Isaac Sim 4.0: ModuleNotFoundError: No module named 'omni.isaac'
I install isaaclab using Isaac Sim Binaries.
When I follow this link to verify the isaac lab installation, after I run
python source/standalone/tutorials/00_sim/create_empty.py
I get the following issue:
  File "/home/brain/Workspace/omniverse/isaaclab/IsaacLab/source/standalone/tutorials/00_sim/create_empty.py", line 20, in <module>
    from omni.isaac.lab.app import AppLauncher
Hi @Tips0
Use ./isaaclab.sh -p source/standalone/tutorials/00_sim/create_empty.py to run the script when installing using the Isaac Sim binaries
我也遇到同样问题,如果解决能告诉一下?
I tried. I got the same issue.
I also tried to install “Installation using Isaac Sim pip (experimental)”.
When I run
pip install isaacsim-rl isaacsim-replicator isaacsim-extscache-physics isaacsim-extscache-kit-sdk isaacsim-extscache-kit isaacsim-app --extra-index-url https://pypi.nvidia.com
I got the following errors:
Looking in indexes: https://pypi.org/simple, https://pypi.nvidia.com
Collecting isaacsim-rl
  Using cached isaacsim_rl-4.0.0.0.tar.gz (673 bytes)
  Installing build dependencies ... done
  Getting requirements to build wheel ... done
  Preparing metadata (pyproject.toml) ... error
  error: subprocess-exited-with-error
  × Preparing metadata (pyproject.toml) did not run successfully.
  │ exit code: 1
  ╰─> [51 lines of output]
        File "/tmp/pip-build-env-z4yxed0z/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 147, in download_wheel
          return download_manual(wheel_directory, distribution, version)
        File "/tmp/pip-build-env-z4yxed0z/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 114, in download_manual
          raise RuntimeError(f"Didn't find wheel for {distribution} {version}")
      RuntimeError: Didn't find wheel for isaacsim-rl 4.0.0.0
      During handling of the above exception, another exception occurred:
        File "/home/brain/anaconda3/envs/isaaclab/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
          main()
        File "/home/brain/anaconda3/envs/isaaclab/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
          json_out['return_val'] = hook(**hook_input['kwargs'])
        File "/home/brain/anaconda3/envs/isaaclab/lib/python3.10/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 152, in prepare_metadata_for_build_wheel
          whl_basename = backend.build_wheel(metadata_directory, config_settings)
        File "/tmp/pip-build-env-z4yxed0z/overlay/lib/python3.10/site-packages/nvidia_stub/buildapi.py", line 29, in build_wheel
          return download_wheel(pathlib.Path(wheel_directory), config_settings)
        File "/tmp/pip-build-env-z4yxed0z/overlay/lib/python3.10/site-packages/nvidia_stub/wheel.py", line 149, in download_wheel
          report_install_failure(distribution, version, exception_context)
        File "/tmp/pip-build-env-z4yxed0z/overlay/lib/python3.10/site-packages/nvidia_stub/error.py", line 63, in report_install_failure
          raise InstallFailedError(
      nvidia_stub.error.InstallFailedError:
      The installation of isaacsim-rl for version 4.0.0.0 failed.
      This is a special placeholder package which downloads a real wheel package
      from https://pypi.nvidia.com. If https://pypi.nvidia.com is not reachable, we
      cannot download the real wheel file to install.
      You might try installing this package via
      $ pip install --extra-index-url https://pypi.nvidia.com isaacsim-rl
      Here is some debug information about your platform to include in any bug
      report:
      Python Version: CPython 3.10.14
      Operating System: Linux 5.15.0-107-generic
      CPU Architecture: x86_64
      Driver Version: 535.183
      CUDA Version: 12.2
      [end of output]
  note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
× Encountered error while generating package metadata.
╰─> See above for output.
note: This is an issue with the package mentioned above, not pip.
hint: See above for details.
Hi @Tips0
Installing Isaac Sim with pip requires GLIBC 2.34+ version compatibility.
To check the GLIBC version on your system, use command ldd --version .
Got the same issue, no solution? if I installed verything from pip, I am OK, but I want to check those source code so I installed isaac-sim from the omniverse, and got such issue.
Try installing setuptools and wheel.
pip install setuptools wheel
