Hi community!
I am not able to install scipy on Jetson AGX Xavier.
sudo su
and
pip install scipy
returns the following
Collecting scipy
Using cached https://files.pythonhosted.org/packages/ee/5b/5afcd1c46f97b3c2ac3489dbc95d6ca28eacf8e3634e51f495da68d97f0f/scipy-1.3.1.tar.gz
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing wheel metadata ... done
Building wheels for collected packages: scipy
Building wheel for scipy (PEP 517) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/local/lib/python3.6/dist-packages/pip/_vendor/pep517/_in_process.py build_wheel /tmp/tmpfucqyf4c
cwd: /tmp/pip-install-igqt1qhy/scipy
Complete output (798 lines):
lapack_opt_info:
lapack_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_lapack_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_threads_info:
Setting PTATLAS=ATLAS
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/aarch64-linux-gnu/atlas
libraries tatlas,tatlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/aarch64-linux-gnu/atlas
<class 'numpy.distutils.system_info.atlas_info'>
get_default_fcompiler: matching types: '['gnu95', 'intel', 'lahey', 'pg', 'absoft', 'nag', 'vast', 'compaq', 'intele', 'intelem', 'gnu', 'g95', 'pathf95', 'nagfor']'
customize Gnu95FCompiler
Could not locate executable gfortran
Could not locate executable f95
customize IntelFCompiler
Could not locate executable ifort
Could not locate executable ifc
customize LaheyFCompiler
Could not locate executable lf95
customize PGroupFCompiler
Could not locate executable pgfortran
customize AbsoftFCompiler
Could not locate executable f90
Could not locate executable f77
customize NAGFCompiler
customize VastFCompiler
customize CompaqFCompiler
Could not locate executable fort
customize IntelItaniumFCompiler
Could not locate executable efort
Could not locate executable efc
customize IntelEM64TFCompiler
customize GnuFCompiler
Could not locate executable g77
customize G95FCompiler
Could not locate executable g95
customize PathScaleFCompiler
Could not locate executable pathf95
customize NAGFORCompiler
Could not locate executable nagfor
don't know how to compile Fortran code on platform 'posix'
compiling '_configtest.c':
/* This file is generated from numpy/distutils/system_info.py */
void ATL_buildinfo(void);
int main(void) {
ATL_buildinfo();
return 0;
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC
compile options: '-c'
aarch64-linux-gnu-gcc: _configtest.c
aarch64-linux-gnu-gcc -pthread _configtest.o -lf77blas -lcblas -latlas -o _configtest
FOUND:
language = f77
libraries = ['lapack', 'f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
library_dirs = ['/usr/lib/aarch64-linux-gnu']
define_macros = [('NO_ATLAS_INFO', -1)]
FOUND:
language = f77
Splitting linalg.interpolative Fortran source files
blas_opt_info:
blas_mkl_info:
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
openblas_info:
NOT AVAILABLE
atlas_3_10_blas_threads_info:
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu/atlas', '/usr/lib/aarch64-linux-gnu']
NOT AVAILABLE
atlas_blas_info:
int main(void) {
ATL_buildinfo();
return 0;
FOUND:
language = c
define_macros = [('HAVE_CBLAS', None), ('NO_ATLAS_INFO', -1)]
libraries = ['f77blas', 'cblas', 'atlas', 'f77blas', 'cblas']
FOUND:
language = c
[makenpz] scipy/special/tests/data/boost.npz not rebuilt
[makenpz] scipy/special/tests/data/gsl.npz not rebuilt
[makenpz] scipy/special/tests/data/local.npz not rebuilt
non-existing path in 'scipy/signal/windows': 'tests'
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
building library "dfftpack" sources
building library "fftpack" sources
building library "mach" sources
building library "quadpack" sources
building library "lsoda" sources
building library "vode" sources
building library "dop" sources
building library "fitpack" sources
building library "fwrappers" sources
building library "odrpack" sources
building library "minpack" sources
building library "rootfind" sources
building library "superlu_src" sources
building library "arpack_scipy" sources
building library "sc_c_misc" sources
building library "sc_cephes" sources
building library "sc_mach" sources
building library "sc_amos" sources
building library "sc_cdf" sources
building library "sc_specfun" sources
building library "statlib" sources
building extension "scipy.cluster._vq" sources
building extension "scipy.cluster._hierarchy" sources
building extension "scipy.cluster._optimal_leaf_ordering" sources
building extension "scipy.fftpack._fftpack" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/fftpack/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/fftpack' to include_dirs.
building extension "scipy.fftpack.convolve" sources
f2py options: []
building extension "scipy.integrate._quadpack" sources
building extension "scipy.integrate._odepack" sources
building extension "scipy.integrate.vode" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/integrate/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/integrate' to include_dirs.
building extension "scipy.integrate.lsoda" sources
f2py options: []
building extension "scipy.integrate._dop" sources
f2py options: []
building extension "scipy.integrate._test_multivariate" sources
building extension "scipy.integrate._test_odeint_banded" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/scipy/integrate/_test_odeint_banded-f2pywrappers.f' to sources.
building extension "scipy.interpolate.interpnd" sources
building extension "scipy.interpolate._ppoly" sources
building extension "scipy.interpolate._bspl" sources
building extension "scipy.interpolate._fitpack" sources
building extension "scipy.interpolate.dfitpack" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/interpolate/src/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/interpolate/src' to include_dirs.
adding 'build/src.linux-aarch64-3.6/scipy/interpolate/src/dfitpack-f2pywrappers.f' to sources.
building extension "scipy.io._test_fortran" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/io/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/io' to include_dirs.
building extension "scipy.io.matlab.streams" sources
building extension "scipy.io.matlab.mio_utils" sources
building extension "scipy.io.matlab.mio5_utils" sources
building extension "scipy.linalg._fblas" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg' to include_dirs.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/_fblas-f2pywrappers.f' to sources.
building extension "scipy.linalg._flapack" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/_flapack-f2pywrappers.f' to sources.
building extension "scipy.linalg._flinalg" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/linalg' to include_dirs.
building extension "scipy.linalg._interpolative" sources
f2py options: []
building extension "scipy.linalg._solve_toeplitz" sources
building extension "scipy.linalg.cython_blas" sources
building extension "scipy.linalg.cython_lapack" sources
building extension "scipy.linalg._decomp_update" sources
building extension "scipy.odr.__odrpack" sources
building extension "scipy.optimize._minpack" sources
building extension "scipy.optimize._zeros" sources
building extension "scipy.optimize._lbfgsb" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/lbfgsb_src/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/lbfgsb_src' to include_dirs.
building extension "scipy.optimize.moduleTNC" sources
building extension "scipy.optimize._cobyla" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/cobyla/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/cobyla' to include_dirs.
building extension "scipy.optimize.minpack2" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/minpack2/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/minpack2' to include_dirs.
building extension "scipy.optimize._slsqp" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/slsqp/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/slsqp' to include_dirs.
building extension "scipy.optimize._nnls" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/nnls/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/optimize/nnls' to include_dirs.
building extension "scipy.optimize._group_columns" sources
building extension "scipy.optimize._bglu_dense" sources
building extension "scipy.optimize._lsq.givens_elimination" sources
building extension "scipy.optimize._trlib._trlib" sources
building extension "scipy.optimize.cython_optimize._zeros" sources
building extension "scipy.signal.sigtools" sources
building extension "scipy.signal._spectral" sources
building extension "scipy.signal._max_len_seq_inner" sources
building extension "scipy.signal._peak_finding_utils" sources
building extension "scipy.signal._upfirdn_apply" sources
building extension "scipy.signal.spline" sources
building extension "scipy.sparse.linalg.isolve._iterative" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/isolve/iterative/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/isolve/iterative' to include_dirs.
building extension "scipy.sparse.linalg.dsolve._superlu" sources
building extension "scipy.sparse.linalg.eigen.arpack._arpack" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack' to include_dirs.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack/_arpack-f2pywrappers.f' to sources.
building extension "scipy.sparse.csgraph._shortest_path" sources
building extension "scipy.sparse.csgraph._traversal" sources
building extension "scipy.sparse.csgraph._min_spanning_tree" sources
building extension "scipy.sparse.csgraph._reordering" sources
building extension "scipy.sparse.csgraph._tools" sources
building extension "scipy.sparse._csparsetools" sources
building extension "scipy.sparse._sparsetools" sources
[generate_sparsetools] 'scipy/sparse/sparsetools/bsr_impl.h' already up-to-date
[generate_sparsetools] 'scipy/sparse/sparsetools/csr_impl.h' already up-to-date
[generate_sparsetools] 'scipy/sparse/sparsetools/csc_impl.h' already up-to-date
[generate_sparsetools] 'scipy/sparse/sparsetools/other_impl.h' already up-to-date
[generate_sparsetools] 'scipy/sparse/sparsetools/sparsetools_impl.h' already up-to-date
building extension "scipy.spatial.qhull" sources
building extension "scipy.spatial.ckdtree" sources
building extension "scipy.spatial._distance_wrap" sources
building extension "scipy.spatial._voronoi" sources
building extension "scipy.spatial._hausdorff" sources
building extension "scipy.special.specfun" sources
f2py options: ['--no-wrap-functions']
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/special/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/special' to include_dirs.
building extension "scipy.special._ufuncs" sources
building extension "scipy.special._ufuncs_cxx" sources
building extension "scipy.special._ellip_harm_2" sources
building extension "scipy.special.cython_special" sources
building extension "scipy.special._comb" sources
building extension "scipy.special._test_round" sources
building extension "scipy.stats.statlib" sources
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/stats/fortranobject.c' to sources.
adding 'build/src.linux-aarch64-3.6/build/src.linux-aarch64-3.6/scipy/stats' to include_dirs.
building extension "scipy.stats._stats" sources
building extension "scipy.stats.mvn" sources
f2py options: []
adding 'build/src.linux-aarch64-3.6/scipy/stats/mvn-f2pywrappers.f' to sources.
building extension "scipy.ndimage._nd_image" sources
building extension "scipy.ndimage._ni_label" sources
building extension "scipy.ndimage._ctest" sources
building extension "scipy.ndimage._ctest_oldapi" sources
building extension "scipy.ndimage._cytest" sources
building extension "scipy._lib._ccallback_c" sources
building extension "scipy._lib._test_ccallback" sources
building extension "scipy._lib._fpumode" sources
building extension "scipy._lib.messagestream" sources
compile options: '-I/usr/include/python3.6m -c'
aarch64-linux-gnu-gcc -pthread _configtest.o -o _configtest
success!
removing: _configtest.c _configtest.o _configtest.o.d _configtest
building data_files sources
build_src: building npy-pkg config files
running build_py
creating build/lib.linux-aarch64-3.6
creating build/lib.linux-aarch64-3.6/scipy
copying scipy/setup.py -> build/lib.linux-aarch64-3.6/scipy
copying scipy/conftest.py -> build/lib.linux-aarch64-3.6/scipy
copying scipy/__init__.py -> build/lib.linux-aarch64-3.6/scipy
copying scipy/version.py -> build/lib.linux-aarch64-3.6/scipy
copying scipy/_distributor_init.py -> build/lib.linux-aarch64-3.6/scipy
copying build/src.linux-aarch64-3.6/scipy/__config__.py -> build/lib.linux-aarch64-3.6/scipy
creating build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/setup.py -> build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/vq.py -> build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/__init__.py -> build/lib.linux-aarch64-3.6/scipy/cluster
copying scipy/cluster/hierarchy.py -> build/lib.linux-aarch64-3.6/scipy/cluster
creating build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/setup.py -> build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/__init__.py -> build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/constants.py -> build/lib.linux-aarch64-3.6/scipy/constants
copying scipy/constants/codata.py -> build/lib.linux-aarch64-3.6/scipy/constants
creating build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/setup.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/helper.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/__init__.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/realtransforms.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/basic.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
copying scipy/fftpack/pseudo_diffs.py -> build/lib.linux-aarch64-3.6/scipy/fftpack
creating build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/setup.py -> build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/__init__.py -> build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/quadrature.py -> build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/odepack.py -> build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/_bvp.py -> build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/quadpack.py -> build/lib.linux-aarch64-3.6/scipy/integrate
copying scipy/integrate/_ode.py -> build/lib.linux-aarch64-3.6/scipy/integrate
creating build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/base.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/bdf.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/radau.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/__init__.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/common.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/lsoda.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/rk.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
copying scipy/integrate/_ivp/ivp.py -> build/lib.linux-aarch64-3.6/scipy/integrate/_ivp
creating build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/fitpack.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/setup.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/interpnd_info.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/ndgriddata.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/fitpack2.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/interpolate.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_bsplines.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/__init__.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_pade.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/polyint.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/rbf.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_fitpack_impl.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
copying scipy/interpolate/_cubic.py -> build/lib.linux-aarch64-3.6/scipy/interpolate
creating build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/netcdf.py -> build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/setup.py -> build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/_fortran.py -> build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/idl.py -> build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/wavfile.py -> build/lib.linux-aarch64-3.6/scipy/io
copying scipy/io/mmio.py -> build/lib.linux-aarch64-3.6/scipy/io
creating build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio4.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/setup.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio5_params.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/miobase.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/byteordercodes.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
copying scipy/io/matlab/mio5.py -> build/lib.linux-aarch64-3.6/scipy/io/matlab
creating build/lib.linux-aarch64-3.6/scipy/io/arff
copying scipy/io/arff/setup.py -> build/lib.linux-aarch64-3.6/scipy/io/arff
copying scipy/io/arff/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io/arff
copying scipy/io/arff/arffread.py -> build/lib.linux-aarch64-3.6/scipy/io/arff
creating build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/_fortran_format_parser.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/setup.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/hb.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
copying scipy/io/harwell_boeing/__init__.py -> build/lib.linux-aarch64-3.6/scipy/io/harwell_boeing
creating build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/setup.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_svd.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_qr.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_decomp_qz.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_lu.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/misc.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/flinalg.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_sketches.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_testutils.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_generate_pyx.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/linalg_version.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_matfuncs_inv_ssq.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/interpolative.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/__init__.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/blas.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_cython_signature_generator.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_decomp_ldl.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_decomp_polar.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/special_matrices.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_interpolative_backend.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_expm_frechet.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/matfuncs.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_cholesky.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_procrustes.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_solvers.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/basic.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/decomp_schur.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/_matfuncs_sqrtm.py -> build/lib.linux-aarch64-3.6/scipy/linalg
copying scipy/linalg/lapack.py -> build/lib.linux-aarch64-3.6/scipy/linalg
creating build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/setup.py -> build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/__init__.py -> build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/common.py -> build/lib.linux-aarch64-3.6/scipy/misc
copying scipy/misc/doccer.py -> build/lib.linux-aarch64-3.6/scipy/misc
creating build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/setup.py -> build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/odrpack.py -> build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/__init__.py -> build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/models.py -> build/lib.linux-aarch64-3.6/scipy/odr
copying scipy/odr/add_newdocs.py -> build/lib.linux-aarch64-3.6/scipy/odr
creating build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_exact.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_shgo.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_ncg.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_remove_redundancy.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_constraints.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_tstutils.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_krylov.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_hessian_update_strategy.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/nnls.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/zeros.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_differentialevolution.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_numdiff.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/tnc.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/linesearch.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_util.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_simplex.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/slsqp.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/minpack.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/lbfgsb.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_rs.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_linprog_ip.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/optimize.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_dual_annealing.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_spectral.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_basinhopping.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_differentiable_functions.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/cobyla.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_root_scalar.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/nonlin.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_minimize.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_trustregion_dogleg.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_hungarian.py -> build/lib.linux-aarch64-3.6/scipy/optimize
copying scipy/optimize/_root.py -> build/lib.linux-aarch64-3.6/scipy/optimize
creating build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/trf.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/lsq_linear.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/dogbox.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/common.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/least_squares.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/bvls.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
copying scipy/optimize/_lsq/trf_linear.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_lsq
creating build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
copying scipy/optimize/_trlib/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
copying scipy/optimize/_trlib/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trlib
creating build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/setup.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/equality_constrained_sqp.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/tr_interior_point.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/projections.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/report.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/minimize_trustregion_constr.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/qp_subproblem.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
copying scipy/optimize/_trustregion_constr/canonical_constraint.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_trustregion_constr
creating build/lib.linux-aarch64-3.6/scipy/optimize/cython_optimize
copying scipy/optimize/cython_optimize/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/cython_optimize
creating build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
copying scipy/optimize/_shgo_lib/__init__.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
copying scipy/optimize/_shgo_lib/triangulation.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
copying scipy/optimize/_shgo_lib/sobol_seq.py -> build/lib.linux-aarch64-3.6/scipy/optimize/_shgo_lib
creating build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_max_len_seq.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/setup.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_peak_finding.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/wavelets.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/bsplines.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/__init__.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/filter_design.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/spectral.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/lti_conversion.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_arraytools.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/waveforms.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_savitzky_golay.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/ltisys.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/signaltools.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/_upfirdn.py -> build/lib.linux-aarch64-3.6/scipy/signal
copying scipy/signal/fir_filter_design.py -> build/lib.linux-aarch64-3.6/scipy/signal
creating build/lib.linux-aarch64-3.6/scipy/signal/windows
copying scipy/signal/windows/setup.py -> build/lib.linux-aarch64-3.6/scipy/signal/windows
copying scipy/signal/windows/__init__.py -> build/lib.linux-aarch64-3.6/scipy/signal/windows
copying scipy/signal/windows/windows.py -> build/lib.linux-aarch64-3.6/scipy/signal/windows
creating build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/base.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/dok.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/bsr.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/lil.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/sputils.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/sparsetools.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/coo.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/csr.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/data.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/generate_sparsetools.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/dia.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/spfuncs.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/csc.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/compressed.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/extract.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/construct.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/_index.py -> build/lib.linux-aarch64-3.6/scipy/sparse
copying scipy/sparse/_matrix_io.py -> build/lib.linux-aarch64-3.6/scipy/sparse
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/_expm_multiply.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/matfuncs.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/interface.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/_norm.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
copying scipy/sparse/linalg/_onenormest.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/minres.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/_gcrotmk.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/iterative.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/lsmr.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/lgmres.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/lsqr.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
copying scipy/sparse/linalg/isolve/utils.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/isolve
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/_add_newdocs.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
copying scipy/sparse/linalg/dsolve/linsolve.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/dsolve
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
copying scipy/sparse/linalg/eigen/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
copying scipy/sparse/linalg/eigen/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
copying scipy/sparse/linalg/eigen/arpack/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
copying scipy/sparse/linalg/eigen/arpack/arpack.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
copying scipy/sparse/linalg/eigen/arpack/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/arpack
creating build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
copying scipy/sparse/linalg/eigen/lobpcg/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
copying scipy/sparse/linalg/eigen/lobpcg/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
copying scipy/sparse/linalg/eigen/lobpcg/lobpcg.py -> build/lib.linux-aarch64-3.6/scipy/sparse/linalg/eigen/lobpcg
creating build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/setup.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/_laplacian.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/__init__.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
copying scipy/sparse/csgraph/_validation.py -> build/lib.linux-aarch64-3.6/scipy/sparse/csgraph
creating build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/setup.py -> build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/__init__.py -> build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/_plotutils.py -> build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/_spherical_voronoi.py -> build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/_procrustes.py -> build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/distance.py -> build/lib.linux-aarch64-3.6/scipy/spatial
copying scipy/spatial/kdtree.py -> build/lib.linux-aarch64-3.6/scipy/spatial
creating build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/setup.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/rotation.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/_rotation_spline.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
copying scipy/spatial/transform/__init__.py -> build/lib.linux-aarch64-3.6/scipy/spatial/transform
creating build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_mptestutils.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/setup.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/lambertw.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_testutils.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_generate_pyx.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/__init__.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/sf_error.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_logsumexp.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_spherical_bessel.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/_ellip_harm.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/orthogonal.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/basic.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/add_newdocs.py -> build/lib.linux-aarch64-3.6/scipy/special
copying scipy/special/spfun_stats.py -> build/lib.linux-aarch64-3.6/scipy/special
creating build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/setup.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/gammainc_asy.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/lambertw.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/__init__.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/expn_asy.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/loggamma.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/zetac.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/struve_convergence.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/gammainc_data.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
copying scipy/special/_precompute/utils.py -> build/lib.linux-aarch64-3.6/scipy/special/_precompute
creating build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_stats_mstats_common.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/setup.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_distr_params.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/stats.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/__init__.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/mstats_extras.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/kde.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_multivariate.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_distn_infrastructure.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/mstats.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_discrete_distns.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_constants.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_rvs_sampling.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/distributions.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_binned_statistic.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_hypotests.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/mstats_basic.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/morestats.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/vonmises.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_continuous_distns.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/contingency.py -> build/lib.linux-aarch64-3.6/scipy/stats
copying scipy/stats/_tukeylambda_stats.py -> build/lib.linux-aarch64-3.6/scipy/stats
creating build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/setup.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/fourier.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/morphology.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/__init__.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/measurements.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/_ni_docstrings.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/_ni_support.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/interpolation.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
copying scipy/ndimage/filters.py -> build/lib.linux-aarch64-3.6/scipy/ndimage
creating build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/__init__.py -> build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/_fortran.py -> build/lib.linux-aarch64-3.6/scipy/_build_utils
copying scipy/_build_utils/system_info.py -> build/lib.linux-aarch64-3.6/scipy/_build_utils
creating build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/setup.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_tmpdirs.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_gcutils.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/decorator.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_testutils.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/__init__.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_numpy_compat.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_threadsafety.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/six.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/doccer.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_util.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_version.py -> build/lib.linux-aarch64-3.6/scipy/_lib
copying scipy/_lib/_ccallback.py -> build/lib.linux-aarch64-3.6/scipy/_lib
running build_clib
customize UnixCCompiler using build_clib
building 'dfftpack' library
Running from scipy source directory.
/usr/local/lib/python3.6/dist-packages/numpy/distutils/system_info.py:782: UserWarning: Specified path /usr/local/include/python3.6m is invalid.
return self.get_paths(self.section, key)
error: library dfftpack has Fortran sources but no Fortran compiler found
ERROR: Failed building wheel for scipy
Running setup.py clean for scipy
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-igqt1qhy/scipy/setup.py'"'"'; __file__='"'"'/tmp/pip-install-igqt1qhy/scipy/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' clean --all
Complete output (9 lines):
`setup.py clean` is not supported, use one of the following instead:
- `git clean -xdf` (cleans all files)
- `git clean -Xdf` (cleans all versioned files, doesn't touch
files that aren't checked into the git repo)
Add `--force` to your command to use it anyway if you must (unsupported).
ERROR: Failed cleaning build dir for scipy
Failed to build scipy
ERROR: Could not build wheels for scipy which use PEP 517 and cannot be installed directly
What I tried:
apt-get update
apt-get upgrade
My guess is that gfortran needs to be installed, however
apt-get install gfortran
yields
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
gfortran : Depends: gfortran-7 (>= 7.3.0-12~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Maybe gfortran is already installed, but pip cannot find it. Anyway, there is a file
usr/bin/gfortran5
My etc/apt/sources.list reads
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic main restricted
## Major bug fix updates produced after the final release of the
## distribution.
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic multiverse
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-backports main restricted universe$
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu bionic partner
# deb-src http://archive.canonical.com/ubuntu bionic partner
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-security main restricted
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-security universe
# deb-src http://ports.ubuntu.com/ubuntu-ports/ bionic-security multiverse
deb http://ports.ubuntu.com/ubuntu-ports/ bionic main universe
System:
- ubuntu 18.04 LTS on Jetson AGX Xavier
- Fresh installed OS image using the SDK-Manager
Any help highly appreciated!
Lorenz
