Scipy not getting installed on Jetson Nano inspite of all dependencies
I am using the latest JetPack version on my jetson Nano. Inspite of having all the dependencies required for Scipy, I am not able to get it installed.
I am using sudo pip3 install scipy to install it. And following is the error trace I am getting:
[code]$ sudo pip3 install scipy
Collecting scipy
Using cached https://files.pythonhosted.org/packages/04/ab/e2eb3e3f90b9363040a3d885ccc5c79fe20c5b8a3caa8fe3bf47ff653260/scipy-1.4.1.tar.gz
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing wheel metadata … done
Building wheels for collected packages: scipy
Building wheel for scipy (PEP 517) … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmphu0rr_di
cwd: /tmp/pip-install-ad6_yj9u/scipy
Complete output (4884 lines):
lapack_opt_info:
lapack_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
openblas_lapack_info:
libraries openblas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
flame_info:
libraries flame not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_3_10_threads_info:
Setting PTATLAS=ATLAS
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu/atlas
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class ‘numpy.distutils.system_info.atlas_3_10_threads_info’>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class ‘numpy.distutils.system_info.atlas_3_10_info’>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class ‘numpy.distutils.system_info.atlas_threads_info’>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class ‘numpy.distutils.system_info.atlas_info’>
get_default_fcompiler: matching types: ‘[‘gnu95’, ‘intel’, ‘lahey’, ‘pg’, ‘absoft’, ‘nag’, ‘vast’, ‘compaq’, ‘intele’, ‘intelem’, ‘gnu’, ‘g95’, ‘pathf95’, ‘nagfor’]’
customize Gnu95FCompiler
Found executable /usr/bin/gfortran
customize Gnu95FCompiler using config
compiling ‘_configtest.c’:
/* This file is generated from numpy/distutils/system_info.py */
void ATL_buildinfo(void);
int main(void) {
ATL_buildinfo();
return 0;
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: ‘-c’
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -lf77blas -lcblas -latlas -o _configtest
FOUND:
language = f77
libraries = [‘lapack’, ‘f77blas’, ‘cblas’, ‘atlas’, ‘f77blas’, ‘cblas’]
library_dirs = [‘/usr/lib/aarch64-linux-gnu’]
define_macros = [(‘NO_ATLAS_INFO’, -1)]
FOUND:
  language = f77
  libraries = ['lapack', 'f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
  library_dirs = ['/usr/lib/aarch64-linux-gnu']
  define_macros = [('NO_ATLAS_INFO', -1)]
non-existing path in ‘scipy/fft/_pocketfft’: ‘/home/pyimagesearch/.local/include/python3.6m’
non-existing path in ‘scipy/fft/_pocketfft’: ‘/usr/local/include/python3.6’
non-existing path in ‘scipy/interpolate’: ‘src/multipack.h’
Splitting linalg.interpolative Fortran source files
blas_opt_info:
blas_mkl_info:
NOT AVAILABLE
blis_info:
libraries blis not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
openblas_info:
NOT AVAILABLE
atlas_3_10_blas_threads_info:
libraries tatlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu/atlas’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu/atlas’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu/atlas’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
atlas_blas_info:
int main(void) {
ATL_buildinfo();
return 0;
FOUND:
language = c
define_macros = [(‘HAVE_CBLAS’, None), (‘NO_ATLAS_INFO’, -1)]
libraries = [‘f77blas’, ‘cblas’, ‘atlas’, ‘f77blas’, ‘cblas’]
FOUND:
  language = c
  define_macros = [('HAVE_CBLAS', None), ('NO_ATLAS_INFO', -1)]
  libraries = ['f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
[makenpz] scipy/special/tests/data/boost.npz not rebuilt
[makenpz] scipy/special/tests/data/gsl.npz not rebuilt
[makenpz] scipy/special/tests/data/local.npz not rebuilt
non-existing path in ‘scipy/signal/windows’: ‘tests’
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
building library “mach” sources
building library “quadpack” sources
building library “lsoda” sources
building library “vode” sources
building library “dop” sources
building library “fitpack” sources
building library “fwrappers” sources
building library “odrpack” sources
building library “minpack” sources
building library “rectangular_lsap” sources
building library “rootfind” sources
building library “superlu_src” sources
building library “arpack_scipy” sources
building library “sc_cephes” sources
building library “sc_mach” sources
building library “sc_amos” sources
building library “sc_cdf” sources
building library “sc_specfun” sources
building library “statlib” sources
building extension “scipy.cluster._vq” sources
building extension “scipy.cluster._hierarchy” sources
building extension “scipy.cluster._optimal_leaf_ordering” sources
building extension “scipy.fft._pocketfft.pypocketfft” sources
building extension “scipy.fftpack.convolve” sources
building extension “scipy.integrate._quadpack” sources
building extension “scipy.integrate._odepack” sources
building extension “scipy.integrate.vode” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/integrate/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/integrate’ to include_dirs.
building extension “scipy.integrate.lsoda” sources
f2py options:
building extension “scipy.integrate._dop” sources
f2py options:
building extension “scipy.integrate._test_multivariate” sources
building extension “scipy.integrate._test_odeint_banded” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/scipy/integrate/_test_odeint_banded-f2pywrappers.f’ to sources.
building extension “scipy.interpolate.interpnd” sources
building extension “scipy.interpolate._ppoly” sources
building extension “scipy.interpolate._bspl” sources
building extension “scipy.interpolate._fitpack” sources
building extension “scipy.interpolate.dfitpack” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/interpolate/src/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/interpolate/src’ to include_dirs.
adding ‘build/src.linux-aarch64-3.6/scipy/interpolate/src/dfitpack-f2pywrappers.f’ to sources.
building extension “scipy.io._test_fortran” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/io/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/io’ to include_dirs.
building extension “scipy.io.matlab.streams” sources
building extension “scipy.io.matlab.mio_utils” sources
building extension “scipy.io.matlab.mio5_utils” sources
building extension “scipy.linalg._fblas” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg’ to include_dirs.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/_fblas-f2pywrappers.f’ to sources.
building extension “scipy.linalg._flapack” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/_flapack-f2pywrappers.f’ to sources.
building extension “scipy.linalg._flinalg” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg’ to include_dirs.
building extension “scipy.linalg._interpolative” sources
f2py options:
building extension “scipy.linalg._solve_toeplitz” sources
building extension “scipy.linalg.cython_blas” sources
building extension “scipy.linalg.cython_lapack” sources
building extension “scipy.linalg._decomp_update” sources
building extension “scipy.odr.__odrpack” sources
building extension “scipy.optimize._minpack” sources
building extension “scipy.optimize._lsap_module” sources
building extension “scipy.optimize._zeros” sources
building extension “scipy.optimize._lbfgsb” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/lbfgsb_src/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/lbfgsb_src’ to include_dirs.
building extension “scipy.optimize.moduleTNC” sources
building extension “scipy.optimize._cobyla” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/cobyla/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/cobyla’ to include_dirs.
building extension “scipy.optimize.minpack2” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/minpack2/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/minpack2’ to include_dirs.
building extension “scipy.optimize._slsqp” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/slsqp/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/slsqp’ to include_dirs.
building extension “scipy.optimize._nnls” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/nnls/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/nnls’ to include_dirs.
building extension “scipy.optimize._group_columns” sources
building extension “scipy.optimize._bglu_dense” sources
building extension “scipy.optimize._lsq.givens_elimination” sources
building extension “scipy.optimize._trlib._trlib” sources
building extension “scipy.optimize.cython_optimize._zeros” sources
building extension “scipy.signal.sigtools” sources
building extension “scipy.signal._spectral” sources
building extension “scipy.signal._max_len_seq_inner” sources
building extension “scipy.signal._peak_finding_utils” sources
building extension “scipy.signal._sosfilt” sources
building extension “scipy.signal._upfirdn_apply” sources
building extension “scipy.signal.spline” sources
building extension “scipy.sparse.linalg.isolve._iterative” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/isolve/iterative/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/isolve/iterative’ to include_dirs.
building extension “scipy.sparse.linalg.dsolve._superlu” sources
building extension “scipy.sparse.linalg.eigen.arpack._arpack” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack’ to include_dirs.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack/_arpack-f2pywrappers.f’ to sources.
building extension “scipy.sparse.csgraph._shortest_path” sources
building extension “scipy.sparse.csgraph._traversal” sources
building extension “scipy.sparse.csgraph._min_spanning_tree” sources
building extension “scipy.sparse.csgraph._matching” sources
building extension “scipy.sparse.csgraph._flow” sources
building extension “scipy.sparse.csgraph._reordering” sources
building extension “scipy.sparse.csgraph._tools” sources
building extension “scipy.sparse._csparsetools” sources
building extension “scipy.sparse._sparsetools” sources
[generate_sparsetools] ‘scipy/sparse/sparsetools/bsr_impl.h’ already up-to-date
[generate_sparsetools] ‘scipy/sparse/sparsetools/csr_impl.h’ already up-to-date
[generate_sparsetools] ‘scipy/sparse/sparsetools/csc_impl.h’ already up-to-date
[generate_sparsetools] ‘scipy/sparse/sparsetools/other_impl.h’ already up-to-date
[generate_sparsetools] ‘scipy/sparse/sparsetools/sparsetools_impl.h’ already up-to-date
building extension “scipy.spatial.qhull” sources
building extension “scipy.spatial.ckdtree” sources
building extension “scipy.spatial._distance_wrap” sources
building extension “scipy.spatial._voronoi” sources
building extension “scipy.spatial._hausdorff” sources
building extension “scipy.special.specfun” sources
f2py options: [‘–no-wrap-functions’]
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/special/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/special’ to include_dirs.
building extension “scipy.special._ufuncs” sources
building extension “scipy.special._ufuncs_cxx” sources
building extension “scipy.special._ellip_harm_2” sources
building extension “scipy.special.cython_special” sources
building extension “scipy.special._comb” sources
building extension “scipy.special._test_round” sources
building extension “scipy.stats.statlib” sources
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/stats/fortranobject.c’ to sources.
adding ‘build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/stats’ to include_dirs.
building extension “scipy.stats._stats” sources
building extension “scipy.stats.mvn” sources
f2py options:
adding ‘build/src.linux-aarch64-3.6/scipy/stats/mvn-f2pywrappers.f’ to sources.
building extension “scipy.ndimage._nd_image” sources
building extension “scipy.ndimage._ni_label” sources
building extension “scipy.ndimage._ctest” sources
building extension “scipy.ndimage._ctest_oldapi” sources
building extension “scipy.ndimage._cytest” sources
building extension “scipy._lib._ccallback_c” sources
building extension “scipy._lib._test_ccallback” sources
building extension “scipy._lib._fpumode” sources
building extension “scipy._lib.messagestream” sources
building extension “scipy._lib._uarray._uarray” sources
building data_files sources
build_src: building npy-pkg config files
running build_py
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/scipy
copying scipy/_distributor_init.py → build/lib.linux-aarch64-3.6/scipy
copying scipy/conftest.py → build/lib.linux-aarch64-3.6/scipy
copying scipy/init.py → build/lib.linux-aarch64-3.6/scipy
copying scipy/setup.py → build/lib.linux-aarch64-3.6/scipy
copying scipy/version.py → build/lib.linux-aarch64-3.6/scipy
copying build/src.linux-aarch64-3.6/scipy/config.py → build/lib.linux-aarch64-3.6/scipy
creating build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/vq.py → build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/hierarchy.py → build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/init.py → build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/setup.py → build/lib.linux-aarch64-3.6/scipy/cluster
creating build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/constants.py → build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/init.py → build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/setup.py → build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/codata.py → build/lib.linux-aarch64-3.6/scipy/constants
creating build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/_basic.py → build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/_realtransforms.py → build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/_backend.py → build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/init.py → build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/_helper.py → build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/setup.py → build/lib.linux-aarch64-3.6/scipy/fft
copying scipy/fft/_debug_backends.py → build/lib.linux-aarch64-3.6/scipy/fft
creating build/lib.linux-aarch64-3.6/scipy/fft/_pocketfft
copying scipy/fft/_pocketfft/basic.py → build/lib.linux-aarch64-3.6/scipy/fft/_pocketfft
copying scipy/fft/_pocketfft/realtransforms.py → build/lib.linux-aarch64-3.6/scipy/fft/_pocketfft
copying scipy/fft/_pocketfft/init.py → build/lib.linux-aarch64-3.6/scipy/fft/_pocketfft
copying scipy/fft/_pocketfft/setup.py → build/lib.linux-aarch64-3.6/scipy/fft/_pocketfft
copying scipy/fft/_pocketfft/helper.py → build/lib.linux-aarch64-3.6/scipy/fft/_pocketfft
creating build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/basic.py → build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/realtransforms.py → build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/pseudo_diffs.py → build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/init.py → build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/setup.py → build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/helper.py → build/lib.linux-aarch64-3.6/scipy/fftpack
creating build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/_bvp.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/quadpack.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/odepack.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/quadrature.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/_ode.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/_quad_vec.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/init.py → build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/setup.py → build/lib.linux-aarch64-3.6/scipy/integrate
creating build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/bdf.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/common.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/rk.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/dop853_coefficients.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/init.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/lsoda.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/radau.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/base.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/ivp.py → build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
creating build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_bsplines.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_pade.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_fitpack_impl.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/interpolate.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/interpnd_info.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/polyint.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/fitpack.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/init.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_cubic.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/setup.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/rbf.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/ndgriddata.py → build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/fitpack2.py → build/lib.linux-aarch64-3.6/scipy/interpolate
creating build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/idl.py → build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/wavfile.py → build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/_fortran.py → build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/netcdf.py → build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/init.py → build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/mmio.py → build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/setup.py → build/lib.linux-aarch64-3.6/scipy/io
creating build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/miobase.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/byteordercodes.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio4.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/init.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio5.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/setup.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio5_params.py → build/lib.linux-aarch64-3.6/scipy/io/matlab
creating build/lib.linux-aarch64-3.6/scipy/io/arff
copying scipy/io/arff/arffread.py → build/lib.linux-aarch64-3.6/scipy/io/arff
copying scipy/io/arff/init.py → build/lib.linux-aarch64-3.6/scipy/io/arff
copying scipy/io/arff/setup.py → build/lib.linux-aarch64-3.6/scipy/io/arff
creating build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/_fortran_format_parser.py → build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/init.py → build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/hb.py → build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/setup.py → build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
creating build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/blas.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_generate_pyx.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_cython_signature_generator.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_expm_frechet.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/basic.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/interpolative.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_interpolative_backend.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_lu.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_matfuncs_inv_ssq.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/flinalg.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/lapack.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_decomp_ldl.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/misc.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_solvers.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_decomp_qz.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_sketches.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/special_matrices.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/linalg_version.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_matfuncs_sqrtm.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_cholesky.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/init.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/matfuncs.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_procrustes.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/setup.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_qr.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_svd.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_testutils.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_schur.py → build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_decomp_polar.py → build/lib.linux-aarch64-3.6/scipy/linalg
creating build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/common.py → build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/doccer.py → build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/init.py → build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/setup.py → build/lib.linux-aarch64-3.6/scipy/misc
creating build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/add_newdocs.py → build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/odrpack.py → build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/models.py → build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/init.py → build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/setup.py → build/lib.linux-aarch64-3.6/scipy/odr
creating build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_basinhopping.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/slsqp.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/linesearch.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_root_scalar.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_simplex.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_minimize.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_tstutils.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_dogleg.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/optimize.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_shgo.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_dual_annealing.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_util.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_krylov.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/cobyla.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/lbfgsb.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_ip.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/zeros.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_ncg.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/minpack.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_hessian_update_strategy.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/nnls.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/nonlin.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_lsap.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/tnc.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_constraints.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_remove_redundancy.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_spectral.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/init.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_exact.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_numdiff.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_root.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_differentiable_functions.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_differentialevolution.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/setup.py → build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_rs.py → build/lib.linux-aarch64-3.6/scipy/optimize
creating build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/common.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/trf.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/trf_linear.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/bvls.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/least_squares.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/dogbox.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/init.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/setup.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/lsq_linear.py → build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
creating build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
copying scipy/optimize/_trlib/init.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
copying scipy/optimize/_trlib/setup.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
creating build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/canonical_constraint.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/qp_subproblem.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/report.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/tr_interior_point.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/projections.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/init.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/minimize_trustregion_constr.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/setup.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/equality_constrained_sqp.py → build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
creating build/lib.linux-aarch64-3.6/scipy/optimize/cython_optimize
copying scipy/optimize/cython_optimize/init.py → build/lib.linux-aarch64-3.6/scipy/optimize/cython_optimize
creating build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
copying scipy/optimize/_shgo_lib/sobol_seq.py → build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
copying scipy/optimize/_shgo_lib/triangulation.py → build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
copying scipy/optimize/_shgo_lib/init.py → build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
creating build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_arraytools.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_savitzky_golay.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/lti_conversion.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_upfirdn.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/waveforms.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/bsplines.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/spectral.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/filter_design.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/fir_filter_design.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/signaltools.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_peak_finding.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/wavelets.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/init.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/ltisys.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_max_len_seq.py → build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/setup.py → build/lib.linux-aarch64-3.6/scipy/signal
creating build/lib.linux-aarch64-3.6/scipy/signal/windows
copying scipy/signal/windows/init.py → build/lib.linux-aarch64-3.6/scipy/signal/windows
copying scipy/signal/windows/windows.py → build/lib.linux-aarch64-3.6/scipy/signal/windows
copying scipy/signal/windows/setup.py → build/lib.linux-aarch64-3.6/scipy/signal/windows
creating build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/csr.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/extract.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/coo.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/lil.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/construct.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/csc.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/generate_sparsetools.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/sparsetools.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/data.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/_index.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/spfuncs.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/dia.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/_matrix_io.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/compressed.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/sputils.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/init.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/base.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/bsr.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/dok.py → build/lib.linux-aarch64-3.6/scipy/sparse
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/_onenormest.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/interface.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/_expm_multiply.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/_norm.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/matfuncs.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/lsqr.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/lsmr.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/utils.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/lgmres.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/minres.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/_gcrotmk.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/iterative.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/linsolve.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/_add_newdocs.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
copying scipy/sparse/linalg/eigen/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
copying scipy/sparse/linalg/eigen/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
copying scipy/sparse/linalg/eigen/arpack/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
copying scipy/sparse/linalg/eigen/arpack/arpack.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
copying scipy/sparse/linalg/eigen/arpack/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
copying scipy/sparse/linalg/eigen/lobpcg/lobpcg.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
copying scipy/sparse/linalg/eigen/lobpcg/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
copying scipy/sparse/linalg/eigen/lobpcg/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
creating build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/_laplacian.py → build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/_validation.py → build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/init.py → build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/setup.py → build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
creating build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/distance.py → build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/_plotutils.py → build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/kdtree.py → build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/init.py → build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/_spherical_voronoi.py → build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/_procrustes.py → build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/setup.py → build/lib.linux-aarch64-3.6/scipy/spatial
creating build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/_rotation_spline.py → build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/_rotation_groups.py → build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/rotation.py → build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/init.py → build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/setup.py → build/lib.linux-aarch64-3.6/scipy/spatial/transform
creating build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_generate_pyx.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/lambertw.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/basic.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/sf_error.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_basic.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/add_newdocs.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/spfun_stats.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_mptestutils.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_ellip_harm.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/init.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_logsumexp.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_spherical_bessel.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/setup.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_testutils.py → build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/orthogonal.py → build/lib.linux-aarch64-3.6/scipy/special
creating build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/gammainc_data.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/lambertw.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/struve_convergence.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/wrightomega.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/zetac.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/utils.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/loggamma.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/gammainc_asy.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/init.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/expn_asy.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/setup.py → build/lib.linux-aarch64-3.6/scipy/special/_precompute
creating build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_discrete_distns.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_binned_statistic.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/contingency.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_multivariate.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/stats.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/vonmises.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/mstats.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_tukeylambda_stats.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_hypotests.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/morestats.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_stats_mstats_common.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/mstats_basic.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_constants.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_distn_infrastructure.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/mstats_extras.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/init.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_rvs_sampling.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_distr_params.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/distributions.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/setup.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_continuous_distns.py → build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/kde.py → build/lib.linux-aarch64-3.6/scipy/stats
creating build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/filters.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/morphology.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/_ni_support.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/measurements.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/fourier.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/_ni_docstrings.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/interpolation.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/init.py → build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/setup.py → build/lib.linux-aarch64-3.6/scipy/ndimage
creating build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/_fortran.py → build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/system_info.py → build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/init.py → build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/setup.py → build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/compiler_helper.py → build/lib.linux-aarch64-3.6/scipy/_build_utils
creating build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_pep440.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_version.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_tmpdirs.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_ccallback.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_util.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/uarray.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_numpy_compat.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/doccer.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/init.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/six.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/setup.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/decorator.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_threadsafety.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_testutils.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_gcutils.py → build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/deprecation.py → build/lib.linux-aarch64-3.6/scipy/_lib
creating build/lib.linux-aarch64-3.6/scipy/_lib/_uarray
copying scipy/_lib/_uarray/_backend.py → build/lib.linux-aarch64-3.6/scipy/_lib/_uarray
copying scipy/_lib/_uarray/init.py → build/lib.linux-aarch64-3.6/scipy/_lib/_uarray
copying scipy/_lib/_uarray/setup.py → build/lib.linux-aarch64-3.6/scipy/_lib/_uarray
running build_clib
customize UnixCCompiler using build_clib
customize Gnu95FCompiler using build_clib
building ‘mach’ library
using additional config_fc from setup script for fortran compiler: {‘noopt’: (‘scipy/integrate/setup.py’, 1)}
compiling Fortran sources
Fortran f77 compiler: /usr/bin/gfortran -Wall -g -ffixed-form -fno-second-underscore -fPIC
Fortran f90 compiler: /usr/bin/gfortran -Wall -g -fno-second-underscore -fPIC
Fortran fix compiler: /usr/bin/gfortran -Wall -g -ffixed-form -fno-second-underscore -Wall -g -fno-second-underscore -fPIC
creating build/temp.linux-aarch64-3.6
creating build/temp.linux-aarch64-3.6/scipy
creating build/temp.linux-aarch64-3.6/scipy/integrate
creating build/temp.linux-aarch64-3.6/scipy/integrate/mach
compile options: ‘-I/usr/local/lib/python3.6/dist-packages/numpy/core/include -c’
gfortran:f77: scipy/integrate/mach/xerror.f
gfortran:f77: scipy/integrate/mach/d1mach.f
scipy/integrate/mach/xerror.f:1:37:
     SUBROUTINE XERROR(MESS,NMESS,L1,L2)
                                   1
Warning: Unused dummy argument ‘l1’ at (1) [-Wunused-dummy-argument]
scipy/integrate/mach/xerror.f:1:40:
                                      1
Warning: Unused dummy argument ‘l2’ at (1) [-Wunused-dummy-argument]
aarch64-linux-gnu-gcc-ar: adding 2 object files to build/temp.linux-aarch64-3.6/libmach.a
building ‘quadpack’ library
Fortran f77 compiler: /usr/bin/gfortran -Wall -g -ffixed-form -fno-second-underscore -fPIC -O3 -funroll-loops
Fortran f90 compiler: /usr/bin/gfortran -Wall -g -fno-second-underscore -fPIC -O3 -funroll-loops
Fortran fix compiler: /usr/bin/gfortran -Wall -g -ffixed-form -fno-second-underscore -Wall -g -fno-second-underscore -fPIC -O3 -funroll-loops
creating build/temp.linux-aarch64-3.6/scipy/integrate/quadpack
gfortran:f77: scipy/integrate/quadpack/dqag.f
gfortran:f77: scipy/integrate/quadpack/dqagie.f
gfortran:f77: scipy/integrate/quadpack/dqags.f
gfortran:f77: scipy/integrate/quadpack/dqawce.f
gfortran:f77: scipy/integrate/quadpack/dqage.f
gfortran:f77: scipy/integrate/quadpack/dqagse.f
scipy/integrate/quadpack/dqagie.f:411:0:
       small = small*0.5d+00
Warning: ‘small’ may be used uninitialized in this function [-Wmaybe-uninitialized]
scipy/integrate/quadpack/dqagie.f:372:0:
  40   if(ierro.eq.3.or.erlarg.le.ertest) go to 60
Warning: ‘ertest’ may be used uninitialized in this function [-Wmaybe-uninitialized]
scipy/integrate/quadpack/dqagie.f:362:0:
       erlarg = erlarg-erlast
Warning: ‘erlarg’ may be used uninitialized in this function [-Wmaybe-uninitialized]
scipy/integrate/quadpack/dqagie.f:425:0:
     if(ierro.eq.3) abserr = abserr+correc
Warning: ‘correc’ may be used uninitialized in this function [-Wmaybe-uninitialized]
scipy/integrate/quadpack/dqagse.f:404:0:
scipy/integrate/quadpack/dqagse.f:363:0:
scipy/integrate/quadpack/dqagse.f:353:0:
scipy/integrate/quadpack/dqagse.f:418:0:
gfortran:f77: scipy/integrate/quadpack/dqawf.f
gfortran:f77: scipy/integrate/quadpack/dqawfe.f
gfortran:f77: scipy/integrate/quadpack/dqagi.f
scipy/integrate/quadpack/dqawfe.f:267:10:
  10 l = dabs(omega)
        1
Warning: Possible change of value in conversion from REAL(8) to INTEGER(4) at (1) [-Wconversion]
scipy/integrate/quadpack/dqawfe.f:358:0:
     if(ier.ge.1.and.ier.ne.7) abserr = abserr+drl
Warning: ‘drl’ may be used uninitialized in this function [-Wmaybe-uninitialized]
scipy/integrate/quadpack/dqawfe.f:316:0:
  20   psum(numrl2) = psum(ll)+rslst(lst)
Warning: ‘ll’ may be used uninitialized in this function [-Wmaybe-uninitialized]
gfortran:f77: scipy/integrate/quadpack/dqawo.f
gfortran:f77: scipy/integrate/quadpack/dqagp.f
gfortran:f77: scipy/integrate/quadpack/dqawoe.f
gfortran:f77: scipy/integrate/quadpack/dqawc.f
gfortran:f77: scipy/integrate/quadpack/dqawse.f
gfortran:f77: scipy/integrate/quadpack/dqagpe.f
gfortran:f77: scipy/integrate/quadpack/dqc25s.f
scipy/integrate/quadpack/dqawoe.f:449:0:
  70   if(ierro.eq.3.or.erlarg.le.ertest) go to 90
scipy/integrate/quadpack/dqawoe.f:428:0:
scipy/integrate/quadpack/dqawoe.f:505:0:
scipy/integrate/quadpack/dqagpe.f:350:0:
       iord(k) = iord(i)
Warning: ‘k’ may be used uninitialized in this function [-Wmaybe-uninitialized]
gfortran:f77: scipy/integrate/quadpack/dqc25c.f
gfortran:f77: scipy/integrate/quadpack/dqc25f.f
gfortran:f77: scipy/integrate/quadpack/dqaws.f
gfortran:f77: scipy/integrate/quadpack/dqk15.f
scipy/integrate/quadpack/dqc25f.f:103:0:
     integer i,iers,integr,isym,j,k,ksave,m,momcom,neval,maxp1,
Warning: ‘m’ may be used uninitialized in this function [-Wmaybe-uninitialized]
gfortran:f77: scipy/integrate/quadpack/dqk15i.f
gfortran:f77: scipy/integrate/quadpack/dqk21.f
gfortran:f77: scipy/integrate/quadpack/dqcheb.f
gfortran:f77: scipy/integrate/quadpack/dqk15w.f
gfortran:f77: scipy/integrate/quadpack/dqk31.f
gfortran:f77: scipy/integrate/quadpack/dqelg.f
gfortran:f77: scipy/integrate/quadpack/dqk51.f
gfortran:f77: scipy/integrate/quadpack/dqng.f
gfortran:f77: scipy/integrate/quadpack/dqk41.f
gfortran:f77: scipy/integrate/quadpack/dqk61.f
gfortran:f77: scipy/integrate/quadpack/dqwgtf.f
scipy/integrate/quadpack/dqwgtf.f:1:49:
     double precision function dqwgtf(x,omega,p2,p3,p4,integr)
                                               1
Warning: Unused dummy argument ‘p2’ at (1) [-Wunused-dummy-argument]
scipy/integrate/quadpack/dqwgtf.f:1:52:
                                                  1
Warning: Unused dummy argument ‘p3’ at (1) [-Wunused-dummy-argument]
scipy/integrate/quadpack/dqwgtf.f:1:55:
                                                     1
Warning: Unused dummy argument ‘p4’ at (1) [-Wunused-dummy-argument]
gfortran:f77: scipy/integrate/quadpack/dqwgts.f
gfortran:f77: scipy/integrate/quadpack/dqmomo.f
scipy/integrate/quadpack/dqmomo.f:126:5:
  90 return
   1
Warning: Label 90 at (1) defined but not used [-Wunused-label]
gfortran:f77: scipy/integrate/quadpack/dqpsrt.f
gfortran:f77: scipy/integrate/quadpack/dqwgtc.f
scipy/integrate/quadpack/dqwgtc.f:1:54:
     double precision function dqwgtc(x,c,p2,p3,p4,kp)
                                                    1
Warning: Unused dummy argument ‘kp’ at (1) [-Wunused-dummy-argument]
scipy/integrate/quadpack/dqwgtc.f:1:45:
                                           1
scipy/integrate/quadpack/dqwgtc.f:1:48:
                                              1
scipy/integrate/quadpack/dqwgtc.f:1:51:
                                                 1
aarch64-linux-gnu-gcc-ar: adding 35 object files to build/temp.linux-aarch64-3.6/libquadpack.a
building ‘lsoda’ library
creating build/temp.linux-aarch64-3.6/scipy/integrate/odepack
gfortran:f77: scipy/integrate/odepack/blkdta000.f
gfortran:f77: scipy/integrate/odepack/ewset.f
gfortran:f77: scipy/integrate/odepack/cfode.f
gfo
You will need to build scipy from source for the Jetson.
Please check this comment for the detail:
https://devtalk.nvidia.com/default/topic/1066391/jetson-nano/keras-and-scipy-throwing-weird-errors-while-installing-on-jetson-nano-no-links-could-help-me-/post/5415052/#5415052
Thanks for passing that along. I will try that and will get back to you.
Is this for the new JetPack update because I remember not having built scipy from scratch for the earlier versions of jetPack?
Well I followed the instructions from the link you mentioned and here’s the last part of the installation log:
copying THANKS.txt -> build/bdist.linux-aarch64/egg/scipy
copying LICENSE.txt -> build/bdist.linux-aarch64/egg/scipy
copying HACKING.rst.txt -> build/bdist.linux-aarch64/egg/scipy
copying INSTALL.rst.txt -> build/bdist.linux-aarch64/egg/scipy
running install_clib
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying scipy.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying scipy.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying scipy.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying scipy.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
writing build/bdist.linux-aarch64/egg/EGG-INFO/native_libs.txt
zip_safe flag not set; analyzing archive contents...
scipy.__pycache__.__config__.cpython-36: module references __file__
scipy._build_utils.__pycache__._fortran.cpython-36: module references __file__
scipy._lib.__pycache__._ccallback_c.cpython-36: module references __file__
scipy._lib.__pycache__._fpumode.cpython-36: module references __file__
scipy._lib.__pycache__._numpy_compat.cpython-36: module references __file__
scipy._lib.__pycache__._test_ccallback.cpython-36: module references __file__
scipy._lib.__pycache__._testutils.cpython-36: module references __path__
scipy._lib.__pycache__.messagestream.cpython-36: module references __file__
scipy._lib.__pycache__.setup.cpython-36: module references __file__
scipy.cluster.__pycache__._hierarchy.cpython-36: module references __file__
scipy.cluster.__pycache__._optimal_leaf_ordering.cpython-36: module references __file__
scipy.cluster.__pycache__._vq.cpython-36: module references __file__
scipy.fftpack.__pycache__._fftpack.cpython-36: module references __file__
scipy.fftpack.__pycache__.convolve.cpython-36: module references __file__
scipy.integrate.__pycache__._dop.cpython-36: module references __file__
scipy.integrate.__pycache__._odepack.cpython-36: module references __file__
scipy.integrate.__pycache__._quadpack.cpython-36: module references __file__
scipy.integrate.__pycache__._test_multivariate.cpython-36: module references __file__
scipy.integrate.__pycache__._test_odeint_banded.cpython-36: module references __file__
scipy.integrate.__pycache__.lsoda.cpython-36: module references __file__
scipy.integrate.__pycache__.setup.cpython-36: module references __file__
scipy.integrate.__pycache__.vode.cpython-36: module references __file__
scipy.interpolate.__pycache__._bspl.cpython-36: module references __file__
scipy.interpolate.__pycache__._fitpack.cpython-36: module references __file__
scipy.interpolate.__pycache__._ppoly.cpython-36: module references __file__
scipy.interpolate.__pycache__.dfitpack.cpython-36: module references __file__
scipy.interpolate.__pycache__.interpnd.cpython-36: module references __file__
scipy.io.__pycache__._test_fortran.cpython-36: module references __file__
scipy.io.matlab.__pycache__.mio5_utils.cpython-36: module references __file__
scipy.io.matlab.__pycache__.mio_utils.cpython-36: module references __file__
scipy.io.matlab.__pycache__.streams.cpython-36: module references __file__
scipy.linalg.__pycache__._decomp_update.cpython-36: module references __file__
scipy.linalg.__pycache__._fblas.cpython-36: module references __file__
scipy.linalg.__pycache__._flapack.cpython-36: module references __file__
scipy.linalg.__pycache__._flinalg.cpython-36: module references __file__
scipy.linalg.__pycache__._generate_pyx.cpython-36: module references __file__
scipy.linalg.__pycache__._interpolative.cpython-36: module references __file__
scipy.linalg.__pycache__._solve_toeplitz.cpython-36: module references __file__
scipy.linalg.__pycache__.cython_blas.cpython-36: module references __file__
scipy.linalg.__pycache__.cython_lapack.cpython-36: module references __file__
scipy.linalg.__pycache__.setup.cpython-36: module references __file__
scipy.misc.__pycache__.common.cpython-36: module references __file__
scipy.ndimage.__pycache__._ctest.cpython-36: module references __file__
scipy.ndimage.__pycache__._ctest_oldapi.cpython-36: module references __file__
scipy.ndimage.__pycache__._cytest.cpython-36: module references __file__
scipy.ndimage.__pycache__._nd_image.cpython-36: module references __file__
scipy.ndimage.__pycache__._ni_label.cpython-36: module references __file__
scipy.ndimage.__pycache__.setup.cpython-36: module references __file__
scipy.odr.__pycache__.__odrpack.cpython-36: module references __file__
scipy.optimize.__pycache__._bglu_dense.cpython-36: module references __file__
scipy.optimize.__pycache__._cobyla.cpython-36: module references __file__
scipy.optimize.__pycache__._group_columns.cpython-36: module references __file__
scipy.optimize.__pycache__._lbfgsb.cpython-36: module references __file__
scipy.optimize.__pycache__._minpack.cpython-36: module references __file__
scipy.optimize.__pycache__._nnls.cpython-36: module references __file__
scipy.optimize.__pycache__._shgo.cpython-36: module references __file__
scipy.optimize.__pycache__._slsqp.cpython-36: module references __file__
scipy.optimize.__pycache__._zeros.cpython-36: module references __file__
scipy.optimize.__pycache__.minpack2.cpython-36: module references __file__
scipy.optimize.__pycache__.moduleTNC.cpython-36: module references __file__
scipy.optimize.__pycache__.setup.cpython-36: module references __file__
scipy.optimize._lsq.__pycache__.givens_elimination.cpython-36: module references __file__
scipy.optimize._trlib.__pycache__._trlib.cpython-36: module references __file__
scipy.optimize._trlib.__pycache__.setup.cpython-36: module references __file__
scipy.optimize.cython_optimize.__pycache__._zeros.cpython-36: module references __file__
scipy.signal.__pycache__._max_len_seq_inner.cpython-36: module references __file__
scipy.signal.__pycache__._peak_finding_utils.cpython-36: module references __file__
scipy.signal.__pycache__._spectral.cpython-36: module references __file__
scipy.signal.__pycache__._upfirdn_apply.cpython-36: module references __file__
scipy.signal.__pycache__.sigtools.cpython-36: module references __file__
scipy.signal.__pycache__.spline.cpython-36: module references __file__
scipy.sparse.__pycache__._csparsetools.cpython-36: module references __file__
scipy.sparse.__pycache__._sparsetools.cpython-36: module references __file__
scipy.sparse.__pycache__.generate_sparsetools.cpython-36: module references __file__
scipy.sparse.__pycache__.setup.cpython-36: module references __file__
scipy.sparse.csgraph.__pycache__._min_spanning_tree.cpython-36: module references __file__
scipy.sparse.csgraph.__pycache__._reordering.cpython-36: module references __file__
scipy.sparse.csgraph.__pycache__._shortest_path.cpython-36: module references __file__
scipy.sparse.csgraph.__pycache__._tools.cpython-36: module references __file__
scipy.sparse.csgraph.__pycache__._traversal.cpython-36: module references __file__
scipy.sparse.linalg.dsolve.__pycache__._superlu.cpython-36: module references __file__
scipy.sparse.linalg.dsolve.__pycache__.setup.cpython-36: module references __file__
scipy.sparse.linalg.eigen.arpack.__pycache__._arpack.cpython-36: module references __file__
scipy.sparse.linalg.isolve.__pycache__._iterative.cpython-36: module references __file__
scipy.spatial.__pycache__._distance_wrap.cpython-36: module references __file__
scipy.spatial.__pycache__._hausdorff.cpython-36: module references __file__
scipy.spatial.__pycache__._voronoi.cpython-36: module references __file__
scipy.spatial.__pycache__.ckdtree.cpython-36: module references __file__
scipy.spatial.__pycache__.qhull.cpython-36: module references __file__
scipy.spatial.__pycache__.setup.cpython-36: module references __file__
scipy.special.__pycache__._comb.cpython-36: module references __file__
scipy.special.__pycache__._ellip_harm_2.cpython-36: module references __file__
scipy.special.__pycache__._generate_pyx.cpython-36: module references __file__
scipy.special.__pycache__._test_round.cpython-36: module references __file__
scipy.special.__pycache__._ufuncs.cpython-36: module references __file__
scipy.special.__pycache__._ufuncs_cxx.cpython-36: module references __file__
scipy.special.__pycache__.cython_special.cpython-36: module references __file__
scipy.special.__pycache__.setup.cpython-36: module references __file__
scipy.special.__pycache__.specfun.cpython-36: module references __file__
scipy.special._precompute.__pycache__.gammainc_asy.cpython-36: module references __file__
scipy.special._precompute.__pycache__.gammainc_data.cpython-36: module references __file__
scipy.stats.__pycache__._stats.cpython-36: module references __file__
scipy.stats.__pycache__.mvn.cpython-36: module references __file__
scipy.stats.__pycache__.statlib.cpython-36: module references __file__
creating dist
creating 'dist/scipy-1.3.3-py3.6-linux-aarch64.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing scipy-1.3.3-py3.6-linux-aarch64.egg
creating /home/pyimagesearch/.local/lib/python3.6/site-packages/scipy-1.3.3-py3.6-linux-aarch64.egg
Extracting scipy-1.3.3-py3.6-linux-aarch64.egg to /home/pyimagesearch/.local/lib/python3.6/site-packages
Adding scipy 1.3.3 to easy-install.pth file
Installed /home/pyimagesearch/.local/lib/python3.6/site-packages/scipy-1.3.3-py3.6-linux-aarch64.egg
Processing dependencies for scipy==1.3.3
Finished processing dependencies for scipy==1.3.3
Now when I am executing:
$ python3
Python 3.6.9 (default, Nov  7 2019, 10:44:02)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import scipy
I am getting:
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'scipy'
But when I run sudo python3 and import scipy it works. This is because I ransudo python3 setup.py install --user while installing scipy.
Good to know it works now. : )
