I’ve tried to run composer
on a virtual machine Ubuntu 20.04 and Ubuntu 18.04 and it crashes on startup.
Nvidia RTX 3090 is passed through directly but the graphical desktop runs on a virtual GPU - Proxmox, QXL, (SPICE).
Regular ML frameworks/CUDA and GPU compute works without issues but it seems that displaying things requres the same or phisical GPU? I have similar issue when using DeepStream 6.0.1 where I have to replace nveglglessink
with glimagesink
to be able to display anything. I suspect some opengl related issues but I can’t put my finger on it.
Is there any way to bypass this problem without running on the bare metal?
$ composer
Preparing files...
Done.
./kit/kit ./composer/composer-standalone.kit --ext-path ./composer/omni.exp.graph.composer/ --/plugins/carb.scripting-python.plugin/pythonPath=./registry/ --allow-root
[Info] [carb] Logging to file: /home/tvc/.nvidia-omniverse/logs/Kit/composer-standalone/1.0/kit_20220521_080016.log
tvc@gpu-vm2:~$ [0.221s] [ext: omni.kit.pipapi-0.0.0] startup
[0.243s] [ext: omni.usd.config-1.0.0] startup
[0.245s] [ext: omni.usd.libs-1.0.0] startup
[0.387s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.408s] [ext: omni.stats-0.0.0] startup
[0.410s] [ext: omni.gpu_foundation-0.0.0] startup
2022-05-21 00:00:16 [378ms] [Warning] [omni.ext.plugin] [ext: omni.gpu_foundation-0.0.0] Failed to load plugins, folder doesn't exist: '/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx'.
2022-05-21 00:00:16 [378ms] [Warning] [omni.ext.plugin] [ext: omni.gpu_foundation-0.0.0] '/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx/rtx.xrtools.plugin' in '[[native.plugin]]' was not found.
[0.414s] [ext: omni.assets.plugins-0.0.0] startup
[0.415s] [ext: omni.kit.loop-default-0.1.0] startup
[0.415s] [ext: omni.kit.async_engine-0.0.0] startup
[0.428s] [ext: omni.appwindow-1.0.0] startup
[0.445s] [ext: omni.client-0.1.0] startup
[0.454s] [ext: omni.kit.test-0.0.0] startup
[0.649s] [ext: omni.kit.renderer.core-0.0.0] startup
2022-05-21 00:00:16 [618ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] Failed to load plugins, folder doesn't exist: '/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx'.
2022-05-21 00:00:16 [618ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.core-0.0.0] '/tmp/.tmpNvXgRaphComposer/run/kit/plugins/rtx/rtx.xrtools.plugin' in '[[native.plugin]]' was not found.
| Driver Version: 510.47 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3090 | Yes: 0 | | 24576 MB | 10de | 0 |
| | | | | | 2204 | 3993ef72.. |
| OS: Linux gpu-vm2, Version: 5.13.0-40-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: AMD Ryzen 9 5950X 16-Core Processor | Cores: Unknown | Logical: 24
| Total Memory (MB): 32102 | Free Memory: 559
| Total Page/Swap (MB): 1497 | Free Page/Swap: 1497
X Error of failed request: GLXBadFBConfig
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 287
Current serial number in output stream: 287
Hardware details:
$ lspci | grep VGA
00:01.0 VGA compatible controller: Red Hat, Inc. QXL paravirtual graphic card (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 2204 (rev a1)
$ sudo lshw -C video
*-display
description: VGA compatible controller
product: QXL paravirtual graphic card
vendor: Red Hat, Inc.
physical id: 1
bus info: pci@0000:00:01.0
version: 05
width: 32 bits
clock: 33MHz
capabilities: vga_controller rom
configuration: driver=qxl latency=0
resources: irq:21 memory:c0000000-dfffffff memory:e0000000-efffffff memory:f3014000-f3015fff ioport:6040(size=32) memory:c0000-dffff
*-display
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=nvidia latency=0 mode=1024x768 visual=truecolor xres=1024 yres=768
resources: iomemory:100-ff iomemory:180-17f irq:69 memory:f0000000-f0ffffff memory:1000000000-17ffffffff memory:1800000000-1801ffffff ioport:5000(size=128) memory:f1000000-f107ffff
Additional GL info:
$ glxinfo | grep GL
GLX_ARB_context_flush_control, GLX_ARB_create_context,
GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_SGI_make_current_read
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
GLX_ATI_pixel_format_float, GLX_EXT_buffer_age,
GLX_EXT_import_context, GLX_EXT_no_config_context, GLX_EXT_swap_control,
GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_NV_float_buffer,
GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_OML_swap_method,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
Extended renderer info (GLX_MESA_query_renderer):
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 12.0.0, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.2.6
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth,
GL_AMD_draw_buffers_blend, GL_AMD_gpu_shader_int64,
GL_AMD_multi_draw_indirect, GL_AMD_query_buffer_object,
GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended,
GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
GL_ARB_clip_control, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
GL_ARB_shader_bit_encoding, GL_ARB_shader_draw_parameters,
GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store,
GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_stencil_export, GL_ARB_shader_storage_buffer_object,
GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples,
GL_ARB_shader_texture_lod, GL_ARB_shader_viewport_layer_array,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
GL_ARB_texture_barrier, GL_ARB_texture_buffer_object,
GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map_array, GL_ARB_texture_filter_minmax,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
GL_ARB_viewport_array, GL_ATI_blend_equation_separate,
GL_ATI_texture_float, GL_ATI_texture_mirror_once,
GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr,
GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_shader_framebuffer_fetch_non_coherent,
GL_EXT_shader_integer_mix, GL_EXT_texture_array,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_minmax,
GL_EXT_texture_integer, GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_IBM_multimode_draw_arrays,
GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
GL_KHR_texture_compression_astc_ldr,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_framebuffer_flip_y,
GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
GL_MESA_texture_signed_rgba, GL_MESA_ycbcr_texture,
GL_NV_conditional_render, GL_NV_copy_image, GL_NV_depth_clamp,
GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_OES_EGL_image,
GL_S3_s3tc
OpenGL version string: 3.1 Mesa 21.2.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect,
GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture,
GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
GL_AMD_texture_texture4, GL_ANGLE_texture_compression_dxt3,
GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,
GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_clip_control, GL_ARB_color_buffer_float, GL_ARB_compatibility,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_derivative_control,
GL_ARB_direct_state_access, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_spirv_extensions,
GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier,
GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_filter_minmax,
GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
GL_ARB_texture_stencil8, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_blend_equation_separate,
GL_ATI_draw_buffers, GL_ATI_fragment_shader, GL_ATI_separate_stencil,
GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color,
GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix,
GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_minmax,
GL_EXT_texture_integer, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square,
GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
GL_NV_depth_clamp, GL_NV_fog_distance, GL_NV_half_float,
GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
GL_ANDROID_extension_pack_es31a, GL_ANGLE_pack_reverse_row_order,
GL_APPLE_texture_max_level, GL_EXT_EGL_image_storage,
GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
GL_EXT_buffer_storage, GL_EXT_clip_control, GL_EXT_clip_cull_distance,
GL_EXT_color_buffer_float, GL_EXT_color_buffer_half_float,
GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_copy_image,
GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers,
GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
GL_EXT_draw_instanced, GL_EXT_float_blend, GL_EXT_frag_depth,
GL_EXT_geometry_point_size, GL_EXT_geometry_shader, GL_EXT_gpu_shader5,
GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra,
GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
GL_EXT_separate_shader_objects,
GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_group_vote,
GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
GL_EXT_shader_io_blocks, GL_EXT_tessellation_point_size,
GL_EXT_tessellation_shader, GL_EXT_texture_border_clamp,
GL_EXT_texture_buffer, GL_EXT_texture_compression_bptc,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_s3tc_srgb,
GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_minmax,
GL_EXT_texture_format_BGRA8888, GL_EXT_texture_norm16,
GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
GL_EXT_texture_sRGB_RG8, GL_EXT_texture_sRGB_decode,
GL_EXT_texture_shadow_lod, GL_EXT_texture_type_2_10_10_10_REV,
GL_EXT_texture_view, GL_EXT_unpack_subimage,
GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_bgra,
GL_MESA_framebuffer_flip_y, GL_MESA_shader_integer_functions,
GL_NV_conditional_render, GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
GL_NV_image_formats, GL_NV_pixel_buffer_object, GL_NV_read_buffer,
GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
GL_OES_EGL_image, GL_OES_EGL_image_external,
GL_OES_EGL_image_external_essl3, GL_OES_EGL_sync,
GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
GL_OES_geometry_point_size, GL_OES_geometry_shader,
GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
GL_OES_required_internalformat, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
GL_OES_sample_variables, GL_OES_shader_image_atomic,
GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
GL_OES_texture_cube_map_array, GL_OES_texture_float,
GL_OES_texture_float_linear, GL_OES_texture_half_float,
GL_OES_texture_half_float_linear, GL_OES_texture_npot,
GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
GL_OES_viewport_array
390 GLX Visuals
840 GLXFBConfigs:
