- via remote SSH in the Jetson nano I run:
xhost +
ds=/ds
mkdir -p /tmp/data/{models,out}
docker run -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix \
--name ds \
-v $(pwd)/ds:${ds} \
-v /tmp/data:/data \
-e DISPLAY=${DISPLAY:?} \
-e ds=${ds:?} \
-p 8554:8554 \
-p 5400:5400/udp \
--shm-size=1g \
--ulimit memlock=-1 \
--ulimit stack=67108864 \
-w $ds \
-h ds nvcr.io/nvidia/deepstream-l4t:5.0-dp-20.04-samples
- inside the container then:
access control disabled, clients can connect from any host
xhost: must be on local machine to enable or disable access control.
root@ds:/ds# export GST_PLUGIN_PATH=/usr/lib/aarch64-linux-gnu/gstreamer-1.0
root@ds:/ds# export CUDA_HOME=/usr/local/cuda
root@ds:/ds# export LD_LIBRARY_PATH="${LD_LIBRARY_PATH}:/opt/nvidia/deepstream/deepstream/lib"
root@ds:/ds# export GST_DEBUG=4
root@ds:/ds# cd /opt/nvidia/deepstream/deepstream/samples/configs/tlt_pretrained_models/
- Then when the sample app is executed:
root@ds:/opt/nvidia/deepstream/deepstream/samples/configs/tlt_pretrained_models# rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.bin ; deepstream-app -c deepstream_app_source1_peoplenet.txt 2>&1 | grep ERROR
I get this output:
0:00:01.086762450 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so failed to load. Blacklisting
0:00:01.282806897 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so failed to load. Blacklisting
0:00:01.456059481 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so failed to load. Blacklisting
0:00:01.624129165 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so failed to load. Blacklisting
0:00:03.325587828 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so failed to load. Blacklisting
0:00:03.529381290 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so failed to load. Blacklisting
0:00:03.844039668 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so failed to load. Blacklisting
0:00:04.021118035 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so failed to load. Blacklisting
0:00:05.163563576 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so failed to load. Blacklisting
0:00:05.379325227 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_osd.so failed to load. Blacklisting
0:00:05.581461928 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistreamtiler.so failed to load. Blacklisting
0:00:05.745427600 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_dsexample.so failed to load. Blacklisting
0:00:07.445637211 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so failed to load. Blacklisting
0:00:07.645553751 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_tracker.so failed to load. Blacklisting
0:00:07.938407122 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_infer.so failed to load. Blacklisting
0:00:08.109747266 204 0x2bd1a800 ERROR GST_PLUGIN_LOADING gstpluginloader.c:277:plugin_loader_replay_pending: Plugin file /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libgstnvvideoconvert.so failed to load. Blacklisting
** ERROR: <create_multi_source_bin:1029>: Failed to create element 'src_bin_muxer'
** ERROR: <create_multi_source_bin:1104>: create_multi_source_bin failed
** ERROR: <create_pipeline:1263>: create_pipeline failed
** ERROR: <main:632>: Failed to create pipeline
Any clue on how to solve this?
I have search through the forums, but no solution seems to work for me at all!
