I’m trying to force powermizer to only use level 0 for powersaving purposes, but nothing I’ve tried has worked.
So far I tried:
options nvidia NVreg_RegistryDwords="PowerMizerEnable=0x1; PowerMizerDefaultAC=0x3; PowerMizerLevelAC=0x3; PowerMizerLevel=0x3; PerfLevelSrc=0x2222;"
and alternatively
options nvidia NVreg_RegistryDwords="OverrideMaxPerf=0x1"
in /etc/modprobe.d/nvidia-user-registry.conf (and I did rebuild my initramfs ater setting these, still didn’t work)
I’ve also tried setting similar settings in /etc/X11/xorg.conf.d/10-nvidia.conf
But nothing seems to work; powermizer just keeps jumping between all levels as it pleases no matter what I do, it’s like the settings just get ignored :(
The only option that got me a reaction was the first one, the reaction was to lock powermizer to level 4 (maximum performance mode), I imagine that would be due to PerfLevelSrc=0x2222
I’m just about at my wit’s end over this issue, any help would be appreciated.
nvidia-bug-report.log.gz (266.4 KB)
System info:
$inxi --admin --verbosity=7 --filter --no-host --width
System:
Kernel: 5.18.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=f87ef1fe-5eec-4ec5-b98c-105742ac8e6d rw quiet
sysrq_always_enabled=1 mitigations=off nowatchdog pci=nommconf
cpufreq.default_governor=powersave apparmor=1 security=apparmor
udev.log_priority=3 acpi_osi=! acpi_osi=Linux "acpi_osi=Windows 2009"
nogpumanager intel_idle.max_cstate=1 i915.enable_gvt=1 i915-enable_fbc=1
iommu=pt intel_iommu=on kvm.ignore_msrs=1 rd.driver.pre=vfio-pci
default_hugepagesz=1G hugepagesz=1G hugepages=0 transparent_hugepage=never
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Distro: Manjaro Linux base: Arch Linux
Machine:
Type: Laptop System: Micro-Star product: GE75 Raider 8SE v: REV:1.0
serial: <superuser required> Chassis: type: 10 serial: <superuser required>
Mobo: Micro-Star model: MS-17E2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E17E2IMS.11A date: 05/19/2020
Battery:
ID-1: BAT1 charge: 32.7 Wh (77.7%) condition: 42.1/53.4 Wh (78.7%)
volts: 11.5 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A status: N/A
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
status: discharging
Memory:
RAM: total: 31.19 GiB used: 3.8 GiB (12.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
CPU:
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache:
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 952 high: 1367 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 970 2: 800 3: 800 4: 800
5: 1273 6: 802 7: 1108 8: 922 9: 800 10: 1367 11: 987 12: 800
bogomips: 52815
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities:
Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: mmio_stale_data status: Vulnerable
Type: retbleed status: Vulnerable
Type: spec_store_bypass status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable
Type: tsx_async_abort status: Not affected
Graphics:
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f11
class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.67x14.41")
s-diag: 748mm (29.44")
Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x409d built: 2018
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Audio:
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.18.17-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Network:
Device-1: Intel Cannon Lake PCH CNVi WiFi vendor: Rivet Networks Killer
Wireless-AC 1550i Wireless driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 05:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
WAN IP: <filter>
Bluetooth:
Message: No bluetooth data found.
Logical:
Message: No logical block device data found.
RAID:
Message: No RAID data found.
Drives:
Local Storage: total: 2.07 TiB used: 1.83 TiB (88.3%)
SMART Message: Unable to run smartctl. Root privileges required.
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3256GJ size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK11.C temp: 42.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS100T2B0B-00YS70 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: KingSpec model: ACSC4M1TS25
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4H scheme: GPT
Message: No optical or floppy data found.
Partition:
ID-1: / raw-size: 113.18 GiB size: 110.84 GiB (97.94%) used: 76.35 GiB
(68.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: root
uuid: f87ef1fe-5eec-4ec5-b98c-105742ac8e6d
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 1.8 MiB
(0.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 2FA5-9041
ID-3: /run/media/rabcor/86069E6C069E5D4D raw-size: 124.98 GiB size: 124.98
GiB (100.00%) used: 55.12 GiB (44.1%) fs: ntfs dev: /dev/nvme0n1p4
maj-min: 259:4 label: N/A uuid: 86069E6C069E5D4D
ID-4: /run/media/rabcor/KingSpec raw-size: 953.87 GiB size: 953.4 GiB
(99.95%) used: 944.91 GiB (99.1%) fs: xfs dev: /dev/sdb1 maj-min: 8:17
label: N/A uuid: 7081018e-cce8-4d7d-b093-bb681ff46b8e
ID-5: /run/media/rabcor/WD raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 798.66 GiB (85.7%) fs: f2fs dev: /dev/sda1 maj-min: 8:1
label: Western Digital uuid: ae81d12d-6838-4833-b47b-8dd120364382
Swap:
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Unmounted:
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-2:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7:3 info: Realtek RTS5129 Card Reader Controller
type: <vendor specific> driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-9:4 info: SteelSeries ApS KLC type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 300mA chip-ID: 1038:1122 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Sensors:
System Temperatures: cpu: 49.0 C pch: 52.0 C mobo: N/A gpu: nvidia
temp: 51 C
Fan Speeds (RPM): N/A
Info:
Processes: 339 Uptime: 10m wakeups: 3 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 alt: 11
clang: 14.0.6 Packages: pm: pacman pkgs: 1614 libs: 496 tools: pamac,yay
pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Update: I was able to use sudo nvidia-smi -lgc 300,645 to limit the clock speed the same way powermizer would at level 0, however -lmc is not supported so I can’t limit the memory speed (and it likes to really ramp up at every opportunity so al ot of power gets lost to that still)
