"pip install scikit-learn" failing on Xavier board
[code] pip install --no-cache-dir scikit-learn
Collecting scikit-learn
Downloading https://files.pythonhosted.org/packages/1a/7c/da34889e0a58e801675af88bc6e0dd1fcb4b01d26d1b437eb15df85b50a6/scikit-learn-0.20.1.tar.gz (9.7MB)
100% |████████████████████████████████| 9.7MB 21.2MB/s
Collecting numpy>=1.8.2 (from scikit-learn)
Downloading https://files.pythonhosted.org/packages/2d/80/1809de155bad674b494248bcfca0e49eb4c5d8bee58f26fe7a0dd45029e2/numpy-1.15.4.zip (4.5MB)
100% |████████████████████████████████| 4.5MB 23.3MB/s
Collecting scipy>=0.13.3 (from scikit-learn)
Downloading https://files.pythonhosted.org/packages/07/76/7e844757b9f3bf5ab9f951ccd3e4a8eed91ab8720b0aac8c2adcc2fdae9f/scipy-1.1.0.tar.gz (15.6MB)
100% |████████████████████████████████| 15.6MB 7.6MB/s
Installing collected packages: numpy, scipy, scikit-learn
Running setup.py install for numpy … done
Running setup.py install for scipy … \
done
Running setup.py install for scikit-learn … error
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=‘/tmp/pip-build-Kjsn11/scikit-learn/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(‘\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-J0dFru-record/install-record.txt --single-version-externally-managed --compile --user --prefix=:
Partial import of sklearn during the build process.
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in [‘/usr/local/lib’, ‘/usr/lib’, ‘/usr/lib/aarch64-linux-gnu’]
NOT AVAILABLE
blis_info:
  libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/aarch64-linux-gnu']
  NOT AVAILABLE
openblas_info:
  FOUND:
    libraries = ['openblas', 'openblas']
    library_dirs = ['/usr/lib/aarch64-linux-gnu']
    language = c
    define_macros = [('HAVE_CBLAS', None)]
  FOUND:
    language = c
running install
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building library "libsvm-skl" sources
building extension "sklearn.__check_build._check_build" sources
building extension "sklearn.cluster._dbscan_inner" sources
building extension "sklearn.cluster._hierarchical" sources
building extension "sklearn.cluster._k_means_elkan" sources
building extension "sklearn.cluster._k_means" sources
building extension "sklearn.datasets._svmlight_format" sources
building extension "sklearn.decomposition._online_lda" sources
building extension "sklearn.decomposition.cdnmf_fast" sources
building extension "sklearn.ensemble._gradient_boosting" sources
building extension "sklearn.feature_extraction._hashing" sources
building extension "sklearn.manifold._utils" sources
building extension "sklearn.manifold._barnes_hut_tsne" sources
building extension "sklearn.metrics.cluster.expected_mutual_info_fast" sources
building extension "sklearn.metrics.pairwise_fast" sources
building extension "sklearn.neighbors.ball_tree" sources
building extension "sklearn.neighbors.kd_tree" sources
building extension "sklearn.neighbors.dist_metrics" sources
building extension "sklearn.neighbors.typedefs" sources
building extension "sklearn.neighbors.quad_tree" sources
building extension "sklearn.tree._tree" sources
building extension "sklearn.tree._splitter" sources
building extension "sklearn.tree._criterion" sources
building extension "sklearn.tree._utils" sources
building extension "sklearn.svm.libsvm" sources
building extension "sklearn.svm.liblinear" sources
building extension "sklearn.svm.libsvm_sparse" sources
building extension "sklearn._isotonic" sources
building extension "sklearn.linear_model.cd_fast" sources
building extension "sklearn.linear_model.sgd_fast" sources
building extension "sklearn.linear_model.sag_fast" sources
building extension "sklearn.utils.sparsefuncs_fast" sources
building extension "sklearn.utils.arrayfuncs" sources
building extension "sklearn.utils.murmurhash" sources
building extension "sklearn.utils.lgamma" sources
building extension "sklearn.utils.graph_shortest_path" sources
building extension "sklearn.utils.fast_dict" sources
building extension "sklearn.utils.seq_dataset" sources
building extension "sklearn.utils.weight_vector" sources
building extension "sklearn.utils._random" sources
building extension "sklearn.utils._logistic_sigmoid" sources
building data_files sources
build_src: building npy-pkg config files
running build_py
creating build
creating build/lib.linux-aarch64-2.7
creating build/lib.linux-aarch64-2.7/sklearn
copying sklearn/pipeline.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/multiclass.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/kernel_approximation.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/calibration.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/discriminant_analysis.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/_config.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/naive_bayes.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/kernel_ridge.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/base.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/impute.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/isotonic.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/random_projection.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/multioutput.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/__init__.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/setup.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/dummy.py -> build/lib.linux-aarch64-2.7/sklearn
copying sklearn/exceptions.py -> build/lib.linux-aarch64-2.7/sklearn
creating build/lib.linux-aarch64-2.7/sklearn/__check_build
copying sklearn/__check_build/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/__check_build
copying sklearn/__check_build/setup.py -> build/lib.linux-aarch64-2.7/sklearn/__check_build
creating build/lib.linux-aarch64-2.7/sklearn/_build_utils
copying sklearn/_build_utils/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/_build_utils
creating build/lib.linux-aarch64-2.7/sklearn/compose
copying sklearn/compose/_column_transformer.py -> build/lib.linux-aarch64-2.7/sklearn/compose
copying sklearn/compose/_target.py -> build/lib.linux-aarch64-2.7/sklearn/compose
copying sklearn/compose/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/compose
creating build/lib.linux-aarch64-2.7/sklearn/compose/tests
copying sklearn/compose/tests/test_target.py -> build/lib.linux-aarch64-2.7/sklearn/compose/tests
copying sklearn/compose/tests/test_column_transformer.py -> build/lib.linux-aarch64-2.7/sklearn/compose/tests
copying sklearn/compose/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/compose/tests
creating build/lib.linux-aarch64-2.7/sklearn/covariance
copying sklearn/covariance/graph_lasso_.py -> build/lib.linux-aarch64-2.7/sklearn/covariance
copying sklearn/covariance/elliptic_envelope.py -> build/lib.linux-aarch64-2.7/sklearn/covariance
copying sklearn/covariance/empirical_covariance_.py -> build/lib.linux-aarch64-2.7/sklearn/covariance
copying sklearn/covariance/robust_covariance.py -> build/lib.linux-aarch64-2.7/sklearn/covariance
copying sklearn/covariance/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/covariance
copying sklearn/covariance/shrunk_covariance_.py -> build/lib.linux-aarch64-2.7/sklearn/covariance
creating build/lib.linux-aarch64-2.7/sklearn/covariance/tests
copying sklearn/covariance/tests/test_covariance.py -> build/lib.linux-aarch64-2.7/sklearn/covariance/tests
copying sklearn/covariance/tests/test_graph_lasso.py -> build/lib.linux-aarch64-2.7/sklearn/covariance/tests
copying sklearn/covariance/tests/test_elliptic_envelope.py -> build/lib.linux-aarch64-2.7/sklearn/covariance/tests
copying sklearn/covariance/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/covariance/tests
copying sklearn/covariance/tests/test_robust_covariance.py -> build/lib.linux-aarch64-2.7/sklearn/covariance/tests
copying sklearn/covariance/tests/test_graphical_lasso.py -> build/lib.linux-aarch64-2.7/sklearn/covariance/tests
creating build/lib.linux-aarch64-2.7/sklearn/cross_decomposition
copying sklearn/cross_decomposition/cca_.py -> build/lib.linux-aarch64-2.7/sklearn/cross_decomposition
copying sklearn/cross_decomposition/pls_.py -> build/lib.linux-aarch64-2.7/sklearn/cross_decomposition
copying sklearn/cross_decomposition/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/cross_decomposition
creating build/lib.linux-aarch64-2.7/sklearn/cross_decomposition/tests
copying sklearn/cross_decomposition/tests/test_pls.py -> build/lib.linux-aarch64-2.7/sklearn/cross_decomposition/tests
copying sklearn/cross_decomposition/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/cross_decomposition/tests
creating build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/from_model.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/rfe.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/variance_threshold.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/univariate_selection.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/base.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/mutual_info_.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
copying sklearn/feature_selection/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection
creating build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_variance_threshold.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_mutual_info.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_chi2.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_feature_select.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_base.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_from_model.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/test_rfe.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
copying sklearn/feature_selection/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/feature_selection/tests
creating build/lib.linux-aarch64-2.7/sklearn/gaussian_process
copying sklearn/gaussian_process/gpr.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process
copying sklearn/gaussian_process/correlation_models.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process
copying sklearn/gaussian_process/kernels.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process
copying sklearn/gaussian_process/gpc.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process
copying sklearn/gaussian_process/regression_models.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process
copying sklearn/gaussian_process/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process
creating build/lib.linux-aarch64-2.7/sklearn/gaussian_process/tests
copying sklearn/gaussian_process/tests/test_gpc.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process/tests
copying sklearn/gaussian_process/tests/test_kernels.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process/tests
copying sklearn/gaussian_process/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process/tests
copying sklearn/gaussian_process/tests/test_gpr.py -> build/lib.linux-aarch64-2.7/sklearn/gaussian_process/tests
creating build/lib.linux-aarch64-2.7/sklearn/mixture
copying sklearn/mixture/bayesian_mixture.py -> build/lib.linux-aarch64-2.7/sklearn/mixture
copying sklearn/mixture/gaussian_mixture.py -> build/lib.linux-aarch64-2.7/sklearn/mixture
copying sklearn/mixture/base.py -> build/lib.linux-aarch64-2.7/sklearn/mixture
copying sklearn/mixture/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/mixture
creating build/lib.linux-aarch64-2.7/sklearn/mixture/tests
copying sklearn/mixture/tests/test_mixture.py -> build/lib.linux-aarch64-2.7/sklearn/mixture/tests
copying sklearn/mixture/tests/test_gaussian_mixture.py -> build/lib.linux-aarch64-2.7/sklearn/mixture/tests
copying sklearn/mixture/tests/test_bayesian_mixture.py -> build/lib.linux-aarch64-2.7/sklearn/mixture/tests
copying sklearn/mixture/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/mixture/tests
creating build/lib.linux-aarch64-2.7/sklearn/model_selection
copying sklearn/model_selection/_split.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection
copying sklearn/model_selection/_validation.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection
copying sklearn/model_selection/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection
copying sklearn/model_selection/_search.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection
creating build/lib.linux-aarch64-2.7/sklearn/model_selection/tests
copying sklearn/model_selection/tests/test_search.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection/tests
copying sklearn/model_selection/tests/test_validation.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection/tests
copying sklearn/model_selection/tests/test_split.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection/tests
copying sklearn/model_selection/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection/tests
copying sklearn/model_selection/tests/common.py -> build/lib.linux-aarch64-2.7/sklearn/model_selection/tests
creating build/lib.linux-aarch64-2.7/sklearn/neural_network
copying sklearn/neural_network/rbm.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network
copying sklearn/neural_network/multilayer_perceptron.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network
copying sklearn/neural_network/_stochastic_optimizers.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network
copying sklearn/neural_network/_base.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network
copying sklearn/neural_network/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network
creating build/lib.linux-aarch64-2.7/sklearn/neural_network/tests
copying sklearn/neural_network/tests/test_stochastic_optimizers.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network/tests
copying sklearn/neural_network/tests/test_mlp.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network/tests
copying sklearn/neural_network/tests/test_rbm.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network/tests
copying sklearn/neural_network/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/neural_network/tests
creating build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/imputation.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/_discretization.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/_encoders.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/base.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/label.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/_function_transformer.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
copying sklearn/preprocessing/data.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing
creating build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_common.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_discretization.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_function_transformer.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_base.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_imputation.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_data.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_encoders.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
copying sklearn/preprocessing/tests/test_label.py -> build/lib.linux-aarch64-2.7/sklearn/preprocessing/tests
creating build/lib.linux-aarch64-2.7/sklearn/semi_supervised
copying sklearn/semi_supervised/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/semi_supervised
copying sklearn/semi_supervised/label_propagation.py -> build/lib.linux-aarch64-2.7/sklearn/semi_supervised
creating build/lib.linux-aarch64-2.7/sklearn/semi_supervised/tests
copying sklearn/semi_supervised/tests/test_label_propagation.py -> build/lib.linux-aarch64-2.7/sklearn/semi_supervised/tests
copying sklearn/semi_supervised/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/semi_supervised/tests
creating build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/mean_shift_.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/bicluster.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/k_means_.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/_feature_agglomeration.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/hierarchical.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/spectral.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/affinity_propagation_.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/dbscan_.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/birch.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
copying sklearn/cluster/setup.py -> build/lib.linux-aarch64-2.7/sklearn/cluster
creating build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_birch.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_feature_agglomeration.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_bicluster.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_k_means.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_mean_shift.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_dbscan.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_hierarchical.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_affinity_propagation.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/common.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
copying sklearn/cluster/tests/test_spectral.py -> build/lib.linux-aarch64-2.7/sklearn/cluster/tests
creating build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/twenty_newsgroups.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/kddcup99.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/california_housing.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/openml.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/samples_generator.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/olivetti_faces.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/rcv1.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/svmlight_format.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/covtype.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/base.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/species_distributions.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/lfw.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/mlcomp.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/setup.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
copying sklearn/datasets/mldata.py -> build/lib.linux-aarch64-2.7/sklearn/datasets
creating build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_mldata.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_svmlight_format.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_kddcup99.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_common.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_rcv1.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_samples_generator.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_lfw.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_openml.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_covtype.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_base.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_20news.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
copying sklearn/datasets/tests/test_california_housing.py -> build/lib.linux-aarch64-2.7/sklearn/datasets/tests
creating build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/factor_analysis.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/online_lda.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/dict_learning.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/incremental_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/base.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/sparse_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/nmf.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/truncated_svd.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/kernel_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/setup.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
copying sklearn/decomposition/fastica_.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition
creating build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_truncated_svd.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_dict_learning.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_incremental_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_fastica.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_nmf.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_online_lda.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_kernel_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_sparse_pca.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/test_factor_analysis.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
copying sklearn/decomposition/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/decomposition/tests
creating build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/weight_boosting.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/forest.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/voting_classifier.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/bagging.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/base.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/gradient_boosting.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/partial_dependence.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/iforest.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
copying sklearn/ensemble/setup.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble
creating build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_forest.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_iforest.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_gradient_boosting_loss_functions.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_voting_classifier.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_partial_dependence.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_base.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_weight_boosting.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_gradient_boosting.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/test_bagging.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
copying sklearn/ensemble/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/ensemble/tests
creating build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/_pilutil.py -> build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/funcsigs.py -> build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/conftest.py -> build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/_arff.py -> build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/six.py -> build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/externals
copying sklearn/externals/setup.py -> build/lib.linux-aarch64-2.7/sklearn/externals
creating build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/hashing.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_memmapping_reducer.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/func_inspect.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/backports.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/parallel.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_multiprocessing_helpers.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/memory.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_memory_helpers.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_parallel_backends.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/executor.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/numpy_pickle_utils.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/logger.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/disk.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/pool.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/my_exceptions.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/format_stack.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/numpy_pickle.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_compat.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_store_backends.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/_dask.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/testing.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/compressor.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
copying sklearn/externals/joblib/numpy_pickle_compat.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib
creating build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals
copying sklearn/externals/joblib/externals/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals
creating build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky
copying sklearn/externals/joblib/externals/loky/process_executor.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky
copying sklearn/externals/joblib/externals/loky/_base.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky
copying sklearn/externals/joblib/externals/loky/reusable_executor.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky
copying sklearn/externals/joblib/externals/loky/cloudpickle_wrapper.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky
copying sklearn/externals/joblib/externals/loky/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky
creating build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/popen_loky_win32.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/semlock.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/fork_exec.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/popen_loky_posix.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/reduction.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/process.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/_posix_reduction.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/_win_reduction.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/compat_win32.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/_posix_wait.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/context.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/spawn.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/_win_wait.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/semaphore_tracker.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/queues.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/compat_posix.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/synchronize.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/utils.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/managers.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/compat.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
copying sklearn/externals/joblib/externals/loky/backend/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/loky/backend
creating build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/cloudpickle
copying sklearn/externals/joblib/externals/cloudpickle/cloudpickle.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/cloudpickle
copying sklearn/externals/joblib/externals/cloudpickle/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/externals/joblib/externals/cloudpickle
creating build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/image.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/hashing.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/stop_words.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/dict_vectorizer.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/setup.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
copying sklearn/feature_extraction/text.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction
creating build/lib.linux-aarch64-2.7/sklearn/feature_extraction/tests
copying sklearn/feature_extraction/tests/test_image.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction/tests
copying sklearn/feature_extraction/tests/test_dict_vectorizer.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction/tests
copying sklearn/feature_extraction/tests/test_feature_hasher.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction/tests
copying sklearn/feature_extraction/tests/test_text.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction/tests
copying sklearn/feature_extraction/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/feature_extraction/tests
creating build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/spectral_embedding_.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/locally_linear.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/isomap.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/t_sne.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/mds.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
copying sklearn/manifold/setup.py -> build/lib.linux-aarch64-2.7/sklearn/manifold
creating build/lib.linux-aarch64-2.7/sklearn/manifold/tests
copying sklearn/manifold/tests/test_locally_linear.py -> build/lib.linux-aarch64-2.7/sklearn/manifold/tests
copying sklearn/manifold/tests/test_isomap.py -> build/lib.linux-aarch64-2.7/sklearn/manifold/tests
copying sklearn/manifold/tests/test_t_sne.py -> build/lib.linux-aarch64-2.7/sklearn/manifold/tests
copying sklearn/manifold/tests/test_mds.py -> build/lib.linux-aarch64-2.7/sklearn/manifold/tests
copying sklearn/manifold/tests/test_spectral_embedding.py -> build/lib.linux-aarch64-2.7/sklearn/manifold/tests
copying sklearn/manifold/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/manifold/tests
creating build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/ranking.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/classification.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/pairwise.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/regression.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/base.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/scorer.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
copying sklearn/metrics/setup.py -> build/lib.linux-aarch64-2.7/sklearn/metrics
creating build/lib.linux-aarch64-2.7/sklearn/metrics/cluster
copying sklearn/metrics/cluster/bicluster.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster
copying sklearn/metrics/cluster/unsupervised.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster
copying sklearn/metrics/cluster/supervised.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster
copying sklearn/metrics/cluster/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster
copying sklearn/metrics/cluster/setup.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster
creating build/lib.linux-aarch64-2.7/sklearn/metrics/cluster/tests
copying sklearn/metrics/cluster/tests/test_bicluster.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster/tests
copying sklearn/metrics/cluster/tests/test_common.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster/tests
copying sklearn/metrics/cluster/tests/test_unsupervised.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster/tests
copying sklearn/metrics/cluster/tests/test_supervised.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster/tests
copying sklearn/metrics/cluster/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/cluster/tests
creating build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/test_pairwise.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/test_common.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/test_classification.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/test_regression.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/test_ranking.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/test_score_objects.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
copying sklearn/metrics/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/metrics/tests
creating build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/nearest_centroid.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/unsupervised.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/classification.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/graph.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/lof.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/approximate.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/regression.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/base.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/kde.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
copying sklearn/neighbors/setup.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors
creating build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_approximate.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_ball_tree.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_neighbors.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_lof.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_kde.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_nearest_centroid.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_kd_tree.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_dist_metrics.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
copying sklearn/neighbors/tests/test_quad_tree.py -> build/lib.linux-aarch64-2.7/sklearn/neighbors/tests
creating build/lib.linux-aarch64-2.7/sklearn/tree
copying sklearn/tree/export.py -> build/lib.linux-aarch64-2.7/sklearn/tree
copying sklearn/tree/tree.py -> build/lib.linux-aarch64-2.7/sklearn/tree
copying sklearn/tree/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/tree
copying sklearn/tree/setup.py -> build/lib.linux-aarch64-2.7/sklearn/tree
creating build/lib.linux-aarch64-2.7/sklearn/tree/tests
copying sklearn/tree/tests/test_tree.py -> build/lib.linux-aarch64-2.7/sklearn/tree/tests
copying sklearn/tree/tests/test_export.py -> build/lib.linux-aarch64-2.7/sklearn/tree/tests
copying sklearn/tree/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/tree/tests
creating build/lib.linux-aarch64-2.7/sklearn/svm
copying sklearn/svm/bounds.py -> build/lib.linux-aarch64-2.7/sklearn/svm
copying sklearn/svm/classes.py -> build/lib.linux-aarch64-2.7/sklearn/svm
copying sklearn/svm/base.py -> build/lib.linux-aarch64-2.7/sklearn/svm
copying sklearn/svm/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/svm
copying sklearn/svm/setup.py -> build/lib.linux-aarch64-2.7/sklearn/svm
creating build/lib.linux-aarch64-2.7/sklearn/svm/tests
copying sklearn/svm/tests/test_sparse.py -> build/lib.linux-aarch64-2.7/sklearn/svm/tests
copying sklearn/svm/tests/test_svm.py -> build/lib.linux-aarch64-2.7/sklearn/svm/tests
copying sklearn/svm/tests/test_bounds.py -> build/lib.linux-aarch64-2.7/sklearn/svm/tests
copying sklearn/svm/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/svm/tests
creating build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/perceptron.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/ransac.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/omp.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/huber.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/logistic.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/bayes.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/coordinate_descent.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/base.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/stochastic_gradient.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/passive_aggressive.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/ridge.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/theil_sen.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/sag.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/randomized_l1.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/setup.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
copying sklearn/linear_model/least_angle.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model
creating build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_logistic.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_passive_aggressive.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_theil_sen.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_least_angle.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_coordinate_descent.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_sgd.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_ransac.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_huber.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_ridge.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_sag.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_base.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_perceptron.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_bayes.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_omp.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_sparse_coordinate_descent.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
copying sklearn/linear_model/tests/test_randomized_l1.py -> build/lib.linux-aarch64-2.7/sklearn/linear_model/tests
creating build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/multiclass.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/validation.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/linear_assignment_.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/fixes.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/_show_versions.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/_joblib.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/deprecation.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/graph.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/mocking.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/stats.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/_unittest_backport.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/metaestimators.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/extmath.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/arpack.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/estimator_checks.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/bench.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/class_weight.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/_scipy_sparse_lsqr_backport.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/optimize.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/testing.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/sparsefuncs.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/setup.py -> build/lib.linux-aarch64-2.7/sklearn/utils
copying sklearn/utils/random.py -> build/lib.linux-aarch64-2.7/sklearn/utils
creating build/lib.linux-aarch64-2.7/sklearn/utils/sparsetools
copying sklearn/utils/sparsetools/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/utils/sparsetools
copying sklearn/utils/sparsetools/setup.py -> build/lib.linux-aarch64-2.7/sklearn/utils/sparsetools
creating build/lib.linux-aarch64-2.7/sklearn/utils/sparsetools/tests
copying sklearn/utils/sparsetools/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/utils/sparsetools/tests
creating build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_seq_dataset.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_estimator_checks.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_class_weight.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_testing.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_metaestimators.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_optimize.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_extmath.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_validation.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_multiclass.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_fast_dict.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_fixes.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_show_versions.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_linear_assignment.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_bench.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_shortest_path.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_murmurhash.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_stats.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_graph.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_utils.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_random.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_deprecation.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
copying sklearn/utils/tests/test_sparsefuncs.py -> build/lib.linux-aarch64-2.7/sklearn/utils/tests
creating build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_kernel_ridge.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_metaestimators.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_discriminant_analysis.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_common.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_impute.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_multiclass.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_random_projection.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_dummy.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_isotonic.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_site_joblib.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_init.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_kernel_approximation.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_docstring_parameters.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_base.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_naive_bayes.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_pipeline.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_multioutput.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_config.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/__init__.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_calibration.py -> build/lib.linux-aarch64-2.7/sklearn/tests
copying sklearn/tests/test_check_build.py -> build/lib.linux-aarch64-2.7/sklearn/tests
running build_clib
customize UnixCCompiler using build_clib
building 'libsvm-skl' library
compiling C++ sources
C compiler: aarch64-linux-gnu-g++ -pthread -DNDEBUG -g -fwrapv -O2 -Wall -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ytvI67/python2.7-2.7.15~rc1=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC
creating build/temp.linux-aarch64-2.7
creating build/temp.linux-aarch64-2.7/sklearn
creating build/temp.linux-aarch64-2.7/sklearn/svm
creating build/temp.linux-aarch64-2.7/sklearn/svm/src
creating build/temp.linux-aarch64-2.7/sklearn/svm/src/libsvm
compile options: '-I/home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include -c'
aarch64-linux-gnu-g++: sklearn/svm/src/libsvm/libsvm_template.cpp
aarch64-linux-gnu-gcc-ar: adding 1 object files to build/temp.linux-aarch64-2.7/liblibsvm-skl.a
running build_ext
customize UnixCCompiler using build_ext
resetting extension 'sklearn.svm.liblinear' language from 'c' to 'c++'.
building 'sklearn.__check_build._check_build' extension
compiling C sources
C compiler: aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ytvI67/python2.7-2.7.15~rc1=. -fstack-protector-strong -Wformat -Werror=format-security -fPIC
creating build/temp.linux-aarch64-2.7/sklearn/__check_build
compile options: '-I/home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include -I/home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include -I/usr/include/python2.7 -c'
aarch64-linux-gnu-gcc: sklearn/__check_build/_check_build.c
aarch64-linux-gnu-gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ytvI67/python2.7-2.7.15~rc1=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-Bsymbolic-functions -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ytvI67/python2.7-2.7.15~rc1=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-aarch64-2.7/sklearn/__check_build/_check_build.o -Lbuild/temp.linux-aarch64-2.7 -o build/lib.linux-aarch64-2.7/sklearn/__check_build/_check_build.so
building 'sklearn.cluster._dbscan_inner' extension
creating build/temp.linux-aarch64-2.7/sklearn/cluster
aarch64-linux-gnu-g++: sklearn/cluster/_dbscan_inner.cpp
In file included from /home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include/numpy/ndarraytypes.h:1821:0,
                 from /home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include/numpy/ndarrayobject.h:18,
                 from /home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include/numpy/arrayobject.h:4,
                 from sklearn/cluster/_dbscan_inner.cpp:271:
/home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include/numpy/npy_1_7_deprecated_api.h:15:2: warning: #warning "Using deprecated NumPy API, disable it by " "#defining NPY_NO_DEPRECATED_API NPY_1_7_API_VERSION" [-Wcpp]
 #warning "Using deprecated NumPy API, disable it by " \
In file included from /home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include/numpy/ndarrayobject.h:27:0,
/home/nvidia/.local/lib/python2.7/site-packages/numpy/core/include/numpy/__multiarray_api.h:1463:1: warning: ???int _import_array()??? defined but not used [-Wunused-function]
 _import_array(void)
aarch64-linux-gnu-g++ -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-Bsymbolic-functions -Wl,-z,relro -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ytvI67/python2.7-2.7.15~rc1=. -fstack-protector-strong -Wformat -Werror=format-security -Wl,-Bsymbolic-functions -Wl,-z,relro -Wdate-time -D_FORTIFY_SOURCE=2 -g -fdebug-prefix-map=/build/python2.7-ytvI67/python2.7-2.7.15~rc1=. -fstack-protector-strong -Wformat -Werror=format-security build/temp.linux-aarch64-2.7/sklearn/cluster/_dbscan_inner.o -Lbuild/temp.linux-aarch64-2.7 -o build/lib.linux-aarch64-2.7/sklearn/cluster/_dbscan_inner.so
building 'sklearn.cluster._hierarchical' extension
aarch64-linux-gnu-g++: sklearn/cluster/_hierarchical.cpp
                 from sklearn/cluster/_hierarchical.cpp:269:
sudo pip install git+https://github.com/scikit-learn/scikit-learn.git
This worked
same error happened in tx2 also ?
is there any solution?
i tries the above code it also shows the error
Can you send logs?
As sometimes pip uses cached directory to install libraries. It may give error.
I had a similar problem when installing Keras.
While installing scipy, it failed. The suggested #2 solution didn’t work.
I got it running by:
  1. sudo apt-get install libblas-dev liblapack-dev
  2. sudo apt-get install gfortran
  3. sudo pip install keras
I forgot to update here.
Yes it’s gfortran compiler issue.
scikit-learn library uses the compiler to build.
Installing it solved the issue.
When i am trying to install scipy its showing
Running from scipy source directory.
/tmp/pip-build-env-i46z9d05/overlay/lib/python3.6/site-packages/numpy/distutils/system_info.py:664: UserWarning: Specified path /usr/local/include/python3.6m is invalid.
return self.get_paths(self.section, key)
scipy/fft/_pocketfft/pypocketfft.cxx:15:10: fatal error: pybind11/pybind11.h: No such file or directory
include <pybind11/pybind11.h>
compilation terminated.
error: Command “aarch64-linux-gnu-g++ -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DPOCKETFFT_PTHREADS -I/home/agvvit/.local/include/python3.6m -I/usr/local/include/python3.6 -I/tmp/pip-build-env-i46z9d05/overlay/lib/python3.6/site-packages/numpy/core/include -I/usr/include/python3.6m -c scipy/fft/_pocketfft/pypocketfft.cxx -o build/temp.linux-aarch64-3.6/scipy/fft/_pocketfft/pypocketfft.o -MMD -MF build/temp.linux-aarch64-3.6/scipy/fft/_pocketfft/pypocketfft.o.d -std=c++14 -fvisibility=hidden” failed with exit status 1
ERROR: Failed building wheel for scipy
Failed to build scipy
ERROR: Could not build wheels for scipy which use PEP 517 and cannot be installed directly
Can anyone help me solve this issue?
@venkatmukthineni
https://devtalk.nvidia.com/default/topic/1064276/jetson-agx-xavier/unable-to-install-scipy/
https://devtalk.nvidia.com/default/topic/1069064/jetson-agx-xavier/issue-with-installing-scipy-on-jetson-agx-xavier/
you may build scipy from sources or install with a package manager.
