The difference in the glxinfo output bewteen these two driver versions.
diff -Napur glxinfo-334.21.txt glxinfo-340.24.txt
--- glxinfo-334.21.txt 2014-07-31 22:23:17.752964993 -0400
+++ glxinfo-340.24.txt 2014-07-31 22:30:56.687978105 -0400
@@ -8,8 +8,9 @@ server glx extensions:
GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
- GLX_EXT_framebuffer_sRGB, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
- GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
+ GLX_EXT_framebuffer_sRGB, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
+ GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
+ GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_delay_before_swap,
GLX_NV_float_buffer, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
@@ -20,25 +21,27 @@ client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
- GLX_EXT_import_context, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
- GLX_NV_copy_image, GLX_NV_float_buffer, GLX_NV_multisample_coverage,
- GLX_NV_present_video, GLX_NV_swap_group, GLX_NV_video_capture,
- GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
- GLX_SGI_swap_control, GLX_SGI_video_sync
+ GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
+ GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_image,
+ GLX_NV_delay_before_swap, GLX_NV_float_buffer,
+ GLX_NV_multisample_coverage, GLX_NV_present_video, GLX_NV_swap_group,
+ GLX_NV_video_capture, GLX_NV_video_out, GLX_SGIX_fbconfig,
+ GLX_SGIX_pbuffer, GLX_SGI_swap_control, GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
GLX_ARB_create_context, GLX_ARB_create_context_profile,
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: GeForce GTX 750 Ti/PCIe/SSE2
-OpenGL core profile version string: 4.3.0 NVIDIA 334.21
+OpenGL core profile version string: 4.3.0 NVIDIA 340.24
OpenGL core profile shading language version string: 4.30 NVIDIA via Cg compiler
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
@@ -134,12 +137,14 @@ OpenGL core profile extensions:
GL_EXT_texture_swizzle, GL_EXT_timer_query, GL_EXT_transform_feedback2,
GL_EXT_vertex_array, GL_EXT_vertex_array_bgra, GL_EXT_vertex_attrib_64bit,
GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
- GL_IBM_texture_mirrored_repeat, GL_KHR_debug, GL_KTX_buffer_region,
- GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
- GL_NV_ES1_1_compatibility, GL_NV_bindless_multi_draw_indirect,
- GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
- GL_NV_blend_equation_advanced_coherent, GL_NV_blend_square,
- GL_NV_compute_program5, GL_NV_conditional_render,
+ GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
+ GL_KHR_blend_equation_advanced_coherent, GL_KHR_debug,
+ GL_KTX_buffer_region, GL_NVX_conditional_render, GL_NVX_gpu_memory_info,
+ GL_NVX_nvenc_interop, GL_NV_ES1_1_compatibility,
+ GL_NV_ES3_1_compatibility, GL_NV_bindless_multi_draw_indirect,
+ GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
+ GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
+ GL_NV_blend_square, GL_NV_compute_program5, GL_NV_conditional_render,
GL_NV_copy_depth_to_color, GL_NV_copy_image, GL_NV_depth_buffer_float,
GL_NV_depth_clamp, GL_NV_draw_texture, GL_NV_explicit_multisample,
GL_NV_fence, GL_NV_float_buffer, GL_NV_fog_distance,
@@ -155,13 +160,13 @@ OpenGL core profile extensions:
GL_NV_pixel_data_range, GL_NV_point_sprite, GL_NV_primitive_restart,
GL_NV_register_combiners, GL_NV_register_combiners2,
GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
- GL_NV_shader_buffer_load, GL_NV_shader_storage_buffer_object,
- GL_NV_shader_thread_group, GL_NV_shader_thread_shuffle,
- GL_NV_texgen_reflection, GL_NV_texture_barrier,
- GL_NV_texture_compression_vtc, GL_NV_texture_env_combine4,
- GL_NV_texture_expand_normal, GL_NV_texture_multisample,
- GL_NV_texture_rectangle, GL_NV_texture_shader, GL_NV_texture_shader2,
- GL_NV_texture_shader3, GL_NV_transform_feedback,
+ GL_NV_shader_atomic_int64, GL_NV_shader_buffer_load,
+ GL_NV_shader_storage_buffer_object, GL_NV_shader_thread_group,
+ GL_NV_shader_thread_shuffle, GL_NV_texgen_reflection,
+ GL_NV_texture_barrier, GL_NV_texture_compression_vtc,
+ GL_NV_texture_env_combine4, GL_NV_texture_expand_normal,
+ GL_NV_texture_multisample, GL_NV_texture_rectangle, GL_NV_texture_shader,
+ GL_NV_texture_shader2, GL_NV_texture_shader3, GL_NV_transform_feedback,
GL_NV_transform_feedback2, GL_NV_vdpau_interop, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_attrib_integer_64bit,
GL_NV_vertex_buffer_unified_memory, GL_NV_vertex_program,
@@ -170,7 +175,7 @@ OpenGL core profile extensions:
GL_SGIS_generate_mipmap, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SGIX_shadow, GL_SUN_slice_accum
-OpenGL version string: 4.4.0 NVIDIA 334.21
+OpenGL version string: 4.4.0 NVIDIA 340.24
OpenGL shading language version string: 4.40 NVIDIA via Cg compiler
OpenGL context flags: (none)
OpenGL profile mask: (none)
@@ -267,12 +272,14 @@ OpenGL extensions:
@@ -288,13 +295,13 @@ OpenGL extensions:
@@ -307,274 +314,274 @@ OpenGL extensions:
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
-0x021 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
-0x022 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x021 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x022 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x024 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x025 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x025 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x026 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x027 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x027 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x028 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x029 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x029 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x02a 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x02b 24 tc 0 32 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x02b 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x02c 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x02d 24 tc 0 32 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x02d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x02e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x02f 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x02f 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x030 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x031 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x031 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x032 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x033 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x033 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x034 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x035 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x035 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x036 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x037 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x037 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x038 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x039 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x039 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x03a 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x03b 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x03b 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x03c 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x03d 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x03d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x03e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x03f 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x03f 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x040 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x041 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x041 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x042 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x043 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x043 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x044 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x045 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x045 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x046 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x047 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x047 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x048 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x049 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x049 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x04a 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x04b 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x04b 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x04c 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x04d 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x04d 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x04e 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
0x04f 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x050 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x050 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x051 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x052 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x052 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x053 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x054 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x054 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x055 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x056 24 dc 0 32 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x056 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x057 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x058 24 dc 0 32 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x058 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x059 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x05a 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x05a 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x05b 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x05c 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x05c 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x05d 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x05e 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x05e 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x05f 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x060 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x060 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x061 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x062 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x062 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x063 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x064 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x064 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x065 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x066 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x066 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x067 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x068 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x068 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x069 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x06a 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x06a 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x06b 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x06c 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x06c 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x06d 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x06e 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x06e 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x06f 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x070 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x070 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x071 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x072 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x072 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x073 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x074 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x074 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x075 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x076 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x076 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x077 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x078 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x078 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x079 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x023 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x023 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x07a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x07b 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x07b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x07c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x07d 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x07d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x07e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x07f 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x07f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x080 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x081 32 tc 0 32 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x081 32 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x082 32 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x083 32 tc 0 32 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x083 32 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x084 32 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x085 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x085 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x086 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x087 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x087 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x088 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x089 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x089 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x08a 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x08b 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x08b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x08c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x08d 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x08d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x08e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x08f 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x08f 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x090 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x091 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x091 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x092 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x093 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x093 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x094 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x095 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x095 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x096 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x097 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x097 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x098 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x099 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x099 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x09a 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x09b 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x09b 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x09c 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x09d 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x09d 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x09e 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x09f 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x09f 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x0a0 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x0a1 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x0a1 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x0a2 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x0a3 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x0a3 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x0a4 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
215 GLXFBConfigs:
-0x0a5 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
-0x0a6 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x0a5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x0a6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0a7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0a8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x0a9 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
-0x0aa 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x0a9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x0aa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0ab 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
0x0ac 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x0ad 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
-0x0ae 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x0ad 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x0ae 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0af 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x0b1 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
-0x0b2 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x0b1 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x0b2 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
0x0b4 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x0b5 24 tc 0 32 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
-0x0b6 24 dc 0 32 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x0b6 24 dc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0b7 24 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0b8 24 dc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x0b9 24 tc 0 32 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
-0x0ba 24 dc 0 32 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x0b9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x0ba 24 dc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x0bb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
0x0bc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x0bd 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x0be 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x0bd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x0be 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x0bf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
0x0c0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x0c1 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x0c2 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x0c1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x0c2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x0c3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
0x0c4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x0c5 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x0c6 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x0c5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x0c6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x0c7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
0x0c8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x0c9 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x0ca 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x0c9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x0ca 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x0cb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
0x0cc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x0cd 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x0ce 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x0cd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x0ce 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x0cf 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
0x0d0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x0d1 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x0d2 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x0d1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x0d2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x0d3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
0x0d4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x0d5 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x0d6 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x0d5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x0d6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x0d7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
0x0d8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x0d9 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x0da 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x0d9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x0da 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x0db 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
0x0dc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x0dd 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x0de 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x0dd 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x0de 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x0df 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
0x0e0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x0e1 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x0e2 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x0e1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x0e2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x0e3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
0x0e4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x0e5 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x0e6 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x0e5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x0e6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x0e7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
0x0e8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x0e9 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x0ea 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x0e9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x0ea 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x0eb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
0x0ec 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x0ed 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x0ee 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x0ed 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x0ee 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x0ef 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
0x0f0 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x0f1 24 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x0f2 24 dc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x0f1 24 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x0f2 24 dc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x0f3 24 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
0x0f4 24 dc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x0f5 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x0f6 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x0f5 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x0f6 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x0f7 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
0x0f8 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x0f9 24 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x0fa 24 dc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x0f9 24 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x0fa 24 dc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x0fb 24 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
0x0fc 24 dc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x0fd 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x0fd 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x0fe 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x0ff 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
+0x0ff 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 0 0 None
0x100 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 0 0 None
-0x101 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x101 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x102 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x103 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
+0x103 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 0 0 None
0x104 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 0 0 None
-0x105 32 tc 0 32 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x105 32 tc 0 24 0 r y . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x106 32 tc 0 32 0 r y . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x107 32 tc 0 32 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
+0x107 32 tc 0 24 0 r . . 8 8 8 0 . s 4 0 0 16 16 16 16 0 0 None
0x108 32 tc 0 32 0 r . . 8 8 8 8 . s 4 0 0 16 16 16 16 0 0 None
-0x109 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x109 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x10a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x10b 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x10b 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x10c 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x10d 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
+0x10d 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 2 1 Ncon
0x10e 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 2 1 Ncon
-0x10f 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
+0x10f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 4 1 Ncon
0x110 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 4 1 Ncon
-0x111 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x111 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x112 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x113 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x113 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x114 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x115 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
+0x115 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 2 1 Ncon
0x116 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 2 1 Ncon
-0x117 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
+0x117 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 4 1 Ncon
0x118 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 4 1 Ncon
-0x119 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x119 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x11a 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x11b 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x11b 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x11c 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x11d 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
+0x11d 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 8 1 Ncon
0x11e 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 8 1 Ncon
-0x11f 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
+0x11f 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 0 16 16 16 16 16 1 Ncon
0x120 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 0 16 16 16 16 16 1 Ncon
-0x121 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x121 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x122 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x123 32 tc 0 32 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x123 32 tc 0 24 0 r y . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x124 32 tc 0 32 0 r y . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
-0x125 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
+0x125 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 8 1 Ncon
0x126 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 8 1 Ncon
-0x127 32 tc 0 32 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
+0x127 32 tc 0 24 0 r . . 8 8 8 0 . s 4 24 8 16 16 16 16 16 1 Ncon
0x128 32 tc 0 32 0 r . . 8 8 8 8 . s 4 24 8 16 16 16 16 16 1 Ncon
0x129 0 sg 0 16 0 r y . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
0x12a 0 sg 0 16 0 r . . 5 6 5 0 . . 4 16 0 16 16 16 16 0 0 None
