I am trying to convert a torch model to tensorrt via onnx in two steps.
- Convert torch to onnx using detectron2 script.
- Convert onnx to tensorrt using
/usr/src/tensorrt/bin/trtexec --onnx=model.onnx --saveEngine=model.trt
Step1 looks ok, but in step2 I get the following output
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=model.onnx --saveEngine=model.trt
[09/22/2020-20:58:12] [I] === Model Options ===
[09/22/2020-20:58:12] [I] Format: ONNX
[09/22/2020-20:58:12] [I] Model: model.onnx
[09/22/2020-20:58:12] [I] Output:
[09/22/2020-20:58:12] [I] === Build Options ===
[09/22/2020-20:58:12] [I] Max batch: 1
[09/22/2020-20:58:12] [I] Workspace: 16 MB
[09/22/2020-20:58:12] [I] minTiming: 1
[09/22/2020-20:58:12] [I] avgTiming: 8
[09/22/2020-20:58:12] [I] Precision: FP32
[09/22/2020-20:58:12] [I] Calibration:
[09/22/2020-20:58:12] [I] Safe mode: Disabled
[09/22/2020-20:58:12] [I] Save engine: alexnet.trt
[09/22/2020-20:58:12] [I] Load engine:
[09/22/2020-20:58:12] [I] Builder Cache: Enabled
[09/22/2020-20:58:12] [I] NVTX verbosity: 0
[09/22/2020-20:58:12] [I] Inputs format: fp32:CHW
[09/22/2020-20:58:12] [I] Outputs format: fp32:CHW
[09/22/2020-20:58:12] [I] Input build shapes: model
[09/22/2020-20:58:12] [I] Input calibration shapes: model
[09/22/2020-20:58:12] [I] === System Options ===
[09/22/2020-20:58:12] [I] Device: 0
[09/22/2020-20:58:12] [I] DLACore:
[09/22/2020-20:58:12] [I] Plugins:
[09/22/2020-20:58:12] [I] === Inference Options ===
[09/22/2020-20:58:12] [I] Batch: 1
[09/22/2020-20:58:12] [I] Input inference shapes: model
[09/22/2020-20:58:12] [I] Iterations: 10
[09/22/2020-20:58:12] [I] Duration: 3s (+ 200ms warm up)
[09/22/2020-20:58:12] [I] Sleep time: 0ms
[09/22/2020-20:58:12] [I] Streams: 1
[09/22/2020-20:58:12] [I] ExposeDMA: Disabled
[09/22/2020-20:58:12] [I] Spin-wait: Disabled
[09/22/2020-20:58:12] [I] Multithreading: Disabled
[09/22/2020-20:58:12] [I] CUDA Graph: Disabled
[09/22/2020-20:58:12] [I] Skip inference: Disabled
[09/22/2020-20:58:12] [I] Inputs:
[09/22/2020-20:58:12] [I] === Reporting Options ===
[09/22/2020-20:58:12] [I] Verbose: Disabled
[09/22/2020-20:58:12] [I] Averages: 10 inferences
[09/22/2020-20:58:12] [I] Percentile: 99
[09/22/2020-20:58:12] [I] Dump output: Disabled
[09/22/2020-20:58:12] [I] Profile: Disabled
[09/22/2020-20:58:12] [I] Export timing to JSON file:
[09/22/2020-20:58:12] [I] Export output to JSON file:
[09/22/2020-20:58:12] [I] Export profile to JSON file:
Input filename: model.onnx
ONNX IR version: 0.0.6
Opset version: 11
Producer name: pytorch
Producer version: 1.6
Domain:
Model version: 0
Doc string:
[09/22/2020-20:58:15] [I] [TRT] ModelImporter.cpp:135: No importer registered for op: AliasWithName. Attempting to import as plugin.
[09/22/2020-20:58:15] [I] [TRT] builtin_op_importers.cpp:3659: Searching for plugin: AliasWithName, plugin_version: 1, plugin_namespace:
[09/22/2020-20:58:15] [E] [TRT] INVALID_ARGUMENT: getPluginCreator could not find plugin AliasWithName version 1
ERROR: builtin_op_importers.cpp:3661 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
[09/22/2020-20:58:15] [E] Failed to parse onnx file
[09/22/2020-20:58:15] [E] Parsing model failed
[09/22/2020-20:58:15] [E] Engine creation failed
[09/22/2020-20:58:15] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=model.onnx --saveEngine=model.trt
Can you please help? Thanks
