I’m new to the Nano but am trying to do something that we regularly do on RPi and other PCs - namely install the Raspberry Pi Meteor System (RMS). The RMS install is fairly straightforward, but it has a dependency on Python >= 3.7. So, the default install Jetson won’t work for me.
What I’ve done is…
- Install Python 3.7 w/ sudo apt install python3.7-dev
1a. I’ve also tried Python 3.8 installed from source - Create a virtual env with python3.7 -m venv vRMS (also tried with --system-site-packages and then pip’ing everything except matplotlib with a -I)
- Enter my venv with source ~/vRMS/bin/activate
- pip install --upgrade pip setuptools wheel (I end up with versions 21.0, 52.0.0, and 0.36.2 respectively)
- pip install numpy
- pip install Pillow
- pip install freetype-py pypng (also installed libfreetype and libpng system-wide)
- pip install gitpython scipy cython pyephem astropy paramiko (relevant to RMS, but doesn’t affect the outcome of the next step)
pip install matplotlib
9a. Try installing matplotlib from source
The output from step 9 (or 9a, for that matter) is…
Collecting matplotlib
Using cached matplotlib-3.3.3.tar.gz (37.9 MB)
ERROR: Command errored out with exit status -4:
command: /home/mike/vRMS/bin/python3.8 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-rezgayjg/matplotlib_c0fbca83fd8b4552a8a22a15a6f02c6d/setup.py'"'"'; __file__='"'"'/tmp/pip-install-rezgayjg/matplotlib_c0fbca83fd8b4552a8a22a15a6f02c6d/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-p8ppq7gy
cwd: /tmp/pip-install-rezgayjg/matplotlib_c0fbca83fd8b4552a8a22a15a6f02c6d/
Complete output (19 lines):
Edit setup.cfg to change the build options; suppress output with --quiet.
BUILDING MATPLOTLIB
matplotlib: yes [3.3.3]
python: yes [3.8.7 (default, Jan 25 2021, 22:49:08) [GCC 7.5.0]]
platform: yes [linux]
sample_data: yes [installing]
tests: no [skipping due to configuration]
macosx: no [Mac OS-X only]
running egg_info
creating /tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info
writing /tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info/PKG-INFO
writing dependency_links to /tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info/dependency_links.txt
writing namespace_packages to /tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info/namespace_packages.txt
writing requirements to /tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info/requires.txt
writing top-level names to /tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info/top_level.txt
writing manifest file '/tmp/pip-pip-egg-info-p8ppq7gy/matplotlib.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/7b/b3/7c48f648bf83f39d4385e0169d1b68218b838e185047f7f613b1cfc57947/matplotlib-3.3.3.tar.gz#sha256=b1b60c6476c4cfe9e5cf8ab0d3127476fd3d5f05de0f343a452badaad0e4bdec (from https://pypi.org/simple/matplotlib/) (requires-python:>=3.6). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
I’ve also tried installing matplotlib system-wide while not in a venv and get the same results. I’m stumped on this one. Does anyone out there have tips for installing matplotlib with Python 3.7 or 3.8?
Thanks,
Mike
