Target Platform: Windows. Connection:localhost
I can launch interactive profiler and system trace, but every try to non-interactive profiler failed, wither the app is an exe or python.
Hi, @345096093
Sorry for the issue you met.
- Can you execute the ncu command line directly to see if any other info printed ?
- Can you try non-interactive profile with a simple CUDA sample? Like vectorAdd, matrixMul
Thank you for your answer.
I tried, they are both no.
Could it possible that there is a WSL with Nsight Compute in my compute?
This one in the WSL can work fine.
Can you clarify your user scenario ?
Are you launching Nsight Compute on your windows ? Where is your sample located at ?
On the same machine in WSL works ?
Nsight Compute in windows itself can not non-interactivate profiler;
Nsight Compute in WSL of same windows can work fine.
I don’t think WSL will impact profile on Windows itself.
Can you try “ncu -f --section-folder-restore” to restore the sections and try ncu ${your_sample} again ?
