Hi all,
Please find the Gst-Discover of the media i am trying to run mentioned below.
I wanted to know what changes need to be made to the deepstream-test2 to run the file with below mentioned details.
Also is there a sample code to be used for gst-Uridecode?
GST-DISCOVER DETAILS:
Analyzing file:///SOME-PATH/sample_day.mp4
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Done discovering file:///SOME-PATH/sample_day.mp4
Topology:
container: video/quicktime, variant=(string)iso
audio: audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)12100000000000000000000000000000, rate=(int)44100, channels=(int)2
Tags:
audio codec: MPEG-4 AAC audio
datetime: 2019-03-11T14:00:15Z
encoder: Google
QT atom: buffer of 25 bytes
container format: ISO MP4/M4A
Codec:
Additional info:
None
Stream ID: 931de4ff8cdc5703733661695fa6af53eecd5f61ef6d48d378939f3cc67140bd/002
Language: <unknown>
Channels: 2 (front-left, front-right)
Sample rate: 44100
Depth: 32
Bitrate: 0
Max bitrate: 0
video: video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3.1, profile=(string)high, width=(int)1280, height=(int)720, framerate=(fraction)25/1, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, chroma-format=(string)4:2:0, bit-depth-luma=(uint)8, bit-depth-chroma=(uint)8, parsed=(boolean)true
Tags:
video codec: H.264 / AVC
encoder: Google
Codec:
Additional info:
None
Stream ID: 931de4ff8cdc5703733661695fa6af53eecd5f61ef6d48d378939f3cc67140bd/001
Width: 1280
Height: 720
Depth: 24
Frame rate: 25/1
Pixel aspect ratio: 1/1
Interlaced: false
Bitrate: 0
Max bitrate: 0
Properties:
Duration: 1:09:28.121000000
Seekable: yes
Live: no
Tags:
encoder: Google
