Cannot creat a Vulkan device, Try updating your video driver to more recent version
I’m trying to open a game which I made in unreal engine 5 and build for arm64 and when I try to open that game I am getting an error “Cannot creat a Vulkan device, Try updating your video driver to more recent version” I coudn’t figure out which driver is that driver I have gstreamer v4l2.
We have document for running Vulkan on Jetson platforms:
Vulkan Support on Jetson Linux | NVIDIA Developer
Vulkan SC — Jetson Linux Developer Guide documentation
Please take a look and give it a try. Ideally it should work well if you follow the guidance.
We have been trying to do links you gave us. We done the first instruction fully after update “cmake” but we couldn’t understand second instruction very well and first instruction couldn’t solve our problem.
Please use Jetpack 5.1.2 and check
Can't find Vulkan SDK on Jetson AGX Orin - #6 by DaneLLL
I am using jetpack 5.1.2 version as I know
Heres the log for the Unreal Engine 5 we still couldn’t figure out the problem we upgrade the SDL video driver to latest version but it won’t work.
MyProject11.log (62.7 KB)
The vulkaninfo is here
VULKANINFO
Vulkan Instance Version: 1.3.204
Instance Extensions: count = 18
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 10
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
Layers: count = 0
Presentable Surfaces:
GPU id : 0 (NVIDIA Tegra Orin (nvgpu)):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_UNORM
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_SRGB
	Present Modes: count = 3
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
		PRESENT_MODE_IMMEDIATE_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount       = 2
		maxImageCount       = 8
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms:
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform:
		supportedCompositeAlpha:
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
		supportedUsageFlags:
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
			IMAGE_USAGE_INPUT_ATTACHMENT_BIT
	VkSurfaceCapabilities2EXT:
		supportedSurfaceCounters:
			None
	VkSharedPresentSurfaceCapabilitiesKHR:
		sharedPresentSupportedUsageFlags:
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
Groups:
	Device Group Properties (Group 0):
		physicalDeviceCount: count = 1
			NVIDIA Tegra Orin (nvgpu) (ID: 0)
		subsetAllocation = 0
	Device Group Present Capabilities (Group 0):
		Can present images from the following devices:
		Present modes:
			DEVICE_GROUP_PRESENT_MODE_LOCAL_BIT_KHR
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion     = 4206804 (1.3.212)
	driverVersion  = 146866240 (0x8c10040)
	vendorID       = 0x10de
	deviceID       = 0x97ba03d7
	deviceType     = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
	deviceName     = NVIDIA Tegra Orin (nvgpu)
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 32768
	maxImageDimension2D                             = 32768
	maxImageDimension3D                             = 16384
	maxImageDimensionCube                           = 32768
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 134217728
	maxUniformBufferRange                           = 65536
	maxStorageBufferRange                           = 4294967295
	maxPushConstantsSize                            = 256
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 4000
	bufferImageGranularity                          = 0x00000400
	sparseAddressSpaceSize                          = 0xffffffffff
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 1048576
	maxPerStageDescriptorUniformBuffers             = 1048576
	maxPerStageDescriptorStorageBuffers             = 1048576
	maxPerStageDescriptorSampledImages              = 1048576
	maxPerStageDescriptorStorageImages              = 1048576
	maxPerStageDescriptorInputAttachments           = 1048576
	maxPerStageResources                            = 4294967295
	maxDescriptorSetSamplers                        = 1048576
	maxDescriptorSetUniformBuffers                  = 1048576
	maxDescriptorSetUniformBuffersDynamic           = 15
	maxDescriptorSetStorageBuffers                  = 1048576
	maxDescriptorSetStorageBuffersDynamic           = 16
	maxDescriptorSetSampledImages                   = 1048576
	maxDescriptorSetStorageImages                   = 1048576
	maxDescriptorSetInputAttachments                = 1048576
	maxVertexInputAttributes                        = 32
	maxVertexInputBindings                          = 32
	maxVertexInputAttributeOffset                   = 2047
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 120
	maxTessellationControlTotalOutputComponents     = 4216
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 32
	maxGeometryInputComponents                      = 128
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 1024
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 128
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 4294967295
	maxComputeSharedMemorySize                      = 49152
	maxComputeWorkGroupCount: count = 3
		2147483647
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		64
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 15
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		32768
		32768
	viewportBoundsRange: count = 2
		-65536
		65536
	viewportSubPixelBits                            = 8
	minMemoryMapAlignment                           = 64
	minTexelBufferOffsetAlignment                   = 0x00000010
	minUniformBufferOffsetAlignment                 = 0x00000040
	minStorageBufferOffsetAlignment                 = 0x00000010
	minTexelOffset                                  = -8
	maxTexelOffset                                  = 7
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -0.5
	maxInterpolationOffset                          = 0.4375
	subPixelInterpolationOffsetBits                 = 4
	maxFramebufferWidth                             = 32768
	maxFramebufferHeight                            = 32768
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	framebufferNoAttachmentsSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageDepthSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	storageImageSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 1
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		1
		2047.94
	lineWidthRange: count = 2
		1
		64
	pointSizeGranularity                            = 0.0625
	lineWidthGranularity                            = 0.0625
	strictLines                                     = true
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000001
	optimalBufferCopyRowPitchAlignment              = 0x00000001
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = true
	residencyStandard2DMultisampleBlockShape = true
	residencyStandard3DBlockShape            = true
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = true
VkPhysicalDeviceBlendOperationAdvancedPropertiesEXT:
	advancedBlendMaxColorAttachments      = 8
	advancedBlendIndependentBlend         = false
	advancedBlendNonPremultipliedSrcColor = true
	advancedBlendNonPremultipliedDstColor = true
	advancedBlendCorrelatedOverlap        = true
	advancedBlendAllOperations            = true
VkPhysicalDeviceConservativeRasterizationPropertiesEXT:
	primitiveOverestimationSize                 = 0.00195312
	maxExtraPrimitiveOverestimationSize         = 0.75
	extraPrimitiveOverestimationSizeGranularity = 0.25
	primitiveUnderestimation                    = true
	conservativePointAndLineRasterization       = true
	degenerateTrianglesRasterized               = true
	degenerateLinesRasterized                   = true
	fullyCoveredFragmentShaderInputVariable     = true
	conservativeRasterizationPostDepthCoverage  = true
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes:
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes:
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 4294967295
	shaderUniformBufferArrayNonUniformIndexingNative     = true
	shaderSampledImageArrayNonUniformIndexingNative      = true
	shaderStorageBufferArrayNonUniformIndexingNative     = true
	shaderStorageImageArrayNonUniformIndexingNative      = true
	shaderInputAttachmentArrayNonUniformIndexingNative   = true
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = true
	maxPerStageDescriptorUpdateAfterBindSamplers         = 1048576
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 1048576
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 1048576
	maxPerStageUpdateAfterBindResources                  = 4294967295
	maxDescriptorSetUpdateAfterBindSamplers              = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 15
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 1048576
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 16
	maxDescriptorSetUpdateAfterBindSampledImages         = 1048576
	maxDescriptorSetUpdateAfterBindStorageImages         = 1048576
	maxDescriptorSetUpdateAfterBindInputAttachments      = 1048576
VkPhysicalDeviceDiscardRectanglePropertiesEXT:
	maxDiscardRectangles = 8
VkPhysicalDeviceDriverProperties:
	driverID           = DRIVER_ID_NVIDIA_PROPRIETARY
	driverName         = NVIDIA
	driverInfo         = 35.4.1
	conformanceVersion = 1.3.1.1
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = true
	shaderDenormPreserveFloat32           = false
	shaderDenormPreserveFloat64           = false
	shaderDenormFlushToZeroFloat16        = false
	shaderDenormFlushToZeroFloat32        = false
	shaderDenormFlushToZeroFloat64        = false
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = false
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = b7bfa579-749a-5375-ad43-c9abbe74b5e4
	driverUUID      = 3720a1b3-c3cb-5ed3-8b36-d2d267ed4776
	deviceNodeMask  = 1
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
	maxInlineUniformBlockSize                               = 256
	maxPerStageDescriptorInlineUniformBlocks                = 32
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
	maxDescriptorSetInlineUniformBlocks                     = 32
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 8
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 4294967295
	maxMemoryAllocationSize = 0xffe00000
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 32
	maxMultiviewInstanceIndex = 134217727
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
		SAMPLE_COUNT_16_BIT
	maxSampleLocationGridSize:
		width  = 1
		height = 1
	sampleLocationCoordinateRange: count = 2
		0
		0.9375
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = true
	filterMinmaxImageComponentMapping  = true
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 32
	supportedStages:
		SHADER_STAGE_VERTEX_BIT
		SHADER_STAGE_TESSELLATION_CONTROL_BIT
		SHADER_STAGE_TESSELLATION_EVALUATION_BIT
		SHADER_STAGE_GEOMETRY_BIT
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
		SHADER_STAGE_ALL_GRAPHICS
		SHADER_STAGE_ALL
		SHADER_STAGE_RAYGEN_BIT_NV
		SHADER_STAGE_ANY_HIT_BIT_NV
		SHADER_STAGE_CLOSEST_HIT_BIT_NV
		SHADER_STAGE_MISS_BIT_NV
		SHADER_STAGE_INTERSECTION_BIT_NV
		SHADER_STAGE_CALLABLE_BIT_NV
		SHADER_STAGE_TASK_BIT_NV
		SHADER_STAGE_MESH_BIT_NV
	supportedOperations:
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_ARITHMETIC_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_CLUSTERED_BIT
		SUBGROUP_FEATURE_QUAD_BIT
		SUBGROUP_FEATURE_PARTITIONED_BIT_NV
	quadOperationsInAllStages = true
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
	minSubgroupSize              = 32
	maxSubgroupSize              = 32
	maxComputeWorkgroupSubgroups = 2097152
	requiredSubgroupSizeStages:
		SHADER_STAGE_ALL
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000010
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000010
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0xffffffff
	maxTransformFeedbackStreamDataSize         = 2048
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 2048
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = false
	transformFeedbackRasterizationStreamSelect = true
	transformFeedbackDraw                      = true
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 4294967295
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 1
	subgroupSize                      = 32
	subgroupSupportedStages:
		SHADER_STAGE_ALL
	subgroupSupportedOperations:
	subgroupQuadOperationsInAllStages = true
VkPhysicalDeviceVulkan12Properties:
	driverName                                           = NVIDIA
	driverInfo                                           = 35.4.1
	framebufferIntegerColorSampleCounts:
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_2_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
Device Extensions: count = 159
	VK_EXT_4444_formats                         : extension revision 1
	VK_EXT_blend_operation_advanced             : extension revision 2
	VK_EXT_border_color_swizzle                 : extension revision 1
	VK_EXT_buffer_device_address                : extension revision 2
	VK_EXT_calibrated_timestamps                : extension revision 2
	VK_EXT_color_write_enable                   : extension revision 1
	VK_EXT_conditional_rendering                : extension revision 2
	VK_EXT_conservative_rasterization           : extension revision 1
	VK_EXT_custom_border_color                  : extension revision 12
	VK_EXT_depth_clip_control                   : extension revision 1
	VK_EXT_depth_clip_enable                    : extension revision 1
	VK_EXT_depth_range_unrestricted             : extension revision 1
	VK_EXT_descriptor_indexing                  : extension revision 2
	VK_EXT_discard_rectangles                   : extension revision 1
	VK_EXT_display_control                      : extension revision 1
	VK_EXT_extended_dynamic_state               : extension revision 1
	VK_EXT_extended_dynamic_state2              : extension revision 1
	VK_EXT_external_memory_dma_buf              : extension revision 1
	VK_EXT_external_memory_host                 : extension revision 1
	VK_EXT_fragment_shader_interlock            : extension revision 1
	VK_EXT_global_priority                      : extension revision 2
	VK_EXT_global_priority_query                : extension revision 1
	VK_EXT_graphics_pipeline_library            : extension revision 1
	VK_EXT_host_query_reset                     : extension revision 1
	VK_EXT_image_2d_view_of_3d                  : extension revision 1
	VK_EXT_image_drm_format_modifier            : extension revision 2
	VK_EXT_image_robustness                     : extension revision 1
	VK_EXT_image_view_min_lod                   : extension revision 1
	VK_EXT_index_type_uint8                     : extension revision 1
	VK_EXT_inline_uniform_block                 : extension revision 1
	VK_EXT_line_rasterization                   : extension revision 1
	VK_EXT_load_store_op_none                   : extension revision 1
	VK_EXT_memory_budget                        : extension revision 1
	VK_EXT_multi_draw                           : extension revision 1
	VK_EXT_physical_device_drm                  : extension revision 1
	VK_EXT_pipeline_creation_cache_control      : extension revision 3
	VK_EXT_pipeline_creation_feedback           : extension revision 1
	VK_EXT_post_depth_coverage                  : extension revision 1
	VK_EXT_primitive_topology_list_restart      : extension revision 1
	VK_EXT_primitives_generated_query           : extension revision 1
	VK_EXT_private_data                         : extension revision 1
	VK_EXT_provoking_vertex                     : extension revision 1
	VK_EXT_queue_family_foreign                 : extension revision 1
	VK_EXT_robustness2                          : extension revision 1
	VK_EXT_sample_locations                     : extension revision 1
	VK_EXT_sampler_filter_minmax                : extension revision 2
	VK_EXT_scalar_block_layout                  : extension revision 1
	VK_EXT_separate_stencil_usage               : extension revision 1
	VK_EXT_shader_atomic_float                  : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation   : extension revision 1
	VK_EXT_shader_image_atomic_int64            : extension revision 1
	VK_EXT_shader_subgroup_ballot               : extension revision 1
	VK_EXT_shader_subgroup_vote                 : extension revision 1
	VK_EXT_shader_viewport_index_layer          : extension revision 1
	VK_EXT_subgroup_size_control                : extension revision 2
	VK_EXT_texel_buffer_alignment               : extension revision 1
	VK_EXT_tooling_info                         : extension revision 1
	VK_EXT_transform_feedback                   : extension revision 1
	VK_EXT_vertex_attribute_divisor             : extension revision 3
	VK_EXT_vertex_input_dynamic_state           : extension revision 2
	VK_EXT_ycbcr_2plane_444_formats             : extension revision 1
	VK_EXT_ycbcr_image_arrays                   : extension revision 1
	VK_KHR_16bit_storage                        : extension revision 1
	VK_KHR_8bit_storage                         : extension revision 1
	VK_KHR_acceleration_structure               : extension revision 13
	VK_KHR_bind_memory2                         : extension revision 1
	VK_KHR_buffer_device_address                : extension revision 1
	VK_KHR_copy_commands2                       : extension revision 1
	VK_KHR_create_renderpass2                   : extension revision 1
	VK_KHR_dedicated_allocation                 : extension revision 3
	VK_KHR_deferred_host_operations             : extension revision 4
	VK_KHR_depth_stencil_resolve                : extension revision 1
	VK_KHR_descriptor_update_template           : extension revision 1
	VK_KHR_device_group                         : extension revision 4
	VK_KHR_draw_indirect_count                  : extension revision 1
	VK_KHR_driver_properties                    : extension revision 1
	VK_KHR_dynamic_rendering                    : extension revision 1
	VK_KHR_external_fence                       : extension revision 1
	VK_KHR_external_fence_fd                    : extension revision 1
	VK_KHR_external_memory                      : extension revision 1
	VK_KHR_external_memory_fd                   : extension revision 1
	VK_KHR_external_semaphore                   : extension revision 1
	VK_KHR_external_semaphore_fd                : extension revision 1
	VK_KHR_format_feature_flags2                : extension revision 1
	VK_KHR_fragment_shading_rate                : extension revision 2
	VK_KHR_get_memory_requirements2             : extension revision 1
	VK_KHR_global_priority                      : extension revision 1
	VK_KHR_image_format_list                    : extension revision 1
	VK_KHR_imageless_framebuffer                : extension revision 1
	VK_KHR_maintenance1                         : extension revision 2
	VK_KHR_maintenance2                         : extension revision 1
	VK_KHR_maintenance3                         : extension revision 1
	VK_KHR_maintenance4                         : extension revision 2
	VK_KHR_multiview                            : extension revision 1
	VK_KHR_pipeline_executable_properties       : extension revision 1
	VK_KHR_pipeline_library                     : extension revision 1
	VK_KHR_push_descriptor                      : extension revision 2
	VK_KHR_ray_query                            : extension revision 1
	VK_KHR_ray_tracing_pipeline                 : extension revision 1
	VK_KHR_relaxed_block_layout                 : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge         : extension revision 3
	VK_KHR_sampler_ycbcr_conversion             : extension revision 14
	VK_KHR_separate_depth_stencil_layouts       : extension revision 1
	VK_KHR_shader_atomic_int64                  : extension revision 1
	VK_KHR_shader_clock                         : extension revision 1
	VK_KHR_shader_draw_parameters               : extension revision 1
	VK_KHR_shader_float16_int8                  : extension revision 1
	VK_KHR_shader_float_controls                : extension revision 4
	VK_KHR_shader_integer_dot_product           : extension revision 1
	VK_KHR_shader_non_semantic_info             : extension revision 1
	VK_KHR_shader_subgroup_extended_types       : extension revision 1
	VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
	VK_KHR_shader_terminate_invocation          : extension revision 1
	VK_KHR_shared_presentable_image             : extension revision 1
	VK_KHR_spirv_1_4                            : extension revision 1
	VK_KHR_storage_buffer_storage_class         : extension revision 1
	VK_KHR_swapchain                            : extension revision 70
	VK_KHR_swapchain_mutable_format             : extension revision 1
	VK_KHR_synchronization2                     : extension revision 1
	VK_KHR_timeline_semaphore                   : extension revision 2
	VK_KHR_uniform_buffer_standard_layout       : extension revision 1
	VK_KHR_variable_pointers                    : extension revision 1
	VK_KHR_vulkan_memory_model                  : extension revision 3
	VK_KHR_workgroup_memory_explicit_layout     : extension revision 1
	VK_KHR_zero_initialize_workgroup_memory     : extension revision 1
	VK_NVX_binary_import                        : extension revision 1
	VK_NVX_image_view_handle                    : extension revision 2
	VK_NVX_multiview_per_view_attributes        : extension revision 1
	VK_NV_clip_space_w_scaling                  : extension revision 1
	VK_NV_compute_shader_derivatives            : extension revision 1
	VK_NV_cooperative_matrix                    : extension revision 1
	VK_NV_corner_sampled_image                  : extension revision 2
	VK_NV_coverage_reduction_mode               : extension revision 1
	VK_NV_cuda_kernel_launch                    : extension revision 2
	VK_NV_dedicated_allocation                  : extension revision 1
	VK_NV_dedicated_allocation_image_aliasing   : extension revision 1
	VK_NV_device_diagnostic_checkpoints         : extension revision 2
	VK_NV_device_diagnostics_config             : extension revision 1
	VK_NV_device_generated_commands             : extension revision 3
	VK_NV_fill_rectangle                        : extension revision 1
	VK_NV_fragment_coverage_to_color            : extension revision 1
	VK_NV_fragment_shader_barycentric           : extension revision 1
	VK_NV_fragment_shading_rate_enums           : extension revision 1
	VK_NV_framebuffer_mixed_samples             : extension revision 1
	VK_NV_geometry_shader_passthrough           : extension revision 1
	VK_NV_inherited_viewport_scissor            : extension revision 1
	VK_NV_linear_color_attachment               : extension revision 1
	VK_NV_mesh_shader                           : extension revision 1
	VK_NV_ray_tracing                           : extension revision 3
	VK_NV_ray_tracing_motion_blur               : extension revision 1
	VK_NV_representative_fragment_test          : extension revision 2
	VK_NV_sample_mask_override_coverage         : extension revision 1
	VK_NV_scissor_exclusive                     : extension revision 1
	VK_NV_shader_image_footprint                : extension revision 2
	VK_NV_shader_sm_builtins                    : extension revision 1
	VK_NV_shader_subgroup_partitioned           : extension revision 1
	VK_NV_shading_rate_image                    : extension revision 3
	VK_NV_viewport_array2                       : extension revision 1
	VK_NV_viewport_swizzle                      : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 16
		queueFlags                  = QUEUE_GRAPHICS | QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING | QUEUE_PROTECTED
		timestampValidBits          = 64
		present support:
			VK_KHR_xcb_surface  = true
			VK_KHR_xlib_surface = true
	queueProperties[1]:
		queueCount                  = 2
		queueFlags                  = QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		present support = false
	queueProperties[2]:
		queueCount                  = 8
		queueFlags                  = QUEUE_COMPUTE | QUEUE_TRANSFER | QUEUE_SPARSE_BINDING
		present support:
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 2
	memoryHeaps[0]:
		size   = 65851158528 (0xf5508f000) (61.33 GiB)
		budget = 60146999296
		usage  = 0
		flags:
			MEMORY_HEAP_DEVICE_LOCAL_BIT
	memoryHeaps[1]:
		size   = 914358272 (0x36800000) (872.00 MiB)
		budget = 914358272
		usage  = 0
		flags:
memoryTypes: count = 4
	memoryTypes[0]:
		heapIndex     = 0
		propertyFlags = 0x0001:
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
		usable for:
			IMAGE_TILING_OPTIMAL: color images, FORMAT_D16_UNORM, FORMAT_X8_D24_UNORM_PACK32, FORMAT_D32_SFLOAT, FORMAT_S8_UINT, FORMAT_D24_UNORM_S8_UINT, FORMAT_D32_SFLOAT_S8_UINT
			IMAGE_TILING_LINEAR: None
	memoryTypes[1]:
		heapIndex     = 0
		propertyFlags = 0x0007:
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
			IMAGE_TILING_OPTIMAL: None
	memoryTypes[2]:
		heapIndex     = 0
		propertyFlags = 0x000f:
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
	memoryTypes[3]:
		heapIndex     = 1
		propertyFlags = 0x0021:
			MEMORY_PROPERTY_PROTECTED_BIT
		usable for:
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = true
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = true
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = true
	textureCompressionASTC_LDR              = true
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = true
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = true
	shaderStorageImageReadWithoutFormat     = true
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = true
	shaderInt64                             = true
	shaderInt16                             = true
	shaderResourceResidency                 = true
	shaderResourceMinLod                    = true
	sparseBinding                           = true
	sparseResidencyBuffer                   = true
	sparseResidencyImage2D                  = true
	sparseResidencyImage3D                  = true
	sparseResidency2Samples                 = true
	sparseResidency4Samples                 = true
	sparseResidency8Samples                 = true
	sparseResidency16Samples                = true
	sparseResidencyAliased                  = true
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = true
	uniformAndStorageBuffer16BitAccess = true
	storagePushConstant16              = true
	storageInputOutput16               = false
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = true
	uniformAndStorageBuffer8BitAccess = true
	storagePushConstant8              = true
VkPhysicalDeviceBlendOperationAdvancedFeaturesEXT:
	advancedBlendCoherentOperations = true
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = true
	bufferDeviceAddressCaptureReplay = false
	bufferDeviceAddressMultiDevice   = true
VkPhysicalDeviceBufferDeviceAddressFeaturesEXT:
VkPhysicalDeviceConditionalRenderingFeaturesEXT:
	conditionalRendering          = true
	inheritedConditionalRendering = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = true
	shaderUniformTexelBufferArrayDynamicIndexing       = true
	shaderStorageTexelBufferArrayDynamicIndexing       = true
	shaderUniformBufferArrayNonUniformIndexing         = true
	shaderSampledImageArrayNonUniformIndexing          = true
	shaderStorageBufferArrayNonUniformIndexing         = true
	shaderStorageImageArrayNonUniformIndexing          = true
	shaderInputAttachmentArrayNonUniformIndexing       = true
	shaderUniformTexelBufferArrayNonUniformIndexing    = true
	shaderStorageTexelBufferArrayNonUniformIndexing    = true
	descriptorBindingUniformBufferUpdateAfterBind      = true
	descriptorBindingSampledImageUpdateAfterBind       = true
	descriptorBindingStorageImageUpdateAfterBind       = true
	descriptorBindingStorageBufferUpdateAfterBind      = true
	descriptorBindingUniformTexelBufferUpdateAfterBind = true
	descriptorBindingStorageTexelBufferUpdateAfterBind = true
	descriptorBindingUpdateUnusedWhilePending          = true
	descriptorBindingPartiallyBound                    = true
	descriptorBindingVariableDescriptorCount           = true
	runtimeDescriptorArray                             = true
VkPhysicalDeviceFragmentShaderInterlockFeaturesEXT:
	fragmentShaderSampleInterlock      = true
	fragmentShaderPixelInterlock       = true
	fragmentShaderShadingRateInterlock = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = true
	bresenhamLines           = true
	smoothLines              = true
	stippledRectangularLines = true
	stippledBresenhamLines   = true
	stippledSmoothLines      = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = true
	shaderSharedInt64Atomics = true
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = true
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = true
	shaderInt8    = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = true
	descriptorIndexing                                 = true
	samplerFilterMinmax                                = true
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = true
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
Are you able to build and run our samples correctly? We would suggest try the reference samples.
how to find reference samples.
I found vulkan sample and run it GitHub - KhronosGroup/Vulkan-Samples: One stop solution for all Vulkan samples I build the file but can’t install but I ran from build and that window opened so is it working ? I didn’t understand.
Please refer to the steps and try the samples:
Vulkan SC Samples — Jetson Linux Developer Guide documentation
Thanks for the link I did steps and
        sudo ./vksc_01tri -o
        [sudo] password for [user]:
          Trying to read cache from: data/pipeline/vksc_01tri/pipeline_cache.bin
        Error opening cache file, using embedded bimnary.
        vksc_01tri: /usr/src/nvidia/vulkan-sc/vulkan-sc-ecosystem/vulkan-sc-sample/vksc_01tri/vksc_01tri.cpp:1080: VkResult createInstanceAndDevice(): Assertion `err == VK_SUCCESS' failed.
        Aborted
This error return when we tries to use vksc_01tri -o command
We have validated the samples and it can be built and run successfully. So you can compiled the sample successfully, but fail to run it?
Yes we complied samples successfully we didn’t get an error while compiled but when we try run int that error showed up.
cd $VKSC_SAMPLES/build/bin
./vulkanscinfo —help
is working.
Please try the commands and see if you can run the sample successfully:
nv@tegra-ubuntu:~$ export VKSC_SAMPLES=/usr/src/nvidia/vulkan-sc/vulkan-sc-ecosystem/vulkan-sc-sample
nv@tegra-ubuntu:~$ cd $VKSC_SAMPLES/build/bin/data/pipeline/vksc_01tri
nv@tegra-ubuntu:/usr/src/nvidia/vulkan-sc/vulkan-sc-ecosystem/vulkan-sc-sample/build/bin/data/pipeline/vksc_01tri$ sudo pcc -chip ga10b -path ./ -out pipeline_cache.bin
Starting PCC tool
Build information:
Date            Aug  1 2023
Time            12:38:55
Driver Version  35.4.1
[INFO] Reading JSON files from .//
[INFO] Enabled device extensions:
[INFO] Found the following files:
[INFO] vk_01tri_pipeline_0.json
[INFO] Parsing JSON: .//vk_01tri_pipeline_0.json
[INFO] Compiling JSON: .//vk_01tri_pipeline_0.json
[INFO] Loading shaders:
[INFO] .//vk_01tri_pipeline_0.vert.spv
[INFO] .//vk_01tri_pipeline_0.frag.spv
[INFO] Compiled JSON: .//vk_01tri_pipeline_0.json successfully.
[INFO]
[INFO] Nothing to merge.
[INFO] CacheData written to pipeline_cache.bin
nv@tegra-ubuntu:/usr/src/nvidia/vulkan-sc/vulkan-sc-ecosystem/vulkan-sc-sample/build/bin/data/pipeline/vksc_01tri$ cd $VKSC_SAMPLES/build/bin
nv@tegra-ubuntu:/usr/src/nvidia/vulkan-sc/vulkan-sc-ecosystem/vulkan-sc-sample/build/bin$ sudo ./vksc_01tri -o -c
  Pipeline cache HIT!
  cacheData loaded from data/pipeline/vksc_01tri/pipeline_cache.bin
vkCreateRenderPass OK
vkAllocateMemory OK
vkBindImageMemory OK
vkCreateImageView OK
vkCreateFramebuffer OK
vkCreatePipelineCache OK
vkAllocateMemory OK
vkCreatePipelineLayout OK
  Trying to read pipeline UUID from: data/pipeline/vksc_01tri/vk_01tri_pipeline_
0.json
readPipelineUUID OK
vkCreateGraphicsPipelines OK
vkBeginCommandBuffer OK
vkEndCommandBuffer OK
vkQueueSubmit OK
vkQueueWaitIdle OK
vkBeginCommandBuffer copy OK
vkEndCommandBuffer copy OK
vkQueueSubmit OK
vkQueueWaitIdle OK
vkMapMemory OK
wrote out file.
