Please use --force as specified
sudo dkms install nvidia/520.56.06 --force
sudo dkms remove --force nvidia/520.56.06
Module nvidia-520.56.06 for kernel 5.19.0-23-generic (x86_64).
Before uninstall, this module version was ACTIVE on this kernel.
nvidia.ko:
- Uninstallation
- Deleting from: /lib/modules/5.19.0-23-generic/
rmdir: failed to remove '': No such file or directory
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
nvidia-modeset.ko:
- Uninstallation
- Deleting from: /lib/modules/5.19.0-23-generic/updates/dkms/
- Original module
nvidia-drm.ko:
- Uninstallation
- Original module
nvidia-uvm.ko:
- Uninstallation
- Original module
nvidia-peermem.ko:
- Uninstallation
- Original module
depmod...
dkms status
nvidia/520.56.06, 6.0.5-060005-generic, x86_64: installed
openrazer-driver/3.4.0, 5.19.0-23-generic, x86_64: installed
openrazer-driver/3.4.0, 6.0.5-060005-generic, x86_64: installed
sudo dkms install --force nvidia/520.56.06
Sign command: /usr/lib/linux-kbuild-5.19/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Binary kmod-sign not found, modules won't be signed
Building module:
Cleaning build area...
unset ARCH; [ ! -h /usr/bin/cc ] && export CC=/usr/bin/gcc; env NV_VERBOSE=1 'make' -j8 NV_EXCLUDE_BUILD_MODULES='' KERNEL_UNAME=5.19.0-23-generic IGNORE_XEN_PRESENCE=1 IGNORE_CC_MISMATCH=1 SYSSRC=/lib/modules/5.19.0-23-generic/build LD=/usr/bin/ld.bfd CONFIG_X86_KERNEL_IBT= modules..........
nvidia.ko:
Running module version sanity check.
- Original module
- Installation
- Installing to /lib/modules/5.19.0-23-generic/updates/dkms/
nvidia-modeset.ko:
- Original module
- Installation
nvidia-drm.ko:
- Original module
- Installation
nvidia-uvm.ko:
- Original module
- Installation
nvidia-peermem.ko:
- Original module
- Installation
depmod...
sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': Exec format error
dkms status
nvidia/520.56.06, 5.19.0-23-generic, x86_64: installed
Looks like the reinstall still didnt work?
Your build system is broken. Please post the output of
cc -v
ld -v
@generix, see below
➜ ~ cc -v
Using built-in specs.
COLLECT_GCC=cc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/12/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Ubuntu 12.2.0-3ubuntu1' --with-bugurl=file:///usr/share/doc/gcc-12/README.Bugs --enable-languages=c,ada,c++,go,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-12 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --enable-cet --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-12-U8K4Qv/gcc-12-12.2.0/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-12-U8K4Qv/gcc-12-12.2.0/debian/tmp-gcn/usr --enable-offload-defaulted --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 12.2.0 (Ubuntu 12.2.0-3ubuntu1)
➜ ~ ld -v
GNU ld (GNU Binutils for Ubuntu) 2.39
I ran a history | grep 'gcc' → which outputted sudo apt install gcc-8. Maybe when I ran this command I broke the build system? Whats the fix for that?
Looks fine. Please try purging and installing the kernel headers instead of reinstalling them.
OK, @generix I did the following, still cannot modprobe nivida…
➜ ~ sudo apt remove --purge linux-headers-$(uname -r)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following package was automatically installed and is no longer required:
linux-headers-5.19.0-23
Use 'sudo apt autoremove' to remove it.
The following packages will be REMOVED:
linux-headers-5.19.0-23-generic* linux-headers-generic*
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 27.6 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 523239 files and directories currently installed.)
Removing linux-headers-generic (5.19.0.23.22) ...
Removing linux-headers-5.19.0-23-generic (5.19.0-23.24) ...
➜ ~ sudo apt install linux-headers-$(uname -r)
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 3,270 kB of archives.
After this operation, 27.6 MB of additional disk space will be used.
Get:1 http://ca.archive.ubuntu.com/ubuntu kinetic-updates/main amd64 linux-headers-5.19.0-23-generic amd64 5.19.0-23.24 [3,270 kB]
Fetched 3,270 kB in 0s (11.6 MB/s)
Selecting previously unselected package linux-headers-5.19.0-23-generic.
(Reading database ... 513426 files and directories currently installed.)
Preparing to unpack .../linux-headers-5.19.0-23-generic_5.19.0-23.24_amd64.deb ...
Unpacking linux-headers-5.19.0-23-generic (5.19.0-23.24) ...
Setting up linux-headers-5.19.0-23-generic (5.19.0-23.24) ...
/etc/kernel/header_postinst.d/dkms:
* dkms: running auto installation service for kernel 5.19.0-23-generic
...done.
➜ ~ sudo modprobe nvidia
➜ ~ dkms status
modinfo nvidia
filename: /lib/modules/5.19.0-23-generic/updates/dkms/nvidia.ko
firmware: nvidia/520.56.06/gsp.bin
alias: char-major-195-*
version: 520.56.06
supported: external
license: NVIDIA
srcversion: 16DD2AB6F8E16BF9E137E59
alias: pci:v000010DEd*sv*sd*bc06sc80i00*
alias: pci:v000010DEd*sv*sd*bc03sc02i00*
alias: pci:v000010DEd*sv*sd*bc03sc00i00*
depends: drm
retpoline: Y
vermagic: 5.19.0-23-generic SMP preempt mod_unload modversions
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid...] (charp)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_EnableS0ixPowerManagement:int
parm: NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableGpuFirmware:int
parm: NVreg_EnableGpuFirmwareLogs:int
parm: NVreg_OpenRmEnableUnsupportedGpus:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_EnableDbgBreakpoint:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
parm: NVreg_ExcludedGpus:charp
parm: NVreg_DmaRemapPeerMmio:int
parm: rm_firmware_active:charp
Update. I uninstalled nvidia, purged and reinstalled my headers, and rebooted my pc. I just ran an install of the 520 driver, and now I get this with modprobe:
[sudo] password for cboin:
modprobe: ERROR: could not insert 'nvidia': No such device
This is a different error from before. @generix, what do you think? Also do you have patreon? You contribute quite a bit to the community, I wanted to donate.
OKOKOKOKO I got it working.
Thank you so much for your help @generix.
Heres what I did, line by line.
sudo apt install --reinstall linux-image-generic
sudo apt install --reinstall linux-headers-generic
Next,
sudo apt remove --purge '^nvidia-.*'
sudo apt remove --purge '^libnvidia-.*'
sudo rm /etc/X11/xorg.conf | true
sudo rm /etc/X11/xorg.conf.d/90-nvidia-primary.conf | true
sudo rm /usr/share/X11/xorg.conf.d/10-nvidia.conf | true
sudo rm /usr/share/X11/xorg.conf.d/11-nvidia-prime.conf | true
sudo rm /etc/modprobe.d/nvidia-kms.conf | true
sudo rm /lib/modprobe.d/nvidia-kms.conf | true
sudo apt update -y && sudo apt full-upgrade -y && sudo apt autoremove -y && sudo apt clean -y && sudo apt autoclean -y
Rebooted.
Installed nvidia-driver-520 from the additional drivers tab of ubuntu.
Rebooted
nvidia-smi
Thu Oct 27 18:42:58 2022
| NVIDIA-SMI 520.56.06 Driver Version: 520.56.06 CUDA Version: 11.8 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| 33% 38C P0 32W / 225W | 826MiB / 8192MiB | 17% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2389 G /usr/lib/xorg/Xorg 214MiB |
| 0 N/A N/A 2713 G /usr/bin/gnome-shell 195MiB |
| 0 N/A N/A 3024 G ...3/usr/lib/firefox/firefox 237MiB |
| 0 N/A N/A 3036 G ...b/thunderbird/thunderbird 145MiB |
| 0 N/A N/A 3225 G ...mail/bridge/proton-bridge 2MiB |
| 0 N/A N/A 3567 G ...AAAAAAAAA= --shared-files 26MiB |
Works! Once again, if you have patreon I would be happy to donate.
@christianboin this post was a lifesaver. I too was able to get it working again after following your outline. It appears that the Ubuntu 20.04 install seems to pick the 520 open-kernel meta package, which does not work for me. The plain 520 meta package does work. Thanks for this detailed post!
