Can't import any python package from pip-installed IsaacSim
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
Other (please specify): Ubuntu 24.04
Topic Description
Installing IsaacSim via pip and starting a SimulationApp works perfectly fine. However, none of the other IsaacSim packages installed can be imported / used.
Detailed Description
After successfull installation, the next thing I wanted to try was going through the standalone python intro. However, as soon as I try to import any isaac sim package beyond isaacsim itself, I get a ModuleNotFoundError.
Steps to Reproduce
  1. pip install isaacsim[all]==4.5.0 --extra-index-url https://pypi.nvidia.com
  2. In python, execute, for example:
import isaacsim  # all good
import isaacsim.examples  # breaks
import isaacsim.core  # also breaks
The isaacsim installation itself seems to be successful. I can run:
import isaacsim
from isaacsim import SimulationApp
SimulationApp()  # After accepting the EULA, I get the startup log of the SimulationApp
Error Messages
For example:
  File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'isaacsim.core'
A deeper dive
I’ve been looking into the code that’s executed when importing isaacsim and found the following snippets (from isaacsim.__init__.py:
    paths += [
        os.path.join(isaacsim_path, "exts", "isaacsim.simulation_app"),
        os.path.join(isaacsim_path, "extsDeprecated", "omni.isaac.kit"),
    # update sys.path
    for path in paths:
        if not path in sys.path:
            if not os.path.exists(path):
                print(f"PYTHONPATH: path doesn't exist ({path})")
                continue
            sys.path.insert(0, path)
and
      try:
          # get isaacsim/simulation_app folder path
          isaacsim_path = os.path.dirname(os.path.abspath(os.path.realpath(__file__)))
          path = glob.glob(
              os.path.join(
                  os.environ.get("ISAAC_PATH", isaacsim_path), "exts*", "isaacsim.simulation_app*", "isaacsim"
          )[0]
          if os.path.exists(path):
              # register path
              # import API
              from simulation_app import AppFramework, SimulationApp
              # register module to support 'from isaacsim.simulation_app import SimulationApp'
              sys.modules["isaacsim.simulation_app"] = type(sys)("isaacsim.simulation_app")
              sys.modules["isaacsim.simulation_app.SimulationApp"] = SimulationApp
              sys.modules["isaacsim.simulation_app.AppFramework"] = AppFramework
          else:
so it seems, that for the simulation_app only, it is ensured that it is actually in the pythonpath and registered as a module. However, this is not happening for any over exts in isaac – so apparently, there is a known issue with importing the simulation app. So I tried the following:
import isaacsim
import traceback
try:
    import isaacsim.core.api
except ModuleNotFoundError as e:
    print('Unable to import isaacsim.core.api')
    print(e)
    print(traceback.format_exc())
import os
import sys
path = "/home/chicken/anaconda3/envs/isaac/lib/python3.10/site-packages/isaacsim/exts/isaacsim.core.api"
sys.path.insert(0, path + '/isaacsim')
try:
    from core import api
    print("Failed with the following error")
    print(e)
As expected, the first import of isaacsim.core.api fails completely. However, when manually adding the path to the source code, it fails with a different traceback, because core.api can now be found, but is still not registered properly. Here’s the print statements of the above program:
  File "/home/chicken/Code/IsaacSims/mcfly/debug.py", line 5, in <module>
  File "/home/chicken/Code/IsaacSims/mcfly/debug.py", line 17, in <module>
  File "/home/chicken/anaconda3/envs/isaac/lib/python3.10/site-packages/isaacsim/exts/isaacsim.core.api/isaacsim/core/api/__init__.py", line 11, in <module>
    from isaacsim.core.api.physics_context.physics_context import PhysicsContext
My assumption: The naming convention of the extensions clashes with Python naming conventions. However, it seems to be a bug that could be fixed either by renaming the extensions, or by extending the isaacsim __init__ function to check not only if the SimulationApp can be imported, but any of the packages.
Additional Information
The packages were successfully installed, which shows in pip list:
pip list | grep isaac
isaacsim                   4.5.0.0
isaacsim-app               4.5.0.0
isaacsim-asset             4.5.0.0
isaacsim-benchmark         4.5.0.0
isaacsim-code-editor       4.5.0.0
isaacsim-core              4.5.0.0
isaacsim-cortex            4.5.0.0
isaacsim-example           4.5.0.0
isaacsim-extscache-kit     4.5.0.0
isaacsim-extscache-kit-sdk 4.5.0.0
isaacsim-extscache-physics 4.5.0.0
isaacsim-gui               4.5.0.0
isaacsim-kernel            4.5.0.0
isaacsim-replicator        4.5.0.0
isaacsim-rl                4.5.0.0
isaacsim-robot             4.5.0.0
isaacsim-robot-motion      4.5.0.0
isaacsim-robot-setup       4.5.0.0
isaacsim-ros1              4.5.0.0
isaacsim-ros2              4.5.0.0
isaacsim-sensor            4.5.0.0
isaacsim-storage           4.5.0.0
isaacsim-template          4.5.0.0
isaacsim-test              4.5.0.0
isaacsim-utils             4.5.0.0
They seem to be where they are supposed to be:
(isaac) ➜  ~ pip show isaacsim
Version: 4.5.0.0
Summary: A metapackage to manage the Isaac Sim installation
Home-page:
Author: Isaac Sim team
Author-email:
License: NVIDIA Proprietary Software
Location: /home/.../anaconda3/envs/isaac/lib/python3.10/site-packages
Requires: isaacsim-kernel
Required-by:
(isaac) ➜  ~ pip show isaacsim-example
Version: 4.5.0.0
Summary: Isaac Sim examples
Home-page:
Author-email:
Requires: isaacsim-cortex
Required-by:
Edit
Just out of curiosity, I tried the same using the python runtime shipped with isaacsim – still, I got an import error:
>>> ./python.sh -c 'import isaacsim.core.api'
  File "<string>", line 1, in <module>
Hi, is there any fix to this error? I cannot use Isaaclab because of this error!
You need to Run with the top-level launcher (not kit/python.sh):$ISAAC/python.sh
ISAAC = /path/to/your/Isaacsim/
Hi, please import the isaacsim modules after the App started, e.g, after
import isaacsim
Please try with the latest release and open new topics if you still have issues.
Closing this old topic.
