Xzz
June 10, 2023, 8:19am
1
Hi , I use my driver to control GPIO in the kernel.
And it works well in the L4T 32.7.3 (Xavier NX).
But when I change to the 35.3.1(Orin NX 8GB), I get the error
[ 2.154614] failed to request rs232 enable GPIO err: -517
This is my driver source code, could you please give me some help?
struct gpio_desc rs232_enable_gpio;
rs232_enable_gpio = devm_gpiod_get_index_optional(dev, "rs232-enable", 0, GPIOD_OUT_LOW);
if (IS_ERR(rs232_enable_gpio)) {
int err = PTR_ERR(rs232_enable_gpio);
printk("failed to request rs232 enable GPIO err: %d\n", err);
} else {
printk("request rs232 enable GPIO success\n");
gpiod_export(rs232_enable_gpio, true);
And this is dts code:
rs232-enable-gpios = <&tegra_main_gpio TEGRA234_MAIN_GPIO(G, 6) GPIO_ACTIVE_HIGH>;
Hi Xzz,
Could you control this pin (PG.06) with sysfs?
Xzz:
Do you use the same pin for both Xavier NX and Orin NX?
Xzz
June 12, 2023, 7:43am
4
Hi, KevinFFF,
I can control this pin success with sysfs.
echo PG.06 > /sys/class/gpio/export
Actually some are the same, but both can’t control in my driver.
Is there any special config between 32.7.3 and 35.3.1?
Xzz
June 12, 2023, 10:18am
5
I found the same problem in this link,
Issue migration of MCP23S08 from Jetpack-4.x.y to Jetpack-5.0.1 :
But I got following error :
[ 13.486508] adv7280 8-0020: request for reset pin failed: -517
Meanwhile I was working perfectly in Jetpack-4.x.y
Could you help to point out what was missing, please ?
And I try this method but -517 error again.
rs232-enable-gpios = <&tegra_main_gpio 389 GPIO_ACTIVE_HIGH>;
So it is not a special but common problem, Please check, thanks!
Xzz
June 13, 2023, 1:23am
6
Hi, @KevinFFF ,do you have any suggestion?
This question is a little urgent, thank you.
hello Xzz,
please try this to get a GPIO number by using with GPIO APIs.
for example,
int rs232_enable_gpio;
rs232_enable_gpio = of_get_named_gpio(dev->of_node, "rs232-enable", 0);
you may see-also the header file as below about this GPIO API.
i.e. $public_sources/kernel_src/kernel/kernel-5.10/include/linux/of_gpio.h
Xzz
June 13, 2023, 6:10am
8
Hi, this is my code:
if (gpio_is_valid(rs232_enable_gpio)) {
printk("xz request rs232 enable GPIO success\n");
} else printk("xz request failed\n");
but gpio is failed again,and log is :
[ 2.139903] xz request failed
Xzz
June 13, 2023, 6:29am
9
I find there is something wrong with my code,
-rs232_enable_gpio = of_get_named_gpio(dev->of_node, "rs232-enable", 0);
+rs232_enable_gpio = of_get_named_gpio(dev->of_node, "rs232-enable-gpios", 0);
and the same error log happened again :(
Xzz:
dev->of_node,
it should be… struct device_node *np,
could you please check you’ve assign correct device node to get GPIO from.
Xzz
June 13, 2023, 7:23am
11
I use this standard code to get dev and node , and it works fine in the 32.7.3.
And -517 , this error code is a standard Linux error code, which means -EINVAL, i.e., “invalid argument”.
So I suspect that the GPIO pin cannot be found cause this problem.
static int test_gpio_probe(struct platform_device *pdev){
struct device *dev = &pdev->dev;
could you please have a quick test.
is this gpio_is_valid(389)
return true or false? since the pin number should be 389
for PG.06.
Xzz
June 13, 2023, 8:46am
14
This is my code:
printk("xz rs232_enable_gpio is %d\n",rs232_enable_gpio);
if (gpio_is_valid(389)) {
the result is :
[ 2.153854] xz rs232_enable_gpio is -517
[ 2.157771] xz request rs232 enable GPIO success
Xzz
June 13, 2023, 8:47am
15
So of_get_named_gpio function get a wrong index, and gpio_is_valid output error.
Xzz
June 14, 2023, 2:10am
17
Hi,JerryChang,
Now the reason of this question is clear, and my code works ok in L4T37.2.3
Xzz:
} else {
what should I do next?
Could you provide your driver source for this pin and the modification in device tree for us to reproduce on the devkit?
Xzz
June 14, 2023, 6:02am
19
Sure. Let me check the source, This will take some time.
Xzz
June 14, 2023, 9:45am
20
Hi,JerryChang,
Thank you for waiting,this is my diff code in kernel:
--- a/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0001-p3509-a02.dts
+++ b/hardware/nvidia/platform/t23x/p3768/kernel-dts/tegra234-p3767-0001-p3509-a02.dts
@@ -22,4 +22,11 @@
nvidia,dtbbuildtime = __DATE__, __TIME__;
compatible = "nvidia,p3509-0000+p3767-0001", "nvidia,p3767-0001", "nvidia,tegra234", "nvidia,tegra23x";
model = "NVIDIA Orin NX Developer Kit";
+ seavo_gpio {
+ status = "okay";
+ compatible = "seavo,gpio";
+ rs232-enable-gpios = <&tegra_main_gpio 389 GPIO_ACTIVE_HIGH>;
diff --git a/kernel/kernel-5.10/drivers/gpio/Makefile b/kernel/kernel-5.10/drivers/gpio/Makefile
index 09dada80a..fd6bb8720 100644
--- a/kernel/kernel-5.10/drivers/gpio/Makefile
+++ b/kernel/kernel-5.10/drivers/gpio/Makefile
@@ -180,3 +180,4 @@ obj-$(CONFIG_GPIO_XTENSA) += gpio-xtensa.o
obj-$(CONFIG_GPIO_ZEVIO) += gpio-zevio.o
obj-$(CONFIG_GPIO_ZX) += gpio-zx.o
obj-$(CONFIG_GPIO_ZYNQ) += gpio-zynq.o
+obj-y += gpio-seavo.o
This is my driver file.
gpio-seavo.c (1.7 KB)
And this is the result:
root@tegra-ubuntu:~# dmesg | grep xz
[ 2.120336] xz failed to request rs232 enable GPIO err: -517
Xzz
June 15, 2023, 5:58am
21
Hi,JerryChang,
Do you find any problem in my driver or SDK?
Xzz
June 16, 2023, 6:10am
22
@KevinFFF Hi,do you have any suggestion?
This issue is a bit urgent for us, Thanks a lot~
Xzz
June 19, 2023, 2:33am
23
It takes a long time for you to check, could you plese give me some reply?
And I found kernel error when system running:
[ 336.451542] ------------[ cut here ]------------
[ 336.451568] WARNING: CPU: 0 PID: 0 at drivers/gpio/gpio-tegra186.c:937 tegra186_gpio_irq+0x1ac/0x1f0
[ 336.461003] Modules linked in: nvidia_modeset(OE) fuse(E) lzo_rle(E) lzo_compress(E) zram(E) ramoops(E) reed_solomon(E) loop(E) snd_soc_tegra186_dspk(E) snd_soc_tegra210_ope(E) snd_soc_tegra186_asrc(E) snd_soc_tegra186_arad(E) snd_soc_tegra210_mvc(E) snd_soc_tegra210_iqc(E) snd_soc_tegra210_afc(E) snd_soc_tegra210_dmic(E) snd_soc_tegra210_adx(E) snd_soc_tegra210_amx(E) snd_soc_tegra210_mixer(E) snd_soc_tegra210_i2s(E) snd_soc_tegra210_admaif(E) snd_soc_tegra_pcm(E) snd_soc_tegra210_sfc(E) cdc_acm(E) aes_ce_blk(E) crypto_simd(E) cryptd(E) aes_ce_cipher(E) ghash_ce(E) sha2_ce(E) sha256_arm64(E) sha1_ce(E) snd_soc_spdif_tx(E) snd_soc_tegra_machine_driver(E) snd_soc_tegra210_adsp(E) r8168(E) nv_imx219(E) snd_soc_tegra_utils(E) userspace_alert(E) snd_soc_simple_card_utils(E) snd_hda_codec_hdmi(E) nvadsp(E) r8169(E) tegra_bpmp_thermal(E) realtek(E) snd_hda_tegra(E) snd_soc_tegra210_ahub(E) snd_hda_codec(E) snd_hda_core(E) tegra210_adma(E) spi_tegra114(E) nvidia(OE) binfmt_misc(E) ina3221(E)
[ 336.461134] pwm_fan(E) nvgpu(E) nvmap(E) ip_tables(E) x_tables(E) [last unloaded: mtd]
[ 336.461157] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G OE 5.10.104-tegra #17
[ 336.461161] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 3.1-32827747 03/19/2023
[ 336.461167] pstate: 20400089 (nzCv daIf +PAN -UAO -TCO BTYPE=--)
[ 336.461172] pc : tegra186_gpio_irq+0x1ac/0x1f0
[ 336.461177] lr : tegra186_gpio_irq+0x11c/0x1f0
[ 336.461179] sp : ffff800010003ef0
[ 336.461182] x29: ffff800010003ef0 x28: ffff6472c0db1460
[ 336.461188] x27: ffffa9285b59cff8 x26: 0000000000000018
[ 336.461193] x25: ffff6472c5833880 x24: ffff6472c5854000
[ 336.461199] x23: 000000000000000c x22: 000000000000004c
[ 336.461205] x21: 00000000000000b9 x20: 0000000000000000
[ 336.461210] x19: ffffa9285aa5ee50 x18: 0000000000000000
[ 336.461215] x17: 0000000000000000 x16: ffffa9285a976350
[ 336.461221] x15: 0000000000000000 x14: 00000000000050c9
[ 336.461226] x13: 0000000000005db3 x12: 0000000000000024
[ 336.461232] x11: 0000000000000040 x10: ffffa9285b507a80
[ 336.461238] x9 : ffffa9285b507a78 x8 : ffff6472c04b0dd8
[ 336.461244] x7 : 0000000000000000 x6 : 0000000000000001
[ 336.461249] x5 : 0000000000000000 x4 : 0000000000000000
[ 336.461255] x3 : 0000000000000000 x2 : ffffa9285993e170
[ 336.461260] x1 : 000000000000004c x0 : 0000000000000000
[ 336.461267] Call trace:
[ 336.461272] tegra186_gpio_irq+0x1ac/0x1f0
[ 336.461283] generic_handle_irq+0x40/0x60
[ 336.461288] __handle_domain_irq+0x70/0xd0
[ 336.461294] gic_handle_irq+0x68/0x134
[ 336.461297] el1_irq+0xd0/0x180
[ 336.461306] cpuidle_enter_state+0xb8/0x410
[ 336.461310] cpuidle_enter+0x40/0x60
[ 336.461315] call_cpuidle+0x44/0x80
[ 336.461318] do_idle+0x208/0x270
[ 336.461321] cpu_startup_entry+0x2c/0x70
[ 336.461331] rest_init+0xdc/0xe8
[ 336.461338] arch_call_rest_init+0x18/0x20
[ 336.461341] start_kernel+0x514/0x54c
[ 336.461345] ---[ end trace 0c2cee0b48632011 ]---
This is the hole dmesg log:
GPIO报错 dmesg.txt (65.7 KB)
