my HDMI-CSI chip tc358743 connected to tx2, driver installed successfully, and mipi csi singals output normally…
when I command
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=UYVY --stream-mmap --stream-count=10000 --set-ctrl bypass_mode=0
some errors happened, the error logs as below:
# tracer: nop
# entries-in-buffer/entries-written: 1268/1268 #P:6
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/4:1-821 [004] .... 47.174251: rtos_queue_peek_from_isr_failed: tstamp:1826135660 queue:0x0b4b4500
kworker/4:1-821 [004] .... 47.342240: rtos_queue_peek_from_isr_failed: tstamp:1831135663 queue:0x0b4b4500
kworker/4:1-821 [004] .... 47.510238: rtos_queue_peek_from_isr_failed: tstamp:1836135671 queue:0x0b4b4500
kworker/4:1-821 [004] .... 47.622236: rtos_queue_peek_from_isr_failed: tstamp:1841135675 queue:0x0b4b4500
kworker/4:1-821 [004] .... 47.790233: rtos_queue_peek_from_isr_failed: tstamp:1846135684 queue:0x0b4b4500
kworker/4:1-821 [004] .... 47.958254: rtos_queue_peek_from_isr_failed: tstamp:1851135691 queue:0x0b4b4500
kworker/4:1-821 [004] .... 48.126239: rtos_queue_peek_from_isr_failed: tstamp:1856135700 queue:0x0b4b4500
kworker/4:1-821 [004] .... 48.294243: rtos_queue_peek_from_isr_failed: tstamp:1861135743 queue:0x0b4b4500
kworker/4:1-821 [004] .... 48.462244: rtos_queue_peek_from_isr_failed: tstamp:1866135749 queue:0x0b4b4500
kworker/4:1-821 [004] .... 48.630234: rtos_queue_peek_from_isr_failed: tstamp:1871135757 queue:0x0b4b4500
kworker/4:1-821 [004] .... 48.742263: rtos_queue_peek_from_isr_failed: tstamp:1876135764 queue:0x0b4b4500
kworker/4:1-821 [004] .... 48.910279: rtos_queue_peek_from_isr_failed: tstamp:1881135771 queue:0x0b4b4500
kworker/4:1-821 [004] .... 49.078281: rtos_queue_peek_from_isr_failed: tstamp:1886136244 queue:0x0b4b4500
kworker/4:1-821 [004] .... 49.246324: rtos_queue_peek_from_isr_failed: tstamp:1891136250 queue:0x0b4b4500
kworker/4:1-821 [004] .... 49.414266: rtos_queue_peek_from_isr_failed: tstamp:1896135842 queue:0x0b4b4500
kworker/4:1-821 [004] .... 49.582206: rtos_queue_peek_from_isr_failed: tstamp:1901135747 queue:0x0b4b4500
kworker/4:1-821 [004] .... 49.696704: rtos_queue_peek_from_isr_failed: tstamp:1906135765 queue:0x0b4b4500
kworker/4:1-821 [004] .... 49.862172: rtos_queue_peek_from_isr_failed: tstamp:1911135762 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.030360: rtos_queue_peek_from_isr_failed: tstamp:1916136281 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.198278: rtos_queue_peek_from_isr_failed: tstamp:1921136349 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.366181: rtos_queue_peek_from_isr_failed: tstamp:1926135817 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.534408: rtos_queue_peek_from_isr_failed: tstamp:1931135819 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.702274: rtos_queue_peek_from_isr_failed: tstamp:1936136306 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.870309: rtos_queue_peek_from_isr_failed: tstamp:1941136310 queue:0x0b4b4500
kworker/4:1-821 [004] .... 50.982268: rtos_queue_peek_from_isr_failed: tstamp:1946136316 queue:0x0b4b4500
kworker/4:1-821 [004] .... 51.150320: rtos_queue_peek_from_isr_failed: tstamp:1951136323 queue:0x0b4b4500
kworker/4:1-821 [004] .... 51.318286: rtos_queue_peek_from_isr_failed: tstamp:1956136330 queue:0x0b4b4500
kworker/4:1-821 [004] .... 51.486285: rtos_queue_peek_from_isr_failed: tstamp:1961136337 queue:0x0b4b4500
kworker/4:1-821 [004] .... 51.654304: rtos_queue_peek_from_isr_failed: tstamp:1966136346 queue:0x0b4b4500
kworker/4:1-821 [004] .... 51.822299: rtos_queue_peek_from_isr_failed: tstamp:1971136353 queue:0x0b4b4500
kworker/4:1-821 [004] .... 51.990278: rtos_queue_peek_from_isr_failed: tstamp:1976136357 queue:0x0b4b4500
kworker/4:1-821 [004] .... 52.102240: rtos_queue_peek_from_isr_failed: tstamp:1979588310 queue:0x0b4b4500
v4l2-ctl-7465 [000] .... 60.628278: tegra_channel_open: vi-output, imx185 2-000f
v4l2-ctl-7465 [000] .... 60.629303: tegra_channel_set_power: imx185 2-000f : 0x1
v4l2-ctl-7465 [000] .... 60.629318: camera_common_s_power: status : 0x1
v4l2-ctl-7465 [000] .... 60.632663: tegra_channel_set_power: 150c0000.nvcsi--1 : 0x1
v4l2-ctl-7465 [000] .... 60.632666: csi_s_power: enable : 0x1
v4l2-ctl-7465 [005] .... 60.642399: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, imx1-7466 [000] .... 60.642493: tegra_channel_set_stream: enable : 0x1
vi-output, imx1-7466 [000] .... 60.644052: tegra_channel_set_stream: 150c0000.nvcsi--1 : 0x1
vi-output, imx1-7466 [000] .... 60.644054: csi_s_stream: enable : 0x1
vi-output, imx1-7466 [000] .... 60.651283: tegra_channel_set_stream: imx185 2-000f : 0x1
kworker/4:1-821 [004] .... 60.670172: rtos_queue_peek_from_isr_failed: tstamp:2248198970 queue:0x0b4b4500
kworker/4:1-821 [004] .... 60.670176: rtcpu_start: tstamp:2248200053
kworker/4:1-821 [004] .... 60.670178: rtos_queue_send_from_isr_failed: tstamp:2248209092 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.670179: rtos_queue_send_from_isr_failed: tstamp:2248209199 queue:0x0b4aad68
kworker/4:1-821 [004] .... 60.670180: rtos_queue_send_from_isr_failed: tstamp:2248209304 queue:0x0b4ac998
kworker/4:1-821 [004] .... 60.670181: rtos_queue_send_from_isr_failed: tstamp:2248209407 queue:0x0b4ae518
kworker/4:1-821 [004] .... 60.670182: rtos_queue_send_from_isr_failed: tstamp:2248209508 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 60.670182: rtos_queue_send_from_isr_failed: tstamp:2248209610 queue:0x0b4b0098
kworker/4:1-821 [004] .... 60.670183: rtos_queue_send_from_isr_failed: tstamp:2248209711 queue:0x0b4b0e58
kworker/4:1-821 [004] .... 60.670184: rtos_queue_send_from_isr_failed: tstamp:2248209812 queue:0x0b4b1c18
kworker/4:1-821 [004] .... 60.670186: rtos_queue_send_failed: tstamp:2248210310 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.670187: rtos_queue_send_from_isr_failed: tstamp:2248212701 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.670187: rtos_queue_send_from_isr_failed: tstamp:2248212805 queue:0x0b4aad68
kworker/4:1-821 [004] .... 60.670188: rtos_queue_send_from_isr_failed: tstamp:2248212907 queue:0x0b4ac998
kworker/4:1-821 [004] .... 60.670189: rtos_queue_send_from_isr_failed: tstamp:2248213009 queue:0x0b4ae518
kworker/4:1-821 [004] .... 60.670190: rtos_queue_send_from_isr_failed: tstamp:2248213111 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 60.670191: rtos_queue_send_from_isr_failed: tstamp:2248213212 queue:0x0b4b0098
kworker/4:1-821 [004] .... 60.670192: rtos_queue_send_from_isr_failed: tstamp:2248213313 queue:0x0b4b0e58
kworker/4:1-821 [004] .... 60.670192: rtos_queue_send_from_isr_failed: tstamp:2248213414 queue:0x0b4b1c18
kworker/4:1-821 [004] .... 60.670193: rtos_queue_send_failed: tstamp:2248214333 queue:0x0b4a7258
vi-output, imx1-7466 [004] .... 60.676168: tegra_channel_capture_frame: sof:60.565582848
kworker/4:1-821 [004] .... 60.726307: rtcpu_vinotify_event: tstamp:2249257352 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2249256437 data:0x00000001
kworker/4:1-821 [004] .... 60.726314: rtcpu_vinotify_event: tstamp:2249257946 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:2249256446 data:0x00000000
kworker/4:1-821 [004] .... 60.726316: rtcpu_vinotify_event: tstamp:2249258413 tag:CHANSEL_FAULT channel:0x00 frame:0 vi_tstamp:2249256673 data:0x00000200
kworker/4:1-821 [004] .... 60.726320: rtcpu_vinotify_event: tstamp:2249259632 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:0 vi_tstamp:2249258716 data:0x08000000
kworker/4:1-821 [004] .... 60.726323: rtcpu_vinotify_event: tstamp:2249260201 tag:CHANSEL_FAULT_FE channel:0x01 frame:0 vi_tstamp:2249259019 data:0x00000001
kworker/4:1-821 [004] .... 60.726325: rtcpu_vinotify_event: tstamp:2249260693 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:2249259022 data:0x00000000
kworker/4:1-821 [004] .... 60.838271: rtos_queue_peek_from_isr_failed: tstamp:2253199492 queue:0x0b4b4500
vi-output, imx1-7466 [003] .... 60.902272: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, imx1-7466 [003] .... 60.902305: tegra_channel_capture_frame: sof:60.565582848
vi-output, imx1-7466 [004] .... 60.909229: tegra_channel_capture_frame: sof:60.798899424
kworker/4:1-821 [004] .... 60.950218: rtos_queue_send_from_isr_failed: tstamp:2256094832 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950222: rtos_queue_send_from_isr_failed: tstamp:2256095104 queue:0x0b4aad68
kworker/4:1-821 [004] .... 60.950224: rtos_queue_send_from_isr_failed: tstamp:2256095378 queue:0x0b4ac998
kworker/4:1-821 [004] .... 60.950226: rtos_queue_send_from_isr_failed: tstamp:2256095658 queue:0x0b4ae518
kworker/4:1-821 [004] .... 60.950228: rtos_queue_send_from_isr_failed: tstamp:2256095925 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 60.950230: rtos_queue_send_from_isr_failed: tstamp:2256096191 queue:0x0b4b0098
kworker/4:1-821 [004] .... 60.950232: rtos_queue_send_from_isr_failed: tstamp:2256096457 queue:0x0b4b0e58
kworker/4:1-821 [004] .... 60.950234: rtos_queue_send_from_isr_failed: tstamp:2256096724 queue:0x0b4b1c18
kworker/4:1-821 [004] .... 60.950238: rtos_queue_send_failed: tstamp:2256098018 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950240: rtos_queue_send_from_isr_failed: tstamp:2256101471 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950242: rtos_queue_send_from_isr_failed: tstamp:2256101742 queue:0x0b4aad68
kworker/4:1-821 [004] .... 60.950245: rtos_queue_send_from_isr_failed: tstamp:2256102016 queue:0x0b4ac998
kworker/4:1-821 [004] .... 60.950247: rtos_queue_send_from_isr_failed: tstamp:2256102293 queue:0x0b4ae518
kworker/4:1-821 [004] .... 60.950249: rtos_queue_send_from_isr_failed: tstamp:2256102562 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 60.950251: rtos_queue_send_from_isr_failed: tstamp:2256102829 queue:0x0b4b0098
kworker/4:1-821 [004] .... 60.950253: rtos_queue_send_from_isr_failed: tstamp:2256103096 queue:0x0b4b0e58
kworker/4:1-821 [004] .... 60.950255: rtos_queue_send_from_isr_failed: tstamp:2256103363 queue:0x0b4b1c18
kworker/4:1-821 [004] .... 60.950257: rtos_queue_send_failed: tstamp:2256104442 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950259: rtos_queue_send_from_isr_failed: tstamp:2256329050 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950261: rtos_queue_send_from_isr_failed: tstamp:2256329154 queue:0x0b4aad68
kworker/4:1-821 [004] .... 60.950263: rtos_queue_send_from_isr_failed: tstamp:2256329255 queue:0x0b4ac998
kworker/4:1-821 [004] .... 60.950265: rtos_queue_send_from_isr_failed: tstamp:2256329358 queue:0x0b4ae518
kworker/4:1-821 [004] .... 60.950267: rtos_queue_send_from_isr_failed: tstamp:2256329469 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 60.950269: rtos_queue_send_from_isr_failed: tstamp:2256329579 queue:0x0b4b0098
kworker/4:1-821 [004] .... 60.950271: rtos_queue_send_from_isr_failed: tstamp:2256329681 queue:0x0b4b0e58
kworker/4:1-821 [004] .... 60.950273: rtos_queue_send_from_isr_failed: tstamp:2256329782 queue:0x0b4b1c18
kworker/4:1-821 [004] .... 60.950275: rtos_queue_send_failed: tstamp:2256330204 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950277: rtos_queue_send_from_isr_failed: tstamp:2256333133 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950280: rtos_queue_send_from_isr_failed: tstamp:2256333236 queue:0x0b4aad68
kworker/4:1-821 [004] .... 60.950282: rtos_queue_send_from_isr_failed: tstamp:2256333338 queue:0x0b4ac998
kworker/4:1-821 [004] .... 60.950284: rtos_queue_send_from_isr_failed: tstamp:2256333440 queue:0x0b4ae518
kworker/4:1-821 [004] .... 60.950286: rtos_queue_send_from_isr_failed: tstamp:2256333540 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 60.950288: rtos_queue_send_from_isr_failed: tstamp:2256333641 queue:0x0b4b0098
kworker/4:1-821 [004] .... 60.950290: rtos_queue_send_from_isr_failed: tstamp:2256333743 queue:0x0b4b0e58
kworker/4:1-821 [004] .... 60.950292: rtos_queue_send_from_isr_failed: tstamp:2256333844 queue:0x0b4b1c18
kworker/4:1-821 [004] .... 60.950294: rtos_queue_send_failed: tstamp:2256334732 queue:0x0b4a7258
kworker/4:1-821 [004] .... 60.950298: rtcpu_vinotify_event: tstamp:2256548344 tag:CHANSEL_PXL_SOF channel:0x00 frame:0 vi_tstamp:2256547581 data:0x00000001
kworker/4:1-821 [004] .... 60.950300: rtcpu_vinotify_event: tstamp:2256548629 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:2256547589 data:0x00000000
kworker/4:1-821 [004] .... 60.950301: rtcpu_vinotify_event: tstamp:2256548816 tag:CHANSEL_FAULT channel:0x00 frame:0 vi_tstamp:2256547817 data:0x00000200
kworker/4:1-821 [004] .... 60.950303: rtcpu_vinotify_event: tstamp:2256549672 tag:CHANSEL_LOAD_FRAMED channel:0x01 frame:0 vi_tstamp:2256548984 data:0x08000000
kworker/4:1-821 [004] .... 60.950305: rtcpu_vinotify_event: tstamp:2256549857 tag:CHANSEL_FAULT_FE channel:0x01 frame:0 vi_tstamp:2256548985 data:0x00000001
kworker/4:1-821 [004] .... 60.950306: rtcpu_vinotify_event: tstamp:2256550067 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:2256548988 data:0x00000000
kworker/4:1-821 [004] .... 61.006280: rtos_queue_peek_from_isr_failed: tstamp:2258199399 queue:0x0b4b4500
kworker/4:1-821 [004] .... 61.126321: rtos_queue_peek_from_isr_failed: tstamp:2263199354 queue:0x0b4b4500
vi-output, imx1-7466 [004] .... 61.134004: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt cb
vi-output, imx1-7466 [004] .... 61.134040: tegra_channel_capture_frame: sof:60.798899424
vi-output, imx1-7466 [003] .... 61.142595: tegra_channel_capture_frame: sof:61.32216032
kworker/4:1-821 [004] .... 61.182251: rtos_queue_send_from_isr_failed: tstamp:2263339033 queue:0x0b4a7258
kworker/4:1-821 [004] .... 61.182257: rtos_queue_send_from_isr_failed: tstamp:2263339212 queue:0x0b4aad68
kworker/4:1-821 [004] .... 61.182260: rtos_queue_send_from_isr_failed: tstamp:2263339390 queue:0x0b4ac998
kworker/4:1-821 [004] .... 61.182263: rtos_queue_send_from_isr_failed: tstamp:2263339566 queue:0x0b4ae518
kworker/4:1-821 [004] .... 61.182265: rtos_queue_send_from_isr_failed: tstamp:2263339741 queue:0x0b4af2d8
kworker/4:1-821 [004] .... 61.182268: rtos_queue_send_from_isr_failed: tstamp:2263339915 queue:0x0b4b0098
I dont what is the problem!!!
