How can I solve it?
Could you try if you can install it with apt-get?
sudo apt-get install python-scipy
sudo apt-get install python3-scipy
I’m trying to install the fastai library and it needs scipy. When I try to install it using apt-get, it says that the package is not avaliable.
Please try to install it with pip:
sudo apt-get install python-pip
sudo pip install scipy
It doesn’t install. Here is some of the output:
Collecting scipy
Downloading https://files.pythonhosted.org/packages/a9/b4/5598a706697d1e2929eaf7fe68898ef4bea76e4950b9efbe1ef396b8813a/scipy-1.2.1.tar.gz (23.1MB)
Installing collected packages: scipy
Running setup.py install for scipy: started
Running setup.py install for scipy: finished with status 'error'
Complete output from command /usr/bin/python -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-7NQJsJ/scipy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-GqkOlq-record/install-record.txt --single-version-externally-managed --compile:
Note: if you need reliable uninstall behavior, then install
with pip instead of using `setup.py install`:
- `pip install .` (from a git repo or downloaded source
release)
- `pip install scipy` (last SciPy release on PyPI)
Running from scipy source directory.
lapack_opt_info:
lapack_mkl_info:
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_lapack_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
system_info:
NOT AVAILABLE
atlas_3_10_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
/usr/lib/python2.7/dist-packages/numpy/distutils/system_info.py:572: UserWarning:
Atlas (http://math-atlas.sourceforge.net/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [atlas]) or by setting
the ATLAS environment variable.
self.calc_info()
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
self.calc_info()
lapack_src_info:
NOT AVAILABLE
Lapack (http://www.netlib.org/lapack/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
self.calc_info()
NOT AVAILABLE
File "<string>", line 1, in <module>
File "/tmp/pip-build-7NQJsJ/scipy/setup.py", line 492, in <module>
setup_package()
File "/tmp/pip-build-7NQJsJ/scipy/setup.py", line 488, in setup_package
setup(**metadata)
File "/usr/lib/python2.7/dist-packages/numpy/distutils/core.py", line 135, in setup
config = configuration()
File "/tmp/pip-build-7NQJsJ/scipy/setup.py", line 395, in configuration
raise NotFoundError(msg)
numpy.distutils.system_info.NotFoundError: No lapack/blas resources found.
Please check this comment for the solution:
https://devtalk.nvidia.com/default/topic/1049684/jetson-nano/errors-during-install-sklearn-/post/5327807/#5327807
I always try to do apt-get update before installing or upgrading packages. I never read the output but the last time I did and found probably whats wrong. Did some repos move?
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.26 80]
E: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/bionic/main/binary-arm64/Packages 404 Not Found [IP: 91.189.91.26 80]
Could you try to install the library directly?
Sometimes it still works without any issue.
Sudo apt-get -y install python3-scipy
worked for me.
