:
The profiler returned an error code: 3221226505 (0xc0000409)
PROGRESS LOG:
Launched process: ncu.exe (pid: 9992)
C:/Program Files/NVIDIA Corporation/Nsight Compute 2024.3.2/target/windows-desktop-win7-x64/ncu.exe --config-file off --export C:/Users/user/Nsight_compute_output/1 --force-overwrite --set full C:\Users\user\source\repos\FFT-CUDA\x64\Debug\FFT-CUDA.exe
Launch succeeded.
Profiling...
Process terminated.
What could be the cause? I have tried reinstalling nsight compute and nsight integration for visual studio.
I get the same error even with the basic cuda example project.
I tried running as Administrator
When trying to run ncu from command line, it almost immediately exits without any output.
Thanks to whoever chooses to help me!
Hi, @grande.alfry
Sorry for the issue you met.
Have you tried running “ncu $sample” directly ?
When you say interactive profile works, do you mean you click “Profiler Kernel” and get the report ?
Hi, @veraj
thanks for your answer.
When I try to run the command
ncu .\program.exe -o .\outfile
The command exits with no output and does not generate any files.
On the Nsight Comput GUI, from “start activity”, if I select “Interactive profile” and click “launch” it works.
But if I try to select “Profile” and launch it does not work and gives me the aforementioned error.
Hi, @grande.alfry
Have you enabled the permission for profile ?
Tried your set up internally, can not repro the issue. If possible, please clean current installation, and reinstall again (especially nsight compute and driver )
Also make sure sample can run successfully without ncu.
PS: Please use “ncu -o .\outfile .\program.exe” instead.
I have already allowed performance counter access.
I have tried uninstalling and reinstalling nvidia drivers, CUDA drivers and nsight compute several times.
I have tried the newest version of CUDA drivers and nsight compute 2025 but I still get the same error.
What could be the cause? this is a big problem for me, as I need to profile with nsight compute for a university assignment.
I encountered the same problem, and here’s how I resolved this issue.
Settings → Time and Language → Language and Region → Default language settings → Change system locale → Beta: use unicode utf-8
I’m currently using Korean as default langauge, so the menu name might be different.
ty so much!!!
