• Jetson nano
• DeepStream 5
• JetPack 4.4
• TensorRT Version
I have a problem where pushing multiple buffers to the pipeline only returns the results once. But If I wait before I push the next buffer it works as expected. Does someone have any idea?
I have the following pipeline.
appsrc->jpegparse->nvv4l2decoder->nvstreammux->nvinfer->appsink
I listen for sample using the new-sample signal. and push data to the pipeline using gst_app_src_push_buffer function.
The problem I have is that if I attempt to push more than one buffer at once, I only get the sample once. If I wait for the sample before I push a new buffer everything works fine.
Below is the code.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "gstnvdsmeta.h"
#define MUXER_OUTPUT_WIDTH 704
#define MUXER_OUTPUT_HEIGHT 576
#define MUXER_BATCH_TIMEOUT_USEC 33000
#define NVDS_GST_META_FRAME (nvds_get_user_meta_type("NVIDIA.DECODER.GST_META_FRAME_META"))
typedef struct FrameMeta
int frameIdx;
} FrameMeta;
FrameMeta *probeFrameMeta(GstBuffer *buf) {
NvDsMetaList *l_frame = NULL;
NvDsUserMeta *user_meta = NULL;
FrameMeta *frameMeta = NULL;
NvDsMetaList *l_user_meta = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta(buf);
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta * )(l_frame->data);
for (l_user_meta = frame_meta->frame_user_meta_list; l_user_meta != NULL;
l_user_meta = l_user_meta->next) {
user_meta = (NvDsUserMeta * )(l_user_meta->data);
if (user_meta->base_meta.meta_type == NVDS_GST_META_FRAME) {
frameMeta = (FrameMeta *) user_meta->user_meta_data;
return frameMeta;
return frameMeta;
/* gst meta copy function set by user */
static gpointer frame_meta_copy_func(gpointer data, gpointer user_data) {
FrameMeta *src_frame_meta = (FrameMeta *) data;
FrameMeta *dst_frame_meta = (FrameMeta *) g_malloc0(
sizeof(FrameMeta));
memcpy(dst_frame_meta, src_frame_meta, sizeof(FrameMeta));
return (gpointer) dst_frame_meta;
/* gst meta release function set by user */
static void frame_meta_release_func(gpointer data, gpointer user_data) {
FrameMeta *frame_meta = (FrameMeta *) data;
if (frame_meta) {
g_free(frame_meta);
frame_meta = NULL;
static void frame_gst_nvds_meta_release_func(gpointer data, gpointer user_data) {
NvDsUserMeta *user_meta = (NvDsUserMeta *) data;
FrameMeta *frame_meta = (FrameMeta *) user_meta->user_meta_data;
frame_meta_release_func(frame_meta, NULL);
/* gst to nvds transform function set by user. "data" holds a pointer to NvDsUserMeta */
static gpointer src_gst_to_nvds_meta_transform_func(gpointer data, gpointer user_data) {
(FrameMeta *) frame_meta_copy_func(src_frame_meta, NULL);
bool pushData() {
printf("Trying to push Buffer! \n");
GstFlowReturn ret;
int frameIdx;
char *buffer;
size_t bufferLength;
GstMapInfo map;
GstBuffer *gst_buffer = gst_buffer_new_allocate(NULL, bufferLength, NULL);
gst_buffer_fill(gst_buffer, 0, buffer, bufferLength);
NvDsMeta *meta = NULL;
FrameMeta *frameMeta = (FrameMeta *) g_malloc0(sizeof(FrameMeta));
if (frameMeta != NULL) {
frameMeta->frameIdx = frameIdx;
meta = gst_buffer_add_nvds_meta(gst_buffer, frameMeta, NULL,
frame_meta_copy_func, frame_meta_release_func);
meta->meta_type = (GstNvDsMetaType)NVDS_GST_META_FRAME;
meta->gst_to_nvds_meta_transform_func = src_gst_to_nvds_meta_transform_func;
meta->gst_to_nvds_meta_release_func = frame_gst_nvds_meta_release_func;
gst_buffer_map (gst_buffer, &map, GST_MAP_WRITE);
gst_buffer_unmap (gst_buffer, &map);
ret = gst_app_src_push_buffer ((GstAppSrc *) app_source, gst_buffer);
if (ret != GST_FLOW_OK) {
printf("Failed to push Buffer! \n");
return FALSE;
return TRUE;
GstFlowReturn new_sample(GstElement *sink) {
printf("New_sample signal fired! \n");
GstSample *sample;
GstBuffer *buf = NULL;
NvDsObjectMeta *obj_meta = NULL;
NvDsMetaList *l_obj = NULL;
g_signal_emit_by_name (sink, "pull-sample", &sample);
if (sample) {
printf("Successfully pulled new Sample! \n");
gst_sample_unref(sample);
return GST_FLOW_OK;
return GST_FLOW_ERROR;
void error_cb(GstBus *bus, GstMessage *msg, GMainLoop *main_loop) {
GError *err;
gchar *debug_info;
/* Print error details on the screen */
gst_message_parse_error(msg, &err, &debug_info);
g_printerr("Error received from element %s: %s\n", GST_OBJECT_NAME(msg->src), err->message);
g_printerr("Debugging information: %s\n", debug_info ? debug_info : "none");
g_clear_error(&err);
g_free(debug_info);
g_main_loop_quit(main_loop);
static void
start_feed (GstElement * source, guint size, AppSrcData * data)
if (data->sourceid == 0) {
data->sourceid = g_idle_add ((GSourceFunc) read_data, NULL);
int main(int argc, char *argv[]) {
GstElement *pipeline = NULL, *app_source = NULL, *app_queue = NULL, *jpegparse = NULL, *nvv4l2decoder = NULL, *nvstreammux = NULL, *nvinfer = NULL, *app_sink = NULL;
GMainLoop *main_loop; /* GLib's Main Loop */
guint sourceid;
GstBus *bus;
sourceid = 0;
gst_init (&argc, &argv);
// loop = g_main_loop_new (NULL, FALSE);
app_source = gst_element_factory_make ("appsrc", "appsrc");
app_queue = gst_element_factory_make ("queue", "queue");
jpegparse = gst_element_factory_make ("jpegparse", "jpegparse");
nvv4l2decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2decoder");
nvstreammux = gst_element_factory_make ("nvstreammux", "nvstreammux");
nvinfer = gst_element_factory_make ("nvinfer", "nvinfer");
app_sink = gst_element_factory_make ("appsink", "app_sink");
pipeline = gst_pipeline_new ("inference-pipeline");
if (!pipeline || !app_source || !jpegparse || !app_queue || !nvv4l2decoder || !nvstreammux || !nvinfer || !app_sink) {
g_printerr ("Not all elements could be created.\n");
return -1;
g_object_set (app_sink, "emit-signals", TRUE, NULL);
g_signal_connect (app_sink, "new-sample", G_CALLBACK (new_sample), NULL);
g_object_set (G_OBJECT (app_source), "is-live", 1, NULL);
g_object_set (G_OBJECT (nvstreammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", 1,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
g_object_set(G_OBJECT(nvinfer),
"config-file-path",
"/home/pi/configs/config_infer_primary_yoloV3.txt",
NULL);
gst_bin_add_many (GST_BIN (pipeline), app_source, jpegparse, app_queue, nvv4l2decoder, nvstreammux, nvinfer, app_sink, NULL);
if (!gst_element_link_many (app_source, jpegparse, app_queue, nvv4l2decoder, NULL)) {
g_printerr ("Elements could not be linked: caontext->customData.app_source, context->customData.app_queue, context->customData.nvv4l2decoder. Exiting.\n");
return -1;
if (!gst_element_link_many (nvstreammux, nvinfer, app_sink, NULL)) {
g_printerr ("Elements could not be linked: 1. Exiting. context->customData.nvstreammux, context->customData.nvinfer, context->customData.app_sink \n");
return -1;
GstPad *sinkpad, *srcpad, *infer_src_pad;
gchar pad_name_sink[16] = "sink_0";
gchar pad_name_src[16] = "src";
sinkpad = gst_element_get_request_pad (nvstreammux, pad_name_sink);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (nvv4l2decoder, pad_name_src);
if (!srcpad) {
g_printerr ("Decoder request src pad failed. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
return -1;
gst_object_unref (sinkpad);
gst_object_unref (srcpad);
bus = gst_element_get_bus (pipeline);
gst_bus_add_signal_watch (bus);
g_signal_connect (G_OBJECT (bus), "message::error", (GCallback)error_cb, &main_loop);
gst_object_unref (bus);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
main_loop = g_main_loop_new (NULL, FALSE);
g_main_loop_run (main_loop);
gst_element_set_state (pipeline, GST_STATE_NULL);
gst_object_unref (pipeline);
return 0;
