Opengl render does not choose nvidia card but uses intel mesa as default
Hi Nvidia folks, really need your help on this as I run out of ways to resolved this. I have a laptop with integrated intel graphic card and a gtx3080.
nvidia-smi runs fines, but vulkaninfo and glxinfo both only detects the intel mesa graphic card.
I tried prime-select nvidia, no luck.
installed driver with .run with option --no-opengl-files, still no luck.
tyler@tyler-Alienware-m15-R6:~$ inxi -G
Graphics:
  Device-1: Intel driver: N/A
  Device-2: NVIDIA driver: nvidia v: 515.57
  Display: x11 server: X.Org 1.20.13
  driver: amdgpu,ati,fbdev,intel,modesetting,nouveau,nvidia,radeon,vesa,vmware
  resolution: 1920x1080~60Hz
  OpenGL: renderer: llvmpipe (LLVM 12.0.0 256 bits) v: 4.5 Mesa 21.2.6
tyler@tyler-Alienware-m15-R6:~$ glxinfo
name of display: :1
display: :1  screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
    GLX_ARB_context_flush_control, GLX_ARB_create_context,
    GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
    GLX_ARB_fbconfig_float, GLX_ARB_framebuffer_sRGB, GLX_ARB_multisample,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_libglvnd, GLX_EXT_no_config_context,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_MESA_copy_sub_buffer, GLX_OML_swap_method, GLX_SGIS_multisample,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
    GLX_SGI_make_current_read
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_framebuffer_sRGB, GLX_ARB_get_proc_address, GLX_ARB_multisample,
    GLX_ATI_pixel_format_float, GLX_EXT_buffer_age,
    GLX_EXT_import_context, GLX_EXT_no_config_context, GLX_EXT_swap_control,
    GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_INTEL_swap_event,
    GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
    GLX_MESA_query_renderer, GLX_MESA_swap_control, GLX_NV_float_buffer,
    GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGIS_multisample,
    GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer, GLX_OML_swap_method,
    GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
    GLX_SGIX_visual_select_group, GLX_SGI_make_current_read
Extended renderer info (GLX_MESA_query_renderer):
    Vendor: Mesa/X.org (0xffffffff)
    Device: llvmpipe (LLVM 12.0.0, 256 bits) (0xffffffff)
    Version: 21.2.6
    Accelerated: no
    Video memory: 31849MB
    Unified memory: no
    Preferred profile: core (0x1)
    Max core profile version: 4.5
    Max compat profile version: 3.1
    Max GLES1 profile version: 1.1
    Max GLES[23] profile version: 3.2
OpenGL vendor string: Mesa/X.org
OpenGL renderer string: llvmpipe (LLVM 12.0.0, 256 bits)
OpenGL core profile version string: 4.5 (Core Profile) Mesa 21.2.6
OpenGL core profile shading language version string: 4.50
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_3DFX_texture_compression_FXT1, GL_AMD_conservative_depth,
    GL_AMD_draw_buffers_blend, GL_AMD_gpu_shader_int64,
    GL_AMD_multi_draw_indirect, GL_AMD_query_buffer_object,
    GL_AMD_seamless_cubemap_per_texture, GL_AMD_shader_stencil_export,
    GL_AMD_shader_trinary_minmax, GL_AMD_texture_texture4,
    GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
    GL_ANGLE_texture_compression_dxt3, GL_ANGLE_texture_compression_dxt5,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
    GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_blend_func_extended,
    GL_ARB_buffer_storage, GL_ARB_clear_buffer_object, GL_ARB_clear_texture,
    GL_ARB_clip_control, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_compute_shader, GL_ARB_conditional_render_inverted,
    GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
    GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_derivative_control, GL_ARB_direct_state_access,
    GL_ARB_draw_buffers, GL_ARB_draw_buffers_blend,
    GL_ARB_draw_elements_base_vertex, GL_ARB_draw_indirect,
    GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_shader, GL_ARB_framebuffer_no_attachments,
    GL_ARB_framebuffer_object, GL_ARB_framebuffer_sRGB,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
    GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex,
    GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
    GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
    GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
    GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
    GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
    GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
    GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
    GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
    GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
    GL_ARB_sample_shading, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
    GL_ARB_seamless_cubemap_per_texture, GL_ARB_separate_shader_objects,
    GL_ARB_shader_atomic_counter_ops, GL_ARB_shader_atomic_counters,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_draw_parameters,
    GL_ARB_shader_group_vote, GL_ARB_shader_image_load_store,
    GL_ARB_shader_image_size, GL_ARB_shader_objects, GL_ARB_shader_precision,
    GL_ARB_shader_stencil_export, GL_ARB_shader_storage_buffer_object,
    GL_ARB_shader_subroutine, GL_ARB_shader_texture_image_samples,
    GL_ARB_shader_texture_lod, GL_ARB_shader_viewport_layer_array,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
    GL_ARB_shading_language_packing, GL_ARB_spirv_extensions,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
    GL_ARB_texture_barrier, GL_ARB_texture_buffer_object,
    GL_ARB_texture_buffer_object_rgb32, GL_ARB_texture_buffer_range,
    GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_filter_minmax,
    GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_multisample,
    GL_ARB_texture_non_power_of_two, GL_ARB_texture_query_levels,
    GL_ARB_texture_query_lod, GL_ARB_texture_rectangle, GL_ARB_texture_rg,
    GL_ARB_texture_rgb10_a2ui, GL_ARB_texture_stencil8,
    GL_ARB_texture_storage, GL_ARB_texture_storage_multisample,
    GL_ARB_texture_swizzle, GL_ARB_texture_view, GL_ARB_timer_query,
    GL_ARB_transform_feedback2, GL_ARB_transform_feedback3,
    GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_uniform_buffer_object,
    GL_ARB_vertex_array_bgra, GL_ARB_vertex_array_object,
    GL_ARB_vertex_attrib_64bit, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_viewport_array, GL_ATI_blend_equation_separate,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once,
    GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr,
    GL_EXT_blend_equation_separate, GL_EXT_draw_buffers2,
    GL_EXT_draw_instanced, GL_EXT_framebuffer_blit,
    GL_EXT_framebuffer_multisample, GL_EXT_framebuffer_multisample_blit_scaled,
    GL_EXT_framebuffer_object, GL_EXT_framebuffer_sRGB,
    GL_EXT_packed_depth_stencil, GL_EXT_packed_float,
    GL_EXT_pixel_buffer_object, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_shader_framebuffer_fetch_non_coherent,
    GL_EXT_shader_integer_mix, GL_EXT_texture_array,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_filter_minmax,
    GL_EXT_texture_integer, GL_EXT_texture_mirror_clamp, GL_EXT_texture_sRGB,
    GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
    GL_EXT_texture_snorm, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_transform_feedback, GL_EXT_vertex_array_bgra,
    GL_EXT_vertex_attrib_64bit, GL_IBM_multimode_draw_arrays,
    GL_KHR_blend_equation_advanced, GL_KHR_context_flush_control,
    GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
    GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
    GL_KHR_texture_compression_astc_ldr,
    GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_framebuffer_flip_y,
    GL_MESA_pack_invert, GL_MESA_shader_integer_functions,
    GL_MESA_texture_signed_rgba, GL_MESA_ycbcr_texture,
    GL_NV_conditional_render, GL_NV_copy_image, GL_NV_depth_clamp,
    GL_NV_packed_depth_stencil, GL_NV_texture_barrier, GL_OES_EGL_image,
    GL_S3_s3tc
OpenGL version string: 3.1 Mesa 21.2.6
OpenGL shading language version string: 1.40
OpenGL context flags: (none)
OpenGL extensions:
    GL_AMD_draw_buffers_blend, GL_AMD_multi_draw_indirect,
    GL_AMD_query_buffer_object, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_shader_stencil_export, GL_AMD_shader_trinary_minmax,
    GL_AMD_texture_texture4, GL_ANGLE_texture_compression_dxt3,
    GL_ANGLE_texture_compression_dxt5, GL_APPLE_packed_pixels,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_clip_control, GL_ARB_color_buffer_float, GL_ARB_compatibility,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_depth_texture, GL_ARB_derivative_control,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
    GL_ARB_shader_texture_lod, GL_ARB_shading_language_100,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_spirv_extensions,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_texture_barrier,
    GL_ARB_texture_border_clamp, GL_ARB_texture_buffer_object,
    GL_ARB_texture_compression, GL_ARB_texture_compression_bptc,
    GL_ARB_texture_compression_rgtc, GL_ARB_texture_cube_map,
    GL_ARB_texture_cube_map_array, GL_ARB_texture_env_add,
    GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
    GL_ARB_texture_env_dot3, GL_ARB_texture_filter_minmax,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_binding,
    GL_ARB_vertex_buffer_object, GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_blend_equation_separate,
    GL_ATI_draw_buffers, GL_ATI_fragment_shader, GL_ATI_separate_stencil,
    GL_ATI_texture_compression_3dc, GL_ATI_texture_env_combine3,
    GL_EXT_EGL_image_storage, GL_EXT_EGL_sync, GL_EXT_abgr, GL_EXT_bgra,
    GL_EXT_blend_color, GL_EXT_blend_equation_separate,
    GL_EXT_blend_func_separate, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
    GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
    GL_EXT_direct_state_access, GL_EXT_draw_buffers2, GL_EXT_draw_instanced,
    GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_framebuffer_blit,
    GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
    GL_EXT_multi_draw_arrays, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
    GL_EXT_provoking_vertex, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_separate_specular_color,
    GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_integer_mix,
    GL_EXT_shadow_funcs, GL_EXT_stencil_two_side, GL_EXT_stencil_wrap,
    GL_EXT_subtexture, GL_EXT_texture, GL_EXT_texture3D,
    GL_EXT_texture_array, GL_EXT_texture_buffer_object,
    GL_EXT_texture_compression_dxt1, GL_EXT_texture_compression_latc,
    GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map, GL_EXT_texture_edge_clamp,
    GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
    GL_EXT_texture_env_dot3, GL_EXT_texture_filter_minmax,
    GL_EXT_texture_integer, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object,
    GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_EXT_texture_sRGB_R8,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
    GL_EXT_texture_shared_exponent, GL_EXT_texture_snorm,
    GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback,
    GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_IBM_multimode_draw_arrays, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_INGR_blend_func_separate,
    GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_pack_invert,
    GL_MESA_shader_integer_functions, GL_MESA_texture_signed_rgba,
    GL_MESA_window_pos, GL_MESA_ycbcr_texture, GL_NV_blend_square,
    GL_NV_conditional_render, GL_NV_copy_depth_to_color, GL_NV_copy_image,
    GL_NV_depth_clamp, GL_NV_fog_distance, GL_NV_half_float,
    GL_NV_light_max_exponent, GL_NV_packed_depth_stencil,
    GL_NV_primitive_restart, GL_NV_texgen_reflection, GL_NV_texture_barrier,
    GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_OES_EGL_image,
    GL_OES_read_format, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_border_clamp, GL_SGIS_texture_edge_clamp,
    GL_SGIS_texture_lod, GL_SUN_multi_draw_arrays
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 21.2.6
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
    GL_ANDROID_extension_pack_es31a, GL_ANGLE_pack_reverse_row_order,
    GL_APPLE_texture_max_level, GL_EXT_EGL_image_storage,
    GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
    GL_EXT_buffer_storage, GL_EXT_clip_control, GL_EXT_clip_cull_distance,
    GL_EXT_color_buffer_float, GL_EXT_color_buffer_half_float,
    GL_EXT_compressed_ETC1_RGB8_sub_texture, GL_EXT_copy_image,
    GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
    GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers,
    GL_EXT_draw_buffers_indexed, GL_EXT_draw_elements_base_vertex,
    GL_EXT_draw_instanced, GL_EXT_float_blend, GL_EXT_frag_depth,
    GL_EXT_geometry_point_size, GL_EXT_geometry_shader, GL_EXT_gpu_shader5,
    GL_EXT_map_buffer_range, GL_EXT_multi_draw_arrays,
    GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
    GL_EXT_primitive_bounding_box, GL_EXT_read_format_bgra,
    GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB_write_control,
    GL_EXT_separate_shader_objects,
    GL_EXT_shader_framebuffer_fetch_non_coherent, GL_EXT_shader_group_vote,
    GL_EXT_shader_implicit_conversions, GL_EXT_shader_integer_mix,
    GL_EXT_shader_io_blocks, GL_EXT_tessellation_point_size,
    GL_EXT_tessellation_shader, GL_EXT_texture_border_clamp,
    GL_EXT_texture_buffer, GL_EXT_texture_compression_bptc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_compression_s3tc_srgb,
    GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_minmax,
    GL_EXT_texture_format_BGRA8888, GL_EXT_texture_norm16,
    GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
    GL_EXT_texture_sRGB_RG8, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shadow_lod, GL_EXT_texture_type_2_10_10_10_REV,
    GL_EXT_texture_view, GL_EXT_unpack_subimage,
    GL_KHR_texture_compression_astc_sliced_3d, GL_MESA_bgra,
    GL_MESA_framebuffer_flip_y, GL_MESA_shader_integer_functions,
    GL_NV_conditional_render, GL_NV_draw_buffers, GL_NV_fbo_color_attachments,
    GL_NV_image_formats, GL_NV_pixel_buffer_object, GL_NV_read_buffer,
    GL_NV_read_depth, GL_NV_read_depth_stencil, GL_NV_read_stencil,
    GL_OES_EGL_image, GL_OES_EGL_image_external,
    GL_OES_EGL_image_external_essl3, GL_OES_EGL_sync,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
    GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_geometry_point_size, GL_OES_geometry_shader,
    GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
    GL_OES_required_internalformat, GL_OES_rgb8_rgba8, GL_OES_sample_shading,
    GL_OES_sample_variables, GL_OES_shader_image_atomic,
    GL_OES_shader_io_blocks, GL_OES_shader_multisample_interpolation,
    GL_OES_standard_derivatives, GL_OES_stencil8, GL_OES_surfaceless_context,
    GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
    GL_OES_texture_3D, GL_OES_texture_border_clamp, GL_OES_texture_buffer,
    GL_OES_texture_cube_map_array, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
    GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
    GL_OES_viewport_array
vulkan is having similar output, so not pasting it here…could someone help?
attaching bug report after upgrading kernel to 5.18.
nvidia-bug-report.log.gz (337.5 KB)
You’re using software rendering so I suspect the kernel is too old for your intel gpu. Please use the liquorix ppa to upgrade, uninstall the runfile driver and then install the repo driver.
sorry could you elaborate? My linux kernel is Linux 5.15.0-41-generic, which is pretty new per my understanding.
should be i915. You either did some shady things or you simply have a new 12th gen intel cpu that needs kernel 5.16+
i installed ubuntu20.04 fresh…didn’t install anything else except the nvidia drivers…my machine is dual-bool. I have windows, rocky and ubuntu20.04
So?
i am not getting where the problem is. is it the kernel needs upgrade, or should i install the intel driver since it is the nvidia gpu not getting detected…
The intel driver is integrated in the kernel, so you need a newer kernel to upgrade the intel driver. Please use the liquorix ppa for that.
i’ve upgraded my kernel to 5.18 reboot, still not working. I disabled intel card in bios. (i picked no for hybrid graphics, since it would cause issues to nvidia drivers when turned on, my machine would stuck at cursor blinking, or waiting for the snapd to be fully seeded.)
Odd. Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
updated with bug report. Thanks!
NVIDIA: Failed to load module “glxserver_nvidia”
Do you still have the runfile driver with --no-opengl-files installed?
hi generix, thanks for your time looking over the logs! I reinstalled nvidia driver using the PPA repo, now glxinfo detects nvidia without problem! although inxi -G still outputs N/A for intel.
Please remove “nomodeset”, this disables the intel driver. While the bios switch switches the gpu for the internal display, some external connectors are still driven by the intel gpu.
