Issue:
when I launched the Nsight Compute and try to launch the profilem, it report the following error
It used to work well but somehow it failed to launch the profile. I try to extend port range but it doesn’t work.
I find a similiar post about the problem. I’ve update my Driver according to the post but it doesn’t help.
So what should I do? the error log says i should update the firewall setting, can someone tell me how to solve it ?
Just to double check, you’re running a local windows GUI and trying to profile on the same local Windows machines. Is that correct? If so, this does look like a firewall issue. Can you check your settings to ensure that you allow local connections? Is it possible that you declined a connection when it first ran and now it’s blocked? Checking what’s allowed and blocked may reveal some information.
