I am unable to build the gfx_isaac_tensor_rt package inside the Dev container with colcon build. I get the following error:
Finished <<< gxf_isaac_triton [1.79s]
--- stderr: gxf_isaac_tensor_rt
CMake Error at /usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:230 (message):
Could NOT find TENSORRT: Found unsuitable version "..", but required is at
least "10" (found /usr/include/x86_64-linux-gnu)
Call Stack (most recent call first):
/usr/share/cmake-3.22/Modules/FindPackageHandleStandardArgs.cmake:592 (_FPHSA_FAILURE_MESSAGE)
/workspaces/oakd_isaac_ros/install/isaac_ros_common/share/isaac_ros_common/cmake/modules/FindTENSORRT.cmake:68 (find_package_handle_standard_args)
CMakeLists.txt:30 (find_package)
gmake: *** [Makefile:308: cmake_check_build_system] Error 1
Cuda version:
nvcc: NVIDIA (R) Cuda compiler driver
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Tue_Oct_29_23:50:19_PDT_2024
Cuda compilation tools, release 12.6, V12.6.85
Build cuda_12.6.r12.6/compiler.35059454_0
Tensorrt seems to be installed
dpkg -l | grep tensorrt
ii tensorrt 10.12.0.36-1+cuda12.9 amd64 Meta package for TensorRT
ii tensorrt-dev 10.12.0.36-1+cuda12.9 amd64 Meta package for TensorRT development libraries
