Hi, I’m new to TAO toolkit and I have just finished training my first model of yolov3 with the example notebook.
I’m now trying to use the exported tensorrt engine in my code.
I have this class:
class HostDeviceMem(object):
def __init__(self, host_mem, device_mem):
self.host = host_mem
self.device = device_mem
def __str__(self):
return "Host:\n" + str(self.host) + "\nDevice:\n" + str(self.device)
def __repr__(self):
return self.__str__()
class TrtModel:
This class is copied from: https://stackoverflow.com/questions/59280745/inference-with-tensorrt-engine-file-on-python
and follows instruction provided in the "NVIDIA TensorRT Developer Guide"
def __init__(self, engine_path, max_batch_size=1, dtype=np.float32):
self.engine_path = engine_path
self.dtype = dtype
self.logger = trt.Logger(trt.Logger.WARNING)
self.runtime = trt.Runtime(self.logger)
self.engine = self.load_engine(self.runtime, self.engine_path)
self.engine_batch_size = self.engine.max_batch_size
self.max_batch_size = max_batch_size
self.inputs, self.outputs, self.bindings, self.stream = self.allocate_buffers()
self.context = self.engine.create_execution_context()
@staticmethod
def load_engine(trt_runtime, engine_path):
trt.init_libnvinfer_plugins(None, "")
with open(engine_path, 'rb') as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
def allocate_buffers(self):
inputs = []
outputs = []
bindings = []
stream = cuda.Stream()
for binding in self.engine:
size = trt.volume(self.engine.get_binding_shape(binding)) # * self.max_batch_size
host_mem = cuda.pagelocked_empty(size, self.dtype)
device_mem = cuda.mem_alloc(host_mem.nbytes)
bindings.append(int(device_mem))
if self.engine.binding_is_input(binding):
inputs.append(HostDeviceMem(host_mem, device_mem))
else:
outputs.append(HostDeviceMem(host_mem, device_mem))
return inputs, outputs, bindings, stream
def __call__(self, x: np.ndarray, batch_size=1):
x = x.astype(self.dtype)
np.copyto(self.inputs[0].host, x.ravel())
# np.copyto(self.inputs[1].host, x.ravel())
for inp in self.inputs:
cuda.memcpy_htod_async(inp.device, inp.host, self.stream)
# self.context.execute_async(batch_size=batch_size, bindings=self.bindings, stream_handle=self.stream.handle)
self.context.execute_async(batch_size=self.engine_batch_size, bindings=self.bindings, stream_handle=self.stream.handle)
for out in self.outputs:
cuda.memcpy_dtoh_async(out.host, out.device, self.stream)
self.stream.synchronize()
# return [out.host.reshape(batch_size, -1) for out in self.outputs]
and I want to allocate a TrtModel using the model exported with the notebook but when I do it, I get this error:
[04/19/2022-17:44:59] [TRT] [E] 1: [stdArchiveReader.cpp::StdArchiveReader::35] Error Code 1: Serialization (Serialization assertion safeVersionRead == safeSerializationVersion failed.Version tag does not match. Note: Current Version: 0, Serialized Engine Version: 43)
[04/19/2022-17:44:59] [TRT] [E] 4: [runtime.cpp::deserializeCudaEngine::50] Error Code 4: Internal Error (Engine deserialization failed.)
resulting in a “None” engine.
Can someone explain how to use the exported models from Nvidia TAO? Thank you!
• Hardware (T4/V100/Xavier/Nano/etc):
RTX 2080 Ti
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
YoloV3
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Configuration of the TAO Toolkit Instance
dockers:
nvidia/tao/tao-toolkit-tf:
v3.21.11-tf1.15.5-py3:
docker_registry: nvcr.io
tasks:
1. augment
2. bpnet
3. classification
4. dssd
5. emotionnet
6. efficientdet
7. fpenet
8. gazenet
9. gesturenet
10. heartratenet
11. lprnet
12. mask_rcnn
13. multitask_classification
14. retinanet
15. ssd
16. unet
17. yolo_v3
18. yolo_v4
19. yolo_v4_tiny
20. converter
v3.21.11-tf1.15.4-py3:
tasks:
1. detectnet_v2
2. faster_rcnn
nvidia/tao/tao-toolkit-pyt:
v3.21.11-py3:
tasks:
1. speech_to_text
2. speech_to_text_citrinet
3. text_classification
4. question_answering
5. token_classification
6. intent_slot_classification
7. punctuation_and_capitalization
8. action_recognition
v3.22.02-py3:
tasks:
1. spectro_gen
2. vocoder
nvidia/tao/tao-toolkit-lm:
v3.21.08-py3:
tasks:
1. n_gram
format_version: 2.0
toolkit_version: 3.22.02
published_date: 02/28/2022
• Training spec file(If have, please share here)
Training:
random_seed: 42
yolov3_config {
big_anchor_shape: "[(114.94, 60.67), (159.06, 114.59), (297.59, 176.38)]"
mid_anchor_shape: "[(42.99, 31.91), (79.57, 31.75), (56.80, 56.93)]"
small_anchor_shape: "[(15.60, 13.88), (30.25, 20.25), (20.67, 49.63)]"
matching_neutral_box_iou: 0.7
arch: "resnet"
nlayers: 18
arch_conv_blocks: 2
loss_loc_weight: 0.8
loss_neg_obj_weights: 100.0
loss_class_weights: 1.0
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
batch_size_per_gpu: 8
num_epochs: 80
enable_qat: false
checkpoint_interval: 10
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 1e-6
max_learning_rate: 1e-4
soft_start: 0.1
annealing: 0.5
regularizer {
type: L1
weight: 3e-5
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pretrain_model_path: "/workspace/tao-experiments/yolo_v3/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5"
eval_config {
average_precision_mode: SAMPLE
batch_size: 8
matching_iou_threshold: 0.5
nms_config {
confidence_threshold: 0.001
clustering_iou_threshold: 0.5
top_k: 200
force_on_cpu: True
augmentation_config {
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
horizontal_flip: 0.5
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
randomize_input_shape_period: 0
dataset_config {
data_sources: {
tfrecords_path: "/workspace/tao-experiments/data/tfrecords/kitti_trainval/kitti_trainval*"
image_directory_path: "/workspace/tao-experiments/data/training"
include_difficult_in_training: true
image_extension: "png"
target_class_mapping {
key: "car"
value: "car"
key: "pedestrian"
value: "pedestrian"
key: "cyclist"
value: "cyclist"
key: "van"
value: "car"
key: "person_sitting"
value: "pedestrian"
validation_fold: 0
Re-Training
random_seed: 42
yolov3_config {
arch: "resnet"
nlayers: 18
arch_conv_blocks: 2
freeze_bn: false
#freeze_blocks: 0
force_relu: false
training_config {
num_epochs: 80
enable_qat: false
learning_rate {
soft_start: 0.1
annealing: 0.5
regularizer {
type: NO_REG
weight: 3e-9
optimizer {
adam {
epsilon: 1e-7
beta1: 0.9
beta2: 0.999
amsgrad: false
pruned_model_path: "/workspace/tao-experiments/yolo_v3/experiment_dir_pruned/yolov3_resnet18_pruned.tlt"
eval_config {
batch_size: 8
nms_config {
top_k: 200
force_on_cpu: True
hue: 0.1
saturation: 1.5
exposure:1.5
vertical_flip:0
jitter: 0.3
output_width: 1248
output_height: 384
output_channel: 3
dataset_config {
data_sources: {
key: "car"
value: "car"
key: "pedestrian"
value: "pedestrian"
key: "cyclist"
value: "cyclist"
key: "van"
value: "car"
value: "pedestrian"
validation_fold: 0
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Execute the example notebook “cv_samples_v1.3.0/yolo_v3/yolo_v3.ipynb” and try to instantiate a TrtModel from the above code.
