Error installing seaborn
numpy and matplotlib installed OK, but on trying to install seaborn I get the following:
pip3 install seaborn
Defaulting to user installation because normal site-packages is not writeable
Collecting seaborn
Downloading seaborn-0.10.1-py3-none-any.whl (215 kB)
|████████████████████████████████| 215 kB 1.1 MB/s
Collecting scipy>=1.0.1
Downloading scipy-1.4.1.tar.gz (24.6 MB)
|████████████████████████████████| 24.6 MB 25 kB/s
Installing build dependencies … done
Getting requirements to build wheel … done
Preparing wheel metadata … error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /home/user_1/.local/lib/python3.6/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmpwmkbgj8f
cwd: /tmp/pip-install-301qbx_f/scipy
Complete output (109 lines):
lapack_opt_info:
lapack_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
openblas_lapack_info:
  libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
  NOT AVAILABLE
openblas_clapack_info:
  libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
  NOT AVAILABLE
flame_info:
  libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
  NOT AVAILABLE
atlas_3_10_threads_info:
Setting PTATLAS=ATLAS
  libraries lapack_atlas not found in /usr/local/lib
  libraries tatlas,tatlas not found in /usr/local/lib
  libraries lapack_atlas not found in /usr/lib
  libraries tatlas,tatlas not found in /usr/lib
  libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu
  libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
  NOT AVAILABLE
atlas_3_10_info:
  libraries satlas,satlas not found in /usr/local/lib
  libraries satlas,satlas not found in /usr/lib
  libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_3_10_info'>
  NOT AVAILABLE
atlas_threads_info:
  libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
  libraries ptf77blas,ptcblas,atlas not found in /usr/lib
  libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_threads_info'>
  NOT AVAILABLE
atlas_info:
  libraries f77blas,cblas,atlas not found in /usr/local/lib
  libraries f77blas,cblas,atlas not found in /usr/lib
  libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu
<class 'numpy.distutils.system_info.atlas_info'>
  NOT AVAILABLE
accelerate_info:
  NOT AVAILABLE
lapack_info:
  libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
  NOT AVAILABLE
lapack_src_info:
  NOT AVAILABLE
  NOT AVAILABLE
setup.py:420: UserWarning: Unrecognized setuptools command ('dist_info --egg-base /tmp/pip-modern-metadata-izeuq_bg'), proceeding with generating Cython sources and expanding templates
  ' '.join(sys.argv[1:])))
Running from scipy source directory.
/usr/local/lib/python3.6/dist-packages/numpy/distutils/system_info.py:1730: UserWarning:
    Lapack (http://www.netlib.org/lapack/) libraries not found.
    Directories to search for the libraries can be specified in the
    numpy/distutils/site.cfg file (section [lapack]) or by setting
    the LAPACK environment variable.
  return getattr(self, '_calc_info_{}'.format(name))()
    Lapack (http://www.netlib.org/lapack/) sources not found.
    Directories to search for the sources can be specified in the
    numpy/distutils/site.cfg file (section [lapack_src]) or by setting
    the LAPACK_SRC environment variable.
  File "/home/user_1/.local/lib/python3.6/site-packages/pip/_vendor/pep517/_in_process.py", line 280, in <module>
    main()
  File "/home/user_1/.local/lib/python3.6/site-packages/pip/_vendor/pep517/_in_process.py", line 263, in main
    json_out['return_val'] = hook(**hook_input['kwargs'])
  File "/home/user_1/.local/lib/python3.6/site-packages/pip/_vendor/pep517/_in_process.py", line 133, in prepare_metadata_for_build_wheel
    return hook(metadata_directory, config_settings)
  File "/tmp/pip-build-env-tpebdmy6/overlay/lib/python3.6/site-packages/setuptools/build_meta.py", line 158, in prepare_metadata_for_build_wheel
    self.run_setup()
  File "/tmp/pip-build-env-tpebdmy6/overlay/lib/python3.6/site-packages/setuptools/build_meta.py", line 250, in run_setup
    self).run_setup(setup_script=setup_script)
  File "/tmp/pip-build-env-tpebdmy6/overlay/lib/python3.6/site-packages/setuptools/build_meta.py", line 143, in run_setup
    exec(compile(code, __file__, 'exec'), locals())
  File "setup.py", line 540, in <module>
    setup_package()
  File "setup.py", line 536, in setup_package
    setup(**metadata)
  File "/usr/local/lib/python3.6/dist-packages/numpy/distutils/core.py", line 137, in setup
    config = configuration()
  File "setup.py", line 435, in configuration
    raise NotFoundError(msg)
numpy.distutils.system_info.NotFoundError: No lapack/blas resources found.
ERROR: Command errored out with exit status 1: /usr/bin/python3 /home/user_1/.local/lib/python3.6/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmpwmkbgj8f Check the logs for full command output.
user_1@jetson:~/nano$
Hi @shuntera ,
You can also try to install it directly with the following command:
sudo apt-get install -y python3-seaborn
Regards,
Fabian
www.ridgerun.com
Thanks for that. That got it installed, which was great, but when using ‘import seaborn as sns’ I got this error:
ModuleNotFoundError: No module named ‘numpy.testing.nosetester’
LATER: Well I got round that by finding a reference to uninstalling numpy and installing version numpy==1.17.0 I got a little further this time but now get the error:
/usr/lib/python3/dist-packages/seaborn/categorical.py in
5 from scipy import stats
6 import pandas as pd
----> 7 from pandas.core.series import remove_na
8 import matplotlib as mpl
9 from matplotlib.collections import PatchCollection
ImportError: cannot import name ‘remove_na’
Looks you are missing BLAS libraries. Try sudo apt-get install libopenblas-base libopenblas-dev libblas-dev liblapack-dev libatlas-base-dev gfortran
