Hi All,
I use 2xLAN, the rate of each LAN is 2.5G, and I turn on the deskew function on the deserializer, but the picture cannot be drawn. Please help me take a look.
root@tegra:/home/robot# sudo su
cd /sys/kernel/debug/dynamic_debug/
echo file csi5_fops.c +p > control
echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
echo 0 > /sys/kernel/debug/tracing/tracing_on
cat /sys/kernel/debug/tracing/traceroot@tegra:/home/robot# cd /sys/kernel/debug/dynamic_debug/
root@tegra:/sys/kernel/debug/dynamic_debug# echo file csi5_fops.c +p > control
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
832000000
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
1011200000
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
642900000
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
3199000000
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/tracing_on
root@tegra:/sys/kernel/debug/dynamic_debug# echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
root@tegra:/sys/kernel/debug/dynamic_debug# echo 2 > /sys/kernel/debug/camrtc/log-level
root@tegra:/sys/kernel/debug/dynamic_debug# echo 1 > /sys/kernel/debug/tracing/events/camera_common/enable
root@tegra:/sys/kernel/debug/dynamic_debug# echo > /sys/kernel/debug/tracing/trace
root@tegra:/sys/kernel/debug/dynamic_debug# cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 0/0 #P:8
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
root@tegra:/sys/kernel/debug/dynamic_debug# echo 0 > /sys/kernel/debug/tracing/tracing_on
# tracer: nop
# _-----=> irqs-off
# ||| / delay
root@tegra:/sys/kernel/debug/dynamic_debug# v4l2-ctl -d /dev/video0 --stream-mmap --stream-to-host 192.168.1.111
VIDIOC_CROPCAP returned -1 (Inappropriate ioctl for device)
VIDIOC_G_STD returned -1 (Inappropriate ioctl for device)
VIDIOC_G_DV_TIMINGS returned -1 (Inappropriate ioctl for device)
^C
root@tegra:/sys/kernel/debug/dynamic_debug# ^C
ar0233_a@1b {
compatible = "nvidia,ar0233";
reg = <0x1b>;
/* Physical dimensions of sensor */
physical_w = "15.0";
physical_h = "12.5";
sensor_model ="ar0233";
/* Defines number of frames to be dropped by driver internally after applying */
/* sensor crop settings. Some sensors send corrupt frames after applying */
/* crop co-ordinates */
post_crop_frame_drop = "0";
/* Convert Gain to unit of dB (decibel) befor passing to kernel driver */
//use_decibel_gain = "true";
/* enable CID_SENSOR_MODE_ID for sensor modes selection */
use_sensor_mode_id = "true";
* A modeX node is required to support v4l2 driver
* implementation with NVIDIA camera software stack
* mclk_khz = "";
* Standard MIPI driving clock, typically 24MHz
* num_lanes = "";
* Number of lane channels sensor is programmed to output
* tegra_sinterface = "";
* The base tegra serial interface lanes are connected to
* vc_id = "";
* The virtual channel id of the sensor.
* discontinuous_clk = "";
* The sensor is programmed to use a discontinuous clock on MIPI lanes
* dpcm_enable = "true";
* The sensor is programmed to use a DPCM modes
* cil_settletime = "";
* MIPI lane settle time value.
* A "0" value attempts to autocalibrate based on mclk_khz and pix_clk_hz
* active_w = "";
* Pixel active region width
* active_h = "";
* Pixel active region height
* dynamic_pixel_bit_depth = "";
* sensor dynamic bit depth for sensor mode
* csi_pixel_bit_depth = "";
* sensor output bit depth for sensor mode
* mode_type="";
* Sensor mode type, For eg: yuv, Rgb, bayer, bayer_wdr_pwl
* pixel_phase="";
* Pixel phase for sensor mode, For eg: rggb, vyuy, rgb888
* readout_orientation = "0";
* Based on camera module orientation.
* Only change readout_orientation if you specifically
* Program a different readout order for this mode
* line_length = "";
* Pixel line length (width) for sensor mode.
* This is used to calibrate features in our camera stack.
* pix_clk_hz = "";
* Sensor pixel clock used for calculations like exposure and framerate
* inherent_gain = "";
* Gain obtained inherently from mode (ie. pixel binning)
* min_gain_val = ""; (floor to 6 decimal places)
* max_gain_val = ""; (floor to 6 decimal places)
* Gain limits for mode
* if use_decibel_gain = "true", please set the gain as decibel
* min_exp_time = ""; (ceil to integer)
* max_exp_time = ""; (ceil to integer)
* Exposure Time limits for mode (us)
* min_hdr_ratio = "";
* max_hdr_ratio = "";
* HDR Ratio limits for mode
* min_framerate = "";
* max_framerate = "";
* Framerate limits for mode (fps)
* embedded_metadata_height = "";
* Sensor embedded metadata height in units of rows.
* If sensor does not support embedded metadata value should be 0.
mode0 {/*mode ar0233_MODE_1920X1080_CROP_30FPS_LINEAR*/
mclk_khz = "24000";
num_lanes = "2";
vc_id = "0";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "16";
csi_pixel_bit_depth = "16";
mode_type = "yuv";
pixel_phase = "yuyv";
active_w = "1920";
active_h = "1080";
line_length = "2200";
inherent_gain = "1";
pix_clk_hz = "74250000";
serdes_pix_clk_hz = "312500000";
gain_factor = "100";
min_gain_val = "100"; /* dB */
max_gain_val = "1200"; /* dB */
step_gain_val = "1";
default_gain = "100";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "10000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "49"; /*us, 2 lines*/
max_exp_time = "40000";
step_exp_time = "1";
default_exp_time = "12000";/* us */
embedded_metadata_height = "0";
mode1 {/*mode ar0233_MODE_1920X1536_CROP_30FPS_LINEAR*/
mclk_khz = "24000";
num_lanes = "2";
vc_id = "0";
mode_type = "yuv";
active_w = "1920";
active_h = "1536";
line_length = "2800";
pix_clk_hz = "115500000";
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
ar0233_out0: endpoint {
vc-id = <0>;
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&ar0233_csi_in0>;
gmsl-link {
src-csi-port = "b";
dst-csi-port = "a";
serdes-csi-link = "a";
csi-mode = "2x4";
st-vc = <0>;
vc-id = <0>;
num-lanes = <2>;
streams = "ued-u1", "raw12";
