I am trying to enable DLA core using trtexec.
But I got some error messages when using sample mnist onnx.
/usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx --saveEngine=/usr/src/tensorrt/data/mnist/mnist.trt --fp16 --workspace=2048 --useDLACore=0 --allowGPUFallback
nvidia@xavier:~$ /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx --saveEngine=/usr/src/tensorrt/data/mnist/mnist.trt --fp16 --workspace=2048 --useDLACore=0 --allowGPUFallback
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx --saveEngine=/usr/src/tensorrt/data/mnist/mnist.trt --fp16 --workspace=2048 --useDLACore=0 --allowGPUFallback
[06/28/2022-16:19:41] [I] === Model Options ===
[06/28/2022-16:19:41] [I] Format: ONNX
[06/28/2022-16:19:41] [I] Model: /usr/src/tensorrt/data/mnist/mnist.onnx
[06/28/2022-16:19:41] [I] Output:
[06/28/2022-16:19:41] [I] === Build Options ===
[06/28/2022-16:19:41] [I] Max batch: 1
[06/28/2022-16:19:41] [I] Workspace: 2048 MB
[06/28/2022-16:19:41] [I] minTiming: 1
[06/28/2022-16:19:41] [I] avgTiming: 8
[06/28/2022-16:19:41] [I] Precision: FP32+FP16
[06/28/2022-16:19:41] [I] Calibration:
[06/28/2022-16:19:41] [I] Safe mode: Disabled
[06/28/2022-16:19:41] [I] Save engine: /usr/src/tensorrt/data/mnist/mnist.trt
[06/28/2022-16:19:41] [I] Load engine:
[06/28/2022-16:19:41] [I] Builder Cache: Enabled
[06/28/2022-16:19:41] [I] NVTX verbosity: 0
[06/28/2022-16:19:41] [I] Inputs format: fp32:CHW
[06/28/2022-16:19:41] [I] Outputs format: fp32:CHW
[06/28/2022-16:19:41] [I] Input build shapes: model
[06/28/2022-16:19:41] [I] Input calibration shapes: model
[06/28/2022-16:19:41] [I] === System Options ===
[06/28/2022-16:19:41] [I] Device: 0
[06/28/2022-16:19:41] [I] DLACore: 0(With GPU fallback)
[06/28/2022-16:19:41] [I] Plugins:
[06/28/2022-16:19:41] [I] === Inference Options ===
[06/28/2022-16:19:41] [I] Batch: 1
[06/28/2022-16:19:41] [I] Input inference shapes: model
[06/28/2022-16:19:41] [I] Iterations: 10
[06/28/2022-16:19:41] [I] Duration: 3s (+ 200ms warm up)
[06/28/2022-16:19:41] [I] Sleep time: 0ms
[06/28/2022-16:19:41] [I] Streams: 1
[06/28/2022-16:19:41] [I] ExposeDMA: Disabled
[06/28/2022-16:19:41] [I] Spin-wait: Disabled
[06/28/2022-16:19:41] [I] Multithreading: Disabled
[06/28/2022-16:19:41] [I] CUDA Graph: Disabled
[06/28/2022-16:19:41] [I] Skip inference: Disabled
[06/28/2022-16:19:41] [I] Inputs:
[06/28/2022-16:19:41] [I] === Reporting Options ===
[06/28/2022-16:19:41] [I] Verbose: Disabled
[06/28/2022-16:19:41] [I] Averages: 10 inferences
[06/28/2022-16:19:41] [I] Percentile: 99
[06/28/2022-16:19:41] [I] Dump output: Disabled
[06/28/2022-16:19:41] [I] Profile: Disabled
[06/28/2022-16:19:41] [I] Export timing to JSON file:
[06/28/2022-16:19:41] [I] Export output to JSON file:
[06/28/2022-16:19:41] [I] Export profile to JSON file:
Input filename: /usr/src/tensorrt/data/mnist/mnist.onnx
ONNX IR version: 0.0.3
Opset version: 8
Producer name: CNTK
Producer version: 2.5.1
Domain: ai.cntk
Model version: 1
Doc string:
[06/28/2022-16:19:42] [W] [TRT] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[06/28/2022-16:19:42] [E] Cannot create DLA engine, 0 not available
[06/28/2022-16:19:42] [E] Engine creation failed
[06/28/2022-16:19:42] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/usr/src/tensorrt/data/mnist/mnist.onnx --saveEngine=/usr/src/tensorrt/data/mnist/mnist.trt --fp16 --workspace=2048 --useDLACore=0 --allowGPUFallback
I also tried googlenet, and the same error occurred.
/usr/src/tensorrt/bin/trtexec --deploy=/usr/src/tensorrt/data/googlenet/googlenet.prototxt --output=prob --verbose --useDLACore=0 --allowGPUFallback
I found that two DLA’s status always shows “suspended”
Is there any way to ture it to “active”?
DLA 0
Enabled: enabled
Control: auto
Status: suspended
Usage: 0
DLA 1
Enabled: enabled
Control: auto
Status: suspended
Usage: 0
Device infomation
NVIDIA Jetson AGX Xavier [16GB]
L4T 32.5.0 [ JetPack 4.5 ]
Ubuntu 18.04.6 LTS
Kernel Version: 4.9.201-tegra
CUDA 10.2.89
CUDA Architecture: 7.2
OpenCV version: 4.1.1
OpenCV Cuda: NO
CUDNN: 8.0.0.180
TensorRT: 7.1.3.0
Vision Works: 1.6.0.501
VPI: ii libnvvpi1 1.0.12 arm64 NVIDIA Vision Programming Interface library
Vulcan: 1.2.70
