Hi!
I’ve recently switch to GeForce GTX 960 which is said to support compute capability 5.2. And deviceQuery utility from CUDA Samples also prints that cc 5.2 is supported. I am using CUDA Toolkit 7.0 and the latest driver.
However, when i set ‘Code Generation’ property (in MS visual Studio) to “compute_52,sm_52” i get compile-time error:
Error 1 error MSB3721: The command ““C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5\bin\nvcc.exe” -gencode=arch=compute_52,code="sm_52,compute_52" --use-local-env --cl-version 2013 -ccbin “C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\x86_amd64” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5\include” -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v6.5\include" --keep-dir x64\Release -maxrregcount=0 --machine 64 --compile -cudart static -DWIN32 -DWIN64 -DNDEBUG -D_CONSOLE -D_MBCS -Xcompiler “/EHsc /W3 /nologo /O2 /Zi /MD " -o x64\Release\main.cu.obj “C:\Users\dmsuvorov\Documents\Visual Studio 2013\Projects\cuda_test\cuda_test\main.cu”” exited with code 1. C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V120\BuildCustomizations\CUDA 6.5.targets 593 9 cuda_test
And with ‘Code Generation’ set to “compute_50,sm_50” everything works just fine. What am I doing wrong?
Thanks in advance.
