I am running this command:
sudo pip3 install keras
And I get this error:
The directory '/home/mojito/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/mojito/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Collecting keras
Downloading https://files.pythonhosted.org/packages/ad/fd/6bfe87920d7f4fd475acd28500a42482b6b84479832bdc0fe9e589a60ceb/Keras-2.3.1-py2.py3-none-any.whl (377kB)
100% |████████████████████████████████| 378kB 464kB/s
Requirement already satisfied: pyyaml in /usr/lib/python3/dist-packages (from keras)
Requirement already satisfied: numpy>=1.9.1 in /home/mojito/.local/lib/python3.6/site-packages (from keras)
Collecting h5py (from keras)
Downloading https://files.pythonhosted.org/packages/5f/97/a58afbcf40e8abecededd9512978b4e4915374e5b80049af082f49cebe9a/h5py-2.10.0.tar.gz (301kB)
100% |████████████████████████████████| 307kB 472kB/s
Requirement already satisfied: six>=1.9.0 in /home/mojito/.local/lib/python3.6/site-packages (from keras)
Collecting keras-preprocessing>=1.0.5 (from keras)
Downloading https://files.pythonhosted.org/packages/28/6a/8c1f62c37212d9fc441a7e26736df51ce6f0e38455816445471f10da4f0a/Keras_Preprocessing-1.1.0-py2.py3-none-any.whl (41kB)
100% |████████████████████████████████| 51kB 736kB/s
Collecting scipy>=0.14 (from keras)
Downloading https://files.pythonhosted.org/packages/a7/5c/495190b8c7cc71977c3d3fafe788d99d43eeb4740ac56856095df6a23fbd/scipy-1.3.3.tar.gz (23.8MB)
100% |████████████████████████████████| 23.8MB 20kB/s
Collecting keras-applications>=1.0.6 (from keras)
Downloading https://files.pythonhosted.org/packages/71/e3/19762fdfc62877ae9102edf6342d71b28fbfd9dea3d2f96a882ce099b03f/Keras_Applications-1.0.8-py3-none-any.whl (50kB)
100% |████████████████████████████████| 51kB 722kB/s
Installing collected packages: h5py, keras-preprocessing, scipy, keras-applications, keras
Running setup.py install for h5py ... done
Running setup.py install for scipy ... error
Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-trv7zrqv/scipy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-7_rwoepq-record/install-record.txt --single-version-externally-managed --compile:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install scipy` (last SciPy release on PyPI)
Running from scipy source directory.
lapack_opt_info:
lapack_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_lapack_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_threads_info:
Setting PTATLAS=ATLAS
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
/home/mojito/.local/lib/python3.6/site-packages/numpy/distutils/system_info.py:1712: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
if getattr(self, '_calc_info_{}'.format(lapack))():
lapack_src_info:
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
NOT AVAILABLE
File "<string>", line 1, in <module>
File "/tmp/pip-build-trv7zrqv/scipy/setup.py", line 505, in <module>
setup_package()
File "/tmp/pip-build-trv7zrqv/scipy/setup.py", line 501, in setup_package
setup(**metadata)
File "/home/mojito/.local/lib/python3.6/site-packages/numpy/distutils/core.py", line 137, in setup
config = configuration()
File "/tmp/pip-build-trv7zrqv/scipy/setup.py", line 403, in configuration
raise NotFoundError(msg)
numpy.distutils.system_info.NotFoundError: No lapack/blas resources found.
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-trv7zrqv/scipy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-7_rwoepq-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-trv7zrqv/scipy/
What do I do wrong?
