I’m trying to install matplotlib in vertual env with python3.6:
pip3 install matplotlib
And get the next error:
Collecting matplotlib
Using cached matplotlib-3.3.4.tar.gz (37.9 MB)
ERROR: Command errored out with exit status -4:
command: /home/nvidia/Downloads/test_venv/env36/bin/python3.6 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-ftao42ep/matplotlib_a920bda9f0b947c2b97469537fda63d7/setup.py'"'"'; __file__='"'"'/tmp/pip-install-ftao42ep/matplotlib_a920bda9f0b947c2b97469537fda63d7/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-y7guzvv3
cwd: /tmp/pip-install-ftao42ep/matplotlib_a920bda9f0b947c2b97469537fda63d7/
Complete output (19 lines):
Edit setup.cfg to change the build options; suppress output with --quiet.
BUILDING MATPLOTLIB
matplotlib: yes [3.3.4]
python: yes [3.6.9 (default, Oct 8 2020, 12:12:24) [GCC 8.4.0]]
platform: yes [linux]
sample_data: yes [installing]
tests: no [skipping due to configuration]
macosx: no [Mac OS-X only]
running egg_info
creating /tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info
writing /tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info/PKG-INFO
writing dependency_links to /tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info/dependency_links.txt
writing namespace_packages to /tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info/namespace_packages.txt
writing requirements to /tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info/requires.txt
writing top-level names to /tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info/top_level.txt
writing manifest file '/tmp/pip-pip-egg-info-y7guzvv3/matplotlib.egg-info/SOURCES.txt'
WARNING: Discarding https://files.pythonhosted.org/packages/22/d4/e7ca532e68a9357742604e1e4ae35d9c09a4a810de39a9d80402bd12f50f/matplotlib-3.3.4.tar.gz#sha256=3e477db76c22929e4c6876c44f88d790aacdf3c3f8f3a90cb1975c0bf37825b0 (from https://pypi.org/simple/matplotlib/) (requires-python:>=3.6). Command errored out with exit status -4: python setup.py egg_info Check the logs for full command output.
Using cached matplotlib-3.3.3.tar.gz (37.9 MB)
After it can’t install v.3.3.4 it try v.3.3.3 and so on and so on. I interrupt installation via ctrl+C.
It works ok with python3.7 but I have old project written in python3.6 and I need to work with this.
Any suggestion?
