I don’t have glxsphere installed. Some other relevant info perhaps
glxinfo | less > glxinfo.dat
name of display: :1.0
display: :1 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
GLX_EXT_framebuffer_sRGB, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
GLX_NV_float_buffer, GLX_NV_multisample_coverage, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
GLX_EXT_import_context, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
GLX_NV_copy_image, GLX_NV_float_buffer, GLX_NV_multisample_coverage,
GLX_NV_present_video, GLX_NV_swap_group, GLX_NV_video_capture,
GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX version: 1.4
GLX extensions:
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GT 750M/PCIe/SSE2
OpenGL core profile version string: 4.3.0 NVIDIA 319.32
OpenGL core profile shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended,
GL_ARB_clear_buffer_object, GL_ARB_color_buffer_float,
GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
GL_ARB_depth_texture, GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
GL_ARB_draw_instanced, GL_ARB_explicit_attrib_location,
GL_ARB_explicit_uniform_location, GL_ARB_fragment_coord_conventions,
GL_ARB_fragment_layer_viewport, GL_ARB_fragment_program,
GL_ARB_fragment_program_shadow, GL_ARB_fragment_shader,
GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
GL_ARB_get_program_binary, GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64,
GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
GL_ARB_internalformat_query2, GL_ARB_invalidate_subdata,
GL_ARB_map_buffer_alignment, GL_ARB_map_buffer_range,
GL_ARB_multi_draw_indirect, GL_ARB_multisample, GL_ARB_multitexture,
GL_ARB_occlusion_query, GL_ARB_occlusion_query2,
GL_ARB_pixel_buffer_object, GL_ARB_point_parameters, GL_ARB_point_sprite,
GL_ARB_program_interface_query, GL_ARB_provoking_vertex,
GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counters,
GL_ARB_shader_bit_encoding, GL_ARB_shader_image_load_store,
GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_stencil_texturing,
GL_ARB_sync, GL_ARB_tessellation_shader, GL_ARB_texture_border_clamp,
GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_float, GL_ARB_texture_gather,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_multisample,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_storage,
GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
GL_ARB_transpose_matrix, GL_ARB_uniform_buffer_object,
GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
GL_ARB_vertex_type_2_10_10_10_rev, GL_ARB_viewport_array,
GL_ARB_window_pos, GL_ATI_draw_buffers, GL_ATI_texture_float,
GL_ATI_texture_mirror_once, GL_EXTX_framebuffer_mixed_formats,
GL_EXT_Cg_shader, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_bindable_uniform,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_depth_bounds_test,
GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
GL_EXT_geometry_shader4, GL_EXT_gpu_program_parameters,
GL_EXT_gpu_shader4, GL_EXT_import_sync_object, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_float, GL_EXT_packed_pixels,
GL_EXT_pixel_buffer_object, GL_EXT_point_parameters,
GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_shader_objects, GL_EXT_separate_specular_color,
GL_EXT_shader_image_load_store, GL_EXT_shadow_funcs,
GL_EXT_stencil_two_side, GL_EXT_stencil_wrap, GL_EXT_texture3D,
GL_EXT_texture_array, GL_EXT_texture_buffer_object,
GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
GL_EXT_texture_sRGB_decode, GL_EXT_texture_shared_exponent,
GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
GL_EXT_vertex_attrib_64bit, GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
GL_IBM_texture_mirrored_repeat, GL_KHR_debug, GL_KTX_buffer_region,
GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
GL_NV_ES1_1_compatibility, GL_NV_bindless_texture, GL_NV_blend_square,
GL_NV_compute_program5, GL_NV_conditional_render,
GL_NV_copy_depth_to_color, GL_NV_copy_image, GL_NV_depth_buffer_float,
GL_NV_depth_clamp, GL_NV_draw_texture, GL_NV_explicit_multisample,
GL_NV_fence, GL_NV_float_buffer, GL_NV_fog_distance,
GL_NV_fragment_program, GL_NV_fragment_program2,
GL_NV_fragment_program_option, GL_NV_framebuffer_multisample_coverage,
GL_NV_geometry_shader4, GL_NV_gpu_program4, GL_NV_gpu_program4_1,
GL_NV_gpu_program5, GL_NV_gpu_program5_mem_extended,
GL_NV_gpu_program_fp64, GL_NV_gpu_shader5, GL_NV_half_float,
GL_NV_light_max_exponent, GL_NV_multisample_coverage,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
GL_NV_register_combiners, GL_NV_register_combiners2,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
GL_NV_shader_buffer_load, GL_NV_shader_storage_buffer_object,
GL_NV_texgen_reflection, GL_NV_texture_barrier,
GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
GL_NV_texture_expand_normal, GL_NV_texture_multisample,
GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
GL_NV_texture_shader3, GL_NV_transform_feedback,
GL_NV_transform_feedback2, GL_NV_vdpau_interop, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_attrib_integer_64bit,
GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
GL_NV_vertex_program1_1, GL_NV_vertex_program2,
GL_NV_vertex_program2_option, GL_NV_vertex_program3, GL_S3_s3tc,
GL_SGIS_generate_mipmap, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SUN_slice_accum
OpenGL version string: 4.3.0 NVIDIA 319.32
OpenGL shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
GL_ARB_compatibility, GL_ARB_compressed_texture_pixel_storage,
GL_ARB_compute_shader, GL_ARB_conservative_depth, GL_ARB_copy_buffer,
GL_ARB_copy_image, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_draw_buffers,
GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
GL_ARB_draw_indirect, GL_ARB_draw_instanced,
GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
GL_ARB_geometry_shader4, GL_ARB_get_program_binary, GL_ARB_gpu_shader5,
GL_ARB_gpu_shader_fp64, GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
GL_ARB_imaging, GL_ARB_instanced_arrays, GL_ARB_internalformat_query,
Relevant X.org log
[ 101.978] Initializing built-in extension DRI2
[ 101.978] (II) "glx" will be loaded by default.
[ 101.978] (II) LoadModule: "dri2"
[ 101.978] (II) Module "dri2" already built-in
[ 101.978] (II) LoadModule: "glamoregl"
[ 101.978] (II) Loading /usr/lib64/xorg/modules/libglamoregl.so
[ 102.023] (II) Module glamoregl: vendor="X.Org Foundation"
[ 102.023] compiled for 1.14.0, module version = 0.5.0
[ 102.023] ABI class: X.Org ANSI C Emulation, version 0.4
[ 102.023] (II) LoadModule: "glx"
[ 102.023] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 102.042] (II) Module glx: vendor="NVIDIA Corporation"
[ 102.042] compiled for 4.0.2, module version = 1.0.0
[ 102.042] Module class: X.Org Server Extension
[ 102.042] (II) NVIDIA GLX Module 319.32 Wed Jun 19 14:55:38 PDT 2013
[ 102.042] Loading extension GLX
[ 102.042] (II) LoadModule: "nvidia"
[ 102.042] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 102.044] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 102.044] compiled for 4.0.2, module version = 1.0.0
[ 102.044] Module class: X.Org Video Driver
~: glxgears
33493 frames in 5.0 seconds = 6698.373 FPS
34954 frames in 5.0 seconds = 6990.710 FPS
34931 frames in 5.0 seconds = 6986.154 FPS
34993 frames in 5.0 seconds = 6998.449 FPS
~: lspci -nnk | grep -i vga -A3 | grep ‘Kernel’
Kernel driver in use: i915
Kernel driver in use: nvidia
Also, today I finally got around to turning off the computer and rebooting it. It booted up fine, but I still had to manually start up X as before. Sleeping also seems to be working.
