Manifest Assets Loaded
86 skinnable objects
Shader 'Particles/FXVille Blood World Lighting': fallback shader 'Paricles/Alpha Blended' not found
Shader 'Effects/Explosions/Distortion/CullBack': fallback shader 'Effects/Distortion/Free/CullOff' not found
Receiving unhandled NULL exception
#0 0x007fd796ffa5c0 in funlockfile
Tried also with
__GL_NextGenCompiler=0 %command%
from steam launch options also, with no change.
GTX 1070
Arch Linux x86_64
its an OpenGL game
x75
May 10, 2018, 1:52am
2
I am having the same issue. Thought it would work itself out over time but it has not.
Same issue with 396.24 on Arch Linux.
I’ll chime in with some general feedback:
For the longest time, nvidia was the only sensible choice for high-performance Linux graphics - the driver was pretty much guaranteed to work and everything else had at best 50% of the performance. Furthermore, ATI’s drivers could be relied on to always be broken and to have rendering bugs in anything except the simplest 2D tasks, while Intel’s offerings could be relied on to not have the performance to even properly run a compositing window manager.
However, during the last two years nvidia seems to have had increasing amount of trouble with drivers, and the 39x series of drivers seems to have problems on both Linux and Windows now. They still have the best hardware, and the driver feature set is good, but I’m starting to have doubts about their QA process, especially after their latest “stable” drivers made our production machines unusable, forcing a manual downgrade and maintenance of both the kernel and the display driver.
To be fair, the 390.48 driver now works for programming tasks and running WebGL apps in Chrome again, but Firefox is slow and jittery enough to be considered broken, the Substance suite becomes quite unresponsive during certain operations (such as resizing the viewport and updating material previews) and most games I’ve tried have had performance degradations, running on Fedora 27 on a 1060 GTX 6GB.
What I’d have liked to see would have been a 380 series fallback release, compatible with the latest kernels, for those with problems with the 390 series on Linux. This “mark it stable and don’t look back” approach has caused us a significant amount of unnecessary work, and eroded trust in nvidia as a company.
same issue on 396.24 with verdun game (openGL) in Ubuntu 18.04
but the game start fine with 390.24
I can confirm. I rollbacked to 390.59 and works fine. (nvidia-390xx on the Arch Official Repositories).
This is still an issue. Can we get some kind of reply as to when this could possibly be fixed?
EDIT: This is using 396.24.02 from the launchpad PPA on Ubuntu Studio 18.04
396.24 here and still the same issue. Rust got updated to newer unity engine also (2018.1.0f2 (d4d99f31acba))
issue is still there. Any news on the fix?
It’s been another month, so I figured I’d check the progress on this issue…any news?
Same here. Using 396.24 and still crashes during assets loading (somewhere around 1900). Can’t play Rust since many months. Won’t return to previous driver versions because 396.xx is so much faster (and recommended by The Rise of the Tomb Raider which I am playing too).
GTX 1060, Kubuntu 17.10, Kernel 4.13
What are the exact steps to reproduce the problem?
-Start the game
-connect to random server
-crashes on asset loading at around 1902
x75
July 11, 2018, 12:29pm
13
Install any 396.xx driver.
Launch the game; In the top left of your screen click the rust button to the left of the shirt button.
Click any server in the official server list and connect.
Game will crash while loading.
The game operates as expected with 390.xx
I suspect that this bug: https://github.com/Unity-Technologies/PostProcessing/issues/592 is the same issue. It has a simple reproducer.
We’re tracking this problem as NVIDIA bug 2254861.
Please try __GL_GlslUseCollapsedArrays=0 as a workaround.
system
July 12, 2018, 5:08pm
16
It works, no longer crashes during the loading.
Arch Linux with nvidia-lts (396.24-4)
x75
July 12, 2018, 5:13pm
17
Passing __GL_GlslUseCollapsedArrays=0 lets the game load for me as well.
Thank you for looking into this ahuillet.
Is there any documentation on switches like __GL_GlslUseCollapsedArrays?
confirming, it works with __GL_GlslUseCollapsedArrays=0
on a 396.24.02
perf is still not that great, but that’s nothing to do with the driver i guess. It has been that crap for quite some time, heres hope for vulkan builds some time
Hello. openSuse Tumbleweed.
Rust crashed.
Use workoraund. Don’t work
Lof attach.
Desktop is 1280 x 1024 @ 75 Hz
New context 0x3964e38 created with attributes:
Initialize engine version: 2018.1.4f1 (1a308f4ebef1)
Forcing GfxDevice: OpenGL Core
GfxDevice: creating device client; threaded=1
Renderer: GeForce GT 440/PCIe/SSE2
Vendor: NVIDIA Corporation
Version: 4.5.0 NVIDIA 390.87
GLES: 0
GL_AMD_multi_draw_indirect GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_compute_shader GL_ARB_compute_variable_group_size GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_2_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_s
hader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gl_spirv GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_gpu_shader_int64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_indirect_parameters GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shade
r_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture GL_ARB_spirv_extensions GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_t
exture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_onc
e GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs
GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_EXT_window_rectangles GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_NV_robustness_video_memory_purge GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_parallel_shader_compile GL_KHR_no_error GL_KHR_robust_buffer_access_behavior G
L_KHR_robustness GL_KTX_buffer_region GL_NV_alpha_to_coverage_dither_control GL_NV_bindless_multi_draw_indirect GL_NV_bindless_multi_draw_indirect_count GL_NV_blend_equation_advanced GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5 GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_internalformat_sample_query GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_
path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_query_resource GL_NV_query_resource_tag GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_atomic_counters GL_NV_shader_atomic_float GL_NV_shader_buffer_load GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_rectangle_compressed GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2 GL_NV_uniform_buffer_unified_memory GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NV_shader_thread_group GL_KHR_blend_equation_advanced GL_SGIS_generate_mipmap GL
_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
OPENGL LOG: Creating OpenGL 4.5 graphics device ; Context level <OpenGL 4.5> ; Context handle 60182072
Begin MonoManager ReloadAssembly
- Completed reload, in 0,553 seconds
New context 0x72e2088 created with attributes:
Default vsync count 0
requesting resize 1280 x 1024
Using native desktop resolution 1280 x 1024
requesting fullscreen 1280 x 1024 at 0 Hz
UnloadTime: 0,770000 ms
Bootstrap Startup
System
OS: Linux 4.18 openSUSE 20180926 64bit
CPU
Model: Intel(R) Celeron(R) CPU G1610 @ 2.60GHz
Cores: 2
Memory: 13982 MB
GPU
Model: GeForce GT 440/PCIe/SSE2
API: OpenGL 4.5.0 NVIDIA 390.87
Memory: 1024 MB
SM: 50
Process
Memory: 0 MB
Mono
Collects: 17
Memory: 0 MB
Facepunch.Steamworks Unity: LinuxPlayer
Facepunch.Steamworks Os: Linux
Facepunch.Steamworks Arch: x64
Manifest Metadata Loaded
11842 pooled strings
13 mesh colliders
5427 prefab properties
388 effect categories
590 entity names
86 skinnable names
Command Line: "/home/berkut/.local/share/Steam/SteamApps/common/Rust/rust" "-force-opengl" "-show-screen-selector"
Command 'force-opengl' not found
Command 'show-screen-selector' not found
SteamID: 76561198079122196 (berkut)
[Manifest] URI IS "https://api.facepunch.com/api/public/manifest/?public_key=j0VF6sNnzn9rwt9qTZtI02zTYK8PRdN1"
(Filename: /home/builduser/buildslave/unity/build/Runtime/Export/Debug.bindings.h Line: 43)
Loading Items Took: 18.8199721 seconds
Building Items Took: 18.9414211 seconds / Items: 403 / Blueprints: 247
Config Loaded
Loading EasyAntiCheat
EasyAntiCheat Loaded
Unloading 5 Unused Serialized files (Serialized files now loaded: 64)
UnloadTime: 7,233000 ms
Unloading 139 unused Assets to reduce memory usage. Loaded Objects now: 7260.
Total: 196,360000 ms (FindLiveObjects: 1,015000 ms CreateObjectMapping: 0,815000 ms MarkObjects: 194,310000 ms DeleteObjects: 0,219000 ms)
Wanted to show loading screen but not ready
Unloading 1 Unused Serialized files (Serialized files now loaded: 64)
UnloadTime: 0,727000 ms
Unloading 91 unused Assets to reduce memory usage. Loaded Objects now: 26031.
Total: 272,598000 ms (FindLiveObjects: 5,074000 ms CreateObjectMapping: 3,341000 ms MarkObjects: 263,839000 ms DeleteObjects: 0,342000 ms)
Connecting..
Unloading 2 Unused Serialized files (Serialized files now loaded: 64)
UnloadTime: 2,745000 ms
[CoverageQueries] Disabled due to unsupported Async GPU Reads on device OpenGLCore
Unloading 130 unused Assets to reduce memory usage. Loaded Objects now: 291396.
Total: 385,188000 ms (FindLiveObjects: 21,332000 ms CreateObjectMapping: 33,119000 ms MarkObjects: 329,685000 ms DeleteObjects: 1,050000 ms)
Generating procedural map of size 3000 with seed 2
[1.0s] Loading World
Shader 'Nature/Terrain/Diffuse': dependency 'AddPassShader' shader 'Hidden/TerrainEngine/Splatmap/Diffuse-AddPass' not found
Shader 'Hidden/TerrainEngine/Splatmap/Standard-AddPass': fallback shader 'Hidden/TerrainEngine/Splatmap/Diffuse-AddPass' not found
[41.9s] Spawning World
[8.9s] Processing World
Destroyed 636 map networkables
You died: killed by [DFA] DeathStalker (76561198039832534)
Got Respawn Information
LocalPlayer.Entity.SecondsSinceDeath: 0.02856445
Renderer 'w_rock_LOD0' is registered with more than one LODGroup ('assets/prefabs/player/player_model.prefab' and 'w_rock').
(Filename: Line: 183)
Renderer 'w_wooden_spear_LOD0' is registered with more than one LODGroup ('assets/prefabs/player/player_model.prefab' and 'w_wooden_spear').
Renderer 'w_rock_LOD1' is registered with more than one LODGroup ('assets/prefabs/player/player_model.prefab' and 'w_rock').
Renderer 'w_wooden_spear_LOD1' is registered with more than one LODGroup ('assets/prefabs/player/player_model.prefab' and 'w_wooden_spear').
Renderer 'w_rock_LOD2' is registered with more than one LODGroup ('assets/prefabs/player/player_model.prefab' and 'w_rock').
Renderer 'w_wooden_spear_LOD2' is registered with more than one LODGroup ('assets/prefabs/player/player_model.prefab' and 'w_wooden_spear').
#0 0x007ff70d7b7780 in funlockfile
#1 0x007ff70d7b7c20 in operator delete(void*)
#2 0x007ff70d7b7cb0 in operator delete(void*)
#3 0x007ff70d7b7cd0 in operator delete(void*)
#4 0x007ff70d7b7dc0 in operator delete(void*)
#5 0x007ff70d7b7e90 in operator delete(void*)
#6 0x007ff70d7b7ea0 in operator delete(void*)
#7 0x007ff70d7b7ec0 in start_thread
#8 0x007ff70d7b7f80 in clone
