Can't locate InstallUtils.pm in @INC
This is like the 10th time I have downloaded Cuda 8.0 Toolkit and tried to install it. It fails every time. I say yes for everything except the nvidia driver and install everything in the default location.
FULL LOG :
Using more to view the EULA.
Installing the CUDA Toolkit in /usr/local/cuda-8.0 ...
Verifying archive integrity... All good.
Uncompressing NVIDIA CUDA................................................................................................
Can't locate InstallUtils.pm in @INC (you may need to install the InstallUtils module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.24.1 /usr/local/share/perl/5.24.1 /usr/lib/x86_64-linux-gnu/perl5/5.24 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.24 /usr/share/perl/5.24 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at ./install-linux.pl line 6.
BEGIN failed--compilation aborted at ./install-linux.pl line 6.
Uncompressing NVIDIA CUDA Samples................................................................................................
Can't locate InstallUtils.pm in @INC (you may need to install the InstallUtils module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.24.1 /usr/local/share/perl/5.24.1 /usr/lib/x86_64-linux-gnu/perl5/5.24 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.24 /usr/share/perl/5.24 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at ./install-sdk-linux.pl line 6.
BEGIN failed--compilation aborted at ./install-sdk-linux.pl line 6.
'uninstall_cuda_8.0.pl' -> '/usr/local/cuda-8.0/bin/uninstall_cuda_8.0.pl'
Installing the CUDA Samples in /home/dollarakshay ...
= Summary =
Driver:   Not Selected
Toolkit:  Installation Failed
Samples:  Installation Failed
Logfile is /tmp/cuda_install_6522.log
Please help.
What linux distro is this?
Ubuntu 16.04
maybe try setting a perl environment variable as mentioned here:
[url]https://devtalk.nvidia.com/default/topic/968656/cuda-8-0-on-debian/[/url]
@txbob Yup Tried that before posting this. Tried it again just in case. Still dint work
I have printed the value of $PERL5LIB
Screenshot : https://i.imgur.com/cg71Ujd.png
These are the Nvidia and CUDA Packages that I have installed. The nvidia driver was installed using
sudo apt-get install nvidia-370
Screenshot : https://i.imgur.com/VegkdSM.png
Okay i just noticed that whatever I do to PERL5LIB it dosent change at all when it prints the log file, but I can actually see that it has changed in perl
Hello! i have same problem and decide theese next decisions:
unfortunately try export PERL5LIB and see in log whatever installer not seem file InstallUtils.pm
  1. unpack .run file ./cuda*.run --tar mxvf
  2. copy InstallUtils.pm to /usr/lib/x86_64-linux-gnu/perl-base
  3. export $PERL5LIB
    enjoy
Thank you soo much. Really you have solved a problem that I had for months. I even gave up and moved to windows. I have spend over 250+ hours over a period of 3 months trying to figure out a way around this solution.
Your solution works flawlessly. I really cant thank you enough. Thanks to you I can finally work on Tensorflow GPU in peace.
<3 Thank You
It works like a charm! Thanks a lot.
OMG. OMG. OMG
You are the REAL MVP.
Lost dozens of hours on it too. Finally a solution, after so many tries, in different ways
Total awesomeness! I’ve been trying to get the run-file working on Kubuntu 17.10 beta for the last 3 hours - your post solved my problem!
Thank you so much!!!
For the benefit of Fedora users (I’m working on Fedora 27 with GCC 5.4.0), these commands are:
sh ./cuda_8.0.61_375.26_linux.run --tar mxvf
sudo cp InstallUtils.pm /usr/lib64/perl5/
export $PERL5LIB
sudo rm /usr/lib64/perl5/InstallUtils.pm
I had this problem with Cuda 9.2 on an Ubuntu 16.04 system, and had to run:
apt -y install libmodule-install-perl
To install the perl install modules.
I am curious
how were you able to dual install gcc5 on Fedora 27? Did you have to build this yourself with an alternative linker?
@Robert_Crovella can i install pycuda in the environment that there is cuda10.1pyc6 when i install by “pip install “pycuda>=2017.1.1” --no-cache-dir” ,it shows successbut when i import pycuda ,the errors shows "
import pycuda
File “”, line 1, in
File “/home/ubuntu/datadisk/ZJISS/tensorrt_demos/pycuda.py”, line 2, in
import pycuda.driver as drv
ModuleNotFoundError: No module named ‘pycuda.driver’; ‘pycuda’ is not a package
"what can i do for it?
You need Perl dependencies. For fedora install:
sudo dnf install perl perl-Tie-File perl-Data-Dumper perl-Getopt-Long
