Hello!
We have working system with tc358743 + Xavier AGX devkit with L4T 32.7.1. Now I try to run tc358743 on Jetson Agx Orin devkit with Jetpack 5.0.1 L4T 34.1.1, but video stream is not received by Orin.
I found some similar topics with following solution:
Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
However:
- I have not found how to enable Skew calibration on tc358743, suppose there is no such function on tc358743. Is it possible to disable waiting for skew calibration on Orin?
- Output data rate from tc358743 seems less than 1.5Gbps per lane
Output data rate = (sensor or deserializer pixel clock in hertz) * (bits per pixel) / (number of CSI lanes) = 74250000*16/2 = 594000000 = ~600Mbps.
Does it mean that skew calibration is not required? - Oscilloscope shows that stream is present on CSI lanes, but I always have VIFALC_TDSTATE error. Please find logs below.
tc358743 status:
[154030.580921] tc358743 2-000d: -----Chip status-----
[154030.581237] tc358743 2-000d: Chip ID: 0x00
[154030.581536] tc358743 2-000d: Chip revision: 0x00
[154030.581671] tc358743 2-000d: Reset: IR: 1, CEC: 1, CSI TX: 0, HDMI: 0
[154030.581845] tc358743 2-000d: Sleep mode: off
[154030.581966] tc358743 2-000d: Cable detected (+5V power): yes
[154030.582276] tc358743 2-000d: DDC lines enabled: yes
[154030.582569] tc358743 2-000d: Hotplug enabled: yes
[154030.582884] tc358743 2-000d: CEC enabled: no
[154030.583014] tc358743 2-000d: -----Signal status-----
[154030.583159] tc358743 2-000d: TMDS signal detected: yes
[154030.583300] tc358743 2-000d: Stable sync signal: yes
[154030.583444] tc358743 2-000d: PHY PLL locked: yes
[154030.583576] tc358743 2-000d: PHY DE detected: yes
[154030.586223] tc358743 2-000d: Detected format: 1920x1080p30.00 (2200x1125)
[154030.586431] tc358743 2-000d: horizontal: fp = 0, -sync = 280, bp = 0
[154030.586608] tc358743 2-000d: vertical: fp = 0, -sync = 45, bp = 0
[154030.587498] tc358743 2-000d: pixelclock: 74250000
[154030.592420] tc358743 2-000d: flags (0x0):
[154030.596607] tc358743 2-000d: standards (0x0):
[154030.601071] tc358743 2-000d: Configured format: 1920x1080p30.00 (2200x1125)
[154030.607980] tc358743 2-000d: horizontal: fp = 0, -sync = 280, bp = 0
[154030.614280] tc358743 2-000d: vertical: fp = 0, -sync = 45, bp = 0
[154030.620579] tc358743 2-000d: pixelclock: 74250000
[154030.625392] tc358743 2-000d: flags (0x0):
[154030.629591] tc358743 2-000d: standards (0x0):
[154030.633880] tc358743 2-000d: -----CSI-TX status-----
[154030.639128] tc358743 2-000d: Lanes needed: 2
[154030.643436] tc358743 2-000d: Lanes in use: 2
[154030.647993] tc358743 2-000d: Waiting for particular sync signal: no
[154030.654452] tc358743 2-000d: Transmit mode: yes
[154030.659004] tc358743 2-000d: Receive mode: no
[154030.663376] tc358743 2-000d: Stopped: no
[154030.667400] tc358743 2-000d: Color space: YCbCr 422 16-bit
[154030.673326] tc358743 2-000d: -----DVI-D status-----
[154030.678156] tc358743 2-000d: HDCP encrypted content: no
[154030.683580] tc358743 2-000d: Input color space: RGB full range
dmesg output:
[153998.407804] bwmgr API not supported
[153998.480543] mc-err: (255) csr_vi2falr: EMEM address decode error
[153998.483329] mc-err: status = 0x20001071; hi_addr_reg = 0x0000007d addr = 0x7df84fa060
[153998.483794] mc-err: secure: no, access-type: read
[153998.484253] mc-err: mcerr: unknown intr source intstatus = 0x00000000, intstatus_1 = 0x00000000
[154001.108954] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[154001.109224] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[154001.110287] (NULL device *): vi_capture_control_message: NULL VI channel received
[154001.110490] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
[154001.110765] (NULL device *): vi_capture_control_message: NULL VI channel received
[154001.110959] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 3 vc- 0
[154001.111360] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[154003.669030] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[154003.669302] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[154003.670192] (NULL device *): vi_capture_control_message: NULL VI channel received
[154003.670383] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=3, csi_port=3
camrtc trace:
v4l2-ctl-34115 [000] .... 154803.133123: tegra_channel_open: vi-output, tc358743 2-000d
v4l2-ctl-34115 [000] .... 154803.140596: tegra_channel_set_power: tc358743 2-000d : 0x1
v4l2-ctl-34115 [000] .... 154803.140600: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-34115 [000] .... 154803.140602: csi_s_power: enable : 0x1
v4l2-ctl-34115 [000] .... 154803.140666: tegra_channel_capture_setup: vnc_id 0 W 1920 H 1080 fmt 10
v4l2-ctl-34115 [001] .... 154803.146800: tegra_channel_set_stream: enable : 0x1
v4l2-ctl-34115 [001] .... 154803.155065: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
v4l2-ctl-34115 [001] .... 154803.155069: csi_s_stream: enable : 0x1
v4l2-ctl-34115 [001] .... 154803.155603: tegra_channel_set_stream: tc358743 2-000d : 0x1
kworker/10:1-32861 [010] .... 154803.164688: rtcpu_string: tstamp:4838152387111 id:0x04010000 str:"VM0 activating."
kworker/10:1-32861 [010] .... 154803.164691: rtcpu_nvcsi_intr: tstamp:4838152811482 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x0e000000
kworker/10:1-32861 [010] .... 154803.164692: rtcpu_vinotify_event: tstamp:4838152823453 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:154820880018464 data:0xc55dd70010000000
kworker/10:1-32861 [010] .... 154803.164692: rtcpu_vinotify_event: tstamp:4838152823585 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:154820880025056 data:0x0000000031000001
kworker/10:1-32861 [010] .... 154803.164692: rtcpu_vinotify_event: tstamp:4838152823734 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:154820880066368 data:0xc55dd40010000000
kworker/10:1-32861 [010] .... 154803.164692: rtcpu_vinotify_event: tstamp:4838152823864 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:154820880073472 data:0x0000000031000002
kworker/10:1-32861 [010] .... 154803.164693: rtcpu_nvcsi_intr: tstamp:4838152827972 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/10:1-32861 [010] .... 154803.164693: rtcpu_nvcsi_intr: tstamp:4838152828339 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
kworker/10:1-32861 [010] .... 154803.164693: rtcpu_nvcsi_intr: tstamp:4838152828707 class:GLOBAL type:PHY_INTR0 phy:1 cil:1 st:0 vc:0 status:0x00000044
