suchb
November 5, 2019, 3:53am
#1
In my case there is a 3840x2160@30fps pre-configured mipi csi video connect to TX2 mipi csi-2 port (4lane).
I got below trace log when run ‘v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw’.
I really need help here.
root@nvidia:~# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 2246/2246 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/1:1-728 [001] .... 550.086310: rtos_queue_peek_from_isr_failed: tstamp:17573044936 queue:0x0b4b4500
kworker/1:1-728 [001] .... 550.086319: rtcpu_start: tstamp:17573047028
kworker/1:1-728 [001] .... 550.086321: rtos_queue_send_from_isr_failed: tstamp:17573061072 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.086325: rtos_queue_send_from_isr_failed: tstamp:17573061177 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.086325: rtos_queue_send_from_isr_failed: tstamp:17573061281 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.086326: rtos_queue_send_from_isr_failed: tstamp:17573061385 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.086326: rtos_queue_send_from_isr_failed: tstamp:17573061486 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.086327: rtos_queue_send_from_isr_failed: tstamp:17573061586 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.086328: rtos_queue_send_from_isr_failed: tstamp:17573061691 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.086328: rtos_queue_send_from_isr_failed: tstamp:17573061792 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.086330: rtos_queue_send_failed: tstamp:17573062286 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.086331: rtos_queue_send_from_isr_failed: tstamp:17573070376 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.086332: rtos_queue_send_from_isr_failed: tstamp:17573070481 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.086333: rtos_queue_send_from_isr_failed: tstamp:17573070583 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.086333: rtos_queue_send_from_isr_failed: tstamp:17573070686 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.086334: rtos_queue_send_from_isr_failed: tstamp:17573070787 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.086335: rtos_queue_send_from_isr_failed: tstamp:17573070888 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.086335: rtos_queue_send_from_isr_failed: tstamp:17573070991 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.086336: rtos_queue_send_from_isr_failed: tstamp:17573071092 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.086337: rtos_queue_send_failed: tstamp:17573071985 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.086340: rtcpu_vinotify_event: tstamp:17573145673 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:17573145296 data:0x00000001
kworker/1:1-728 [001] .... 550.086341: rtcpu_vinotify_event: tstamp:17573735474 tag:CHANSEL_PXL_SOF channel:0x00 frame:15010 vi_tstamp:17573734949 data:0x00000001
kworker/1:1-728 [001] .... 550.086342: rtcpu_vinotify_event: tstamp:17573735639 tag:ATOMP_FS channel:0x00 frame:15010 vi_tstamp:17573734957 data:0x00000000
kworker/1:1-728 [001] .... 550.086344: rtcpu_vinotify_event: tstamp:17573740161 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:15010 vi_tstamp:17573739796 data:0x08000000
kworker/1:1-728 [001] .... 550.142342: rtcpu_vinotify_event: tstamp:17574778069 tag:CHANSEL_FAULT channel:0x00 frame:15010 vi_tstamp:17574777181 data:0x027d0200
kworker/1:1-728 [001] .... 550.142351: rtcpu_vinotify_event: tstamp:17574778307 tag:CSIMUX_FRAME channel:0x00 frame:15010 vi_tstamp:17574777189 data:0x000000a0
kworker/1:1-728 [001] .... 550.142354: rtcpu_vinotify_event: tstamp:17574778474 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:15010 vi_tstamp:17574777189 data:0x00000001
kworker/1:1-728 [001] .... 550.142356: rtcpu_vinotify_event: tstamp:17574778645 tag:ATOMP_FE channel:0x00 frame:15010 vi_tstamp:17574777193 data:0x00000000
kworker/1:1-728 [001] .... 550.254282: rtos_queue_peek_from_isr_failed: tstamp:17578045296 queue:0x0b4b4500
kworker/1:1-728 [001] .... 550.310326: rtos_queue_send_from_isr_failed: tstamp:17580053370 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310339: rtos_queue_send_from_isr_failed: tstamp:17580053529 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.310341: rtos_queue_send_from_isr_failed: tstamp:17580053670 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.310342: rtos_queue_send_from_isr_failed: tstamp:17580053828 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.310345: rtos_queue_send_from_isr_failed: tstamp:17580053985 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.310347: rtos_queue_send_from_isr_failed: tstamp:17580054132 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.310348: rtos_queue_send_from_isr_failed: tstamp:17580054269 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.310350: rtos_queue_send_from_isr_failed: tstamp:17580054405 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.310359: rtos_queue_send_failed: tstamp:17580055143 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310368: rtos_queue_send_from_isr_failed: tstamp:17580061682 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310369: rtos_queue_send_from_isr_failed: tstamp:17580061821 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.310371: rtos_queue_send_from_isr_failed: tstamp:17580061960 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.310373: rtos_queue_send_from_isr_failed: tstamp:17580062100 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.310375: rtos_queue_send_from_isr_failed: tstamp:17580062236 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.310376: rtos_queue_send_from_isr_failed: tstamp:17580062373 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.310378: rtos_queue_send_from_isr_failed: tstamp:17580062511 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.310380: rtos_queue_send_from_isr_failed: tstamp:17580062648 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.310382: rtos_queue_send_failed: tstamp:17580063203 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310385: rtos_queue_send_from_isr_failed: tstamp:17580071888 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310386: rtos_queue_send_from_isr_failed: tstamp:17580072027 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.310388: rtos_queue_send_from_isr_failed: tstamp:17580072166 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.310390: rtos_queue_send_from_isr_failed: tstamp:17580072308 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.310392: rtos_queue_send_from_isr_failed: tstamp:17580072446 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.310393: rtos_queue_send_from_isr_failed: tstamp:17580072584 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.310395: rtos_queue_send_from_isr_failed: tstamp:17580072722 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.310397: rtos_queue_send_from_isr_failed: tstamp:17580072859 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.310399: rtos_queue_send_failed: tstamp:17580073425 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310402: rtos_queue_send_from_isr_failed: tstamp:17580080120 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310403: rtos_queue_send_from_isr_failed: tstamp:17580080258 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.310405: rtos_queue_send_from_isr_failed: tstamp:17580080397 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.310407: rtos_queue_send_from_isr_failed: tstamp:17580080536 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.310409: rtos_queue_send_from_isr_failed: tstamp:17580080681 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.310410: rtos_queue_send_from_isr_failed: tstamp:17580080818 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.310412: rtos_queue_send_from_isr_failed: tstamp:17580080956 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.310414: rtos_queue_send_from_isr_failed: tstamp:17580081093 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.310416: rtos_queue_send_failed: tstamp:17580082465 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.310426: rtcpu_vinotify_event: tstamp:17580085174 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:17580084789 data:0x00000001
kworker/1:1-728 [001] .... 550.366399: rtcpu_vinotify_event: tstamp:17581034452 tag:CHANSEL_PXL_SOF channel:0x00 frame:15017 vi_tstamp:17581033883 data:0x00000001
kworker/1:1-728 [001] .... 550.366411: rtcpu_vinotify_event: tstamp:17581034687 tag:ATOMP_FS channel:0x00 frame:15017 vi_tstamp:17581033891 data:0x00000000
kworker/1:1-728 [001] .... 550.366415: rtcpu_vinotify_event: tstamp:17581040178 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:15017 vi_tstamp:17581039795 data:0x08000000
kworker/1:1-728 [001] .... 550.366418: rtcpu_vinotify_event: tstamp:17582076897 tag:CSIMUX_FRAME channel:0x00 frame:15017 vi_tstamp:17582076123 data:0x000000a0
kworker/1:1-728 [001] .... 550.366421: rtcpu_vinotify_event: tstamp:17582077146 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:15017 vi_tstamp:17582076124 data:0x00000001
kworker/1:1-728 [001] .... 550.366425: rtcpu_vinotify_event: tstamp:17582077342 tag:ATOMP_FE channel:0x00 frame:15017 vi_tstamp:17582076127 data:0x00000000
kworker/1:1-728 [001] .... 550.422395: rtos_queue_peek_from_isr_failed: tstamp:17583045353 queue:0x0b4b4500
kworker/1:1-728 [001] .... 550.534258: rtos_queue_send_from_isr_failed: tstamp:17587302617 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534266: rtos_queue_send_from_isr_failed: tstamp:17587302776 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.534268: rtos_queue_send_from_isr_failed: tstamp:17587302918 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.534269: rtos_queue_send_from_isr_failed: tstamp:17587303056 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.534270: rtos_queue_send_from_isr_failed: tstamp:17587303194 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.534271: rtos_queue_send_from_isr_failed: tstamp:17587303331 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.534273: rtos_queue_send_from_isr_failed: tstamp:17587303470 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.534274: rtos_queue_send_from_isr_failed: tstamp:17587303606 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.534280: rtos_queue_send_failed: tstamp:17587304334 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534284: rtos_queue_send_from_isr_failed: tstamp:17587309833 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534285: rtos_queue_send_from_isr_failed: tstamp:17587309995 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.534287: rtos_queue_send_from_isr_failed: tstamp:17587310134 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.534288: rtos_queue_send_from_isr_failed: tstamp:17587310274 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.534289: rtos_queue_send_from_isr_failed: tstamp:17587310410 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.534290: rtos_queue_send_from_isr_failed: tstamp:17587310547 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.534291: rtos_queue_send_from_isr_failed: tstamp:17587310685 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.534292: rtos_queue_send_from_isr_failed: tstamp:17587310823 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.534294: rtos_queue_send_failed: tstamp:17587311396 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534296: rtos_queue_send_from_isr_failed: tstamp:17587319765 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534297: rtos_queue_send_from_isr_failed: tstamp:17587319904 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.534298: rtos_queue_send_from_isr_failed: tstamp:17587320044 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.534300: rtos_queue_send_from_isr_failed: tstamp:17587320184 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.534301: rtos_queue_send_from_isr_failed: tstamp:17587320323 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.534302: rtos_queue_send_from_isr_failed: tstamp:17587320480 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.534303: rtos_queue_send_from_isr_failed: tstamp:17587320617 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.534305: rtos_queue_send_from_isr_failed: tstamp:17587320774 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.534306: rtos_queue_send_failed: tstamp:17587321337 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534308: rtos_queue_send_from_isr_failed: tstamp:17587327893 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534309: rtos_queue_send_from_isr_failed: tstamp:17587328033 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.534311: rtos_queue_send_from_isr_failed: tstamp:17587328173 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.534312: rtos_queue_send_from_isr_failed: tstamp:17587328312 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.534313: rtos_queue_send_from_isr_failed: tstamp:17587328451 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.534314: rtos_queue_send_from_isr_failed: tstamp:17587328588 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.534315: rtos_queue_send_from_isr_failed: tstamp:17587328725 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.534316: rtos_queue_send_from_isr_failed: tstamp:17587328863 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.534318: rtos_queue_send_failed: tstamp:17587330462 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.534324: rtcpu_vinotify_event: tstamp:17587331681 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:17587329966 data:0x00000001
kworker/1:1-728 [001] .... 550.590261: rtos_queue_peek_from_isr_failed: tstamp:17588045373 queue:0x0b4b4500
kworker/1:1-728 [001] .... 550.590276: rtcpu_vinotify_event: tstamp:17588333347 tag:CHANSEL_PXL_SOF channel:0x00 frame:15024 vi_tstamp:17588332817 data:0x00000001
kworker/1:1-728 [001] .... 550.590279: rtcpu_vinotify_event: tstamp:17588333572 tag:ATOMP_FS channel:0x00 frame:15024 vi_tstamp:17588332824 data:0x00000000
kworker/1:1-728 [001] .... 550.590281: rtcpu_vinotify_event: tstamp:17588337582 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:15024 vi_tstamp:17588337199 data:0x08000000
kworker/1:1-728 [001] .... 550.590283: rtcpu_vinotify_event: tstamp:17589375828 tag:CSIMUX_FRAME channel:0x00 frame:15024 vi_tstamp:17589375057 data:0x000000a0
kworker/1:1-728 [001] .... 550.590286: rtcpu_vinotify_event: tstamp:17589376077 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:15024 vi_tstamp:17589375057 data:0x00000001
kworker/1:1-728 [001] .... 550.590288: rtcpu_vinotify_event: tstamp:17589376248 tag:ATOMP_FE channel:0x00 frame:15024 vi_tstamp:17589375060 data:0x00000000
kworker/1:1-728 [001] .... 550.702278: rtos_queue_peek_from_isr_failed: tstamp:17593045405 queue:0x0b4b4500
kworker/1:1-728 [001] .... 550.758275: rtos_queue_send_from_isr_failed: tstamp:17594680234 queue:0x0b4a7258
kworker/1:1-728 [001] .... 550.758289: rtos_queue_send_from_isr_failed: tstamp:17594680438 queue:0x0b4aad68
kworker/1:1-728 [001] .... 550.758291: rtos_queue_send_from_isr_failed: tstamp:17594680617 queue:0x0b4ac998
kworker/1:1-728 [001] .... 550.758293: rtos_queue_send_from_isr_failed: tstamp:17594680792 queue:0x0b4ae518
kworker/1:1-728 [001] .... 550.758295: rtos_queue_send_from_isr_failed: tstamp:17594680964 queue:0x0b4af2d8
kworker/1:1-728 [001] .... 550.758297: rtos_queue_send_from_isr_failed: tstamp:17594681139 queue:0x0b4b0098
kworker/1:1-728 [001] .... 550.758299: rtos_queue_send_from_isr_failed: tstamp:17594681317 queue:0x0b4b0e58
kworker/1:1-728 [001] .... 550.758301: rtos_queue_send_from_isr_failed: tstamp:17594681504 queue:0x0b4b1c18
kworker/1:1-728 [001] .... 550.758310: rtos_queue_send_failed: tstamp:17594682435 queue:0x0b4a7258
Hi suchb,
From your trace log ,i can see that VI is able to recognise Frame start.
Since the incoming frame length is less than actual frame length, VI reporting that as tag:CHANSEL_SHORT_FRAME.
Modifying active_w and active_h device tree entries according to your sensor output should solve your problem.
suchb
November 5, 2019, 7:32am
#3
Thank you, velmurugan.s
Is there any documentcan help me to analysis trace log?
How do you know the meaning of those words:CHANSEL_LOAD_FRAMED CHANSEL_FAULT CHANSEL_SHORT_FRAME…by reading the kernel code or some thing else.
suchb
November 5, 2019, 7:43am
#4
Hi suchb,
Hello velmurugan.s
some of my device tree as follows,
active_w = "3840";
active_h = "2160";
mode_type = "yuv";
pixel_phase = "uyvy";
csi_pixel_bit_depth = "16";
pixel_t = "yuv_uyvy16";
readout_orientation = "90";
line_length = "2200";
The sensor output active_w and active_h should be 3840x2160,but I don’t know what line_length should be.
Hey suchb,
You can edit your V4L command to find the correct frame length, try something like this:
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw --set-fmt-video=width=3840,height=xxxx,pixelformat=RG12
This way you don’t have to keep changing and updating your DTSI’s until you find the correct resolution.
You can find some description of these messages on page 2784 in the Tegra technical reference manual which you can download from:
There’s also some information about decoding the FAULT message here:
https://elinux.org/Jetson_TX2_Camera_BringUp
Good luck!
suchb
November 5, 2019, 7:52am
#6
Hey suchb,
https://developer.nvidia.com/embedded/downloads#?tx=$product,jetson_tx2
Good luck!
Hi IceBlackz,
Thank you for your infomation.
It helps me a lot.
suchb
November 6, 2019, 10:29am
#7
hello,
I modify as bellow,
line_length = "2280";
active_w = "3840";
active_h = "2160";
and run v4l2-ctl command again:
# tracer: nop
# entries-in-buffer/entries-written: 1870/1870 #P:6
# _-----=> irqs-off
# ||| / delay
kworker/2:0-6396 [002] .... 2925.113511: rtos_queue_peek_from_isr_failed: tstamp:91793099482 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2925.281527: rtos_queue_peek_from_isr_failed: tstamp:91798099485 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2925.449514: rtos_queue_peek_from_isr_failed: tstamp:91803099495 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2925.561494: rtos_queue_peek_from_isr_failed: tstamp:91808099504 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2925.729475: rtos_queue_peek_from_isr_failed: tstamp:91813099511 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2925.897507: rtos_queue_peek_from_isr_failed: tstamp:91818099516 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.065467: rtos_queue_send_from_isr_failed: tstamp:91822371405 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.065485: rtos_queue_send_from_isr_failed: tstamp:91822371529 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.065493: rtos_queue_send_from_isr_failed: tstamp:91822371633 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.065501: rtos_queue_send_from_isr_failed: tstamp:91822371741 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.065508: rtos_queue_send_from_isr_failed: tstamp:91822371842 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.065515: rtos_queue_send_from_isr_failed: tstamp:91822371943 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.065672: rtos_queue_send_from_isr_failed: tstamp:91822372044 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.065679: rtos_queue_send_from_isr_failed: tstamp:91822372145 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.065689: rtos_queue_send_failed: tstamp:91822372587 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.065698: rtos_queue_send_from_isr_failed: tstamp:91822378957 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.065705: rtos_queue_send_from_isr_failed: tstamp:91822379062 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.065712: rtos_queue_send_from_isr_failed: tstamp:91822379166 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.065719: rtos_queue_send_from_isr_failed: tstamp:91822379269 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.065726: rtos_queue_send_from_isr_failed: tstamp:91822379370 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.065734: rtos_queue_send_from_isr_failed: tstamp:91822379472 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.065741: rtos_queue_send_from_isr_failed: tstamp:91822379571 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.065748: rtos_queue_send_from_isr_failed: tstamp:91822379673 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.065755: rtos_queue_send_failed: tstamp:91822380566 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.065766: rtcpu_vinotify_event: tstamp:91822447441 tag:CSIMUX_STREAM channel:0xff frame:0 vi_tstamp:91822447065 data:0x00000001
kworker/2:0-6396 [002] .... 2926.065774: rtcpu_vinotify_event: tstamp:91822838707 tag:CHANSEL_PXL_SOF channel:0x00 frame:18167 vi_tstamp:91822838195 data:0x00000001
kworker/2:0-6396 [002] .... 2926.065781: rtcpu_vinotify_event: tstamp:91822838866 tag:ATOMP_FS channel:0x00 frame:18167 vi_tstamp:91822838202 data:0x00000000
kworker/2:0-6396 [002] .... 2926.065788: rtcpu_vinotify_event: tstamp:91822840778 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:18167 vi_tstamp:91822840414 data:0x08000000
kworker/2:0-6396 [002] .... 2926.065796: rtcpu_vinotify_event: tstamp:91822908534 tag:CHANSEL_FAULT channel:0x00 frame:18167 vi_tstamp:91822908165 data:0x00310200
kworker/2:0-6396 [002] .... 2926.065803: rtcpu_vinotify_event: tstamp:91822909315 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:18167 vi_tstamp:91822908670 data:0x08000000
kworker/2:0-6396 [002] .... 2926.065810: rtcpu_vinotify_event: tstamp:91822909421 tag:CHANSEL_FAULT_FE channel:0x01 frame:18167 vi_tstamp:91822908670 data:0x00000001
kworker/2:0-6396 [002] .... 2926.065817: rtcpu_vinotify_event: tstamp:91822909557 tag:ATOMP_FE channel:0x00 frame:18167 vi_tstamp:91822908673 data:0x00000000
kworker/2:0-6396 [002] .... 2926.065826: rtos_queue_peek_from_isr_failed: tstamp:91823099500 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.233501: rtos_queue_peek_from_isr_failed: tstamp:91828099528 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.289493: rtos_queue_send_from_isr_failed: tstamp:91829150082 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289504: rtos_queue_send_from_isr_failed: tstamp:91829150206 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.289512: rtos_queue_send_from_isr_failed: tstamp:91829150319 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.289519: rtos_queue_send_from_isr_failed: tstamp:91829150432 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.289526: rtos_queue_send_from_isr_failed: tstamp:91829150541 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.289633: rtos_queue_send_from_isr_failed: tstamp:91829150650 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.289641: rtos_queue_send_from_isr_failed: tstamp:91829150760 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.289649: rtos_queue_send_from_isr_failed: tstamp:91829150870 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.289657: rtos_queue_send_failed: tstamp:91829151442 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289664: rtos_queue_send_from_isr_failed: tstamp:91829155929 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289672: rtos_queue_send_from_isr_failed: tstamp:91829156052 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.289679: rtos_queue_send_from_isr_failed: tstamp:91829156162 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.289686: rtos_queue_send_from_isr_failed: tstamp:91829156275 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.289694: rtos_queue_send_from_isr_failed: tstamp:91829156385 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.289701: rtos_queue_send_from_isr_failed: tstamp:91829156494 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.289709: rtos_queue_send_from_isr_failed: tstamp:91829156603 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.289716: rtos_queue_send_from_isr_failed: tstamp:91829156712 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.289723: rtos_queue_send_failed: tstamp:91829157166 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289731: rtos_queue_send_from_isr_failed: tstamp:91829165508 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289738: rtos_queue_send_from_isr_failed: tstamp:91829165629 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.289745: rtos_queue_send_from_isr_failed: tstamp:91829165739 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.289753: rtos_queue_send_from_isr_failed: tstamp:91829165851 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.289760: rtos_queue_send_from_isr_failed: tstamp:91829165960 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.289767: rtos_queue_send_from_isr_failed: tstamp:91829166070 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.289775: rtos_queue_send_from_isr_failed: tstamp:91829166179 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.289782: rtos_queue_send_from_isr_failed: tstamp:91829166289 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.289789: rtos_queue_send_failed: tstamp:91829166744 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289797: rtos_queue_send_from_isr_failed: tstamp:91829171833 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.289804: rtos_queue_send_from_isr_failed: tstamp:91829171944 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.289812: rtos_queue_send_from_isr_failed: tstamp:91829172055 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.289819: rtos_queue_send_from_isr_failed: tstamp:91829172167 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.289826: rtos_queue_send_from_isr_failed: tstamp:91829172276 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.289833: rtos_queue_send_from_isr_failed: tstamp:91829172386 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.289841: rtos_queue_send_from_isr_failed: tstamp:91829172495 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.289848: rtos_queue_send_from_isr_failed: tstamp:91829172604 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.289855: rtos_queue_send_failed: tstamp:91829173580 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.401503: rtos_queue_peek_from_isr_failed: tstamp:91833099540 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.457493: rtos_queue_send_from_isr_failed: tstamp:91835526598 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457504: rtos_queue_send_from_isr_failed: tstamp:91835526730 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.457512: rtos_queue_send_from_isr_failed: tstamp:91835526860 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.457519: rtos_queue_send_from_isr_failed: tstamp:91835526970 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.457526: rtos_queue_send_from_isr_failed: tstamp:91835527079 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.457624: rtos_queue_send_from_isr_failed: tstamp:91835527187 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.457632: rtos_queue_send_from_isr_failed: tstamp:91835527296 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.457639: rtos_queue_send_from_isr_failed: tstamp:91835527420 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.457647: rtos_queue_send_failed: tstamp:91835528070 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457655: rtos_queue_send_from_isr_failed: tstamp:91835532488 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457662: rtos_queue_send_from_isr_failed: tstamp:91835532608 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.457669: rtos_queue_send_from_isr_failed: tstamp:91835532718 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.457677: rtos_queue_send_from_isr_failed: tstamp:91835532830 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.457684: rtos_queue_send_from_isr_failed: tstamp:91835532940 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.457691: rtos_queue_send_from_isr_failed: tstamp:91835533049 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.457699: rtos_queue_send_from_isr_failed: tstamp:91835533158 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.457706: rtos_queue_send_from_isr_failed: tstamp:91835533267 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.457714: rtos_queue_send_failed: tstamp:91835533725 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457721: rtos_queue_send_from_isr_failed: tstamp:91835541826 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457728: rtos_queue_send_from_isr_failed: tstamp:91835541938 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.457735: rtos_queue_send_from_isr_failed: tstamp:91835542048 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.457743: rtos_queue_send_from_isr_failed: tstamp:91835542158 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.457750: rtos_queue_send_from_isr_failed: tstamp:91835542268 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.457757: rtos_queue_send_from_isr_failed: tstamp:91835542377 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.457765: rtos_queue_send_from_isr_failed: tstamp:91835542488 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.457772: rtos_queue_send_from_isr_failed: tstamp:91835542597 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.457779: rtos_queue_send_failed: tstamp:91835543050 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457786: rtos_queue_send_from_isr_failed: tstamp:91835547895 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.457794: rtos_queue_send_from_isr_failed: tstamp:91835548005 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.457801: rtos_queue_send_from_isr_failed: tstamp:91835548115 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.457808: rtos_queue_send_from_isr_failed: tstamp:91835548225 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.457815: rtos_queue_send_from_isr_failed: tstamp:91835548334 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.457823: rtos_queue_send_from_isr_failed: tstamp:91835548443 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.457830: rtos_queue_send_from_isr_failed: tstamp:91835548564 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.457837: rtos_queue_send_from_isr_failed: tstamp:91835548675 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.457845: rtos_queue_send_failed: tstamp:91835549670 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.569480: rtos_queue_peek_from_isr_failed: tstamp:91838099545 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.681484: rtos_queue_send_from_isr_failed: tstamp:91841899371 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681496: rtos_queue_send_from_isr_failed: tstamp:91841899491 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.681504: rtos_queue_send_from_isr_failed: tstamp:91841899603 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.681511: rtos_queue_send_from_isr_failed: tstamp:91841899717 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.681518: rtos_queue_send_from_isr_failed: tstamp:91841899827 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.681628: rtos_queue_send_from_isr_failed: tstamp:91841899936 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.681635: rtos_queue_send_from_isr_failed: tstamp:91841900046 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.681642: rtos_queue_send_from_isr_failed: tstamp:91841900155 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.681650: rtos_queue_send_failed: tstamp:91841900796 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681658: rtos_queue_send_from_isr_failed: tstamp:91841905294 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681665: rtos_queue_send_from_isr_failed: tstamp:91841905407 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.681673: rtos_queue_send_from_isr_failed: tstamp:91841905518 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.681680: rtos_queue_send_from_isr_failed: tstamp:91841905630 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.681688: rtos_queue_send_from_isr_failed: tstamp:91841905741 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.681695: rtos_queue_send_from_isr_failed: tstamp:91841905850 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.681702: rtos_queue_send_from_isr_failed: tstamp:91841905960 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.681709: rtos_queue_send_from_isr_failed: tstamp:91841906069 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.681717: rtos_queue_send_failed: tstamp:91841906543 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681724: rtos_queue_send_from_isr_failed: tstamp:91841914989 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681732: rtos_queue_send_from_isr_failed: tstamp:91841915103 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.681739: rtos_queue_send_from_isr_failed: tstamp:91841915215 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.681746: rtos_queue_send_from_isr_failed: tstamp:91841915329 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.681754: rtos_queue_send_from_isr_failed: tstamp:91841915438 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.681761: rtos_queue_send_from_isr_failed: tstamp:91841915549 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.681768: rtos_queue_send_from_isr_failed: tstamp:91841915662 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.681775: rtos_queue_send_from_isr_failed: tstamp:91841915771 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.681783: rtos_queue_send_failed: tstamp:91841916239 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681790: rtos_queue_send_from_isr_failed: tstamp:91841920979 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681798: rtos_queue_send_from_isr_failed: tstamp:91841921091 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.681805: rtos_queue_send_from_isr_failed: tstamp:91841921207 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.681812: rtos_queue_send_from_isr_failed: tstamp:91841921318 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.681824: rtos_queue_send_from_isr_failed: tstamp:91841921427 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.681833: rtos_queue_send_from_isr_failed: tstamp:91841921536 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.681841: rtos_queue_send_from_isr_failed: tstamp:91841921646 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.681849: rtos_queue_send_from_isr_failed: tstamp:91841921757 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.681856: rtos_queue_send_failed: tstamp:91841922756 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.681864: rtos_queue_peek_from_isr_failed: tstamp:91843099551 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.849598: rtos_queue_peek_from_isr_failed: tstamp:91848099556 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2926.849611: rtos_queue_send_from_isr_failed: tstamp:91848274645 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849619: rtos_queue_send_from_isr_failed: tstamp:91848274760 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.849627: rtos_queue_send_from_isr_failed: tstamp:91848274873 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.849634: rtos_queue_send_from_isr_failed: tstamp:91848274983 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.849641: rtos_queue_send_from_isr_failed: tstamp:91848275093 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.849648: rtos_queue_send_from_isr_failed: tstamp:91848275202 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.849655: rtos_queue_send_from_isr_failed: tstamp:91848275311 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.849662: rtos_queue_send_from_isr_failed: tstamp:91848275423 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.849670: rtos_queue_send_failed: tstamp:91848276050 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849677: rtos_queue_send_from_isr_failed: tstamp:91848280871 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849684: rtos_queue_send_from_isr_failed: tstamp:91848280983 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.849691: rtos_queue_send_from_isr_failed: tstamp:91848281093 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.849699: rtos_queue_send_from_isr_failed: tstamp:91848281203 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.849706: rtos_queue_send_from_isr_failed: tstamp:91848281317 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.849713: rtos_queue_send_from_isr_failed: tstamp:91848281426 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.849720: rtos_queue_send_from_isr_failed: tstamp:91848281535 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.849727: rtos_queue_send_from_isr_failed: tstamp:91848281644 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.849734: rtos_queue_send_failed: tstamp:91848282098 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849741: rtos_queue_send_from_isr_failed: tstamp:91848289759 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849749: rtos_queue_send_from_isr_failed: tstamp:91848289870 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.849756: rtos_queue_send_from_isr_failed: tstamp:91848289982 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.849763: rtos_queue_send_from_isr_failed: tstamp:91848290104 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.849770: rtos_queue_send_from_isr_failed: tstamp:91848290213 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.849777: rtos_queue_send_from_isr_failed: tstamp:91848290322 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.849784: rtos_queue_send_from_isr_failed: tstamp:91848290430 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.849791: rtos_queue_send_from_isr_failed: tstamp:91848290539 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.849799: rtos_queue_send_failed: tstamp:91848290998 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849806: rtos_queue_send_from_isr_failed: tstamp:91848295659 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2926.849813: rtos_queue_send_from_isr_failed: tstamp:91848295770 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2926.849821: rtos_queue_send_from_isr_failed: tstamp:91848295880 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2926.849828: rtos_queue_send_from_isr_failed: tstamp:91848295992 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2926.849835: rtos_queue_send_from_isr_failed: tstamp:91848296101 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2926.849842: rtos_queue_send_from_isr_failed: tstamp:91848296210 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2926.849849: rtos_queue_send_from_isr_failed: tstamp:91848296320 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2926.849856: rtos_queue_send_from_isr_failed: tstamp:91848296429 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2926.849863: rtos_queue_send_failed: tstamp:91848297423 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.017485: rtos_queue_peek_from_isr_failed: tstamp:91853099564 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2927.073472: rtos_queue_send_from_isr_failed: tstamp:91854649834 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073485: rtos_queue_send_from_isr_failed: tstamp:91854649956 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.073492: rtos_queue_send_from_isr_failed: tstamp:91854650071 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.073499: rtos_queue_send_from_isr_failed: tstamp:91854650182 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.073507: rtos_queue_send_from_isr_failed: tstamp:91854650297 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.073514: rtos_queue_send_from_isr_failed: tstamp:91854650406 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.073612: rtos_queue_send_from_isr_failed: tstamp:91854650516 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.073619: rtos_queue_send_from_isr_failed: tstamp:91854650624 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.073627: rtos_queue_send_failed: tstamp:91854651245 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073635: rtos_queue_send_from_isr_failed: tstamp:91854655464 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073642: rtos_queue_send_from_isr_failed: tstamp:91854655575 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.073650: rtos_queue_send_from_isr_failed: tstamp:91854655686 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.073657: rtos_queue_send_from_isr_failed: tstamp:91854655798 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.073664: rtos_queue_send_from_isr_failed: tstamp:91854655907 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.073671: rtos_queue_send_from_isr_failed: tstamp:91854656021 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.073679: rtos_queue_send_from_isr_failed: tstamp:91854656130 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.073686: rtos_queue_send_from_isr_failed: tstamp:91854656240 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.073694: rtos_queue_send_failed: tstamp:91854656691 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073701: rtos_queue_send_from_isr_failed: tstamp:91854664521 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073708: rtos_queue_send_from_isr_failed: tstamp:91854664646 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.073716: rtos_queue_send_from_isr_failed: tstamp:91854664758 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.073723: rtos_queue_send_from_isr_failed: tstamp:91854664869 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.073730: rtos_queue_send_from_isr_failed: tstamp:91854664978 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.073738: rtos_queue_send_from_isr_failed: tstamp:91854665098 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.073745: rtos_queue_send_from_isr_failed: tstamp:91854665207 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.073752: rtos_queue_send_from_isr_failed: tstamp:91854665315 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.073760: rtos_queue_send_failed: tstamp:91854665776 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073767: rtos_queue_send_from_isr_failed: tstamp:91854670620 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.073774: rtos_queue_send_from_isr_failed: tstamp:91854670732 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.073781: rtos_queue_send_from_isr_failed: tstamp:91854670842 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.073788: rtos_queue_send_from_isr_failed: tstamp:91854670952 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.073796: rtos_queue_send_from_isr_failed: tstamp:91854671062 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.073803: rtos_queue_send_from_isr_failed: tstamp:91854671171 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.073810: rtos_queue_send_from_isr_failed: tstamp:91854671280 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.073818: rtos_queue_send_from_isr_failed: tstamp:91854671392 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.073825: rtos_queue_send_failed: tstamp:91854672373 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.185482: rtos_queue_peek_from_isr_failed: tstamp:91858099583 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2927.297485: rtos_queue_send_from_isr_failed: tstamp:91861024845 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297497: rtos_queue_send_from_isr_failed: tstamp:91861024967 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.297505: rtos_queue_send_from_isr_failed: tstamp:91861025083 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.297512: rtos_queue_send_from_isr_failed: tstamp:91861025193 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.297519: rtos_queue_send_from_isr_failed: tstamp:91861025302 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.297527: rtos_queue_send_from_isr_failed: tstamp:91861025411 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.297534: rtos_queue_send_from_isr_failed: tstamp:91861025519 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.297541: rtos_queue_send_from_isr_failed: tstamp:91861025628 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.297550: rtos_queue_send_failed: tstamp:91861026266 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297557: rtos_queue_send_from_isr_failed: tstamp:91861030377 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297564: rtos_queue_send_from_isr_failed: tstamp:91861030488 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.297572: rtos_queue_send_from_isr_failed: tstamp:91861030600 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.297579: rtos_queue_send_from_isr_failed: tstamp:91861030711 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.297587: rtos_queue_send_from_isr_failed: tstamp:91861030823 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.297594: rtos_queue_send_from_isr_failed: tstamp:91861030932 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.297602: rtos_queue_send_from_isr_failed: tstamp:91861031041 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.297609: rtos_queue_send_from_isr_failed: tstamp:91861031150 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.297616: rtos_queue_send_failed: tstamp:91861031598 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297624: rtos_queue_send_from_isr_failed: tstamp:91861042326 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297631: rtos_queue_send_from_isr_failed: tstamp:91861042436 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.297638: rtos_queue_send_from_isr_failed: tstamp:91861042546 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.297646: rtos_queue_send_from_isr_failed: tstamp:91861042658 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.297653: rtos_queue_send_from_isr_failed: tstamp:91861042769 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.297660: rtos_queue_send_from_isr_failed: tstamp:91861042878 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.297667: rtos_queue_send_from_isr_failed: tstamp:91861042986 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.297674: rtos_queue_send_from_isr_failed: tstamp:91861043095 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.297682: rtos_queue_send_failed: tstamp:91861043547 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297689: rtos_queue_send_from_isr_failed: tstamp:91861048447 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.297697: rtos_queue_send_from_isr_failed: tstamp:91861048559 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.297704: rtos_queue_send_from_isr_failed: tstamp:91861048672 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.297711: rtos_queue_send_from_isr_failed: tstamp:91861048782 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.297718: rtos_queue_send_from_isr_failed: tstamp:91861048891 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.297726: rtos_queue_send_from_isr_failed: tstamp:91861049002 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.297733: rtos_queue_send_from_isr_failed: tstamp:91861049111 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.297740: rtos_queue_send_from_isr_failed: tstamp:91861049220 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.297748: rtos_queue_send_failed: tstamp:91861050232 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.353504: rtos_queue_peek_from_isr_failed: tstamp:91863099585 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2927.465506: rtos_queue_send_from_isr_failed: tstamp:91867399374 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465518: rtos_queue_send_from_isr_failed: tstamp:91867399494 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.465525: rtos_queue_send_from_isr_failed: tstamp:91867399606 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.465533: rtos_queue_send_from_isr_failed: tstamp:91867399717 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.465540: rtos_queue_send_from_isr_failed: tstamp:91867399827 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.465547: rtos_queue_send_from_isr_failed: tstamp:91867399936 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.465661: rtos_queue_send_from_isr_failed: tstamp:91867400045 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.465668: rtos_queue_send_from_isr_failed: tstamp:91867400166 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.465677: rtos_queue_send_failed: tstamp:91867400800 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465684: rtos_queue_send_from_isr_failed: tstamp:91867405237 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465691: rtos_queue_send_from_isr_failed: tstamp:91867405349 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.465698: rtos_queue_send_from_isr_failed: tstamp:91867405464 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.465706: rtos_queue_send_from_isr_failed: tstamp:91867405576 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.465713: rtos_queue_send_from_isr_failed: tstamp:91867405685 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.465720: rtos_queue_send_from_isr_failed: tstamp:91867405793 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.465728: rtos_queue_send_from_isr_failed: tstamp:91867405902 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.465735: rtos_queue_send_from_isr_failed: tstamp:91867406011 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.465743: rtos_queue_send_failed: tstamp:91867406459 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465750: rtos_queue_send_from_isr_failed: tstamp:91867414281 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465757: rtos_queue_send_from_isr_failed: tstamp:91867414392 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.465764: rtos_queue_send_from_isr_failed: tstamp:91867414502 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.465772: rtos_queue_send_from_isr_failed: tstamp:91867414612 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.465779: rtos_queue_send_from_isr_failed: tstamp:91867414721 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.465786: rtos_queue_send_from_isr_failed: tstamp:91867414830 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.465794: rtos_queue_send_from_isr_failed: tstamp:91867414942 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.465801: rtos_queue_send_from_isr_failed: tstamp:91867415050 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.465808: rtos_queue_send_failed: tstamp:91867415515 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465820: rtos_queue_send_from_isr_failed: tstamp:91867420266 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.465829: rtos_queue_send_from_isr_failed: tstamp:91867420377 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.465836: rtos_queue_send_from_isr_failed: tstamp:91867420487 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.465844: rtos_queue_send_from_isr_failed: tstamp:91867420599 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.465851: rtos_queue_send_from_isr_failed: tstamp:91867420708 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.465858: rtos_queue_send_from_isr_failed: tstamp:91867420823 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.465865: rtos_queue_send_from_isr_failed: tstamp:91867420932 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.465872: rtos_queue_send_from_isr_failed: tstamp:91867421041 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.465879: rtos_queue_send_failed: tstamp:91867422010 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.521475: rtos_queue_peek_from_isr_failed: tstamp:91868099580 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2927.689473: rtos_queue_peek_from_isr_failed: tstamp:91873099589 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2927.689488: rtos_queue_send_from_isr_failed: tstamp:91873774257 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689497: rtos_queue_send_from_isr_failed: tstamp:91873774375 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.689504: rtos_queue_send_from_isr_failed: tstamp:91873774489 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.689511: rtos_queue_send_from_isr_failed: tstamp:91873774601 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.689518: rtos_queue_send_from_isr_failed: tstamp:91873774710 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.689622: rtos_queue_send_from_isr_failed: tstamp:91873774819 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.689629: rtos_queue_send_from_isr_failed: tstamp:91873774929 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.689636: rtos_queue_send_from_isr_failed: tstamp:91873775038 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.689645: rtos_queue_send_failed: tstamp:91873775667 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689652: rtos_queue_send_from_isr_failed: tstamp:91873780597 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689659: rtos_queue_send_from_isr_failed: tstamp:91873780708 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.689666: rtos_queue_send_from_isr_failed: tstamp:91873780820 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.689674: rtos_queue_send_from_isr_failed: tstamp:91873780931 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.689681: rtos_queue_send_from_isr_failed: tstamp:91873781040 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.689688: rtos_queue_send_from_isr_failed: tstamp:91873781149 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.689695: rtos_queue_send_from_isr_failed: tstamp:91873781259 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.689702: rtos_queue_send_from_isr_failed: tstamp:91873781368 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.689710: rtos_queue_send_failed: tstamp:91873781827 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689717: rtos_queue_send_from_isr_failed: tstamp:91873790618 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689724: rtos_queue_send_from_isr_failed: tstamp:91873790729 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.689731: rtos_queue_send_from_isr_failed: tstamp:91873790839 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.689738: rtos_queue_send_from_isr_failed: tstamp:91873790951 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.689745: rtos_queue_send_from_isr_failed: tstamp:91873791061 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.689752: rtos_queue_send_from_isr_failed: tstamp:91873791170 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.689760: rtos_queue_send_from_isr_failed: tstamp:91873791279 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.689767: rtos_queue_send_from_isr_failed: tstamp:91873791389 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.689774: rtos_queue_send_failed: tstamp:91873791861 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689781: rtos_queue_send_from_isr_failed: tstamp:91873796913 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.689788: rtos_queue_send_from_isr_failed: tstamp:91873797024 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.689795: rtos_queue_send_from_isr_failed: tstamp:91873797136 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.689802: rtos_queue_send_from_isr_failed: tstamp:91873797246 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.689809: rtos_queue_send_from_isr_failed: tstamp:91873797355 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.689816: rtos_queue_send_from_isr_failed: tstamp:91873797464 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.689823: rtos_queue_send_from_isr_failed: tstamp:91873797573 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.689830: rtos_queue_send_from_isr_failed: tstamp:91873797687 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.689838: rtos_queue_send_failed: tstamp:91873798674 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.801477: rtos_queue_peek_from_isr_failed: tstamp:91878099611 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2927.913484: rtos_queue_send_from_isr_failed: tstamp:91880150224 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913496: rtos_queue_send_from_isr_failed: tstamp:91880150345 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.913504: rtos_queue_send_from_isr_failed: tstamp:91880150457 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.913511: rtos_queue_send_from_isr_failed: tstamp:91880150569 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.913518: rtos_queue_send_from_isr_failed: tstamp:91880150679 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.913526: rtos_queue_send_from_isr_failed: tstamp:91880150788 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.913533: rtos_queue_send_from_isr_failed: tstamp:91880150898 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.913540: rtos_queue_send_from_isr_failed: tstamp:91880151010 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.913548: rtos_queue_send_failed: tstamp:91880151636 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913556: rtos_queue_send_from_isr_failed: tstamp:91880157686 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913563: rtos_queue_send_from_isr_failed: tstamp:91880157799 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.913570: rtos_queue_send_from_isr_failed: tstamp:91880157909 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.913578: rtos_queue_send_from_isr_failed: tstamp:91880158022 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.913585: rtos_queue_send_from_isr_failed: tstamp:91880158132 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.913592: rtos_queue_send_from_isr_failed: tstamp:91880158242 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.913599: rtos_queue_send_from_isr_failed: tstamp:91880158351 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.913607: rtos_queue_send_from_isr_failed: tstamp:91880158460 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.913614: rtos_queue_send_failed: tstamp:91880158910 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913622: rtos_queue_send_from_isr_failed: tstamp:91880168233 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913629: rtos_queue_send_from_isr_failed: tstamp:91880168345 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.913636: rtos_queue_send_from_isr_failed: tstamp:91880168455 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.913643: rtos_queue_send_from_isr_failed: tstamp:91880168567 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.913651: rtos_queue_send_from_isr_failed: tstamp:91880168683 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.913658: rtos_queue_send_from_isr_failed: tstamp:91880168792 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.913665: rtos_queue_send_from_isr_failed: tstamp:91880168902 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.913672: rtos_queue_send_from_isr_failed: tstamp:91880169012 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.913680: rtos_queue_send_failed: tstamp:91880169465 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913687: rtos_queue_send_from_isr_failed: tstamp:91880174529 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.913694: rtos_queue_send_from_isr_failed: tstamp:91880174652 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2927.913701: rtos_queue_send_from_isr_failed: tstamp:91880174765 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2927.913709: rtos_queue_send_from_isr_failed: tstamp:91880174876 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2927.913716: rtos_queue_send_from_isr_failed: tstamp:91880174986 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2927.913723: rtos_queue_send_from_isr_failed: tstamp:91880175095 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2927.913731: rtos_queue_send_from_isr_failed: tstamp:91880175204 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2927.913738: rtos_queue_send_from_isr_failed: tstamp:91880175313 queue:0x0b4b1c18
kworker/2:0-6396 [002] .... 2927.913745: rtos_queue_send_failed: tstamp:91880176305 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2927.969512: rtos_queue_peek_from_isr_failed: tstamp:91883099617 queue:0x0b4b4500
kworker/2:0-6396 [002] .... 2928.081484: rtos_queue_send_from_isr_failed: tstamp:91886525276 queue:0x0b4a7258
kworker/2:0-6396 [002] .... 2928.081497: rtos_queue_send_from_isr_failed: tstamp:91886525398 queue:0x0b4aad68
kworker/2:0-6396 [002] .... 2928.081505: rtos_queue_send_from_isr_failed: tstamp:91886525510 queue:0x0b4ac998
kworker/2:0-6396 [002] .... 2928.081512: rtos_queue_send_from_isr_failed: tstamp:91886525621 queue:0x0b4ae518
kworker/2:0-6396 [002] .... 2928.081519: rtos_queue_send_from_isr_failed: tstamp:91886525730 queue:0x0b4af2d8
kworker/2:0-6396 [002] .... 2928.081526: rtos_queue_send_from_isr_failed: tstamp:91886525839 queue:0x0b4b0098
kworker/2:0-6396 [002] .... 2928.081626: rtos_queue_send_from_isr_failed: tstamp:91886525948 queue:0x0b4b0e58
kworker/2:0-6396 [002] .... 2928.081634: rtos_queue_send_from_isr_failed: tstamp:91886526057 queue:0x0b4b1c18
You received the following error line:
If we decode the 0x200 at the end this means PIXEL_SHORT_LINE (bit 9 is high) ‘A line has fewer pixels than expected width’. So this means it received less than 3840 pixels. Try playing around with the V4L command, reducing in steps of 4 until you get other errors.
Example:
v4l2-ctl -d /dev/video0 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=test.raw --set-fmt-video=width=3836,height=2160,pixelformat=RG12
Edit: Also, I noticed you changed the line length. I don’t think the line length should ever be shorter than the horizontal dimensions of the image. For calculating Sony sensor line length:
Line length = 1H period / (1/pixel_clk_hz)
pixel_clk_hz = (mbps per lane * number of lanes) / bits per pixel
1H period = (1 / Sensor input frequency) * HMAX
suchb
November 7, 2019, 7:41am
#9
hello IceBlackz.
I do some modifications and there is no tag:XXXXXX massages in trace log,but test.raw size is 0kb.
# tracer: nop
# entries-in-buffer/entries-written: 1413/1413 #P:6
# _-----=> irqs-off
# ||| / delay
kworker/0:0-4 [000] .... 99.433887: rtos_queue_peek_from_isr_failed: tstamp:3486186401 queue:0x0b4b4500
kworker/0:0-4 [000] .... 99.433897: rtcpu_start: tstamp:3486197053
kworker/0:0-4 [000] .... 99.433901: rtos_queue_send_from_isr_failed: tstamp:3486274728 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.433902: rtos_queue_send_from_isr_failed: tstamp:3486274903 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.433903: rtos_queue_send_from_isr_failed: tstamp:3486275079 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.433904: rtos_queue_send_from_isr_failed: tstamp:3486275254 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.433905: rtos_queue_send_from_isr_failed: tstamp:3486275427 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.433906: rtos_queue_send_from_isr_failed: tstamp:3486275601 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.433907: rtos_queue_send_from_isr_failed: tstamp:3486275774 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.433908: rtos_queue_send_from_isr_failed: tstamp:3486275949 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.433912: rtos_queue_send_failed: tstamp:3486276722 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.433913: rtos_queue_send_from_isr_failed: tstamp:3486284584 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.433914: rtos_queue_send_from_isr_failed: tstamp:3486284759 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.433915: rtos_queue_send_from_isr_failed: tstamp:3486284933 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.433916: rtos_queue_send_from_isr_failed: tstamp:3486285108 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.433917: rtos_queue_send_from_isr_failed: tstamp:3486285288 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.433918: rtos_queue_send_from_isr_failed: tstamp:3486285462 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.433919: rtos_queue_send_from_isr_failed: tstamp:3486285634 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.433921: rtos_queue_send_from_isr_failed: tstamp:3486285808 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.433922: rtos_queue_send_failed: tstamp:3486287740 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.601999: rtos_queue_peek_from_isr_failed: tstamp:3491186885 queue:0x0b4b4500
kworker/0:0-4 [000] .... 99.657894: rtos_queue_send_from_isr_failed: tstamp:3492751245 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657897: rtos_queue_send_from_isr_failed: tstamp:3492751447 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.657898: rtos_queue_send_from_isr_failed: tstamp:3492751624 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.657898: rtos_queue_send_from_isr_failed: tstamp:3492751800 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.657899: rtos_queue_send_from_isr_failed: tstamp:3492751974 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.657900: rtos_queue_send_from_isr_failed: tstamp:3492752146 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.657901: rtos_queue_send_from_isr_failed: tstamp:3492752319 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.657901: rtos_queue_send_from_isr_failed: tstamp:3492752491 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.657903: rtos_queue_send_failed: tstamp:3492753416 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657904: rtos_queue_send_from_isr_failed: tstamp:3492759375 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657904: rtos_queue_send_from_isr_failed: tstamp:3492759550 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.657905: rtos_queue_send_from_isr_failed: tstamp:3492759724 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.657906: rtos_queue_send_from_isr_failed: tstamp:3492759900 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.657906: rtos_queue_send_from_isr_failed: tstamp:3492760073 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.657907: rtos_queue_send_from_isr_failed: tstamp:3492760245 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.657908: rtos_queue_send_from_isr_failed: tstamp:3492760419 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.657908: rtos_queue_send_from_isr_failed: tstamp:3492760593 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.657909: rtos_queue_send_failed: tstamp:3492761297 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657910: rtos_queue_send_from_isr_failed: tstamp:3492774405 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657910: rtos_queue_send_from_isr_failed: tstamp:3492774580 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.657911: rtos_queue_send_from_isr_failed: tstamp:3492774760 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.657912: rtos_queue_send_from_isr_failed: tstamp:3492774935 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.657912: rtos_queue_send_from_isr_failed: tstamp:3492775116 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.657913: rtos_queue_send_from_isr_failed: tstamp:3492775289 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.657914: rtos_queue_send_from_isr_failed: tstamp:3492775494 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.657914: rtos_queue_send_from_isr_failed: tstamp:3492775667 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.657915: rtos_queue_send_failed: tstamp:3492776412 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657916: rtos_queue_send_from_isr_failed: tstamp:3492781866 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.657917: rtos_queue_send_from_isr_failed: tstamp:3492782041 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.657917: rtos_queue_send_from_isr_failed: tstamp:3492782215 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.657918: rtos_queue_send_from_isr_failed: tstamp:3492782389 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.657919: rtos_queue_send_from_isr_failed: tstamp:3492782587 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.657919: rtos_queue_send_from_isr_failed: tstamp:3492782760 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.657920: rtos_queue_send_from_isr_failed: tstamp:3492782931 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.657921: rtos_queue_send_from_isr_failed: tstamp:3492783103 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.657921: rtos_queue_send_failed: tstamp:3492784991 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.769999: rtos_queue_peek_from_isr_failed: tstamp:3496186829 queue:0x0b4b4500
kworker/0:0-4 [000] .... 99.881885: rtos_queue_send_from_isr_failed: tstamp:3499127490 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881892: rtos_queue_send_from_isr_failed: tstamp:3499127647 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.881894: rtos_queue_send_from_isr_failed: tstamp:3499127787 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.881897: rtos_queue_send_from_isr_failed: tstamp:3499127927 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.881900: rtos_queue_send_from_isr_failed: tstamp:3499128065 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.881902: rtos_queue_send_from_isr_failed: tstamp:3499128207 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.881905: rtos_queue_send_from_isr_failed: tstamp:3499128345 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.881907: rtos_queue_send_from_isr_failed: tstamp:3499128489 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.881911: rtos_queue_send_failed: tstamp:3499129302 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881913: rtos_queue_send_from_isr_failed: tstamp:3499137554 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881915: rtos_queue_send_from_isr_failed: tstamp:3499137694 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.881918: rtos_queue_send_from_isr_failed: tstamp:3499137833 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.881920: rtos_queue_send_from_isr_failed: tstamp:3499137974 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.881923: rtos_queue_send_from_isr_failed: tstamp:3499138111 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.881925: rtos_queue_send_from_isr_failed: tstamp:3499138249 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.881927: rtos_queue_send_from_isr_failed: tstamp:3499138389 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.881930: rtos_queue_send_from_isr_failed: tstamp:3499138525 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.881932: rtos_queue_send_failed: tstamp:3499139085 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881935: rtos_queue_send_from_isr_failed: tstamp:3499147665 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881937: rtos_queue_send_from_isr_failed: tstamp:3499147825 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.881940: rtos_queue_send_from_isr_failed: tstamp:3499147965 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.881942: rtos_queue_send_from_isr_failed: tstamp:3499148109 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.881945: rtos_queue_send_from_isr_failed: tstamp:3499148246 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.881947: rtos_queue_send_from_isr_failed: tstamp:3499148384 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.881949: rtos_queue_send_from_isr_failed: tstamp:3499148521 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.881952: rtos_queue_send_from_isr_failed: tstamp:3499148659 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.881954: rtos_queue_send_failed: tstamp:3499149237 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881957: rtos_queue_send_from_isr_failed: tstamp:3499154145 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.881959: rtos_queue_send_from_isr_failed: tstamp:3499154285 queue:0x0b4aad68
kworker/0:0-4 [000] .... 99.881961: rtos_queue_send_from_isr_failed: tstamp:3499154424 queue:0x0b4ac998
kworker/0:0-4 [000] .... 99.881964: rtos_queue_send_from_isr_failed: tstamp:3499154564 queue:0x0b4ae518
kworker/0:0-4 [000] .... 99.881966: rtos_queue_send_from_isr_failed: tstamp:3499154701 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 99.881968: rtos_queue_send_from_isr_failed: tstamp:3499154839 queue:0x0b4b0098
kworker/0:0-4 [000] .... 99.881971: rtos_queue_send_from_isr_failed: tstamp:3499154975 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 99.881973: rtos_queue_send_from_isr_failed: tstamp:3499155112 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 99.881976: rtos_queue_send_failed: tstamp:3499156524 queue:0x0b4a7258
kworker/0:0-4 [000] .... 99.937887: rtos_queue_peek_from_isr_failed: tstamp:3501186823 queue:0x0b4b4500
kworker/0:0-4 [000] .... 100.049884: rtos_queue_send_from_isr_failed: tstamp:3505501329 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049890: rtos_queue_send_from_isr_failed: tstamp:3505501486 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.049893: rtos_queue_send_from_isr_failed: tstamp:3505501626 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.049895: rtos_queue_send_from_isr_failed: tstamp:3505501766 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.049898: rtos_queue_send_from_isr_failed: tstamp:3505501903 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.049900: rtos_queue_send_from_isr_failed: tstamp:3505502041 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.049903: rtos_queue_send_from_isr_failed: tstamp:3505502178 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.049905: rtos_queue_send_from_isr_failed: tstamp:3505502316 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.049908: rtos_queue_send_failed: tstamp:3505503265 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049911: rtos_queue_send_from_isr_failed: tstamp:3505509051 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049913: rtos_queue_send_from_isr_failed: tstamp:3505509227 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.049915: rtos_queue_send_from_isr_failed: tstamp:3505509402 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.049918: rtos_queue_send_from_isr_failed: tstamp:3505509582 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.049920: rtos_queue_send_from_isr_failed: tstamp:3505509756 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.049922: rtos_queue_send_from_isr_failed: tstamp:3505509936 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.049925: rtos_queue_send_from_isr_failed: tstamp:3505510110 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.049927: rtos_queue_send_from_isr_failed: tstamp:3505510312 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.049930: rtos_queue_send_failed: tstamp:3505511005 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049932: rtos_queue_send_from_isr_failed: tstamp:3505520503 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049935: rtos_queue_send_from_isr_failed: tstamp:3505520678 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.049937: rtos_queue_send_from_isr_failed: tstamp:3505520853 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.049939: rtos_queue_send_from_isr_failed: tstamp:3505521028 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.049942: rtos_queue_send_from_isr_failed: tstamp:3505521202 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.049944: rtos_queue_send_from_isr_failed: tstamp:3505521376 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.049946: rtos_queue_send_from_isr_failed: tstamp:3505521549 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.049949: rtos_queue_send_from_isr_failed: tstamp:3505521723 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.049951: rtos_queue_send_failed: tstamp:3505522426 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049954: rtos_queue_send_from_isr_failed: tstamp:3505528147 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.049956: rtos_queue_send_from_isr_failed: tstamp:3505528322 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.049958: rtos_queue_send_from_isr_failed: tstamp:3505528497 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.049961: rtos_queue_send_from_isr_failed: tstamp:3505528672 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.049963: rtos_queue_send_from_isr_failed: tstamp:3505528846 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.049966: rtos_queue_send_from_isr_failed: tstamp:3505529025 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.049968: rtos_queue_send_from_isr_failed: tstamp:3505529197 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.049970: rtos_queue_send_from_isr_failed: tstamp:3505529375 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.049973: rtos_queue_send_failed: tstamp:3505531344 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.105944: rtos_queue_peek_from_isr_failed: tstamp:3506186790 queue:0x0b4b4500
kworker/0:0-4 [000] .... 100.273835: rtos_queue_peek_from_isr_failed: tstamp:3511186791 queue:0x0b4b4500
kworker/0:0-4 [000] .... 100.273841: rtos_queue_send_from_isr_failed: tstamp:3511876198 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273844: rtos_queue_send_from_isr_failed: tstamp:3511876355 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.273846: rtos_queue_send_from_isr_failed: tstamp:3511876497 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.273849: rtos_queue_send_from_isr_failed: tstamp:3511876635 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.273851: rtos_queue_send_from_isr_failed: tstamp:3511876773 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.273853: rtos_queue_send_from_isr_failed: tstamp:3511876909 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.273855: rtos_queue_send_from_isr_failed: tstamp:3511877045 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.273857: rtos_queue_send_from_isr_failed: tstamp:3511877182 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.273860: rtos_queue_send_failed: tstamp:3511877955 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273862: rtos_queue_send_from_isr_failed: tstamp:3511883474 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273864: rtos_queue_send_from_isr_failed: tstamp:3511883623 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.273867: rtos_queue_send_from_isr_failed: tstamp:3511883763 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.273871: rtos_queue_send_from_isr_failed: tstamp:3511883903 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.273874: rtos_queue_send_from_isr_failed: tstamp:3511884041 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.273877: rtos_queue_send_from_isr_failed: tstamp:3511884178 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.273879: rtos_queue_send_from_isr_failed: tstamp:3511884339 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.273882: rtos_queue_send_from_isr_failed: tstamp:3511884476 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.273884: rtos_queue_send_failed: tstamp:3511885077 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273886: rtos_queue_send_from_isr_failed: tstamp:3511895442 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273888: rtos_queue_send_from_isr_failed: tstamp:3511895586 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.273890: rtos_queue_send_from_isr_failed: tstamp:3511895725 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.273892: rtos_queue_send_from_isr_failed: tstamp:3511895865 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.273895: rtos_queue_send_from_isr_failed: tstamp:3511896001 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.273897: rtos_queue_send_from_isr_failed: tstamp:3511896140 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.273899: rtos_queue_send_from_isr_failed: tstamp:3511896277 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.273901: rtos_queue_send_from_isr_failed: tstamp:3511896419 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.273903: rtos_queue_send_failed: tstamp:3511897041 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273905: rtos_queue_send_from_isr_failed: tstamp:3511907197 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.273907: rtos_queue_send_from_isr_failed: tstamp:3511907337 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.273909: rtos_queue_send_from_isr_failed: tstamp:3511907476 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.273911: rtos_queue_send_from_isr_failed: tstamp:3511907617 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.273914: rtos_queue_send_from_isr_failed: tstamp:3511907755 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.273916: rtos_queue_send_from_isr_failed: tstamp:3511907892 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.273918: rtos_queue_send_from_isr_failed: tstamp:3511908029 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.273920: rtos_queue_send_from_isr_failed: tstamp:3511908167 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.273922: rtos_queue_send_failed: tstamp:3511909562 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.441873: rtos_queue_peek_from_isr_failed: tstamp:3516186933 queue:0x0b4b4500
kworker/0:0-4 [000] .... 100.497831: rtos_queue_send_from_isr_failed: tstamp:3518250687 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497837: rtos_queue_send_from_isr_failed: tstamp:3518250845 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.497839: rtos_queue_send_from_isr_failed: tstamp:3518250985 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.497842: rtos_queue_send_from_isr_failed: tstamp:3518251125 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.497844: rtos_queue_send_from_isr_failed: tstamp:3518251262 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.497847: rtos_queue_send_from_isr_failed: tstamp:3518251409 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.497849: rtos_queue_send_from_isr_failed: tstamp:3518251547 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.497852: rtos_queue_send_from_isr_failed: tstamp:3518251686 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.497855: rtos_queue_send_failed: tstamp:3518252477 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497858: rtos_queue_send_from_isr_failed: tstamp:3518258163 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497860: rtos_queue_send_from_isr_failed: tstamp:3518258302 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.497862: rtos_queue_send_from_isr_failed: tstamp:3518258442 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.497865: rtos_queue_send_from_isr_failed: tstamp:3518258581 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.497867: rtos_queue_send_from_isr_failed: tstamp:3518258718 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.497870: rtos_queue_send_from_isr_failed: tstamp:3518258857 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.497872: rtos_queue_send_from_isr_failed: tstamp:3518258993 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.497874: rtos_queue_send_from_isr_failed: tstamp:3518259136 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.497877: rtos_queue_send_failed: tstamp:3518259731 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497879: rtos_queue_send_from_isr_failed: tstamp:3518273948 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497881: rtos_queue_send_from_isr_failed: tstamp:3518274086 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.497884: rtos_queue_send_from_isr_failed: tstamp:3518274225 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.497887: rtos_queue_send_from_isr_failed: tstamp:3518274369 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.497889: rtos_queue_send_from_isr_failed: tstamp:3518274505 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.497891: rtos_queue_send_from_isr_failed: tstamp:3518274644 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.497894: rtos_queue_send_from_isr_failed: tstamp:3518274780 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.497896: rtos_queue_send_from_isr_failed: tstamp:3518274918 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.497898: rtos_queue_send_failed: tstamp:3518275495 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497901: rtos_queue_send_from_isr_failed: tstamp:3518280830 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.497903: rtos_queue_send_from_isr_failed: tstamp:3518280969 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.497906: rtos_queue_send_from_isr_failed: tstamp:3518281108 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.497908: rtos_queue_send_from_isr_failed: tstamp:3518281248 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.497910: rtos_queue_send_from_isr_failed: tstamp:3518281384 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.497913: rtos_queue_send_from_isr_failed: tstamp:3518281522 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.497915: rtos_queue_send_from_isr_failed: tstamp:3518281658 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.497917: rtos_queue_send_from_isr_failed: tstamp:3518281796 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.497920: rtos_queue_send_failed: tstamp:3518283198 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.553825: rtos_queue_peek_from_isr_failed: tstamp:3521186863 queue:0x0b4b4500
kworker/0:0-4 [000] .... 100.665801: rtos_queue_send_from_isr_failed: tstamp:3524625853 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665807: rtos_queue_send_from_isr_failed: tstamp:3524626010 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.665809: rtos_queue_send_from_isr_failed: tstamp:3524626151 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.665812: rtos_queue_send_from_isr_failed: tstamp:3524626293 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.665814: rtos_queue_send_from_isr_failed: tstamp:3524626430 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.665817: rtos_queue_send_from_isr_failed: tstamp:3524626588 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.665819: rtos_queue_send_from_isr_failed: tstamp:3524626726 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.665821: rtos_queue_send_from_isr_failed: tstamp:3524626863 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.665824: rtos_queue_send_failed: tstamp:3524627622 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665827: rtos_queue_send_from_isr_failed: tstamp:3524633448 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665829: rtos_queue_send_from_isr_failed: tstamp:3524633586 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.665831: rtos_queue_send_from_isr_failed: tstamp:3524633726 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.665834: rtos_queue_send_from_isr_failed: tstamp:3524633865 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.665836: rtos_queue_send_from_isr_failed: tstamp:3524634003 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.665839: rtos_queue_send_from_isr_failed: tstamp:3524634140 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.665841: rtos_queue_send_from_isr_failed: tstamp:3524634277 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.665844: rtos_queue_send_from_isr_failed: tstamp:3524634430 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.665846: rtos_queue_send_failed: tstamp:3524635006 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665849: rtos_queue_send_from_isr_failed: tstamp:3524643437 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665851: rtos_queue_send_from_isr_failed: tstamp:3524643576 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.665853: rtos_queue_send_from_isr_failed: tstamp:3524643715 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.665856: rtos_queue_send_from_isr_failed: tstamp:3524643853 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.665858: rtos_queue_send_from_isr_failed: tstamp:3524643991 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.665861: rtos_queue_send_from_isr_failed: tstamp:3524644129 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.665863: rtos_queue_send_from_isr_failed: tstamp:3524644266 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.665865: rtos_queue_send_from_isr_failed: tstamp:3524644403 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.665868: rtos_queue_send_failed: tstamp:3524644980 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665870: rtos_queue_send_from_isr_failed: tstamp:3524650119 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.665872: rtos_queue_send_from_isr_failed: tstamp:3524650258 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.665875: rtos_queue_send_from_isr_failed: tstamp:3524650395 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.665877: rtos_queue_send_from_isr_failed: tstamp:3524650535 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.665880: rtos_queue_send_from_isr_failed: tstamp:3524650673 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.665882: rtos_queue_send_from_isr_failed: tstamp:3524650819 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.665884: rtos_queue_send_from_isr_failed: tstamp:3524650957 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.665887: rtos_queue_send_from_isr_failed: tstamp:3524651093 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.665889: rtos_queue_send_failed: tstamp:3524652530 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.721848: rtos_queue_peek_from_isr_failed: tstamp:3526186866 queue:0x0b4b4500
kworker/0:0-4 [000] .... 100.889787: rtos_queue_send_from_isr_failed: tstamp:3530999400 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.889794: rtos_queue_send_from_isr_failed: tstamp:3530999561 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.889797: rtos_queue_send_from_isr_failed: tstamp:3530999701 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.889800: rtos_queue_send_from_isr_failed: tstamp:3530999839 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.889802: rtos_queue_send_from_isr_failed: tstamp:3530999975 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.889805: rtos_queue_send_from_isr_failed: tstamp:3531000113 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.889807: rtos_queue_send_from_isr_failed: tstamp:3531000249 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.889809: rtos_queue_send_from_isr_failed: tstamp:3531000387 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.889813: rtos_queue_send_failed: tstamp:3531001175 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.889815: rtos_queue_send_from_isr_failed: tstamp:3531006272 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.889817: rtos_queue_send_from_isr_failed: tstamp:3531006433 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.889820: rtos_queue_send_from_isr_failed: tstamp:3531006576 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.889822: rtos_queue_send_from_isr_failed: tstamp:3531006714 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.889825: rtos_queue_send_from_isr_failed: tstamp:3531006852 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.889827: rtos_queue_send_from_isr_failed: tstamp:3531006989 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.889829: rtos_queue_send_from_isr_failed: tstamp:3531007128 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.889832: rtos_queue_send_from_isr_failed: tstamp:3531007265 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.889834: rtos_queue_send_failed: tstamp:3531007833 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.889836: rtos_queue_send_from_isr_failed: tstamp:3531020825 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.889839: rtos_queue_send_from_isr_failed: tstamp:3531020987 queue:0x0b4aad68
kworker/0:0-4 [000] .... 100.889841: rtos_queue_send_from_isr_failed: tstamp:3531021126 queue:0x0b4ac998
kworker/0:0-4 [000] .... 100.889843: rtos_queue_send_from_isr_failed: tstamp:3531021264 queue:0x0b4ae518
kworker/0:0-4 [000] .... 100.889846: rtos_queue_send_from_isr_failed: tstamp:3531021402 queue:0x0b4af2d8
kworker/0:0-4 [000] .... 100.889848: rtos_queue_send_from_isr_failed: tstamp:3531021539 queue:0x0b4b0098
kworker/0:0-4 [000] .... 100.889851: rtos_queue_send_from_isr_failed: tstamp:3531021678 queue:0x0b4b0e58
kworker/0:0-4 [000] .... 100.889853: rtos_queue_send_from_isr_failed: tstamp:3531021814 queue:0x0b4b1c18
kworker/0:0-4 [000] .... 100.889855: rtos_queue_send_failed: tstamp:3531022399 queue:0x0b4a7258
kworker/0:0-4 [000] .... 100.889858: rtos_queue_send_from_isr_failed: tstamp:3531027599 queue:0x0b4a7258
This usually happens when there is no data received on the MIPI input, you could try to verify that with an oscilloscope. Otherwise, revert your changes and keep applying a change one by one to find out which one gives these problems.
suchb
November 7, 2019, 7:59am
#11
sorry IceBlackz, it is my bad,I modify “csi_pixel_bit_depth” to 8 bit,and sensor probe faild:
[ 3.486667] extract_pixel_format: Need to extend formatyuv_uyvy8
