I’m running into the same issue using driver 415.22 on Gentoo and the workaround didn’t appear to help.
Just to make sure I’m using the workaround correctly, I’m doing this:
$ cat ~/rush.sh
#!/bin/bash
cd ~/.local/share/Steam/steamapps/common/Rust
export LD_LIBRARY_PATH=.
export __GL_GlslUseCollapsedArrays=0
./rust
The LD_LIBRARY_PATH is due to another unrelated issue. I confirmed the enviromment variable was set, based on catting the contents of /proc/RUST_PID/environ.
