tensorflow problem on jetson nano
I followed these commands:
sudo apt-get install python3-pip libhdf5-serial-dev hdf5-tools
pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu==1.13.1+nv19.5 --user
but with the second command I get te below errors:
nobody1@nobody1-desktop:~$ pip3 install --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu==1.13.1+nv19.5 --user
Collecting tensorflow-gpu==1.13.1+nv19.5
  Using cached https://developer.download.nvidia.com/compute/redist/jp/v42/tensorflow-gpu/tensorflow_gpu-1.13.1+nv19.5-cp36-cp36m-linux_aarch64.whl
Collecting absl-py>=0.1.6 (from tensorflow-gpu==1.13.1+nv19.5)
Exception:
  File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 353, in run
    wb.build(autobuilding=True)
  File "/usr/lib/python3/dist-packages/pip/wheel.py", line 749, in build
    self.requirement_set.prepare_files(self.finder)
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file
    require_hashes
  File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link
    self.link = finder.find_requirement(self, upgrade)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement
    all_candidates = self.find_all_candidates(req.name)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates
    for page in self._get_pages(url_locations, project_name):
  File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages
    page = self._get_page(location)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page
    return HTMLPage.get_page(link, session=self.session)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 795, in get_page
    resp.raise_for_status()
  File "/usr/share/python-wheels/requests-2.18.4-py2.py3-none-any.whl/requests/models.py", line 935, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://developer.download.nvidia.com/compute/redist/jp/v42/absl-py/
What I do wrong?
Could you try if this command works form you?
sudo pip3 install --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu
I get this:
  Downloading https://developer.download.nvidia.com/compute/redist/jp/v42/tensorflow-gpu/tensorflow_gpu-1.13.1+nv19.5-cp36-cp36m-linux_aarch64.whl (204.6MB)
    100% |████████████████████████████████| 204.6MB 2.4kB/s
Requirement already satisfied: wheel>=0.26 in /usr/lib/python3/dist-packages (from tensorflow-gpu)
Requirement already satisfied: numpy>=1.13.3 in /usr/local/lib/python3.6/dist-packages (from tensorflow-gpu)
Collecting keras-preprocessing>=1.0.5 (from tensorflow-gpu)
Exception:
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 342, in run
    requirement_set.prepare_files(finder)
    require_hashes
requests.exceptions.HTTPError: 404 Client Error: Not Found for url: https://developer.download.nvidia.com/compute/redist/jp/v42/keras-preprocessing/
Ok I fixed it.
I am following this:
I now run the command:
sudo pip3 install keras
to install keras
and I get these errors:
Building wheel for scipy (PEP 517) ... error
  ERROR: Complete output from command /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmpk8puk65d:
  ERROR: lapack_opt_info:
  lapack_mkl_info:
  customize UnixCCompiler
    libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  openblas_lapack_info:
  C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
  creating /tmp/tmpy2bo3isk/tmp
  creating /tmp/tmpy2bo3isk/tmp/tmpy2bo3isk
  compile options: '-c'
  aarch64-linux-gnu-gcc: /tmp/tmpy2bo3isk/source.c
  aarch64-linux-gnu-gcc -pthread /tmp/tmpy2bo3isk/tmp/tmpy2bo3isk/source.o -lopenblas -o /tmp/tmpy2bo3isk/a.out
    FOUND:
      libraries = ['openblas', 'openblas']
      library_dirs = ['/usr/lib/aarch64-linux-gnu']
      language = c
      define_macros = [('HAVE_CBLAS', None)]
    FOUND:
      language = c
  Splitting linalg.interpolative Fortran source files
  blas_opt_info:
  blas_mkl_info:
    NOT AVAILABLE
  blis_info:
    libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
    NOT AVAILABLE
  openblas_info:
    FOUND:
      language = c
    FOUND:
      language = c
  [makenpz] scipy/special/tests/data/boost.npz not rebuilt
  [makenpz] scipy/special/tests/data/gsl.npz not rebuilt
  [makenpz] scipy/special/tests/data/local.npz not rebuilt
  non-existing path in 'scipy/signal/windows': 'tests'
  running bdist_wheel
  running build
  running config_cc
  unifing config_cc, config, build_clib, build_ext, build commands --compiler options
  running config_fc
  unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
  running build_src
  build_src
  building py_modules sources
  building library "dfftpack" sources
  building library "fftpack" sources
  building library "mach" sources
  building library "quadpack" sources
  building library "lsoda" sources
  building library "vode" sources
  building library "dop" sources
  building library "fitpack" sources
  building library "fwrappers" sources
  building library "odrpack" sources
  building library "minpack" sources
  building library "rootfind" sources
  building library "superlu_src" sources
  building library "arpack_scipy" sources
  building library "sc_c_misc" sources
  building library "sc_cephes" sources
  building library "sc_mach" sources
  building library "sc_amos" sources
  building library "sc_cdf" sources
  building library "sc_specfun" sources
  building library "statlib" sources
  building extension "scipy.cluster._vq" sources
  building extension "scipy.cluster._hierarchy" sources
  building extension "scipy.cluster._optimal_leaf_ordering" sources
  building extension "scipy.fftpack._fftpack" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/fftpack/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/fftpack' to include_dirs.
  building extension "scipy.fftpack.convolve" sources
  f2py options: []
  building extension "scipy.integrate._quadpack" sources
  building extension "scipy.integrate._odepack" sources
  building extension "scipy.integrate.vode" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/integrate/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/integrate' to include_dirs.
  building extension "scipy.integrate.lsoda" sources
  f2py options: []
  building extension "scipy.integrate._dop" sources
  f2py options: []
  building extension "scipy.integrate._test_multivariate" sources
  building extension "scipy.integrate._test_odeint_banded" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/scipy/integrate/_test_odeint_banded-f2pywrappers.f' to sources.
  building extension "scipy.interpolate.interpnd" sources
  building extension "scipy.interpolate._ppoly" sources
  building extension "scipy.interpolate._bspl" sources
  building extension "scipy.interpolate._fitpack" sources
  building extension "scipy.interpolate.dfitpack" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/interpolate/src/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/interpolate/src' to include_dirs.
    adding 'build/src.linux-aarch64-3.6/scipy/interpolate/src/dfitpack-f2pywrappers.f' to sources.
  building extension "scipy.io._test_fortran" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/io/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/io' to include_dirs.
  building extension "scipy.io.matlab.streams" sources
  building extension "scipy.io.matlab.mio_utils" sources
  building extension "scipy.io.matlab.mio5_utils" sources
  building extension "scipy.linalg._fblas" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg' to include_dirs.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/_fblas-f2pywrappers.f' to sources.
  building extension "scipy.linalg._flapack" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/_flapack-f2pywrappers.f' to sources.
  building extension "scipy.linalg._flinalg" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg' to include_dirs.
  building extension "scipy.linalg._interpolative" sources
  f2py options: []
  building extension "scipy.linalg._solve_toeplitz" sources
  building extension "scipy.linalg.cython_blas" sources
  building extension "scipy.linalg.cython_lapack" sources
  building extension "scipy.linalg._decomp_update" sources
  building extension "scipy.odr.__odrpack" sources
  building extension "scipy.optimize._minpack" sources
  building extension "scipy.optimize._zeros" sources
  building extension "scipy.optimize._lbfgsb" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/lbfgsb_src/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/lbfgsb_src' to include_dirs.
  building extension "scipy.optimize.moduleTNC" sources
  building extension "scipy.optimize._cobyla" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/cobyla/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/cobyla' to include_dirs.
  building extension "scipy.optimize.minpack2" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/minpack2/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/minpack2' to include_dirs.
  building extension "scipy.optimize._slsqp" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/slsqp/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/slsqp' to include_dirs.
  building extension "scipy.optimize._nnls" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/nnls/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/nnls' to include_dirs.
  building extension "scipy.optimize._group_columns" sources
  building extension "scipy.optimize._bglu_dense" sources
  building extension "scipy.optimize._lsq.givens_elimination" sources
  building extension "scipy.optimize._trlib._trlib" sources
  building extension "scipy.optimize.cython_optimize._zeros" sources
  building extension "scipy.signal.sigtools" sources
  building extension "scipy.signal._spectral" sources
  building extension "scipy.signal._max_len_seq_inner" sources
  building extension "scipy.signal._peak_finding_utils" sources
  building extension "scipy.signal._upfirdn_apply" sources
  building extension "scipy.signal.spline" sources
  building extension "scipy.sparse.linalg.isolve._iterative" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/isolve/iterative/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/isolve/iterative' to include_dirs.
  building extension "scipy.sparse.linalg.dsolve._superlu" sources
  building extension "scipy.sparse.linalg.eigen.arpack._arpack" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack' to include_dirs.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack/_arpack-f2pywrappers.f' to sources.
  building extension "scipy.sparse.csgraph._shortest_path" sources
  building extension "scipy.sparse.csgraph._traversal" sources
  building extension "scipy.sparse.csgraph._min_spanning_tree" sources
  building extension "scipy.sparse.csgraph._reordering" sources
  building extension "scipy.sparse.csgraph._tools" sources
  building extension "scipy.sparse._csparsetools" sources
  building extension "scipy.sparse._sparsetools" sources
  [generate_sparsetools] 'scipy/sparse/sparsetools/bsr_impl.h' already up-to-date
  [generate_sparsetools] 'scipy/sparse/sparsetools/csr_impl.h' already up-to-date
  [generate_sparsetools] 'scipy/sparse/sparsetools/csc_impl.h' already up-to-date
  [generate_sparsetools] 'scipy/sparse/sparsetools/other_impl.h' already up-to-date
  [generate_sparsetools] 'scipy/sparse/sparsetools/sparsetools_impl.h' already up-to-date
  building extension "scipy.spatial.qhull" sources
  building extension "scipy.spatial.ckdtree" sources
  building extension "scipy.spatial._distance_wrap" sources
  building extension "scipy.spatial._voronoi" sources
  building extension "scipy.spatial._hausdorff" sources
  building extension "scipy.special.specfun" sources
  f2py options: ['--no-wrap-functions']
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/special/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/special' to include_dirs.
  building extension "scipy.special._ufuncs" sources
  building extension "scipy.special._ufuncs_cxx" sources
  building extension "scipy.special._ellip_harm_2" sources
  building extension "scipy.special.cython_special" sources
  building extension "scipy.special._comb" sources
  building extension "scipy.special._test_round" sources
  building extension "scipy.stats.statlib" sources
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/stats/fortranobject.c' to sources.
    adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/stats' to include_dirs.
  building extension "scipy.stats._stats" sources
  building extension "scipy.stats.mvn" sources
  f2py options: []
    adding 'build/src.linux-aarch64-3.6/scipy/stats/mvn-f2pywrappers.f' to sources.
  building extension "scipy.ndimage._nd_image" sources
  building extension "scipy.ndimage._ni_label" sources
  building extension "scipy.ndimage._ctest" sources
  building extension "scipy.ndimage._ctest_oldapi" sources
  building extension "scipy.ndimage._cytest" sources
  building extension "scipy._lib._ccallback_c" sources
  building extension "scipy._lib._test_ccallback" sources
  building extension "scipy._lib._fpumode" sources
  building extension "scipy._lib.messagestream" sources
  get_default_fcompiler: matching types: '['gnu95', 'intel', 'lahey', 'pg', 'absoft', 'nag', 'vast', 'compaq', 'intele', 'intelem', 'gnu', 'g95', 'pathf95', 'nagfor']'
  customize Gnu95FCompiler
  Could not locate executable gfortran
  Could not locate executable f95
  customize IntelFCompiler
  Could not locate executable ifort
  Could not locate executable ifc
  customize LaheyFCompiler
  Could not locate executable lf95
  customize PGroupFCompiler
  Could not locate executable pgfortran
  customize AbsoftFCompiler
  Could not locate executable f90
  Could not locate executable f77
  customize NAGFCompiler
  customize VastFCompiler
  customize CompaqFCompiler
  Could not locate executable fort
  customize IntelItaniumFCompiler
  Could not locate executable efort
  Could not locate executable efc
  customize IntelEM64TFCompiler
  customize GnuFCompiler
  Could not locate executable g77
  customize G95FCompiler
  Could not locate executable g95
  customize PathScaleFCompiler
  Could not locate executable pathf95
  customize NAGFORCompiler
  Could not locate executable nagfor
  don't know how to compile Fortran code on platform 'posix'
  compile options: '-I/usr/include/python3.6m -c'
  aarch64-linux-gnu-gcc: _configtest.c
  aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
  success!
  removing: _configtest.c _configtest.o _configtest.o.d _configtest
  building data_files sources
  build_src: building npy-pkg config files
  running build_py
  creating build/lib.linux-aarch64-3.6
  creating build/lib.linux-aarch64-3.6/scipy
  copying scipy/_distributor_init.py -> build/lib.linux-aarch64-3.6/scipy
  copying scipy/setup.py -> build/lib.linux-aarch64-3.6/scipy
  copying scipy/__init__.py -> build/lib.linux-aarch64-3.6/scipy
  copying scipy/version.py -> build/lib.linux-aarch64-3.6/scipy
  copying scipy/conftest.py -> build/lib.linux-aarch64-3.6/scipy
  copying build/src.linux-aarch64-3.6/scipy/__config__.py -> build/lib.linux-aarch64-3.6/scipy
  creating build/lib.linux-aarch64-3.6/scipy/cluster
  copying scipy/cluster/setup.py -> build/lib.linux-aarch64-3.6/scipy/cluster
  copying scipy/cluster/__init__.py -> build/lib.linux-aarch64-3.6/scipy/cluster
  copying scipy/cluster/vq.py -> build/lib.linux-aarch64-3.6/scipy/cluster
  copying scipy/cluster/hierarchy.py -> build/lib.linux-aarch64-3.6/scipy/cluster
  creating build/lib.linux-aarch64-3.6/scipy/constants
  copying scipy/constants/constants.py -> build/lib.linux-aarch64-3.6/scipy/constants
  copying scipy/constants/setup.py -> build/lib.linux-aarch64-3.6/scipy/constants
  copying scipy/constants/__init__.py -> build/lib.linux-aarch64-3.6/scipy/constants
  copying scipy/constants/codata.py -> build/lib.linux-aarch64-3.6/scipy/constants
  creating build/lib.linux-aarch64-3.6/scipy/fftpack
  copying scipy/fftpack/realtransforms.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
  copying scipy/fftpack/basic.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
  copying scipy/fftpack/setup.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
  copying scipy/fftpack/__init__.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
  copying scipy/fftpack/helper.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
  copying scipy/fftpack/pseudo_diffs.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
  creating build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/quadpack.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/odepack.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/_bvp.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/setup.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/__init__.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/_ode.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  copying scipy/integrate/quadrature.py -> build/lib.linux-aarch64-3.6/scipy/integrate
  creating build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/base.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/radau.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/rk.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/__init__.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/ivp.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/lsoda.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/bdf.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  copying scipy/integrate/_ivp/common.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
  creating build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/_cubic.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/_fitpack_impl.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/fitpack.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/_bsplines.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/ndgriddata.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/rbf.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/interpolate.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/setup.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/__init__.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/interpnd_info.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/fitpack2.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/_pade.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  copying scipy/interpolate/polyint.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
  creating build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/wavfile.py -> build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/_fortran.py -> build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/idl.py -> build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/setup.py -> build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/mmio.py -> build/lib.linux-aarch64-3.6/scipy/io
  copying scipy/io/netcdf.py -> build/lib.linux-aarch64-3.6/scipy/io
  creating build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/mio.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/mio5_params.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/miobase.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/setup.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/mio4.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/byteordercodes.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  copying scipy/io/matlab/mio5.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
  creating build/lib.linux-aarch64-3.6/scipy/io/arff
  copying scipy/io/arff/arffread.py -> build/lib.linux-aarch64-3.6/scipy/io/arff
  copying scipy/io/arff/setup.py -> build/lib.linux-aarch64-3.6/scipy/io/arff
  copying scipy/io/arff/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io/arff
  creating build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
  copying scipy/io/harwell_boeing/_fortran_format_parser.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
  copying scipy/io/harwell_boeing/setup.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
  copying scipy/io/harwell_boeing/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
  copying scipy/io/harwell_boeing/hb.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
  creating build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/blas.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/decomp_lu.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/interpolative.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_decomp_qz.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/flinalg.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/linalg_version.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_interpolative_backend.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_sketches.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/decomp_svd.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_testutils.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_matfuncs_sqrtm.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/basic.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_decomp_ldl.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/decomp_schur.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/setup.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/__init__.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/decomp_qr.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_cython_signature_generator.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/decomp_cholesky.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/lapack.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_expm_frechet.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/matfuncs.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_procrustes.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/decomp.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_matfuncs_inv_ssq.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/misc.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_generate_pyx.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_solvers.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/special_matrices.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  copying scipy/linalg/_decomp_polar.py -> build/lib.linux-aarch64-3.6/scipy/linalg
  creating build/lib.linux-aarch64-3.6/scipy/misc
  copying scipy/misc/setup.py -> build/lib.linux-aarch64-3.6/scipy/misc
  copying scipy/misc/__init__.py -> build/lib.linux-aarch64-3.6/scipy/misc
  copying scipy/misc/doccer.py -> build/lib.linux-aarch64-3.6/scipy/misc
  copying scipy/misc/common.py -> build/lib.linux-aarch64-3.6/scipy/misc
  creating build/lib.linux-aarch64-3.6/scipy/odr
  copying scipy/odr/models.py -> build/lib.linux-aarch64-3.6/scipy/odr
  copying scipy/odr/setup.py -> build/lib.linux-aarch64-3.6/scipy/odr
  copying scipy/odr/__init__.py -> build/lib.linux-aarch64-3.6/scipy/odr
  copying scipy/odr/add_newdocs.py -> build/lib.linux-aarch64-3.6/scipy/odr
  copying scipy/odr/odrpack.py -> build/lib.linux-aarch64-3.6/scipy/odr
  creating build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_linprog_util.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/nonlin.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/zeros.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/optimize.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_tstutils.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/nnls.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/tnc.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_linprog_simplex.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_dual_annealing.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_spectral.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_linprog.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_hessian_update_strategy.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_differentialevolution.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_trustregion_ncg.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_trustregion_krylov.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_numdiff.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_remove_redundancy.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_constraints.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/minpack.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_linprog_ip.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_minimize.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_basinhopping.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_root.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_trustregion_dogleg.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/slsqp.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_linprog_rs.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/linesearch.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/lbfgsb.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_hungarian.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_shgo.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_root_scalar.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_trustregion.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_differentiable_functions.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/cobyla.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  copying scipy/optimize/_trustregion_exact.py -> build/lib.linux-aarch64-3.6/scipy/optimize
  creating build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/trf.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/lsq_linear.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/trf_linear.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/bvls.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/dogbox.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/common.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  copying scipy/optimize/_lsq/least_squares.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
  creating build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
  copying scipy/optimize/_trlib/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
  copying scipy/optimize/_trlib/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
  creating build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/qp_subproblem.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/canonical_constraint.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/tr_interior_point.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/minimize_trustregion_constr.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/report.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/projections.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  copying scipy/optimize/_trustregion_constr/equality_constrained_sqp.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
  creating build/lib.linux-aarch64-3.6/scipy/optimize/cython_optimize
  copying scipy/optimize/cython_optimize/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/cython_optimize
  creating build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
  copying scipy/optimize/_shgo_lib/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
  copying scipy/optimize/_shgo_lib/sobol_seq.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
  copying scipy/optimize/_shgo_lib/triangulation.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
  creating build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/_peak_finding.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/signaltools.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/spectral.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/_savitzky_golay.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/wavelets.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/_max_len_seq.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/waveforms.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/_arraytools.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/setup.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/__init__.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/_upfirdn.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/bsplines.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/lti_conversion.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/fir_filter_design.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/filter_design.py -> build/lib.linux-aarch64-3.6/scipy/signal
  copying scipy/signal/ltisys.py -> build/lib.linux-aarch64-3.6/scipy/signal
  creating build/lib.linux-aarch64-3.6/scipy/signal/windows
  copying scipy/signal/windows/setup.py -> build/lib.linux-aarch64-3.6/scipy/signal/windows
  copying scipy/signal/windows/__init__.py -> build/lib.linux-aarch64-3.6/scipy/signal/windows
  copying scipy/signal/windows/windows.py -> build/lib.linux-aarch64-3.6/scipy/signal/windows
  creating build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/csr.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/dok.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/construct.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/base.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/extract.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/csc.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/dia.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/bsr.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/lil.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/coo.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/sparsetools.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/spfuncs.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/generate_sparsetools.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/compressed.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/data.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/_matrix_io.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/_index.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  copying scipy/sparse/sputils.py -> build/lib.linux-aarch64-3.6/scipy/sparse
  creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/_onenormest.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/interface.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/_norm.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/matfuncs.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  copying scipy/sparse/linalg/_expm_multiply.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
  creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/utils.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/minres.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/lgmres.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/lsqr.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/iterative.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/_gcrotmk.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  copying scipy/sparse/linalg/isolve/lsmr.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
  creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
  copying scipy/sparse/linalg/dsolve/_add_newdocs.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
  copying scipy/sparse/linalg/dsolve/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
  copying scipy/sparse/linalg/dsolve/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
  copying scipy/sparse/linalg/dsolve/linsolve.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
  creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
  copying scipy/sparse/linalg/eigen/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
  copying scipy/sparse/linalg/eigen/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
  creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
  copying scipy/sparse/linalg/eigen/arpack/arpack.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
  copying scipy/sparse/linalg/eigen/arpack/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
  copying scipy/sparse/linalg/eigen/arpack/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
  creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
  copying scipy/sparse/linalg/eigen/lobpcg/lobpcg.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
  copying scipy/sparse/linalg/eigen/lobpcg/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
  copying scipy/sparse/linalg/eigen/lobpcg/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
  creating build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
  copying scipy/sparse/csgraph/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
  copying scipy/sparse/csgraph/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
  copying scipy/sparse/csgraph/_validation.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
  copying scipy/sparse/csgraph/_laplacian.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
  creating build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/_spherical_voronoi.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/setup.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/__init__.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/kdtree.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/_plotutils.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/distance.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  copying scipy/spatial/_procrustes.py -> build/lib.linux-aarch64-3.6/scipy/spatial
  creating build/lib.linux-aarch64-3.6/scipy/spatial/transform
  copying scipy/spatial/transform/setup.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
  copying scipy/spatial/transform/__init__.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
  copying scipy/spatial/transform/_rotation_spline.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
  copying scipy/spatial/transform/rotation.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
  creating build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/sf_error.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/_mptestutils.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/orthogonal.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/_logsumexp.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/_testutils.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/basic.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/_spherical_bessel.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/setup.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/__init__.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/lambertw.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/add_newdocs.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/spfun_stats.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/_generate_pyx.py -> build/lib.linux-aarch64-3.6/scipy/special
  copying scipy/special/_ellip_harm.py -> build/lib.linux-aarch64-3.6/scipy/special
  creating build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/utils.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/struve_convergence.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/gammainc_asy.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/setup.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/__init__.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/lambertw.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/expn_asy.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/zetac.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/loggamma.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  copying scipy/special/_precompute/gammainc_data.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
  creating build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/morestats.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/kde.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_hypotests.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/mstats_extras.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_binned_statistic.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/vonmises.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_distr_params.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_distn_infrastructure.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_continuous_distns.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_constants.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/stats.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_tukeylambda_stats.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_stats_mstats_common.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/distributions.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/contingency.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_discrete_distns.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/setup.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/mstats_basic.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/__init__.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_multivariate.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/mstats.py -> build/lib.linux-aarch64-3.6/scipy/stats
  copying scipy/stats/_rvs_sampling.py -> build/lib.linux-aarch64-3.6/scipy/stats
  creating build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/measurements.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/_ni_support.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/interpolation.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/morphology.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/_ni_docstrings.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/fourier.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/setup.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/__init__.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  copying scipy/ndimage/filters.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
  creating build/lib.linux-aarch64-3.6/scipy/_build_utils
  copying scipy/_build_utils/_fortran.py -> build/lib.linux-aarch64-3.6/scipy/_build_utils
  copying scipy/_build_utils/__init__.py -> build/lib.linux-aarch64-3.6/scipy/_build_utils
  copying scipy/_build_utils/system_info.py -> build/lib.linux-aarch64-3.6/scipy/_build_utils
  creating build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_numpy_compat.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_gcutils.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_version.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_util.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_ccallback.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_threadsafety.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_testutils.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/decorator.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/six.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/setup.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/__init__.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/_tmpdirs.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  copying scipy/_lib/doccer.py -> build/lib.linux-aarch64-3.6/scipy/_lib
  running build_clib
  customize UnixCCompiler using build_clib
  building 'dfftpack' library
  Running from scipy source directory.
  /usr/local/lib/python3.6/dist-packages/numpy/distutils/system_info.py:731: UserWarning: Specified path /usr/local/include/python3.6m is invalid.
    return self.get_paths(self.section, key)
  error: library dfftpack has Fortran sources but no Fortran compiler found
  ERROR: Failed building wheel for scipy
  Running setup.py clean for scipy
  ERROR: Complete output from command /usr/bin/python3 -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-z11iau_5/scipy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all:
  ERROR:
  `setup.py clean` is not supported, use one of the following instead:
    - `git clean -xdf` (cleans all files)
    - `git clean -Xdf` (cleans all versioned files, doesn't touch
                        files that aren't checked into the git repo)
  Add `--force` to your command to use it anyway if you must (unsupported).
  ERROR: Failed cleaning build dir for scipy
Failed to build scipy
ERROR: Could not build wheels for scipy which use PEP 517 and cannot be installed directly
What do I do wrong?
Thank you…
I imagine you can fix this with
sudo apt update
sudo apt install gfortran
You will need gfortran and lapack/blas to install scipy.
Please check this topic for details:
[url]https://devtalk.nvidia.com/default/topic/1049684/jetson-nano/errors-during-install-sklearn-/[/url]
