I am using Ubuntu 18.04 with stock kernel 5.0 after installing nvidia drivers, vulkan is not working at all. Same with 435.23. Dell XPS 15 9570 with 1050 Ti MaxQ
xorg.conf
Section "ServerLayout"
Identifier "layout"
Option "AllowNvidiaGpuScreens"
EndSection
Section "Device"
Identifier "iGPU"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "iGPU"
Device "iGPU"
EndSection
/usr/share/X11/xorg.conf.d/10-nvidia.conf
Section "OutputClass"
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
ModulePath "/usr/lib/x86_64-linux-gnu/nvidia/xorg"
EndSection
nvidia-smi
Thu Dec 12 10:17:28 2019
| NVIDIA-SMI 440.36 Driver Version: 440.36 CUDA Version: 10.2 |
| 0 GeForce GTX 105... Off | 00000000:01:00.0 Off | N/A |
| N/A 56C P8 N/A / N/A | 15MiB / 4042MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 9666 G /usr/lib/xorg/Xorg 15MiB |
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
GLX_NV_multigpu_context, GLX_NV_robustness_video_memory_purge,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
GLX_NV_multigpu_context, GLX_NV_multisample_coverage,
GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_stereo_tree,
GLX_SGI_video_sync
Memory info (GL_NVX_gpu_memory_info):
Dedicated video memory: 4096 MB
Total available memory: 4096 MB
Currently available dedicated video memory: 4024 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 1050 Ti with Max-Q Design/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 440.36
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_fragment_shader_interlock,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_locations, GL_ARB_sample_shading, GL_ARB_sampler_objects,
GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_buffer,
GL_ARB_sparse_texture, GL_ARB_sparse_texture2,
GL_ARB_sparse_texture_clamp, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_filter_anisotropic, GL_ARB_texture_filter_minmax,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_import_sync_object, GL_EXT_memory_object, GL_EXT_memory_object_fd,
GL_EXT_multi_draw_arrays, GL_EXT_multiview_texture_multisample,
GL_EXT_multiview_timer_query, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_provoking_vertex,
GL_EXT_raster_multisample, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_semaphore, GL_EXT_semaphore_fd, GL_EXT_separate_shader_objects,
GL_EXT_separate_specular_color, GL_EXT_shader_image_load_formatted,
GL_EXT_shader_image_load_store, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_sparse_texture2, GL_EXT_stencil_two_side,
GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_array,
GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_filter_minmax,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
GL_KHR_blend_equation_advanced_coherent, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_shader_subgroup, GL_KTX_buffer_region,
GL_NVX_blend_equation_advanced_multi_draw_buffers,
GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
GL_NVX_progress_fence, GL_NV_ES1_1_compatibility,
GL_NV_ES3_1_compatibility, GL_NV_alpha_to_coverage_dither_control,
GL_NV_bindless_multi_draw_indirect,
GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
GL_NV_blend_minmax_factor, GL_NV_blend_square, GL_NV_clip_space_w_scaling,
GL_NV_command_list, GL_NV_compute_program5, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_dilate,
GL_NV_conservative_raster_pre_snap_triangles, GL_NV_copy_depth_to_color,
GL_NV_copy_image, GL_NV_depth_buffer_float, GL_NV_depth_clamp,
GL_NV_draw_texture, GL_NV_draw_vulkan_image, GL_NV_explicit_multisample,
GL_NV_feature_query, GL_NV_fence, GL_NV_fill_rectangle,
GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_program, GL_NV_fragment_program2,
GL_NV_fragment_program_option, GL_NV_fragment_shader_interlock,
GL_NV_framebuffer_mixed_samples, GL_NV_framebuffer_multisample_coverage,
GL_NV_geometry_shader4, GL_NV_geometry_shader_passthrough,
GL_NV_gpu_multicast, GL_NV_gpu_program4, GL_NV_gpu_program4_1,
GL_NV_gpu_program5, GL_NV_gpu_program5_mem_extended,
GL_NV_gpu_program_fp64, GL_NV_gpu_shader5, GL_NV_half_float,
GL_NV_internalformat_sample_query, GL_NV_light_max_exponent,
GL_NV_memory_attachment, GL_NV_multisample_coverage,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_query_resource,
GL_NV_query_resource_tag, GL_NV_register_combiners,
GL_NV_register_combiners2, GL_NV_robustness_video_memory_purge,
GL_NV_sample_locations, GL_NV_sample_mask_override_coverage,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
GL_NV_shader_atomic_float64, GL_NV_shader_atomic_fp16_vector,
GL_NV_shader_atomic_int64, GL_NV_shader_buffer_load,
GL_NV_shader_storage_buffer_object, GL_NV_shader_subgroup_partitioned,
GL_NV_shader_thread_group, GL_NV_shader_thread_shuffle,
GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
GL_NV_texture_barrier, GL_NV_texture_compression_vtc,
GL_NV_texture_env_combine4, GL_NV_texture_multisample,
GL_NV_texture_rectangle, GL_NV_texture_rectangle_compressed,
GL_NV_texture_shader, GL_NV_texture_shader2, GL_NV_texture_shader3,
GL_NV_transform_feedback, GL_NV_transform_feedback2,
GL_NV_uniform_buffer_unified_memory, GL_NV_vdpau_interop,
GL_NV_vdpau_interop2, GL_NV_vertex_array_range, GL_NV_vertex_array_range2,
GL_NV_vertex_attrib_integer_64bit, GL_NV_vertex_buffer_unified_memory,
GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3,
GL_NV_viewport_array2, GL_NV_viewport_swizzle, GL_OVR_multiview,
GL_OVR_multiview2, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
GL_SUN_slice_accum
OpenGL version string: 4.6.0 NVIDIA 440.36
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_SUN_slice_accum
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 440.36
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_ANDROID_extension_pack_es31a, GL_EXT_EGL_image_external_wrap_modes,
GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_buffer_storage, GL_EXT_clear_texture, GL_EXT_clip_control,
GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
GL_EXT_color_buffer_half_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
GL_EXT_conservative_depth, GL_EXT_copy_image, GL_EXT_debug_label,
GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers_indexed,
GL_EXT_draw_elements_base_vertex, GL_EXT_draw_transform_feedback,
GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range,
GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_indirect,
GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
GL_EXT_multisampled_render_to_texture2,
GL_EXT_multiview_texture_multisample, GL_EXT_multiview_timer_query,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_post_depth_coverage, GL_EXT_primitive_bounding_box,
GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
GL_EXT_sRGB, GL_EXT_sRGB_write_control, GL_EXT_semaphore,
GL_EXT_shader_group_vote, GL_EXT_shader_implicit_conversions,
GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks,
GL_EXT_shader_non_constant_global_initializers, GL_EXT_shader_texture_lod,
GL_EXT_shadow_samplers, GL_EXT_sparse_texture, GL_EXT_sparse_texture2,
GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
GL_EXT_texture_compression_bptc, GL_EXT_texture_compression_dxt1,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_filter_minmax, GL_EXT_texture_format_BGRA8888,
GL_EXT_texture_mirror_clamp_to_edge, GL_EXT_texture_norm16,
GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_storage, GL_EXT_texture_view,
GL_EXT_unpack_subimage, GL_EXT_window_rectangles,
GL_KHR_blend_equation_advanced, GL_KHR_blend_equation_advanced_coherent,
GL_KHR_context_flush_control, GL_KHR_debug, GL_KHR_no_error,
GL_KHR_parallel_shader_compile, GL_KHR_robust_buffer_access_behavior,
GL_KHR_robustness, GL_KHR_shader_subgroup,
GL_NVX_blend_equation_advanced_multi_draw_buffers, GL_NV_bgr,
GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
GL_NV_blend_equation_advanced_coherent, GL_NV_blend_minmax_factor,
GL_NV_clip_space_w_scaling, GL_NV_conditional_render,
GL_NV_conservative_raster, GL_NV_conservative_raster_pre_snap_triangles,
GL_NV_copy_buffer, GL_NV_copy_image, GL_NV_draw_buffers,
GL_NV_draw_instanced, GL_NV_draw_texture, GL_NV_draw_vulkan_image,
GL_NV_explicit_attrib_location, GL_NV_fbo_color_attachments,
GL_NV_fill_rectangle, GL_NV_fragment_coverage_to_color,
GL_NV_fragment_shader_interlock, GL_NV_framebuffer_blit,
GL_NV_framebuffer_mixed_samples, GL_NV_framebuffer_multisample,
GL_NV_generate_mipmap_sRGB, GL_NV_geometry_shader_passthrough,
GL_NV_gpu_shader5, GL_NV_image_formats, GL_NV_instanced_arrays,
GL_NV_internalformat_sample_query, GL_NV_memory_attachment,
GL_NV_non_square_matrices, GL_NV_occlusion_query_samples,
GL_NV_pack_subimage, GL_NV_packed_float, GL_NV_packed_float_linear,
GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
GL_NV_pixel_buffer_object, GL_NV_polygon_mode, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_NV_sRGB_formats, GL_NV_sample_locations,
GL_NV_sample_mask_override_coverage, GL_NV_shader_atomic_fp16_vector,
GL_NV_shader_noperspective_interpolation,
GL_NV_shader_subgroup_partitioned, GL_NV_shadow_samplers_array,
GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
GL_NV_texture_array, GL_NV_texture_barrier, GL_NV_texture_border_clamp,
GL_NV_texture_compression_latc, GL_NV_texture_compression_s3tc,
GL_NV_texture_compression_s3tc_update, GL_NV_timer_query,
GL_NV_viewport_array, GL_NV_viewport_array2, GL_NV_viewport_swizzle,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth32, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_geometry_point_size, GL_OES_geometry_shader,
GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables,
GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives,
GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
GL_OES_texture_border_clamp, GL_OES_texture_buffer,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array, GL_OVR_multiview, GL_OVR_multiview2,
GL_OVR_multiview_multisampled_render_to_texture
12 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x19a 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x19b 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x2ad 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x2ae 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x2af 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x2b0 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x2b1 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x2d6 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x2d7 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x2d8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x2d9 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x2da 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
215 GLXFBConfigs:
0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0aa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0ab 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ac 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0ae 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0af 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0ba 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0be 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0bf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0c2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0c3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0c4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0c5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0c6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x0c7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x0c9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0ca 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x0cb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0cc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0ce 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0cf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0d2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0d3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0d4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0d5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0d6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x0d7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x0d9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0da 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x0db 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0dc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x0dd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0de 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0df 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0e2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x0e3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x0e5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0e6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0e7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0e8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0e9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0ea 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x0eb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0ec 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x0ed 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0ee 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0ef 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0f2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x0f3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x0f5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0f6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0f7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0f8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0f9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0fa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x0fb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0fc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x0fd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0fe 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ff 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x100 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x101 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x102 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x103 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x104 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x105 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x106 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x107 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x108 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x109 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x10a 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x10b 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x10c 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x10d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 None
0x10e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 None
0x10f 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 None
0x110 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 None
0x111 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x112 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x113 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x114 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x115 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 None
0x116 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 None
0x117 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 None
0x118 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 None
0x119 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x11a 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x11b 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 None
0x11c 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 None
0x11d 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x11e 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x11f 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 None
0x120 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 None
0x121 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x122 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x123 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 None
0x124 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 None
0x125 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x126 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x127 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 None
0x128 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 None
0x129 0 sg 0 16 0 r y . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12a 0 sg 0 16 0 r . . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12b 0 sg 0 16 0 r y . 5 6 5 0 . . 4 24 0 16 16 16 16 0 0 None
0x12c 0 sg 0 16 0 r . . 5 6 5 0 . . 4 24 0 16 16 16 16 0 0 None
0x12d 0 sg 0 16 0 r y . 5 6 5 0 . . 4 24 8 16 16 16 16 0 0 None
0x12e 0 sg 0 16 0 r . . 5 6 5 0 . . 4 24 8 16 16 16 16 0 0 None
0x12f 0 sg 0 16 0 r y . 5 6 5 0 . . 4 0 0 16 16 16 16 0 0 None
0x130 0 sg 0 16 0 r . . 5 6 5 0 . . 4 0 0 16 16 16 16 0 0 None
0x131 0 sg 0 0 0 r . . 0 0 0 0 . . 4 16 0 16 16 16 16 0 0 None
0x132 0 sg 0 0 0 r . . 0 0 0 0 . . 4 24 0 16 16 16 16 0 0 None
0x133 0 sg 0 0 0 r . . 0 0 0 0 . . 4 24 8 16 16 16 16 0 0 None
0x134 0 sg 0 32 0 r . . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x135 0 sg 0 32 0 . . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x136 0 sg 0 32 0 r y . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x137 0 sg 0 32 0 y . 16 16 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x138 0 sg 0 32 0 r . . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x139 0 sg 0 32 0 . . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13a 0 sg 0 32 0 r y . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13b 0 sg 0 32 0 y . 32 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x13c 0 sg 0 64 0 r . . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13d 0 sg 0 64 0 . . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13e 0 sg 0 64 0 r y . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x13f 0 sg 0 64 0 y . 16 16 16 16 f . 4 0 0 16 16 16 16 0 0 None
0x140 0 sg 0 128 0 r . . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x141 0 sg 0 128 0 . . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x142 0 sg 0 128 0 r y . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x143 0 sg 0 128 0 y . 32 32 32 32 f . 4 0 0 16 16 16 16 0 0 None
0x144 0 sg 0 32 0 r . . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x145 0 sg 0 32 0 . . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x146 0 sg 0 32 0 r y . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x147 0 sg 0 32 0 y . 16 16 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x148 0 sg 0 32 0 r . . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x149 0 sg 0 32 0 . . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14a 0 sg 0 32 0 r y . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14b 0 sg 0 32 0 y . 16 16 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x14c 0 sg 0 32 0 r . . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14d 0 sg 0 32 0 . . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14e 0 sg 0 32 0 r y . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x14f 0 sg 0 32 0 y . 32 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x150 0 sg 0 32 0 r . . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x151 0 sg 0 32 0 . . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x152 0 sg 0 32 0 r y . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x153 0 sg 0 32 0 y . 32 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x154 0 sg 0 64 0 r . . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x155 0 sg 0 64 0 . . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x156 0 sg 0 64 0 r y . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x157 0 sg 0 64 0 y . 16 16 16 16 f . 4 24 0 16 16 16 16 0 0 None
0x158 0 sg 0 64 0 r . . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x159 0 sg 0 64 0 . . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15a 0 sg 0 64 0 r y . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15b 0 sg 0 64 0 y . 16 16 16 16 f . 4 24 8 16 16 16 16 0 0 None
0x15c 0 sg 0 128 0 r . . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15d 0 sg 0 128 0 . . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15e 0 sg 0 128 0 r y . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x15f 0 sg 0 128 0 y . 32 32 32 32 f . 4 24 0 16 16 16 16 0 0 None
0x160 0 sg 0 128 0 r . . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x161 0 sg 0 128 0 . . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x162 0 sg 0 128 0 r y . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x163 0 sg 0 128 0 y . 32 32 32 32 f . 4 24 8 16 16 16 16 0 0 None
0x164 0 sg 0 16 0 r . . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x165 0 sg 0 16 0 . . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x166 0 sg 0 16 0 r y . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x167 0 sg 0 16 0 y . 16 0 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x168 0 sg 0 64 0 r . . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x169 0 sg 0 64 0 . . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16a 0 sg 0 64 0 r y . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16b 0 sg 0 64 0 y . 32 32 0 0 f . 4 0 0 16 16 16 16 0 0 None
0x16c 0 sg 0 16 0 r . . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16d 0 sg 0 16 0 . . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16e 0 sg 0 16 0 r y . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x16f 0 sg 0 16 0 y . 16 0 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x170 0 sg 0 16 0 r . . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x171 0 sg 0 16 0 . . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x172 0 sg 0 16 0 r y . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x173 0 sg 0 16 0 y . 16 0 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x174 0 sg 0 64 0 r . . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x175 0 sg 0 64 0 . . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x176 0 sg 0 64 0 r y . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x177 0 sg 0 64 0 y . 32 32 0 0 f . 4 24 0 16 16 16 16 0 0 None
0x178 0 sg 0 64 0 r . . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x179 0 sg 0 64 0 . . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x17a 0 sg 0 64 0 r y . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
0x17b 0 sg 0 64 0 y . 32 32 0 0 f . 4 24 8 16 16 16 16 0 0 None
vulkaninfo
ERROR: [Loader Message] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_intel.so: wrong ELF class: ELFCLASS32
ERROR: [Loader Message] Code 0 : /usr/lib/i386-linux-gnu/libvulkan_radeon.so: wrong ELF class: ELFCLASS32
WARNING: [Loader Message] Code 0 : loader_icd_scan: Can not find 'ICD' object in ICD JSON file /usr/share/vulkan/icd.d/nvidia_layers.json. Skipping ICD JSON
VULKANINFO
Vulkan Instance Version: 1.1.114
Instance Extensions:
Instance Extensions count = 18
VK_EXT_acquire_xlib_display : extension revision 1
VK_EXT_debug_report : extension revision 9
VK_EXT_debug_utils : extension revision 1
VK_EXT_direct_mode_display : extension revision 1
VK_EXT_display_surface_counter : extension revision 1
VK_KHR_device_group_creation : extension revision 1
VK_KHR_display : extension revision 21
VK_KHR_external_fence_capabilities : extension revision 1
VK_KHR_external_memory_capabilities : extension revision 1
VK_KHR_external_semaphore_capabilities: extension revision 1
VK_KHR_get_display_properties2 : extension revision 1
VK_KHR_get_physical_device_properties2: extension revision 1
VK_KHR_get_surface_capabilities2 : extension revision 1
VK_KHR_surface : extension revision 25
VK_KHR_surface_protected_capabilities: extension revision 1
VK_KHR_wayland_surface : extension revision 6
VK_KHR_xcb_surface : extension revision 6
VK_KHR_xlib_surface : extension revision 6
Layers: count = 6
VK_LAYER_LUNARG_standard_validation (LunarG Standard Validation Layer) Vulkan version 1.0.114, layer version 1
Layer Extensions count = 0
Devices count = 2
GPU id : 0 (Intel(R) UHD Graphics 630 (Coffeelake 3x8 GT2))
Layer-Device Extensions count = 0
GPU id : 1 (GeForce GTX 1050 Ti with Max-Q Design)
VK_LAYER_MESA_overlay (Mesa Overlay layer) Vulkan version 1.1.73, layer version 1
Devices count = 2
VK_LAYER_VALVE_steam_fossilize_32 (Steam Pipeline Caching Layer) Vulkan version 1.1.73, layer version 1
Devices count = 2
VK_LAYER_VALVE_steam_fossilize_64 (Steam Pipeline Caching Layer) Vulkan version 1.1.73, layer version 1
Devices count = 2
VK_LAYER_VALVE_steam_overlay_32 (Steam Overlay Layer) Vulkan version 1.1.73, layer version 1
Devices count = 2
VK_LAYER_VALVE_steam_overlay_64 (Steam Overlay Layer) Vulkan version 1.1.73, layer version 1
Devices count = 2
Presentable Surfaces:
Surface type : VK_KHR_xlib_surface
Formats: count = 2
B8G8R8A8_SRGB
B8G8R8A8_UNORM
Present Modes: count = 3
IMMEDIATE_KHR
MAILBOX_KHR
FIFO_KHR
VkSurfaceCapabilitiesKHR:
minImageCount = 3
maxImageCount = 0
currentExtent:
width = 256
height = 256
minImageExtent:
width = 256
height = 256
maxImageExtent:
width = 256
height = 256
maxImageArrayLayers = 1
supportedTransform:
VK_SURFACE_TRANSFORM_IDENTITY_BIT_KHR
currentTransform:
supportedCompositeAlpha:
VK_COMPOSITE_ALPHA_OPAQUE_BIT_KHR
VK_COMPOSITE_ALPHA_INHERIT_BIT_KHR
supportedUsageFlags:
VK_IMAGE_USAGE_TRANSFER_SRC_BIT
VK_IMAGE_USAGE_TRANSFER_DST_BIT
VK_IMAGE_USAGE_SAMPLED_BIT
VK_IMAGE_USAGE_STORAGE_BIT
VK_IMAGE_USAGE_COLOR_ATTACHMENT_BIT
VkSurfaceCapabilities2EXT:
supportedSurfaceCounters:
None
/build/vulkan-tools-Igvqg5/vulkan-tools-1.1.114.0+dfsg1/vulkaninfo/vulkaninfo.c:1528: failed with VK_ERROR_INITIALIZATION_FAILED
nvidia-bug-report.log.gz (1.2 MB)
